Johndomo
Re: Domoticz app 2.0
The app works again, but unfortunately the problem with the dimmers still exist.
When I change the level of one Fibaro ZWave dimmer, another Fibaro Zwve dimmer reacts too.
- eeve
- Domoticz version: 4.97
Maybe some people has scheduled there heating with it? Or makes an alarm system with it?sammyke007 wrote: Wednesday 04 November 2020 12:21 Updated and fixed indeed. What the hell is wrong with people? This got fixed within 24h! Please have patience. It's an app for playing/controlling your home, it's not TESLA's software controlling your car![]()
Domoticz + Ispy @ Windows 10
A wheelchair doesn't end your life;
but it's a challenge to continu
- bjornhallberg
- Domoticz version: Beta?
I believe I had mishap with the app around Nov 3rd where some of the settings were lost or reset to a previous state, including server settings and geofence settings. Like geofence was still activated, but the actual geographic point was lost.
Also, I get a ton of session errors using the app, manually and while switching geofence in the background:
I.e. "Error: CheckAuthToken(4385cb1e4fc80d2fc888acafdba0df83_OWVjYTI3MzItOGU2MS00NDk0LWI0ZjItNDk3YmYxYjVkYjY5) : session id not found"
Running Domoticz 2020.2.
- galadril
- Domoticz version: latest
New beta is coming with a new cool Android 11 feature!
Control External Devices of Android 11 is now implemented in the Android app (fee + paid)
BertB
I run latest beta of Domoticz on a RPI4.
My question is related to the Domoticz app, that runs on Android.
In Domoticz, I created rooms en added all related devices to them.
I used to be able to see all devices in the app, but now I only see a part of them.
For instance in the room named Attick, I have a ZW96 zwave smart switch with:
- Voltage (utility)
- Usage (utility)
- Power (utility)
- Current (utility)
- A switch (Switches)
In the app I can only see the switch.
Is there somting wrong?
- Voltage (utility)
- Usage (utility)
- Power (utility)
- Current (utility)
Set 1= RPI 3B, latest Beta, RFLink USB, RFLINK WIFI, Zwave
Set 2= RPI 2B, Latest Beta, OTGW (USB), SBFSpot (Bluetooth)
- galadril
No you should be able to see them all.
BertB
Well, I can only see what is favourite on the dashboard in Domoticz.
TAA
- Domoticz version: 3.8799
Same happening to me after upgrading server to 2020.2.12742 on Windows 10
Only those in dashboards show up in rooms in Plans view.
It is same behaviour in webinterface so problem not likely in the app.
Domoticz Beta 3.8799 on Windows10 with RFXtrx433 USB, firmware 94 and Aeotec Z-stick gen 5
peteralm
This has also happened to me - I have the paid app with family library enabled and all family members now only see starred or favourite devices in the plans menu.BertB wrote: Saturday 19 December 2020 14:46 I run latest beta of Domoticz on a RPI4.
- Voltage (utility)
- Usage (utility)
- Power (utility)
- Current (utility)
Is there something wrong?
I see to recall that a couple of beta updates of domoticz ago the whole room plan thing went a bit wobbly - i was thinking that i had database issues, but then it corrected itself. Now Domoticz is back to normal and the app still only shows favourite devices in the plan menu.
I am on the latest beta of domoticz and in the beta programme for the app.
TAA
It seems it has changed from using the Switches (all devices) as base for filteringer into Plans and instead is using the Dashboard view (Favourites) as base for filtering into Plans. In the web-interface this works correctly.
The error is consistent across all my different android devices, and across several updates of the server installation.
I just switched on an old decice that has not been used for å while. It has app-version 7878 and has same problem as my updated devie with app-version 8389.
- galadril
Think i fixed the issue with the plan devices.
New build is coming
New build is coming
peteralm
My app has just updated and bingo! Thanks for the quick fix.galadril wrote: Wednesday 23 December 2020 13:23 Think i fixed the issue with the plan devices.
