Controlicz - Domoticz to Google Home/Assistant integration Topic is solved
Alexa, Google Home and Siri
sundodger
Re: Controlicz - Domoticz to Google Home/Assistant integration
Post by sundodger »
Hi all, I am trying to get my echo dot to speak when the doorbell is pressed. No luck so far.
I have Domoticz running on a raspberry Pi with the doorbell connected to the GPIO. When the doorbell is pressed it triggers various actions, pushbullet notifications etc.
I did set up a routine in the Alexa app that should trigger when that same switch closes. Nothing happens.
I also setup a dummy motion sensor with a delayed off to see if that worked, still will not trigger.
I feel i am missing something obvious. Has anyone implemented similar? If so how did you get it to work?
astrapowerrr
Post by astrapowerrr »
Check you have any devices with special characters in them, change them (details in the email), and then reconnect your account in the Home app
i tried to delete the plan $hidden devices but my other plans disapeared..
can i get them back with a backup? and do i do this with de db file?
pfff why did i even started this... :oops:
btw is the $hidden device floorplan the one who is making it not to work? or is it really a device with a special character...
Madgeni
Post by Madgeni »
It's a device, not the $hidden devices room plan.
jvandermeijs
Post by jvandermeijs »
I'm new to Controlicz and have to following problem when setting up my information.
I accidentally put my http port in instead of my https port and now I'm trying to edit this in my profile.
However each time i'm trying to edit the website keeps asking for my username and password and does not continue actually editing my profile.
Could you maybe help me fixing this?
With kind regards.
Madgeni
Post by Madgeni »
Can you put your controlicz username + password in there
AthomeDomotica
Domoticz version: 2022.2
Post by AthomeDomotica »
astrapowerrr wrote: Monday 30 December 2019 14:41
It looks ok, can you try linking your Controlicz account again in the Home app?
just tried a few minutes ago.. nothing..
i have a video of it what happens but cant upload i think only pictures?
Try this link to set-up you're Controlicz.
https://ehoco.nl/domoticz-bedienen-goog ... ontrolicz/
Controlicz WAN IP-address = 35.178.116.149
From the outside (WAN) the next https trafic PORT 443 from IP-address: 35.178.116.149 has to be Forwarded to you're STATIC IP-adress of you're Domoticz controller internal (LAN) on you're Router/Firewall!
You need also set WEBSITE protection on you're Domoticz setings....
Please let us know
Cheers,
Mike
Domoticz, Controlicz, Philips HUE Gateway and bulbs, Z-Wave (Aecotec Stick) and Fibaro Dimmers, RFLink Gateway.
jvandermeijs
Madgeni wrote: Tuesday 31 December 2019 13:57 Can you put your controlicz username + password in there
When I do so it just keeps on popping up. By username you mean my emailadress right?
AthomeDomotica
Hello All, all the best for 2020.
The question is; what is usable from Domoticz/Controlicz as VOICE CONTROLE?
Is it possible to use "Groups or Scenes" within Domoticz and CALL these names? (Google Home)
Or can you make these "Groups" ONLY within the "Home APP" on you're mobile phone?
I thought Domoticz would be the Leader in this, but for now it's not working as I thought it would.....
Are de (light) switches only usable....
Please advise, it's looking great but can't get it working :idea:
A link/hint in the right direction would be nice.
Mike
Madgeni
Post by Madgeni »
Hi Mike -
you can use Domoticz Scenes/Groups in Google Home (Hey Google Activate <SceneName>) - just make sure the Scenes toggle is enabled in your Domoticz User settings.
You can use lights (brightness + colour)/switches/temps/selector switches in most languages
AthomeDomotica
Madgeni wrote: Wednesday 01 January 2020 12:37 Hi Mike -
Thx for the quick responce,
I'll try that.
Greetings,
Mike
AthomeDomotica
AthomeDomotica wrote: Wednesday 01 January 2020 12:42
I'll try that.
Greetings,
Mike
Thx,
That worked like a charm :-)
It's all in the "words" you are using, trying in Dutch!
For now active.
All I need to find out is how to get the scenes from the "HUE Gateway" in place and usable....
Cheers,
Mike
Madgeni
Post by Madgeni »
Just to let everyone know logging of commands is now available in your profiles
phoenixblue
Post by phoenixblue »
I'm busy now to install everything but I searching for an push notification solution for example an doorbell.
I see in the past x hundreds of posts (big topic btw ) some of the same questions but without an solution as far I see.
So is it possible to setup push notifications to the GA?
andreasm80
Post by andreasm80 »
Madgeni wrote: Saturday 14 December 2019 19:09 Ok, the issue of non-reporting devices should now be fixed. Apologies - any errors still, drop a message in your profile
The issue is also resolved here. Thanks again Madgeni for outstanding support and help.
Madgeni
Post by Madgeni »
Hi - there's no method of push notification for smart home yet. It's an ongoing (and frustrating) conversation with Google. Alexa provided it for sensors over a year ago, but Google continue to drag their feet on sensors + notifications
poweredge
Post by poweredge »
madgeni - send you a pm as well - issues here the same with pushing new devices...visible in the controlicz site - but not appearing at the alexa app so i can voice control them.
DM2021.1 (pri+sec) VM/RPI4. Dashticz @touchscreen. IT: Dell ESXi cluster, UPS, fiber+4g WAN. Smart: Aeotec/Neo/Qubino/Eurotronic zwave, Philips Hue, P1, rfxom433, OTGW, ITHO WiFi, Shelly shutter/water sens, NEST v3, 9x Alexa
Madgeni
Post by Madgeni »
Hi, I see the pm has been deleted, is this an issue still?
poweredge
Post by poweredge »
yes there is - sent it via the controlicz website :-) but pm you again - np
edit: done
djdevil
Domoticz version: 2021.1
Post by djdevil »
hello the site is slow and not response why?
Madgeni
Post by Madgeni »
Hi -
the site seems ok - will look at the logs and see if there was any issues last night
