Page 12 of 17
Re: Introducing dzVents - Domoticz Lua file based event scripting made e-z!
Posted: Sunday 22 May 2016 20:28
by fhwessels
dannybloe wrote:
So, until I make this feature (which is an interesting idea) you have to check the time yourself (and remove the timer setting completely). You can use dzVents domoticz.time property:
CODE: SELECT ALL
if (domoticz.time.hour > 0 and domoticz.time.hour < 6) then
But it would be nice if you can define a trigger and combine a time constraint. I'll consider it for 1.1.
I did this and it is not working. I don't get any errors in the log is there something wrong with my code?
return{
active = true,
236, -- index of the device - 39 book motion led 237 pir 236
execute = function(domoticz, mySwitch)
if (domoticz.time.hour > 19 and domoticz.time.hour < 6) then
if (domoticz.devices[236].state == 'On') then
domoticz.devices[237].dimTo(20)
if(domoticz.devices[236].lastUpdate.minutesAgo > 1) then
domoticz.devices[237].switchOff()
thanks
Francois
Posted: Sunday 22 May 2016 21:54
by dannybloe
Well, I'm not sure. The first if-statement I get. As soon as the pir detects motion at night, you turn on a light. Now, how is the light turned off? If the pir isn't activated again, then this script will not be executed so the second if-statement won't do anything. Unless the pir also triggers the script when it doesn't see any motion anymore ( I know they exist). But let's assume the pir only triggers when it sees something. In that case you indeed need a timer as well. This is what I would write:
active = true,
timer = { 'at 20:*', 'at 21:*', 'at 22:*', 'at 23:*', 'at 00:*', 'at 01:*', 'at 02:*', 'at 03:*', 'at 04:*', 'at 05:*',
'at 06:01'} -- the last one is to make sure the light is turned of when the pir turned it on at 05:59 exactly'
execute = function(domoticz, pir)
local light = domoticz.devices[237]
if (domoticz.time.hour > 19 and domoticz.time.hour < 6 and pir.state == 'Motion' then
light.dimTo(20)
if (light.state == 'On' and pir.lastUpdate.minutesAgo > 1) then
-- only do anything if the light is indeed On. Otherwise you will keep sending commands to Domoticz.
light.switchOff()
I suspect that with pir's domoticz sends the
Motion state and not the
On state. That could also be the reason why it didn't work for you. Best practice when things don't work is to print information to the domoticz log. You could call domoticz.logDevice( domoticz.device[...] ) to get a full dump of the device state in the log or you could log anything else using domoticz.log(....). I alway check if the script is executed at all, and I put log statements in the if branches to see if you get there as well, and print ohter information like in your case the actual state (domoticz.log(pir.state)) or domoticz.log(domoticz.time.hour). That way you see what is happening.
1.0 Released
Posted: Friday 27 May 2016 7:52
by dannybloe
Just to let you peepz know.
1.0 was released yesterday.
Posted: Friday 03 June 2016 15:01
by micke
return{
active = true,
Francois,
You can't have a domoticz.time.hour that is both greater than 19 and smaller than 6. Change the 'and' to 'or'.
/Micke
Posted: Friday 10 June 2016 17:53
by kiwi
Hi there,
I am trying to use dzVents on my FreeBSD port of domoticz. For unknown reasons domoticz doesn't seems to load the files, so I am puzzled :/
Posted: Friday 10 June 2016 18:00
by dannybloe
Just some checks:
- Make sure you have the dzVents folder in the correct place with all its contents (../domoticz/scripts/lua/dzVents)
- put both scripts script_device.main.lua and script_time_main.lua in your Lua script folder (../domoticz/scripts/lua) and
- Rename the settings file to dzVents_settings.lua (and set the http parameters inside to correct ip address etc).
- Created a subfolder 'scripts' inside your Lua folder (../domoticz/scripts/lua/scripts) and
- in there create a script file according to the examples/generic.lua (edited to your needs).
- Make sure the script is active: active=true
If that still doesn't work try to see if Domoticz calls script_time_main.lua. Check the logs or put a print statement in there. That file must be found, that's just basic Domoticz functionality.
Posted: Wednesday 15 June 2016 17:30
by kiwi
I make it step by step and it works. I used previously symlinks but it seems that domoticz doesn't like it.
Posted: Friday 17 June 2016 11:25
by Bororo
Can somebody publish working example for sending temperature and humidity data from Oregon sensors to Thingspeak only if values changed, please? I think it will be appreciated by many beginners. Thank you.
