Page 107 of 114
Posted: Monday 30 December 2019 15:15
by sundodger
Hi all, I am trying to get my echo dot to speak when the doorbell is pressed. No luck so far.
I have Domoticz running on a raspberry Pi with the doorbell connected to the GPIO. When the doorbell is pressed it triggers various actions, pushbullet notifications etc.
I did set up a routine in the Alexa app that should trigger when that same switch closes. Nothing happens.
I also setup a dummy motion sensor with a delayed off to see if that worked, still will not trigger.
I feel i am missing something obvious. Has anyone implemented similar? If so how did you get it to work?
Posted: Monday 30 December 2019 15:19
by astrapowerrr
Check you have any devices with special characters in them, change them (details in the email), and then reconnect your account in the Home app
i tried to delete the plan $hidden devices but my other plans disapeared..
can i get them back with a backup? and do i do this with de db file?
pfff why did i even started this...
btw is the $hidden device floorplan the one who is making it not to work? or is it really a device with a special character...
Posted: Monday 30 December 2019 21:47
by Madgeni
It's a device, not the $hidden devices room plan.
Posted: Tuesday 31 December 2019 12:09
by jvandermeijs
I'm new to Controlicz and have to following problem when setting up my information.
I accidentally put my http port in instead of my https port and now I'm trying to edit this in my profile.
However each time i'm trying to edit the website keeps asking for my username and password and does not continue actually editing my profile.
Could you maybe help me fixing this?
With kind regards.
Posted: Tuesday 31 December 2019 13:57
by Madgeni
Can you put your controlicz username + password in there
Posted: Tuesday 31 December 2019 14:52
by AthomeDomotica
astrapowerrr wrote: Monday 30 December 2019 14:41
It looks ok, can you try linking your Controlicz account again in the Home app?
just tried a few minutes ago.. nothing..
i have a video of it what happens but cant upload i think only pictures?
Try this link to set-up you're Controlicz.
https://ehoco.nl/domoticz-bedienen-goog ... ontrolicz/
Controlicz WAN IP-address =
35.178.116.149
From the outside (WAN) the next
https trafic
PORT 443 from IP-address:
35.178.116.149 has to be
Forwarded to you're STATIC IP-adress of you're Domoticz controller internal (LAN) on you're Router/Firewall!
You need also set WEBSITE protection on you're Domoticz setings....
Please let us know
Cheers,
Mike
Posted: Tuesday 31 December 2019 19:05
by jvandermeijs
Madgeni wrote: Tuesday 31 December 2019 13:57
When I do so it just keeps on popping up. By username you mean my emailadress right?
Posted: Wednesday 01 January 2020 11:51
by AthomeDomotica
Hello All, all the best for 2020.
The question is; what is usable from Domoticz/Controlicz as
VOICE CONTROLE?
Is it possible to use "Groups or Scenes" within Domoticz and
CALL these names? (Google Home)
Or can you make these "Groups"
ONLY within the "Home APP" on you're mobile phone?
I thought Domoticz would be the Leader in this, but for now it's not working as I thought it would.....
Are de (light) switches only usable....
Please advise, it's looking great but can't get it working
A link/hint in the right direction would be nice.
Mike
Posted: Wednesday 01 January 2020 12:37
by Madgeni
Hi Mike -
you can use Domoticz Scenes/Groups in Google Home (Hey Google Activate <SceneName>) - just make sure the Scenes toggle is enabled in your Domoticz User settings.
You can use lights (brightness + colour)/switches/temps/selector switches in most languages
Posted: Wednesday 01 January 2020 12:42
by AthomeDomotica
Madgeni wrote: Wednesday 01 January 2020 12:37
Hi Mike -
Thx for the quick responce,
I'll try that.
Greetings,
Mike
Posted: Wednesday 01 January 2020 13:53
by AthomeDomotica
AthomeDomotica wrote: Wednesday 01 January 2020 12:42
Hi Mike -
I'll try that.
Greetings,
Mike
Thx,
That worked like a charm
It's all in the "words" you are using, trying in
Dutch!
For now active.
All I need to find out is how to get the scenes from the "
HUE Gateway" in place and usable....
Cheers,
Mike
Posted: Thursday 02 January 2020 19:34
by Madgeni
Just to let everyone know logging of commands is now available in your profiles
Posted: Friday 03 January 2020 1:11
by phoenixblue
I'm busy now to install everything but I searching for an push notification solution for example an doorbell.
I see in the past x hundreds of posts (big topic btw
) some of the same questions but without an solution as far I see.
So is it possible to setup push notifications to the GA?
Posted: Friday 03 January 2020 8:44
by andreasm80
Madgeni wrote: Saturday 14 December 2019 19:09
Ok, the issue of non-reporting devices should now be fixed. Apologies - any errors still, drop a message in your profile
The issue is also resolved here. Thanks again Madgeni for outstanding support and help.
Posted: Friday 03 January 2020 10:15
by Madgeni
Hi - there's no method of push notification for smart home yet. It's an ongoing (and frustrating) conversation with Google. Alexa provided it for sensors over a year ago, but Google continue to drag their feet on sensors + notifications
Posted: Monday 06 January 2020 17:25
by poweredge
madgeni - send you a pm as well - issues here the same with pushing new devices...visible in the controlicz site - but not appearing at the alexa app so i can voice control them.
Posted: Monday 06 January 2020 19:50
by Madgeni
Hi, I see the pm has been deleted, is this an issue still?
Posted: Monday 06 January 2020 20:43
by poweredge
yes there is - sent it via the controlicz website
but pm you again - np
edit: done
Posted: Saturday 11 January 2020 0:05
by djdevil
hello the site is slow and not response why?
Posted: Saturday 11 January 2020 10:02
by Madgeni
Hi -
the site seems ok - will look at the logs and see if there was any issues last night
