Page 108 of 184
Posted: Saturday 06 May 2017 17:13
by EdwinK
I'm trying to switch the title and data from a switch. Normally I would to something like this:
blocks['139_2'] = {}
blocks['139_2']['title'] = 'Luchtvochtigheid';
blocks['139_2']['switch'] = true;
blocks['139_3'] = {}
blocks['139_3']['title'] = 'Baro';
blocks['139_3']['switch'] = true;
But in this case it isn't working. It might not be possible
Posted: Saturday 06 May 2017 17:16
by crashingdutchman
Ierlandfan wrote:
crashingdutchman wrote:Would anyone be interested in adding Flightradar24 to his dashboard? I have this setup now and it seems to work nice, although I would like to be able to remove the left part of that site.Image
I was playing with that also. I use this:
frames.flightradar = {height:250,frameurl:"https://www.flightradar24.com/52.8,5/10",width:12}
Gives you the Northern part of Holland. No menu on the left side for me.
Edit, found a better source (thanx to Vliegveld Middenmeer)
https://www.flightradar24.com/simple?la ... 2=altspeed
If you want all aiprplanes you have to delete maxspeed and minspeed. If you only want light aircraft like Microlights, gliders, Cessna, Piper and that kind of airplanes leave them in place.
The 'simple' site where you link to in your edit is not supported anymore by FR24. It works now, but might not work in the future. I noticed that the menu on the left is not there if the screen resolution is smaller.
Posted: Saturday 06 May 2017 17:55
by jake
how to pull from the beta instead of the stable version? I now use 'git pull', but wat command should I use for pulling the beta?
Verstuurd vanaf mijn K00C met Tapatalk
Posted: Saturday 06 May 2017 18:10
by EdwinK
I would make a backup of ALL changed file, CONFIG.js custom.css and custom.jss
Then I deleted the dasthicz folder and
git clone https://github.com/robgeerts/dashticz_v2.git
To check if it's really the beta, you can do
 git branche
Hope this helps.
(changed a bit)
Re: RE: Re: Dashticz - General Discussions
Posted: Saturday 06 May 2017 18:21
by jake
EdKo66 wrote:I would make a backup of ALL changed file, CONFIG.js custom.css and custom.jss
Then I deleted the dasthicz folder and then on https://github.com/robgeerts/dashticz_v2/tree/beta and after that a
 git branche
Hope this helps.
I don't understand your line to go "https://github.com/robgeerts/dashticz_v2/tree/beta" what to do there?
Posted: Saturday 06 May 2017 18:23
by HansieNL
 git branche
Hope this helps.
In addition to your response:
Run command from your Domoticz www folder and change dashticz if you wanna install to subfolder with other name
git clone https://github.com/robgeerts/dashticz_v2.git --branch beta dashticz
Posted: Saturday 06 May 2017 18:26
by EdwinK
Easier
Posted: Saturday 06 May 2017 18:29
by mlamie
It looks like the beta version doesn't refresh the Domoticz icons (need to do a browser refresh), The stable version does. Is there a known issue there?
Posted: Saturday 06 May 2017 19:00
by HansieNL
mlamie wrote:It looks like the beta version doesn't refresh the Domoticz icons (need to do a browser refresh), The stable version does. Is there a known issue there?
Already reported in Dashticz - Bug report https://www.domoticz.com/forum/viewtopi ... 67&t=17427.
Thanks for asking.
Posted: Saturday 06 May 2017 22:22
by lukev
Hi all, is there a way to fix the output of a graph in 'last month'? It always flips back to 'today' (which isn't actually a day but a few days...)
Posted: Saturday 06 May 2017 22:27
by EdwinK
lukev wrote:Hi all, is there a way to fix the output of a graph in 'last month'? It always flips back to 'today' (which isn't actually a day but a few days...)
I don't think so. At least, I've seen this for quite some time nowIt might be on Rob's to-do-list.
Posted: Sunday 07 May 2017 9:12
by tontze
Hi !
I was trying to get Wikis weather frame to work, but it makes screen blank .. I have done as wiki says :
var frames = {}
frames.weather = {refreshiframe:10000,height:500,frameurl:"http://iltasanomat.weatherproof.fi/tutka.php?map=Etel%C3%A4-Suomi",width:12}
columns[1]['blocks'] = [frames.weather];
Posted: Sunday 07 May 2017 15:03
by robgeerts
htilburgs wrote: Error:
About the error, I can confirm that when you have var _STANDBY_AFTER_MINUTES = false; then you get this error. Something is wrong in the main.js file. I wil notice @robgeerts for this.
Put the var _STANDBY_AFTER_MINUTES = 10; than the error is gone for the moment.
Fixed in latest beta!
Posted: Sunday 07 May 2017 15:05
by robgeerts
Please test this in latest version!
Posted: Sunday 07 May 2017 15:14
by EdwinK
Hurray.. new updates :)
*goes doing a "git pull"*
Posted: Sunday 07 May 2017 15:16
by mvveelen
Great, Rob is back with a few fixes :) :)
Posted: Sunday 07 May 2017 15:17
by blacksn0w
Still not working here, have to refresh site to get updated device state.
Posted: Sunday 07 May 2017 15:18
by mvveelen
Same here, unfortunately.
Posted: Sunday 07 May 2017 16:10
by koowee
tontze wrote:Hi !
var frames = {}
I think that you need to add more parameters to "columns", try for example this
var frames = {}
columns[1] = {}
columns[1]['width'] = 4;
screens[2] = {}
screens[2]['background'] = 'bg1.jpg';
screens[2]['columns'] = [1]
Posted: Sunday 07 May 2017 16:23
by Phantom
When i activate these 2 lines in main.js it works for me (not sure if it has any other impact) but it is also active in the master branche.
				if(typeof(_DEBUG)=='undefined' || _DEBUG===false) setTimeout(function(){ getDevices(); },(_DOMOTICZ_REFRESH*1000));
	else {