Posted: Friday 17 June 2016 11:39
by dannybloe
I guess something like this. I don't know the urls for posting to thingspeak but this would probably get you started.
active = true,
'myTempHumDevice'
data = {
previousTemp = { initial = nil },
previousHum = { initial = nil }
execute = function(domoticz, myTempHumDevice)
local previousTemp = domoticz.data['previousTemp']
local previousHum = domoticz.data['previousHum']
local currentTemp = myTempHumDevice.temperature;
local currentHum = myTempHumDevice.humidity;
if (currentTemp and previousTemp ~= currentTemp) then
-- send the currentTemp to thingspeak
domoticz.openURL('http:// ... ') -- construct your url
if (currentHum and previousHum ~= currentHum) then
-- send the currentHum to thingspeak
domoticz.openURL('http:// .... ') -- construct your url
domoticz.data['prevousTemp'] = currentTemp
domoticz.data['prevousHum'] = currentHum
Posted: Tuesday 26 July 2016 10:59
by svenker
Thanks for this easy tool. Really practicale.
Is there a way to use the EzVents tool with the integrate LUA tool of Domoticz ?
It would be really cool to do all LUA scripts directly from the Web Browser versus using Notepad etc and then upload it via FTP.
May be it is working and it is just me that doesn't know how to use it.
Sam
Posted: Tuesday 26 July 2016 12:06
by dhanjel
Another idea is to share the folder with the scripts on your network (I assume that you only develop on your local network), and then use a more pleasant editor. As a .Net developer, I really enjoy Visual Studio Code, which is free.
https://code.visualstudio.com/c?utm_exp ... ogle.se%2F
But of course there are a lot of other editors as well.
Posted: Tuesday 26 July 2016 15:44
by svenker
Hello dhanjel,
Thanks for the idea. I have just done that and it works very well
It would be still VERY cool to get it directly via Domoticz in the "Events" page.
Thanks anyway !
Rgds
Sam
Posted: Tuesday 26 July 2016 19:08
by dhanjel
Yes, it would be convinient
Guess I am old fashioned and want to work outside the browser
Posted: Friday 29 July 2016 8:06
by dannybloe
Yeah, same applies for me. External editors are way better. I use WebStorm with the Lua plug-in. Works like a charm.
Anyhow, first step is to get dzVents integrated into Domoticz. I'm currently preparing that with gizmocus. Then we can see how we can have the internal event system use it too. Shouldn't be so hard but requires some C++ programming that I cannot do myself.
Posted: Friday 29 July 2016 10:19
by julianmclean
Firstly, just want to say that dzVents is excellent, and together with the new selector switches in Domoticz, I have just re-written all of my previous logic (spread across Blockly and Lua scripts) into dzVents. In the process of doing this I've managed to make a lot of simplifications, remove a load dummy switches that were used to supplement the blockly/lua, and generally get everything in a much more manageable state. So, many thanks to the developer(s) on this - it really is a major enhancement for the Domoticz environment.
Regarding the points above about integration into Domoticz UI, whilst I am also "old school" and generally develop either directly in vi over SSH or IDE via samba share, it would be great to be able to edit scripts in the browser occasionally, especially when noticing a problem away from home, without having to VPN in, yadda, yadda.
I was actually wondering if anyone knew of a decent, simple browser-based text editor that could be deployed on the Domoticz box (Node.js based would be ideal) and allows simple browsing, opening, creating/editing and saving of the scripts files? I've seen similar things baked into other unrelated platforms, but a quick web search is not turning much up. What would be really good is to have something like this integrated into the Domoticz UI so it's just another menu option to browse and edit script files.
Posted: Friday 29 July 2016 15:08
by dhanjel
I really don´t get why this isn´t working. Only thing in the log is GCM:
domoticz.sendCommand('Security Panel', 'Arm Away')
Has anyone else tried to arm from a dzVents script?
Posted: Friday 29 July 2016 15:09
by G3rard
@dannybloe, just installed dzVents and it looks great! Thanks for all the effort you have put into this.
I have a question regarding the LUA script below which I am currently using. I store a timestamp in a user variable to determine if a switch is pressed 2 times within 3 seconds.
I want to change this script to dzVents, but I am not sure how to change the lastUpdate correctly as described on GitHub.
