Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
jandoedel99
Re: Xiaomi Mi Flora [Temp/Light/Moisture] BLE Sensor
Post by jandoedel99 »
On RPI 2 with Wheezy i have a problem in the wiki
Python-to-bluetooth
Next, Install Python3 and the required Python3 libraries that let Python script talk to Bluetooth.
sudo aptitude install python3
sudo aptitude install python3-pip
sudo pip3 install pygatt
sudo pip3 install requests
the first 2 lines are going good
the next 2 don´t install
What to do
pvm
Domoticz version: 4.10538
Post by pvm »
Can you share the error message?
devros
Post by devros »
Dunno why, but on my OrangePi myflora works only when i run hcitool lescan before script
so i modifed script that it runs hcitool lescan for few seconds, then all works
(also changed hcitool lescan to run without sudo)
i know that its quite dirty but it works... for me
here is my modifed script
#!/usr/bin/python3
import urllib.request
import base64
import time
import os
from miflora.miflora_poller import MiFloraPoller, \
    MI_CONDUCTIVITY, MI_MOISTURE, MI_LIGHT, MI_TEMPERATURE, MI_BATTERY
# Settings for the domoticz server
# Forum see: http://domoticz.com/forum/viewtopic.php?f=56&t=13306&hilit=mi+flora&start=20#p105255
domoticzserver   = "XXX"
domoticzusername = "XXX"
domoticzpassword = "XXX"
# So id devices use: sudo hcitool lescan
base64string = base64.encodestring(('%s:%s' % (domoticzusername, domoticzpassword)).encode()).decode().replace('\n', '')
def domoticzrequest (url):
  request = urllib.request.Request(url)
  request.add_header("Authorization", "Basic %s" % base64string)
  response = urllib.request.urlopen(request)
  return response.read()
def update(address,idx_moist,idx_temp,idx_lux,idx_cond):
    poller = MiFloraPoller(address)
    loop = 0
    try:
        temp = poller.parameter_value("temperature")
    except:
        temp = 201
    while loop < 2 and temp > 200:
        print("Patched: Error reading value retry after 5 seconds...\n")
        time.sleep(5)
        loop += 1
        try:
        except:
            temp = 201
    if temp > 200:
        print("Patched: Error reading value\n")
        return
    global domoticzserver
    print("Mi Flora: " + address)
    print("Firmware: {}".format(poller.firmware_version()))
    print("Name: {}".format(poller.name()))
    print("Temperature: {}°C".format(poller.parameter_value("temperature")))
    print("Moisture: {}%".format(poller.parameter_value(MI_MOISTURE)))
    print("Light: {} lux".format(poller.parameter_value(MI_LIGHT)))
    print("Fertility: {} uS/cm?".format(poller.parameter_value(MI_CONDUCTIVITY)))
    print("Battery: {}%".format(poller.parameter_value(MI_BATTERY)))
    val_bat  = "{}".format(poller.parameter_value(MI_BATTERY))
    # Update temp
    val_temp = "{}".format(poller.parameter_value("temperature"))
    domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_temp + "&nvalue=0&svalue=" + val_temp + "&battery=" + val_bat)
    # Update lux
    val_lux = "{}".format(poller.parameter_value(MI_LIGHT))
    domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_lux + "&svalue=" + val_lux + "&battery=" + val_bat)
    # Update moisture
    val_moist = "{}".format(poller.parameter_value(MI_MOISTURE))
    domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_moist + "&svalue=" + val_moist + "&battery=" + val_bat)
    # Update fertility
    val_cond = "{}".format(poller.parameter_value(MI_CONDUCTIVITY))
    domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_cond + "&svalue=" + val_cond + "&battery=" + val_bat)
    time.sleep(1)
# format address, moist (%), temp (°C), lux, fertility
os.system("timeout 2 hcitool lescan 5")
print ("predping")
update("C4:7C:8D:61:B4:DA","142","133","136","143")
jandoedel99
jandoedel99 wrote:On RPI 2 with Wheezy i have a problem in the wiki
Python-to-bluetooth
What to do
error is
pi@raspberrypi ~ $ sudo pip3 install pygatt
/usr/local/bin/python3.5: error while loading shared libraries: libpython3.5m.so                                    .1.0: cannot open shared object file: No such file or directory
micksel
Post by micksel »
Seems that on my Pi2 with the Domoticz image, the command isn't pip3 but pip-3.2
So close now but But I still recieve Error:
pi@domo1 ~/domoticz/scripts/python/miflora $ /usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/domoticz.py
File "/home/pi/domoticz/scripts/python/miflora/domoticz.py", line 4, in <module>
File "/home/pi/domoticz/scripts/python/miflora/miflora/miflora_poller.py", line 12, in <module>
from subprocess import PIPE, Popen, TimeoutExpired
ImportError: cannot import name TimeoutExpired
And Sudo pip-3.2 install timeoutexpired won't solve anything :(
pi@domo1 ~/domoticz/scripts/python/miflora $ sudo pip-3.2 install TimeoutExpired
Downloading/unpacking TimeoutExpired
Could not find any downloads that satisfy the requirement TimeoutExpired
No distributions at all found for TimeoutExpired
Storing complete log in /root/.pip/pip.log
micksel
Post by micksel »
I downloaded the new and updated miflora_poller.py from https://github.com/open-homeautomation/ ... ant-sensor but still recive the same error
I found my ID using : sudo hcitool lescan)
C4:7C:8D:62:0C:81 Flower care
I edit demo.py with this but when I run it I get the following errors:
pi@domo1 ~ $ sudo /usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/demo.py
pi@domo1 ~/domoticz/scripts/python/miflora/miflora/tests $ /usr/bin/python3 /home/pi/domoticz/scripts/python/miflora/demo.py
File "/home/pi/domoticz/scripts/python/miflora/demo.py", line 1, in <module>
I can connect with gatttool -I and Connect
pi@domo1 ~/domoticz/scripts/python $ gatttool -I
[ ][LE]> connect c4:7c:8d:62:0c:81
Attempting to connect to c4:7c:8d:62:0c:81
Connection successful
Notification handle = 0x0021 value: 00
[c4:7c:8d:62:0c:81][LE]>
(gatttool:9429): GLib-WARNING **: Invalid file descriptor.
