HansieNL
Post by HansieNL »
Hello Rob,
Is it possible to change the icon/image for the trash block. I've made a kliko image and wanna use that one if possible...
Blah blah blah
maninblack30
Post by maninblack30 »
Hello everyone!
I'm new to Domoticz etc, but I am loving it! I have a bunch of sonoff's running Espeasy, and some Xiaomi sensors, and a Broadlink RM2, everything is working really well, but now I want to do a touchscreen on the wall in my living area and use Dashticz.
I have followed the wiki and have it working except all I'm getting are my favorite switches, no clock, no weather, nothing else appears to work.
I have tried other peoples config.js and all I get is a blank screen!
Are there any dependencies etc that I need to install?
I'm running beta 3.7412 on Ubuntu 16.04 LTS as a VM under Hyper-v.
Any help would be appreciated.
Ta,
Fraser
HansieNL
Post by HansieNL »
maninblack30 wrote:Hello everyone!
Ta,
Fraser
Hello Fraser,
Can you tell us what version (master/beta) you are using and post your config.js If you post your config.js as code we can check your code.
Blah blah blah
maninblack30
I think Master, i just did a git clone https://github.com/robgeerts/dashticz_v2
This one is one I copied and just changed my server details, it reults in a just my favorite switches, nothing else:
(Please keep in mind I know nothing about code!)
var _LANGUAGE 				= 'en_US'; //or: en_US, fr_FR, hu_HU
var _HOST_DOMOTICZ		  	= 'http://192.168.1.4:80';
var _DOMOTICZ_REFRESH		= 5; //in seconds
var _DASHTICZ_REFRESH		= 30; //in minutes
var _HOST_ZIGGO_HORIZON	  	= ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND  	= '';
var _WEATHER_CITY 			= 'Eindhoven';
var _WEATHER_CITYNAME 		= ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY 		= 'NL';
var _USE_AUTO_POSITIONING 	= true; //don't want to configure positions, use auto positioning
var _USE_FAVORITES			= true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK  = false; //do not show the seconds in the clock
var _NEWS_RSSFEED			= 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT			= false;
var _USE_BEAUFORT 			= true; //Bft instead of m/s
var _TRANSLATE_SPEED 		= false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES  = false; //enter amount of minutes like: 5 (5 minutes)
var _SCROLL_NEWS_AFTER 		= 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE 		= true;
var _LASTUPDATE_FORMAT 		= 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT 	= 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
var _APIKEY_MAPS			= '';
var _MAPS_LATITUDE			= '';
var _MAPS_LONGITUDE			= '';
var _AUTO_SWIPEBACK_TO		= 1; //when no activity, swipe back to main screen after x seconds
var _AUTO_SWIPEBACK_TIME	= 10; //seconds
// Online Radio Stream Plugin, Note: you must enable  plugin in column section 'streamplayer', see columns[3]['blocks'] example below.
var _STREAMPLAYER_TRACKS  	= [
								{"track":1,"name":"Music FM","file":"http://stream.musicfm.hu:8000/musicfm.mp3"},
								{"track":2,"name":"Radio 1","file":"http://213.181.210.106:8000/high.mp3"},
								{"track":3,"name":"Test FM","file":"http://213.181.210.106:8000/high.mp3"},
// iCalendar Plugin, supports all .ics calendar types like Google Calendar, Apple Calendar
var _ICALENDAR_URL			= 'https://testurl.com/ical.ics'; //supports .ics type calendars (Google Calendar, Apple Calendar etc.)
var _ICALENDAR_DATEFORMAT	= 'friendly'; //'friendly', 'MM.DD.YYYY HH:mm', 'DD.MM.YYYY HH:mm', 'YYYY.MM.DD HH:mm'
var _ICALENDAR_LOCALE		= 'en'; //en,hu, etc.