New build is coming
P.
BertB
Yes, problem is gone here too.galadril wrote: Wednesday 23 December 2020 13:23 Think i fixed the issue with the plan devices.
New build is coming
wocko
Great feature! Unfortenately it works only when i open the domoticz app and directly after it use the power off menu. When i use it a second time or without opening the app first, then it keeps saying "loading". Same problem on my wifes phone (Both Pixel4a, Android 11). Anybody else also this problem? Any idea how to solve?galadril wrote: Saturday 12 December 2020 14:11 New beta is coming with a new cool Android 11 feature!
Creaky
- Domoticz version: 2020.2
Hi @Galadril,
I’m using the latest version of the Tradfri plugin (0.10.3) by Moroen and I've found a slight issue with the plugin and the Domoticz App for Android. The fault lies with the app I'm afraid.
When you drag a Tradfri dimmer slider in the Domoticz app to a level of 100%, it actually tells Domoticz to go to level 101, which is not a legal value and rightfully causes an error message by the plugin.
Here are the lines in the log file:
2021-01-07 13:25:10.714 (Tradfri) Processing 'onCommandCallback' message
2021-01-07 13:25:10.714 (Tradfri) Calling message handler 'onCommand'.
2021-01-07 13:25:10.714 (Tradfri) onCommand called for Unit 11: Parameter 'Set Level', Level: 101
2021-01-07 13:25:10.715 (Tradfri) Command Level: 101
2021-01-07 13:25:10.668 Status: User: bas initiated a switch command (595/Schemerlamp werkkamer/Set Level)
2021-01-07 13:25:10.720 Error: (Tradfri) 'onCommand' failed 'UnknownError'.
2021-01-07 13:25:10.720 Error: (Tradfri) ----> Line 770 in '/config/plugins/IKEA-Tradfri/plugin.py'
2021-01-07 13:25:10.720 Error: (Tradfri) ----> Line 687 in '/config/plugins/IKEA-Tradfri/plugin.py'
2021-01-07 13:25:10.720 Error: (Tradfri) ----> Line 257 in '/usr/local/lib/python3.8/dist-packages/tradfricoap/device.py'
2021-01-07 13:25:10.720 Error: (Tradfri) ----> Line 36 in '/usr/local/lib/python3.8/dist-packages/tradfricoap/request.py'
2021-01-07 13:25:10.720 Error: (Tradfri) ----> Line 61 in '/usr/local/lib/python3.8/dist-packages/tradfricoap/pycoap_api.py'
2021-01-07 13:25:10.720 Error: (Tradfri) ----> Line 54 in '/usr/local/lib/python3.8/dist-packages/py3coap/py3coap.py'
Can you please fix this in the app?
Best regards,
Bas
Best regards,
Bas
Greetz,
·´¯`·.¸¸.·´¯`·. ( Creaky ) .·´¯`·.¸¸.·´¯ `·
Creaky
Hi @Galadril,galadril wrote: Wednesday 23 December 2020 13:23 Think i fixed the issue with the plan devices.
New build is coming
Best regards,
Bas
Greetz,
Somewhat special question:
I recently purchased/installed the paid premium version on my Android mobile phone (v0.2.285 (8394), everything works fine, thank you!
Now I want to install this app on my wife's cell phone too. Do I now have to purchase it separately again (she has her own Google account) ?
Thanks.
Greetings, Theo.
Thanks.
Greetings, Theo.
Plantje
No, there is no need to. Fortunately Domoticz is one of the few apps that you can add to your family group!
That way your wife (I assume being part of your family) can install the app free of charge.
I would hope they'd add the Android TV app to this as well.
Creaky
Hi Plantje,
Any news on the 101% level bug? (See my post above...)
Greetz,
Plantje
I saw your post, but I am no Domoticz (app) developer... I am only a user
