Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
djdevil
Domoticz version: 2021.1
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by djdevil »
Madgeni wrote: Thursday 05 March 2020 12:27 can you restart Domoticz? I had another user also having issues with http calls.
Notifications are working in Controlicz ok
Yes i restart it but not work! sometimes it goes and more often than not 🤔 can you check why this happens? I have important routines that don't work! Thx
Madgeni
Post by Madgeni »
Hi -
looking in the domoticz forum, it seems to be a recurring issue with Domoticz for some users :(
djdevil
Post by djdevil »
everything has always worked correctly for me and for 5/6 days it has happened domoticz tries to send the notification and then from http error!
Madgeni
Post by Madgeni »
ok, i can certainly check the backend - can you mail me from your Controlicz profile? thanks
djdevil
Post by djdevil »
Madgeni wrote: Friday 06 March 2020 12:16 ok, i can certainly check the backend - can you mail me from your Controlicz profile? thanks
Thx i send you email from of site! I await your news thanks!
heggink
Domoticz version: 12451
Post by heggink »
Hey Nick,
Weird error: my domoticz log says User: xxxx, scene not found (idx=-586)!
I looked at the IP and it's amazon so suspected it's controlicz.
Looked at the controlicz logs and found 2 log entries for IDX -586 action SetScene status success.
Any idea what causes this?
H
DASHTICZ 🙃
P1 meter & solar panel
Madgeni
Post by Madgeni »
Hi - can you sync your devices and check again?
walberg
Domoticz version: 3.5877
Post by walberg »
I just have Controlicz (registered) setup and i can access my Domotic devices from Controlicz.
But adding Controlicz to Google Home does not work, Google does not ask for login information but directly connecting Controlicz and directly said something went wrong, Try again.
I have had in the past HomeAssistant and Nabu Casa, that works but when adding Nabu Casa to Google Home it asked for inlog name and password and that is not asked when adding Controlicz. Tried to remove Google Home app but the problem stays. Tried to complete erase Google account, a lot of work to reconnect my Bose Soundbar 700 (that act like a Google Home) But the problem remains.
Madgeni
Post by Madgeni »
Can you create a new Home in your Google Home app and try again?
walberg
Post by walberg »
Dit it but the same, not asking for user/password and so not connecting.
Madgeni
Post by Madgeni »
Hi all, vacuums are now controllable via google home :)
"Set Vacuum to <mode>"
Additionally, Selector switches should now work for any level names/types in all supported languages. As usual, any issues, drop me a mail from your Controlicz profile
walberg
Post by walberg »
Still the same. Also changed the default google settings for other or unknown apps from deny to allow (as i also got blocked incoming from Google But that dit not resolve the problem.
When i do ad device and click on Controllicz Google home does not ask for user and password but says Controlicz is connected and a few seconds later: Something went wrong.
Madgeni
Post by Madgeni »
Does the same happen using the Google Assistant app?
arjanw
Target OS: OS X
Post by arjanw »
Eagerly awaiting sensor support !
Madgeni
Post by Madgeni »
Temp sensors are available *however* they are not available using touch controls. Sync your devices and with voice:
What temperature is the <device> set to
Open/Close + On/Off query for sensors are also available
Madgeni
Post by Madgeni »
Battery devices can now be queried - "What is the <devicename> battery level?"
Also, I have provided some new discovery behaviours. Not all devices discover as you would like, and you've asked for the ability to override these - now you can. From the FAQs:
you can provide a specific type of device: Light/Switch/Outlet/Fan/Thermostat/TempSensor/Security/Lock/Sensor/Battery/Selector/Blinds/Vacuum.
for example - Simply put TypeControl: Light in the device description field and sync/discover your devices and Controlicz will treat the device accordingly
Product Release notes updated
Enjoy
tjabas
Post by tjabas »
Hi!
i´ve been using controlicz for a while now, but for a couple of days now its not responding, google home says "sorry i couldt reach controlicz"
i have tried to delete and add controlicz again in the home app, but it still doesnt work, i have also checked on the controlicz webb page and my account is active and i have a connection.
what could be wrong?
phtinix
Post by phtinix »
Same problem for me :(
tjabas
Post by tjabas »
phtinix wrote: Sunday 19 April 2020 21:05 Same problem for me :(
i tried everything, with alot of help from controlicz maker, but it just wouldnt work, so i tried a different service on the google home app, but also there i had problem, google assistant wouldnt work, but what work was to reset the google home mini, and istall it again in the home app, after that everything worked as it should, so its my advice, reset your google home.
phtinix
Post by phtinix »
The thing is, it do the job but complain about controlicz being unavailable