//Buttons or images to open webpages in an iframe, like a news website or weather forecast
var buttons = {}
buttons.buienradar = {width:12, isimage:true, refreshimage:60000, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weeronline.nl/Europa/Nederland/Son/4058667'}
//CUSTOM POSITIONING:
//defining wich blocks to show, de numbers represents the IDX of the device in Domoticz
//only define if you want to use a custom width instead of the default
//var blocks = {}
//blocks[1] = {}
//blocks[1]['width'] = 4; //1 to 12, remove this line if you want to use the default (4)
//blocks[1]['title'] = 'Living room' //if you want change the name of switch different then domoticz
//blocks[1]['icon'] = 'fa-eye'; //if you want an other icon instead of the default, choose from: http://fontawesome.io/cheatsheet/
//blocks[1]['image'] = 'bulb_off.png'; //if you want to show an image instead if icon, place image in img/ folder
//blocks[204] = {} //dimmer
//blocks[204]['width'] = 12;
//blocks[204]['title'] = 'Living room' //if you want change the name of switch different then domoticz
//blocks['blocktitle_1'] = {}
//blocks['blocktitle_1']['type'] = 'blocktitle';
//blocks['blocktitle_1']['title'] = 'Schakelaars';
//var columns = {}
//columns[1] = {}
//columns[1]['blocks'] = ['blocktitle_1',1,2,62,'144_2',204,248,295] //remark: idx 144 produces 2 blocks, so you can use: '144_1' and '144_2' (or of course, just 144 if you want one)
//columns[1]['width'] = 5;
//columns[2] = {}
//columns[2]['blocks'] = ['currentweather_big','weather',5,'144_1']
//columns[2]['width'] = 5;
//columns[3] = {}
//columns[3]['blocks'] = ['clock','sunrise','horizon','streamplayer',buttons.buienradar,buttons.radio,buttons.calendar,buttons.nunl,buttons.nzbget]
//columns[3]['width'] = 2;
//var columns_standby = {}
//columns_standby[1] = {}
//columns_standby[1]['blocks'] = ['clock','currentweather_big','weather']
//columns_standby[1]['width'] = 12;
//if you want to use multiple screens, use the code below:
//var screens = {}
//screens[1] = {}
//screens[1]['background'] = 'bg1.jpg';
//screens[1]['background_morning'] = 'bg_morning.jpg';
//screens[1]['background_noon'] = 'bg_noon.jpg';
//screens[1]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[1]['background_night'] = 'bg_night.jpg';
//screens[1]['columns'] = [1,2,3]
//screens[2] = {}
//screens[2]['background'] = 'bg3.jpg';
//screens[2]['background_morning'] = 'bg_morning.jpg';
//screens[2]['background_noon'] = 'bg_noon.jpg';
//screens[2]['background_afternoon'] = 'bg_afternoon.jpg';
//screens[2]['background_night'] = 'bg_night.jpg';
//screens[2]['columns'] = [4,5,6]
HansieNL
Post by HansieNL »
maninblack30 wrote:This one is one I copied and just changed my server details, it reults in a just my favorite switches, nothing else:
var buttons = {}
//var blocks = {}
//blocks[1] = {}
//var columns = {}
//columns[1] = {}
//columns[2] = {}
//columns[3] = {}
//var screens = {}
//screens[1] = {}
//screens[2] = {}
You have two setting to set to false if you want to create your own setup, but than you have to define all your blocks.
I would advise you to start reading the Wiki https://www.domoticz.com/wiki/Dashticz-v2 first to understand what's what in config.js.
Blah blah blah
htilburgs
Post by htilburgs »
blacksn0w wrote:
htilburgs wrote:
robgeerts wrote:How do you pull the latest version?? Maybe there goes something wrong?
I use TortoiseGit to pull the latest version to my Desktop, then I check everything and when done, I upload it via FTP (the complete dashticz-folder) to my webserver.
Same way....
You are using Dashticz on RPi right? Why are you not using git via SSH? Just clone the repo (beta branch) and then update via git pull.
All your custom files will not be touched by an update, because they are no part of the repo.
I've tried this, but I only was able to do this for the master, not for the beta. Do I need a parameter to get the beta?
Hardware:
tontze
Domoticz version: Beta Ch
Re: Dashticz v2.0, custom positioning and multiple screens
Post by tontze »
robgeerts wrote:
HansieNL wrote:
tontze wrote:I just did git pull, and all my buttons disappeared, they still exist in config.js ?
