I see a nice kliko....HansieNL wrote:Goodmorning,robgeerts wrote:Could you send me that image?HansieNL wrote:Hello Rob,
Is it possible to change the icon/image for the trash block. I've made a kliko image and wanna use that one if possible...
You did accept my pull request already? If so, you should have it in the img folder as kliko.png.
- htilburgs
Re: RE: Re: Dashticz - General Discussions
Hardware:
koowee
Rob, can you add these two new device types to Dashticz
Thermostat mode selector. There is four different mode 0 = Off, 1 = Heat (Default), 2 = Cool, 3 = Energy Heat;
Solar radiation, now Dashticz shows it as a switch
"ActTime" : 1493975839,
"ServerTime" : "2017-05-05 12:17:19",
"Sunrise" : "05:01",
"Sunset" : "21:41",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "Off",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 4,
"HardwareName" : "Razberry",
"HardwareTypeVal" : 21,
"HaveTimeout" : false,
"ID" : "00001801",
"LastUpdate" : "2017-05-05 12:16:43",
"Mode" : 0,
"Modes" : "0;Off;1;Heat (Default);2;Cool;3;Energy Heat;",
"Name" : "Thermostat Mode",
"Notifications" : "false",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"SubType" : "Thermostat Mode",
"Timers" : "false",
"Type" : "General",
"TypeImg" : "mode",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "329"
"status" : "OK",
"title" : "Devices"
}Code: Select all
"ActTime" : 1493976213,
"ServerTime" : "2017-05-05 12:23:33",
"Sunset" : "21:41",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"CustomImage" : 0,
"Data" : "347.2 Watt/m2",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 9,
"HardwareName" : "Dark Sky",
"HardwareType" : "DarkSky (Weather Lookup)",
"HardwareTypeVal" : 25,
"ID" : "0",
"LastUpdate" : "2017-05-05 12:14:53",
"Name" : "Solar",
"PlanID" : "0",
"PlanIDs" : [ 0 ],
"Radiation" : 347.19999999999999,
"SubType" : "Solar Radiation",
"SwitchTypeVal" : 0,
"Timers" : "false",
"Type" : "General",
"TypeImg" : "radiation",
"Unit" : 1,
"Used" : 1,
"XOffset" : "0",
"YOffset" : "0",
"forecast_url" : "aHR0cHM6Ly9kYXJrc2t5Lm5ldC8jL2YvNjEuNjM2NjUzJTJDJTIwMjMuNzg3MjA1",
"idx" : "115"
"status" : "OK",
"title" : "Devices"
}- wizjos
Great new functionality this Afvalwijzer (trash)!
However, I noticed that not all dates are displayed because in trash.js (the mijnafvalwijzer part) the object returnDates has the date as a keyname... When trashcollection on a given date has two different collections (for instance 'restafval' and 'plastic') only the latter of these two is added to the object...
Bit confusing: for some mondays 'plastic' is displayed and for other ones 'restafval'. At my place a monday is always 'restafval' and 'plastic' combined...
To solve this I've added a counter (called 'teller') which takes care of making the keys unique:
In the original situation these moments are displayed (I've hacked a little to display more than 3 collection dates): and with the counter:
Suits my needs a bit more...
Regards,
Wizjos
if(service=='mijnafvalwijzer'){
$.getJSON('http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=' + postcode + '&street=&huisnummer=' + homenumber + '&toevoeging=',function(data){
data = data.data.ophaaldagen.data;
teller=0;
for(d in data){
if(typeof(returnDates[curr])=='undefined'){
returnDates[curr] = {}
var startDate = moment(moment().format("DD-MM-YYYY"), "DD-MM-YYYY");
var endDate = moment(moment(Date.now() + 64 * 24 * 3600 * 1000).format("DD-MM-YYYY"), "DD-MM-YYYY");
var testDate = moment(data[d]['date'], "YYYY-MM-DD");
if(testDate.isBetween(startDate, endDate, 'days', true)){
returnDates[curr][moment(moment(data[d]['date'], "YYYY-MM-DD")).format("YYYY-MM-DD")+teller]='<div>'+data[d]['nameType']+': '+moment(moment(data[d]['date'], "YYYY-MM-DD")).format("DD-MM-YYYY")+'</div>';
teller++;
addToContainer(random,returnDates);
Regards,
Wizjos
robgeerts
- Domoticz version: 3.7067
Thanks, will fix this!wizjos wrote:Great new functionality this Afvalwijzer (trash)!