Old LUA script:
package.path = package.path .. ';' .. '/volume1/@appstore/domoticz/var/scripts/lua/functions/functions.lua' -- dir functions lua script
local fs = require("functions"); --load functions lua script
TimeBetweenPresses = 3 --max time between presses (in seconds)
if (devicechanged['Lamp keukenkastjes'] == 'Off') then
if (fs.timedifference(uservariables_lastupdate['Dubbelklikschakelaar']) < TimeBetweenPresses ) then
--print('Twee keer gedrukt binnen de tijd')
if (otherdevices['Lux Kamer gang'] == 'Off') then
--print('Lampen zijn al uit...')
commandArray['Group:Lampen kamer'] = 'Off'
commandArray['Variable:Dubbelklikschakelaar']=tostring(os.time())
--print('Te lang er tussen')
dzVents script:
active = true,
data = {
--counter = { initial = 1 },
previousClick = { initial = nil }
execute = function(domoticz, switch)
--calculate the difference in seconds between previous and current click
print('Vorige tijdstip: ' .. domoticz.data.previousClick)
local hoursAgo, minsAgo, secsAgo = string.match(domoticz.data.previousClick, "(%d+):(%d+):(%d+)")
local timestamp = hoursAgo*3600 + minsAgo*60 + secsAgo
domoticz.data.previousClick = switch.lastUpdate.raw
local hoursAgo2, minsAgo2, secsAgo2 = string.match(domoticz.data.previousClick, "(%d+):(%d+):(%d+)")
local timestamp2 = hoursAgo2*3600 + minsAgo2*60 + secsAgo2
print('Huidige tijdstip: ' .. domoticz.data.previousClick)
local difference = timestamp2 - timestamp
print('Verschil: ' .. difference)
if (difference < 3) then
print('The switch was pressed 2 times in < 3 seconds!')
--if (domoticz.data.counter == 2) then
--domoticz.data.counter = 1 -- reset the counter
--else
--domoticz.data.counter = domoticz.data.counter + 1
--end
print('Niet binnen de tijd')
I tried to use lastUpdate.secondsAgo but that always returns 0 seconds. So I used lastUpdate.raw and calculate the difference, but I think this can be done easier. What am I doing wrong here
Posted: Saturday 30 July 2016 9:58
by digimate
dannybloe wrote:Anyhow, first step is to get dzVents integrated into Domoticz. I'm currently preparing that with gizmocus.
Great news!!! Will it then also be available for Synology 'users'? When?
Thanks for your efforts!
Sincerely, Nico
Posted: Thursday 04 August 2016 10:28
by ddahya
Hi Guys,
Just wanted to know if someone could please help with my dzVents script. This is my first attempt to creating a script.
What I want to script to achieve is if the changed value of the thermostat is the same as the previous value then do nothing, if the value is different to the previous then execute a python command with new value and device name.
First attempt at script.
active = true,
'Dining', 'Guest Room' -- Thermostat Device Names as seen in App
data = {
local TargetTemp = device.setPoint;
if (TargetTemp and previousTemp ~= TargetTemp) then
-- send the TargetTemp to NeoHub
os.execute('python /home/pi/domoticz/scripts/python/NeoHub.py -s -x '..tonumber(TargetTemp)..' --StatName '.. "'"..deviceName.."'")
-- Added some logging for troubleshooting
domoticz.log(deviceName, domoticz_LOG_INFO)
domoticz.log(device.deviceType, domoticz_LOG_INFO)
domoticz.log(TargetTemp, domoticz_LOG_INFO)
domoticz.data['prevousTemp'] = TargetTemp
Log from Domoticz –
- the device is showing up as a Light/Switch and not a thermostat.
2016-08-04 20:02:41.790 LUA: Handling events for: "Guest Room", value: "23.00"
2016-08-04 20:02:41.790 LUA: =====================================================
2016-08-04 20:02:41.790 LUA: >>> Handler: Neo
2016-08-04 20:02:41.790 LUA: >>> Device: "Guest Room" Index: 113
2016-08-04 20:02:41.790 LUA: .....................................................
2016-08-04 20:02:41.791 LUA: Light/Switch
2016-08-04 20:02:41.792 LUA: .....................................................
2016-08-04 20:02:41.792 LUA: <<< Done
2016-08-04 20:02:41.792 LUA: -----------------------------------------------------
2016-08-04 20:02:41.666 (HM: Heating) Thermostat (Guest Room)
Posted: Thursday 04 August 2016 10:34
by dannybloe
Can you find the device in the devices.lua file and post the table for that device. Then we can see how Domoticz types the device. If it is indeed a switch type then setPoint will not be set. You may have to use one of the other device attributes to get the setpoint.
