Page 12 of 31
Re: Cheap chinese z-wave products
Posted: Wednesday 21 December 2016 9:31
by geezerrr
Does this mean that you’r not able to change “Ambient Illumination Lux Level Report” parameter 9 from
http://www.pepper1.net/zwavedb/device/894 as well?
Posted: Wednesday 21 December 2016 9:55
by deennoo
I can change it, but it doesn't send anything to my system
Posted: Wednesday 21 December 2016 10:00
by JohnBoy32
I guess that because the sensor is long time in sleeping modus, you will have to wait (untill the sensor is awake) before your update of values is operational in the sensor. Update now and wait and see later (eg tomorrow) that your change has become effective.
Or use the trick mentioned above.
Posted: Wednesday 21 December 2016 21:37
by domcao
lost wrote:Welcome in the happy Neo buyers club...
There are many happy buyers; over 90 people (and the numbers are rising) and I do not see complaints @
https://www.aliexpress.com/item/NEO-COO ... 49261.html
Не отправленные с моего BlackBerry через Tapatalk
Posted: Thursday 22 December 2016 8:23
by lost
geezerrr wrote:deennoo wrote:just get a wall plug and a pir, no probleme to add them with domoticz last stable + gen5 w090
Can you try to change the report state (lux) to anytime else then the default 100?
Because I'm unable to change it.
Thnx in advance
On my side, this is the parameter 6, re-trigger interval, that cannot be changed.
It's at 8s, wanting to set it at 30s or a minute, with param 2 (on/off duration) set to 120s (this setup worked, as well as sentivity change, param 1).
I already included latest config patches (there is a quite recent one that's not in current domoticz stable)
The module finally works, but looks quite problematic on the inclusion side as well as for configuration.
Posted: Friday 23 December 2016 18:36
by marigo
Today I received the Neo coolcam wall plug. Including was easy in domoticz. Just set domoticz to learn mode en insert de wall plug.
The plug wil be automaticlly added and will show in the hardware list.
What I noticed is that I need to use a F, CEE 7/4 Schuko plug to switch a device. I first used a flat "euro" plug and it seems that the two pins are sometimes to small te make a good connection with the inside of the Neo Coolcam wall plug. So be aware.
Posted: Friday 23 December 2016 21:57
by u01pei
Re: RE: Re: Cheap chinese z-wave products
Posted: Friday 23 December 2016 22:17
by mschut
LouiS22 wrote:zalsson wrote:so, now one of my power plugs are dead
Stopped responding, no reaction when i push the green button. Nothing.... quailty haha
Have you really tried it? You have to push three times quickly. If you hear any clicking noise then it's working. Maybe you should try it with another socket, etc.
Hmmm, two questions about the wall plug. Have a few now and are working great.
However:
-) Two new plugs did not survive being connected to my fridge plug. Was grounded, so don't really know what the problem is. But, cannot find a fuse. There isn't one is there...
-) The plugs do result in a few devices, sometimes a kwh meter, besides Watt. But this one is so not stable. Any idea how I can improve this device?
Verstuurd vanaf mijn SM-G920F met Tapatalk
Posted: Friday 23 December 2016 23:30
by zalsson
The one that broke for me is the only one that was used with ground pin connected
Skickat från min A0001 via Tapatalk
Posted: Friday 23 December 2016 23:38
by Justintime
The wait is for in wall switches... I have two doorsensors and a wall plug. I think price quality is very good.
Me happy buyer
Posted: Saturday 24 December 2016 0:20
by LouiS22
My second door sensor was somewhat damaged (actually the reed tube was broken), but I fixed it and it's working. Only it has a loud clicking noise upon contacting/breaking with the magnet. It's somehat funny cause this sensor is placed onto the toilet door. No more sneaking quietly into the loo
Posted: Wednesday 28 December 2016 9:32
by kurniawan77
Received two wall plugs and they work wel! Even works with Eneco toon though without energy readings. In domoticz there is kWh but I get strange results...
Anyone knows why?
Sent from my Nexus 6P using Tapatalk
Posted: Wednesday 28 December 2016 10:06
by sincze
domcao wrote:lost wrote:Welcome in the happy Neo buyers club...
Great to read the NEO hardware experiences. The store owner is probably reading this forum as well and keeps increasing the price. Now at Fibaro pricing level of §55.
That is twice the 11-11 sales price so probably increasing his margin a bit
Sent from my SM-G925F using Tapatalk
Posted: Wednesday 28 December 2016 11:09
by kurniawan77
Well I got mine from here €32,-
Home Automation Z wave Sensor Smart Home EU Power Plug Compatible with Z-wave 300 series and 500 series
http://s.aliexpress.com/fmY3AZbq
(from AliExpress Android)
Posted: Wednesday 28 December 2016 11:16
by sincze
kurniawan77 wrote:Well I got mine from here €32,-
Yes keep a look out for different sellers always a good idea
Posted: Wednesday 28 December 2016 11:51
by trixwood
Some of the sellers are different, with the same post address
and they rotate the 'sale'
Posted: Wednesday 28 December 2016 11:53
by sincze
trixwood wrote:Some of the sellers are different, with the same post address
Wow that I did not know. Good tip will look at that from now on.
. Tnx.
Posted: Wednesday 28 December 2016 13:51
by Justintime
Also buy with the Aliexpress app. It had special mobile only discounts.
But indeed prices gone up again. With Christmas I saw one for 26 euro wall plug.
Posted: Wednesday 28 December 2016 13:57
by zalsson
The price goes up and down like I normally do on aliexpress.
Posted: Wednesday 28 December 2016 14:48
by nieass
Justinb81 wrote:nieass4 wrote:Justinb81 wrote:
I have the AS-AB01Z siren as well, and studying on how to create the XML file... just not studying hard enough..
All info needed is here:
http://products.z-wavealliance.org/products/1962
Only the Device ID is wrong, that should be
Neo CoolCam Battery Powered Siren/Doorbell: type=0003, id=1088
I am forced by my wife to stay the Christmas holidays with the family in a vacation park, so maybe I will give it a go when there.
I just created the xml file, I'll test it out and submit it to openzwave github
May I test your XML as well?
I'll post it tomorrow here
Verstuurd vanaf mijn SM-N9005 met Tapatalk