To solve this I've added a counter (called 'teller') which takes care of making the keys unique:In the original situation these moments are displayed (I've hack a little to display more than 3 collection dates):trash1.PNG and with the counter:trash2.PNGCode: Select all
if(service=='mijnafvalwijzer'){ $.getJSON('http://json.mijnafvalwijzer.nl/?method=postcodecheck&postcode=' + postcode + '&street=&huisnummer=' + homenumber + '&toevoeging=',function(data){ data = data.data.ophaaldagen.data; teller=0; for(d in data){ if(typeof(returnDates[curr])=='undefined'){ returnDates[curr] = {} } var startDate = moment(moment().format("DD-MM-YYYY"), "DD-MM-YYYY"); var endDate = moment(moment(Date.now() + 64 * 24 * 3600 * 1000).format("DD-MM-YYYY"), "DD-MM-YYYY"); var testDate = moment(data[d]['date'], "YYYY-MM-DD"); if(testDate.isBetween(startDate, endDate, 'days', true)){ returnDates[curr][moment(moment(data[d]['date'], "YYYY-MM-DD")).format("YYYY-MM-DD")+teller]='<div>'+data[d]['nameType']+': '+moment(moment(data[d]['date'], "YYYY-MM-DD")).format("DD-MM-YYYY")+'</div>'; } teller++; } addToContainer(random,returnDates); });
Suits my needs a bit more...![]()
Regards,
Wizjos
robgeerts
Added in latest beta!koowee wrote:Rob, can you add these two new device types to Dashticz
Solar radiation, now Dashticz shows it as a switchCode: Select all
{ "ActTime" : 1493975839, "ServerTime" : "2017-05-05 12:17:19", "Sunrise" : "05:01", "Sunset" : "21:41", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "Off", "Description" : "", "Favorite" : 0, "HardwareID" : 4, "HardwareName" : "Razberry", "HardwareType" : "OpenZWave USB", "HardwareTypeVal" : 21, "HaveTimeout" : false, "ID" : "00001801", "LastUpdate" : "2017-05-05 12:16:43", "Mode" : 0, "Modes" : "0;Off;1;Heat (Default);2;Cool;3;Energy Heat;", "Name" : "Thermostat Mode", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Thermostat Mode", "Timers" : "false", "Type" : "General", "TypeImg" : "mode", "Unit" : 1, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "idx" : "329" } ], "status" : "OK", "title" : "Devices" }
{ "ActTime" : 1493976213, "ServerTime" : "2017-05-05 12:23:33", "Sunrise" : "05:01", "Sunset" : "21:41", "result" : [ { "AddjMulti" : 1.0, "AddjMulti2" : 1.0, "AddjValue" : 0.0, "AddjValue2" : 0.0, "BatteryLevel" : 255, "CustomImage" : 0, "Data" : "347.2 Watt/m2", "Description" : "", "Favorite" : 0, "HardwareID" : 9, "HardwareName" : "Dark Sky", "HardwareType" : "DarkSky (Weather Lookup)", "HardwareTypeVal" : 25, "HaveTimeout" : false, "ID" : "0", "LastUpdate" : "2017-05-05 12:14:53", "Name" : "Solar", "Notifications" : "false", "PlanID" : "0", "PlanIDs" : [ 0 ], "Protected" : false, "Radiation" : 347.19999999999999, "ShowNotifications" : true, "SignalLevel" : "-", "SubType" : "Solar Radiation", "SwitchTypeVal" : 0, "Timers" : "false", "Type" : "General", "TypeImg" : "radiation", "Unit" : 1, "Used" : 1, "XOffset" : "0", "YOffset" : "0", "forecast_url" : "aHR0cHM6Ly9kYXJrc2t5Lm5ldC8jL2YvNjEuNjM2NjUzJTJDJTIwMjMuNzg3MjA1", "idx" : "115" } ], "status" : "OK", "title" : "Devices" }
- mlamie
- Domoticz version: 3.5877
I really like the Dashticz dashboard, the only issue for me to use it, is the power consumption. My wall tablet (nexus 7 2013) can't charge fast enough. The USB cable is to long and I need to change things, now it is located next to the thermostat. I used 2 wires connected to the thermostat and the other 2 wires for charging. The charger is located at my HR-kettle.
I now use ImperiHome, which does not drain the battery so fast and can be used 24/7 with the right display brightness.
