Page 105 of 184
Posted: Friday 05 May 2017 14:42
by barbaar
HansieNL wrote:barbaar wrote:Hi,
Nothing seems to be wrong. Your screen goes to standby after 1 minute and shows exactly what you told and have configured.
var _STANDBY_AFTER_MINUTES = 1;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
Thanks! That's it
Posted: Friday 05 May 2017 14:44
by Mike
Anyone else experiencing high CPU loads after having dashticz running and open in a tab for a longer period?
The fans in my laptop start kicking in, they normally never do except when I'm playing a game. The process in Chrome was using 20% CPU, when I closed the tab and reopened dashticz it was back to normal: <1%
Posted: Friday 05 May 2017 15:18
by crashingdutchman
Would anyone be interested in adding Flightradar24 to his dashboard? I have this setup now and it seems to work nice, although I would like to be able to remove the left part of that site.
Posted: Friday 05 May 2017 15:49
by wizjos
Concerning the swiper function, I've noticed the continuous loop has been disabled... Lazy as I am I propose to make this configurable as well:
In config.js add:
and in main.js add:
if(typeof(_CONTINUOUS_LOOP)=='undefined') var _CONTINUOUS_LOOP = false;
in the upper part of the file and change function startSwiper to:
function startSwiper(){
if(objectlength(screens)>1 && (typeof(_EDIT_MODE)=='undefined' || _EDIT_MODE===false)){
myswiper = new Swiper('.swiper-container', {
pagination: '.swiper-pagination',
paginationClickable: true,
loop: _CONTINUOUS_LOOP,
effect: _SCREENSLIDER_EFFECT,
keyboardControl:true
Regards,
Wizjos
Posted: Friday 05 May 2017 15:51
by robgeerts
Well yeah but woth the continuous loop i get other bugs... like not loading news etc..on the second slide..
Posted: Friday 05 May 2017 16:50
by Wheeling
I notice that Blocks no longer updates from Domoticz. Only if i refresh the browser manually than update also the times / text from Domoticz. I'm using the last beta, but it's been a while now i think. Do more people have this problem?
Below, I think, the setting for the refresh
var _LANGUAGE = 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ = 'http://192.168.1.200:8080';
var _DOMOTICZ_REFRESH = 5; //in seconds
var _DASHTICZ_REFRESH = 30; //in minutes
var _THEME = 'default'; // default = dashticz default theme
Posted: Friday 05 May 2017 16:57
by wizjos
robgeerts wrote:Well yeah but woth the continuous loop i get other bugs... like not loading news etc..on the second slide..
Hmmm, the news rss is loading allright, but it is a bit overdone: it srolls out of the screen. Very strange behaviour
EDIT: Even weirder: when going in reverse (left arrow key) the rss displays as it should (1 item), but when scrolling with the right arrow key it displays all... But another right key, followed by a left key makes it normal again....
Posted: Friday 05 May 2017 17:06
by Ierlandfan
crashingdutchman wrote:Would anyone be interested in adding Flightradar24 to his dashboard? I have this setup now and it seems to work nice, although I would like to be able to remove the left part of that site.
I was playing with that also. I use this:
frames.flightradar = {height:250,frameurl:"
https://www.flightradar24.com/52.8,5/10",width:12}
Gives you the Northern part of Holland. No menu on the left side for me.
Edit, found a better source (thanx to Vliegveld Middenmeer)
https://www.flightradar24.com/simple?la ... 2=altspeed
If you want all aiprplanes you have to delete maxspeed and minspeed. If you only want light aircraft like Microlights, gliders, Cessna, Piper and that kind of airplanes leave them in place.
Posted: Friday 05 May 2017 18:00
by SwordFish
Wheeling wrote:I notice that Blocks no longer updates from Domoticz. Only if i refresh the browser manually than update also the times / text from Domoticz. I'm using the last beta, but it's been a while now i think. Do more people have this problem?
I noticed it to
Posted: Friday 05 May 2017 18:11
by htilburgs
I think we all have the issue.
See my call in the bug section:
http://www.domoticz.com/forum/viewtopic ... 27#p132893
Re: Dashticz v2.0, custom positioning and multiple screens
Posted: Friday 05 May 2017 18:25
by tontze
DewGew wrote:tontze wrote:koowee wrote:
Did you add ; after that? If not, try if that help
Yes, didnt help :/
Config.js file is moved to custom folder.
// DewGew
Yes it is
I wiped whole directory and cloned again, edited config.js, now i have only background, not even clock
Posted: Friday 05 May 2017 18:49
by EdwinK
Would be fun
Posted: Friday 05 May 2017 18:55
by Mike
Mike wrote:Anyone else experiencing high CPU loads after having dashticz running and open in a tab for a longer period?
after about 4 hours (in the background, whilst doing other stuff) its gone up to 5%, when i look at the webpage it drops down after a while to normal cpu usage.
I'd like to have a window i can alt+tab to but it seems i have to close it to get my laptop to sleep and/or using excessive power.
Might be the webcam or buienradar I have running, but I'm running on the stable version
Posted: Friday 05 May 2017 19:11
by madrian
iCloud style background:
- Screen-Shot-2017-05-05-19-09-52.png (356.84 KiB) Viewed 3304 times
Posted: Friday 05 May 2017 20:41
by DvD
I didn't change anything , except the updates with git pull but now after 5 minutes it goes to a black screen. Normally it should dimm the active screen.
my config
var _HOST_DOMOTICZ = 'http://192.168.0.4:8080';
var _HOST_ZIGGO_HORIZON = 'http://192.168.0.4:8080/dashboard/switch_horizon.php'; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND = ';
var _WEATHER_CITY = 'Spijkenisse';
var _WEATHER_CITYNAME = ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY = 'NL';
var _USE_AUTO_POSITIONING = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES = true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK = true; //do not show the seconds in the clock
var _NEWS_RSSFEED = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT = false;
var _STANDBY_AFTER_MINUTES = 5; //enter amount of minutes like: 5 (5 minutes)
var _USE_DUTCH_TRAFFICINFO = true;
var _STANDBY_CALL_URL = 'http://127.0.0.1/cgi-bin/screen_brightness.cgi?brightness=20'; //adjust brightness raspberry touchscreen, leave empty if not used
var _END_STANDBY_CALL_URL = 'http://127.0.0.1/cgi-bin/screen_brightness.cgi?brightness=250'; //adjust brightness raspberry touchscreen, leave empty if not used
var _IDXmoonpicture = 31; //index of the uservariabele MoonPicture
var _APIKEY_MAPS = ';
var _MAPS_LATITUDE = 51.850978;
var _MAPS_LONGITUDE = 4.321489;
var _MAPS_ZOOMLEVEL = 11
var _SCREENSLIDER_EFFECT = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
Am I missing something ?
Posted: Friday 05 May 2017 20:47
by Phantom
DvD wrote:I didn't change anything , except the updates with git pull but now after 5 minutes it goes to a black screen. Normally it should dimm the active screen.
my config
Hey, you are missing a ' here: var _APIKEY_MAPS = ' ';
Posted: Friday 05 May 2017 20:48
by DvD
thats something you don't want to share with everybody, thats why I hide it
Posted: Friday 05 May 2017 21:00
by Wheeling
my config
Do you have this in your code?
Posted: Friday 05 May 2017 21:09
by DvD
nope... I don't use the "var columns standby" because I only want the screen to dimm
Posted: Friday 05 May 2017 21:12
by josimd
_
