barbaar
Post by barbaar »
HansieNL wrote:
barbaar wrote:Hi,
Nothing seems to be wrong. Your screen goes to standby after 1 minute and shows exactly what you told and have configured.
var _STANDBY_AFTER_MINUTES = 1;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
Thanks! That's it :)
Mike
Domoticz version: 3.5827
Post by Mike »
Anyone else experiencing high CPU loads after having dashticz running and open in a tab for a longer period?
The fans in my laptop start kicking in, they normally never do except when I'm playing a game. The process in Chrome was using 20% CPU, when I closed the tab and reopened dashticz it was back to normal: <1%
crashingdutchman
Domoticz version: Latest
Post by crashingdutchman »
Would anyone be interested in adding Flightradar24 to his dashboard? I have this setup now and it seems to work nice, although I would like to be able to remove the left part of that site.Image
wizjos
Post by wizjos »
Concerning the swiper function, I've noticed the continuous loop has been disabled... Lazy as I am I propose to make this configurable as well:
In config.js add:
var _CONTINUOUS_LOOP		= false;
and in main.js add:
if(typeof(_CONTINUOUS_LOOP)=='undefined') var _CONTINUOUS_LOOP  = false;
in the upper part of the file and change function startSwiper to:
function startSwiper(){
	if(objectlength(screens)>1 && (typeof(_EDIT_MODE)=='undefined' || _EDIT_MODE===false)){
		myswiper = new Swiper('.swiper-container', {
			pagination: '.swiper-pagination',
			paginationClickable: true,
			loop: _CONTINUOUS_LOOP,
			effect: _SCREENSLIDER_EFFECT,
			keyboardControl:true
Regards,
Wizjos
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Well yeah but woth the continuous loop i get other bugs... like not loading news etc..on the second slide..
Wheeling
Domoticz version: 3.5877
Post by Wheeling »
I notice that Blocks no longer updates from Domoticz. Only if i refresh the browser manually than update also the times / text from Domoticz. I'm using the last beta, but it's been a while now i think. Do more people have this problem?
Below, I think, the setting for the refresh
var _LANGUAGE 		= 'nl_NL'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ		= 'http://192.168.1.200:8080';
var _DOMOTICZ_REFRESH		= 5; //in seconds
var _DASHTICZ_REFRESH		= 30; //in minutes
var _THEME 				= 'default'; // default = dashticz default theme
wizjos
Post by wizjos »
robgeerts wrote:Well yeah but woth the continuous loop i get other bugs... like not loading news etc..on the second slide..
Hmmm, the news rss is loading allright, but it is a bit overdone: it srolls out of the screen. Very strange behaviour :shock:
EDIT: Even weirder: when going in reverse (left arrow key) the rss displays as it should (1 item), but when scrolling with the right arrow key it displays all... But another right key, followed by a left key makes it normal again....
Ierlandfan
Post by Ierlandfan »
crashingdutchman wrote:Would anyone be interested in adding Flightradar24 to his dashboard? I have this setup now and it seems to work nice, although I would like to be able to remove the left part of that site.Image
I was playing with that also. I use this:
frames.flightradar = {height:250,frameurl:"https://www.flightradar24.com/52.8,5/10",width:12}
Gives you the Northern part of Holland. No menu on the left side for me.
Edit, found a better source (thanx to Vliegveld Middenmeer)
https://www.flightradar24.com/simple?la ... 2=altspeed
If you want all aiprplanes you have to delete maxspeed and minspeed. If you only want light aircraft like Microlights, gliders, Cessna, Piper and that kind of airplanes leave them in place.
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
Wheeling wrote:I notice that Blocks no longer updates from Domoticz. Only if i refresh the browser manually than update also the times / text from Domoticz. I'm using the last beta, but it's been a while now i think. Do more people have this problem?
I noticed it to
htilburgs
Post by htilburgs »
I think we all have the issue.
See my call in the bug section: http://www.domoticz.com/forum/viewtopic ... 27#p132893
Hardware:
tontze
Domoticz version: Beta Ch
Re: Dashticz v2.0, custom positioning and multiple screens
Post by tontze »
DewGew wrote:
tontze wrote:
koowee wrote:
Did you add ; after that? If not, try if that help
Yes, didnt help :/
Config.js file is moved to custom folder.
// DewGew
Yes it is :)
I wiped whole directory and cloned again, edited config.js, now i have only background, not even clock :(
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
EdwinK
Post by EdwinK »
Would be fun
Mike
Post by Mike »
Mike wrote:Anyone else experiencing high CPU loads after having dashticz running and open in a tab for a longer period?
after about 4 hours (in the background, whilst doing other stuff) its gone up to 5%, when i look at the webpage it drops down after a while to normal cpu usage.
I'd like to have a window i can alt+tab to but it seems i have to close it to get my laptop to sleep and/or using excessive power.
Might be the webcam or buienradar I have running, but I'm running on the stable version :?:
madrian
Post by madrian »
iCloud style background:
DvD
Post by DvD »
I didn't change anything , except the updates with git pull but now after 5 minutes it goes to a black screen. Normally it should dimm the active screen.
my config
var _HOST_DOMOTICZ                      = 'http://192.168.0.4:8080';
var _HOST_ZIGGO_HORIZON         = 'http://192.168.0.4:8080/dashboard/switch_horizon.php'; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND        = ';
var _WEATHER_CITY                       = 'Spijkenisse';
var _WEATHER_CITYNAME           = ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY            = 'NL';
var _USE_AUTO_POSITIONING       = false; //don't want to configure positions, use auto positioning
var _USE_FAVORITES                      = true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK  = true; //do not show the seconds in the clock
var _NEWS_RSSFEED                       = 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT                     = false;
var _STANDBY_AFTER_MINUTES  = 5; //enter amount of minutes like: 5 (5 minutes)
var _USE_DUTCH_TRAFFICINFO      = true;
var _STANDBY_CALL_URL           = 'http://127.0.0.1/cgi-bin/screen_brightness.cgi?brightness=20'; //adjust brightness raspberry touchscreen, leave empty if not used
var _END_STANDBY_CALL_URL       = 'http://127.0.0.1/cgi-bin/screen_brightness.cgi?brightness=250'; //adjust brightness raspberry touchscreen, leave empty if not used
var _IDXmoonpicture      = 31; //index of the uservariabele MoonPicture
var _APIKEY_MAPS         = ';
var _MAPS_LATITUDE         = 51.850978;
var _MAPS_LONGITUDE      = 4.321489;
var _MAPS_ZOOMLEVEL = 11
var _SCREENSLIDER_EFFECT        = 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
Am I missing something ?
Phantom
Domoticz version: 4.11652
Post by Phantom »
DvD wrote:I didn't change anything , except the updates with git pull but now after 5 minutes it goes to a black screen. Normally it should dimm the active screen.
my config
Hey, you are missing a ' here: var _APIKEY_MAPS = ' ';
DvD
Post by DvD »
thats something you don't want to share with everybody, thats why I hide it
Wheeling
Post by Wheeling »
my config
Do you have this in your code?
DvD
Post by DvD »
nope... I don't use the "var columns standby" because I only want the screen to dimm
josimd
Post by josimd »
_
Locked