I had the same, add the following to config.js...
var _THEME = 'default'
Fixed in latest beta!
I added manually, did git pull just now. Still missing those buttons :( Git pull said up to date btw.
Smartthings
zigbee2mqtt
RFLink 433mhz / Nrf 2.4Ghz
Mi Light
esp8266MiLight Hub
tontze
Post by tontze »
koowee wrote:
tontze wrote:
HansieNL wrote: I had the same, add the following to config.js...
Hm, that didnt help for me ..
Did you add ; after that? If not, try if that help
var _THEME = 'default';
Yes, didnt help :/
Smartthings
zigbee2mqtt
Mi Light
esp8266MiLight Hub
clubeddie
Post by clubeddie »
robgeerts wrote:It's here :)
http://www.domoticz.com/forum/viewforum.php?f=67
Please do not add topics yet, I Will first create a few based on some questions :)
Maybe a topic with nice addons like trash, moon, traffic, etc.... or are they all coming in the wiki?
koowee
Post by koowee »
htilburgs wrote:
blacksn0w wrote:
htilburgs wrote:
Same way....
Try this one
git clone --branch beta https://github.com/robgeerts/dashticz_v2.git dashticz_v2_beta
This should clone beta branch to dashticz_v2_beta directory. After that you can check that it is right branch using command
git branch
woody4165
Post by woody4165 »
robgeerts wrote:.
Hi @robgeerts
I have translated the language file for italian.
If you agree, I can share it here and you could include it in Dashticz.
Thanks for your work
robgeerts
Domoticz version: 3.7067
Re: RE: Re: Dashticz - General Discussions
Post by robgeerts »
HansieNL wrote:Hello Rob,
Could you send me that image?
robgeerts
Re: RE: Re: Dashticz v2.0, custom positioning and multiple screens
Post by robgeerts »
woody4165 wrote:
robgeerts wrote:.
Hi @robgeerts
Yes, please share :) Thanks!
woody4165
Post by woody4165 »
robgeerts wrote: Yes, please share :) Thanks!
It's the js file in the "lang" folder.
If you think there are other files that need to be translated, let me know.
here is the file
https://app.box.com/s/ri8hfypzv4o2w2e7xwkc6uwz4pg6jvhu
DewGew
Domoticz version: V4.10618
Post by DewGew »
Yes, didnt help :/
Config.js file is moved to custom folder.
// DewGew
rbo0567
Domoticz version: v4.9701
Post by rbo0567 »
robgeerts wrote:
sonar wrote:
qwerk wrote:has anybody contacted mijnafvalwijzer ?
Mijnafvalwijzer should work in latest beta:
var trashcan = {}
trashcan.deafvalapp = { trashapp: 'deafvalapp', width:4,zipcode:'5692VG', housenumber:'33', country:'NL' }
trashcan.cure = { trashapp: 'cure', width:8, zipcode:'5654SB', housenumber:'3' }
trashcan.mijnafvalwijzer = { trashapp: 'mijnafvalwijzer', width:4, zipcode:'3582ES', housenumber:'1' }
And in de columns part of config.js:
columns[2]['blocks'] = [trashcan.deafvalapp,trashcan.cure,trashcan.mijnafvalwijzer]
Yesss! Mijnafvalwijzer is working great.
qwerk
Post by qwerk »
rbo0567 wrote:
robgeerts wrote:
yep, another happy user over here.
mijnafvalwijzer. great
SwordFish
Domoticz version: V4.11375
Post by SwordFish »
So I went away for one day and a trash plug-in is born new topics are made. You have to stay on it 24/7 :shock:
Nice work with the trash plug-in Rob 8-)
I'll think that I going to use my old script because I like the heads up a day before the pick-up day :D
robgeerts
Post by robgeerts »
I just added support for some more trash calendars in BETA... please add questions or bugs regarding the trash module in this topic: http://www.domoticz.com/forum/viewtopic ... 67&t=17432
HansieNL
Post by HansieNL »
Goodmorning,
You did accept my pull request already? If so, you should have it in the img folder as kliko.png.
Blah blah blah
Locked