Is there a way to improve power usage (other browser, refresh rate...) Any suggestions?
Raspberry Pi 3, RaZberry, RFXtrx433
Various Z-Wave devices, KlikAanKlikUit devices, ESP8266 NodeMCU, Sonoff POW and a Essent E-thermostaat
IP camera: Dahua 4MP IPC-HDBW4421R-AS, Vivotek FD8134V
woody4165
Hi all
I'm using the "currentweather_big" in a small size block, width 2 (below the sunrise block).
I see it in this way.
Is there a way to center the text or resize it and show the weather icon on the left?
sander
- Domoticz version: latest..
Ouch! Hansie, that did the trick, now I just need to configure, but I see manny more posts on that. At least I can access now. Thanks!
Raspberry Pi 2B+
connected: klik aan klik uit switches, dimmers, weather station, water meter (pulse)
Automation use: Blocky
woody4165
Re: Dashticz v2.0, custom positioning and multiple screens
Hi @robgeertsrobgeerts wrote:First preview of color changer:
will it work also with Yeelight bulb ?
robgeerts
Dont know yet, the color choosing is a bit hard for me, especially because I dont have any colored lights...
woody4165
The hue plugin is still on going, isn't it?
I will try to understand if I can contribute for yeelight...
robgeerts
Yes, not finished yet..sorry
Blueone
Here it is:robgeerts wrote:Thanks, please send me when you are done with the weekdays (Especially 'Tomorrow')
function addToContainer(random,returnDates){
var returnDatesSimple={}
var done = {};
for(c in returnDates){
for(cr in returnDates[c]){
returnDatesSimple[cr] = returnDates[c][cr];
done[c]=true;
$('.trash'+random+' .state').html('');
var c=1;
Object.keys(returnDatesSimple).sort().forEach(function(key) {
var date = moment(key).format("DD-MM-YYYY");
var currentdate = moment(Date.now()).format("DD-MM-YYYY");
var tomorrow = moment(new Date()).add(1,'days').format("DD-MM-YYYY")
var nextweek = (moment(new Date()).add(6,'days').format("DD-MM-YYYY"))
if(date == currentdate){
returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, "Today");
else if(date == tomorrow){
returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, "Tomorrow");
else if(date <= nextweek){
returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, moment(moment(date).format("DD-MM-YYYY")).format("dddd"));
else {
//console.log(date)
if(c<=4) $('.trash'+random+' .state').append(returnDatesSimple[key]);
c++;
robgeerts
Added to latest beta! Thanks!
Although I've changed it a bit so today/tomorrow and the daynames shows in the correct language!
Blueone
Cool, I just wanted to upload the code with the other languages, i thought about it when I already posted it.
Thanks again!
Thanks again!
koowee
Thanks, now Dashticz shows correct mode!
There is also possibility to change mode In Domoticz. It can be done via device Edit-button. Can this feature also be implemented to Dashticz?
Blueone
One minor change, the first letter of the day in uppercaserobgeerts wrote:Added to latest beta! Thanks!
var done = {};
done[c]=true;
var c=1;
returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, lang['today']);
returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, lang['tomorrow']);
returnDatesSimple[key] = (returnDatesSimple[key]).replace(date, moment(moment(date).format("DD-MM-YYYY")).locale('nl').format("dddd"));
returnDatesSimple[key]= returnDatesSimple[key].charAt(0).toUpperCase() + date.slice(1);
else {
//console.log(date)
c++;
barbaar
Just starteed using dashticz. Now I'm busybuilding a custom positioning. This works ok when I initially load the page om my Tablet. However, after the first automatic refresh, the screen s black with only the current time and outside temperature forecasts being displayed. Below you find my current CONFIG.js. On my tablet, I use the Kiosk Browser (https://play.google.com/store/apps/deta ... ully&hl=en)
Any idea what is wrong?
- Spoiler: show
- HansieNL
Maybe captalize the first letter of papier, restafval and plastic and change gft to GFT?Blueone wrote:One minor change, the first letter of the day in uppercaserobgeerts wrote:Added to latest beta! Thanks!
- Spoiler: show
Blah blah blah
- HansieNL
Nothing seems to be wrong. Your screen goes to standby after 1 minute and shows exactly what you told and have configured.barbaar wrote:Hi,
- Spoiler: show
var _STANDBY_AFTER_MINUTES = 1;
var columns_standby = {}
columns_standby[1] = {}
columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
Blah blah blah
