Page 109 of 114
Posted: Thursday 05 March 2020 23:47
by djdevil
Madgeni wrote: Thursday 05 March 2020 12:27
can you restart Domoticz? I had another user also having issues with http calls.
Notifications are working in Controlicz ok
Yes i restart it but not work! sometimes it goes and more often than not
can you check why this happens? I have important routines that don't work! Thx
Posted: Friday 06 March 2020 11:48
by Madgeni
Hi -
looking in the domoticz forum, it seems to be a recurring issue with Domoticz for some users
Posted: Friday 06 March 2020 12:10
by djdevil
everything has always worked correctly for me and for 5/6 days it has happened domoticz tries to send the notification and then from http error!
Posted: Friday 06 March 2020 12:16
by Madgeni
ok, i can certainly check the backend - can you mail me from your Controlicz profile? thanks
Posted: Friday 06 March 2020 12:30
by djdevil
Madgeni wrote: Friday 06 March 2020 12:16
Thx i send you email from of site! I await your news thanks!
Posted: Sunday 08 March 2020 13:02
by heggink
Hey Nick,
Weird error: my domoticz log says User: xxxx, scene not found (idx=-586)!
I looked at the IP and it's amazon so suspected it's controlicz.
Looked at the controlicz logs and found 2 log entries for IDX -586 action SetScene status success.
Any idea what causes this?
H
Posted: Sunday 08 March 2020 13:50
by Madgeni
Hi - can you sync your devices and check again?
Posted: Monday 09 March 2020 20:12
by walberg
I just have Controlicz (registered) setup and i can access my Domotic devices from Controlicz.
But adding Controlicz to Google Home does not work, Google does not ask for login information but directly connecting Controlicz and directly said something went wrong, Try again.
I have had in the past HomeAssistant and Nabu Casa, that works but when adding Nabu Casa to Google Home it asked for inlog name and password and that is not asked when adding Controlicz. Tried to remove Google Home app but the problem stays. Tried to complete erase Google account, a lot of work to reconnect my Bose Soundbar 700 (that act like a Google Home) But the problem remains.
Posted: Monday 09 March 2020 20:43
by Madgeni
Can you create a new Home in your Google Home app and try again?
Posted: Monday 09 March 2020 22:46
by walberg
Dit it but the same, not asking for user/password and so not connecting.
Posted: Monday 16 March 2020 17:01
by Madgeni
Hi all, vacuums are now controllable via google home
"Set Vacuum to <mode>"
Additionally, Selector switches should now work for any level names/types in all supported languages. As usual, any issues, drop me a mail from your Controlicz profile
Posted: Monday 16 March 2020 17:17
by walberg
Still the same. Also changed the default google settings for other or unknown apps from deny to allow (as i also got blocked incoming from Google But that dit not resolve the problem.
When i do ad device and click on Controllicz Google home does not ask for user and password but says Controlicz is connected and a few seconds later: Something went wrong.
Posted: Monday 16 March 2020 17:45
by Madgeni
Does the same happen using the Google Assistant app?
Posted: Wednesday 18 March 2020 21:30
by arjanw
Eagerly awaiting sensor support !
Posted: Thursday 19 March 2020 14:30
by Madgeni
Temp sensors are available *however* they are not available using touch controls. Sync your devices and with voice:
What temperature is the <device> set to
Open/Close + On/Off query for sensors are also available
Posted: Friday 20 March 2020 16:02
by Madgeni
Battery devices can now be queried - "What is the <devicename> battery level?"
Also, I have provided some new discovery behaviours. Not all devices discover as you would like, and you've asked for the ability to override these - now you can. From the FAQs:
you can provide a specific type of device: Light/Switch/Outlet/Fan/Thermostat/TempSensor/Security/Lock/Sensor/Battery/Selector/Blinds/Vacuum.
for example - Simply put TypeControl: Light in the device description field and sync/discover your devices and Controlicz will treat the device accordingly
Product Release notes updated
Enjoy
Posted: Thursday 16 April 2020 16:51
by tjabas
Hi!
i´ve been using controlicz for a while now, but for a couple of days now its not responding, google home says "sorry i couldt reach controlicz"
i have tried to delete and add controlicz again in the home app, but it still doesnt work, i have also checked on the controlicz webb page and my account is active and i have a connection.
what could be wrong?
Posted: Sunday 19 April 2020 21:05
by phtinix
Same problem for me
Posted: Sunday 19 April 2020 21:09
by tjabas
phtinix wrote: Sunday 19 April 2020 21:05
Same problem for me
i tried everything, with alot of help from controlicz maker, but it just wouldnt work, so i tried a different service on the google home app, but also there i had problem, google assistant wouldnt work, but what work was to reset the google home mini, and istall it again in the home app, after that everything worked as it should, so its my advice, reset your google home.
Posted: Sunday 19 April 2020 21:15
by phtinix
The thing is, it do the job but complain about controlicz being unavailable