madrian
Post by madrian »
Coldman wrote:
[bluetooth]# scan on
Discovery started
[CHG] Controller 34:C3:D2:E4:13:E3 Discovering: yes
[/quote]
How can I connect to the sensor and watch RSSI with scan on?
Thank you
madrian
Post by madrian »
I am triying:
@orangepizero:~/bluetoothctl
Discovery started
[CHG] Controller 00:1A:7D:DA:71:13 Discovering: yes
[CHG] Device C4:7C:8D:62:6E:22 RSSI: -59
[CHG] Device C4:7C:8D:62:6E:22 ServiceData Value: 0x02
[CHG] Device C4:7C:8D:62:6E:22 ServiceData Value: 0x98
[CHG] Device C4:7C:8D:62:6E:22 ServiceData Value: 0x00
[CHG] Device C4:7C:8D:62:6E:22 ServiceData Value: 0x41
And I see many Servicedata Value lines....how I can filter out only RSSI?
micksel
Post by micksel »
micksel wrote: from miflora.miflora_poller import MiFloraPoller, \
I solved this by manually update to python 3.4
micksel
Post by micksel »
I can see in the python script that the battery parameter is also sent when updating the values.
Like: domoticzrequest("http://" + domoticzserver + "/json.htm?type=command&param=udevice&idx=" + idx_temp + "&nvalue=0&svalue=" + val_temp + "&battery=" + val_bat)
How can I see this value in domotics?
LouiS22
Post by LouiS22 »
micksel wrote:I can see in the python script that the battery parameter is also sent when updating the values.
Right under the Devices tab ;) Check the little green battery icon, and in that row.
micksel
Post by micksel »
Feeling like an idiot, thanks.
bertbigb
Post by bertbigb »
Dear All,
I bought a MiFlora Plant pin and followed the wiki.
I run domoticz on a raspberry 3
I discovered my device with the command
sudo hcitool lescan
it showed C4:7C:8D:63:62:1E Flower care
I used the domoticz.py from the wiki
I updated this value in domoticz.py and when I now run
pi@raspberrypi_V3:~ $ /usr/bin/python3 /home/pi/dev-domoticz/scripts/python/miflora/domoticz.py
I get the following response:
1: Varen (weet ik niet)
connect: Device or resource busy (16) (many times)
Anyone any idea why this is happening? I tried already for a couple of hours but no other results. Do I need to change something else?
It is a bit a pity that I can't read the values of the flower pin into domoticz :?
Best regards Bert
Synology DS1517+ - DSM 6.2
micksel
Post by micksel »
I got that error message when I still was connected with my Phone. Is that the case for you?
bertbigb
Post by bertbigb »
micksel wrote:I got that error message when I still was connected with my Phone. Is that the case for you?
That was exactly the case, now it is working fine. Thanks for your reaction
Best regards Bert
LouiS22
Post by LouiS22 »
Got a firmware upgrade, new version is 2.9.4. I've upgraded, python script is still working (those who wonder).
ilpier
Post by ilpier »
There is no way for Windows?
micksel
Post by micksel »
ilpier wrote:There is no way for Windows?
python exit for windows but not sure about all the moduls, maybe easier just to emulate a Linux system on win
bertbigb
Post by bertbigb »
I have a raspberry PI 3 with bluetooth, MQTT and Domoticz installed.
I can read through the lua script all my plant pins. So far so good.
What I would like is to send the values from the plantpins over MQTT to another domoticz system running on Synology.
From the PI, i tested and i can send messages to the other domoticz system on Synology
Can anyone help me to point out how to do or what to change in the script to make this possible?
Thanks for your help.
Best regards Bert
pvm
Post by pvm »
You can also make a slave Domoticz and have Domoticz sent these values over to the other one
