RoadXY
Domoticz version: 2.2331
Re: Domoticz app 2.0
Post by RoadXY »
Brutus wrote:Nice app. Working nice. I like the features: log, events and uservariables.
Not needing the premium version but bought it any way.
Keep up the gooed work.
Greetings.
RoadXY
Post by RoadXY »
Whatsek wrote:Bug: the order of the switches on my wear change, they open random? And after a second they are ordered alphabetically.
I'll have to look into it.
It'll be after the holidays though
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
I also bought the premium version
What I would like to see:
* Manually reorder the devices on every tab
* Hide the devices which are added to the 'hidden' roomplan
* Switch between tabs by swiping with your finger over the screen
Bugs:
* App crash when moving dimmer slider on dashboard
* Widget with blinds doesn't show buttons
Enjoy your Holidays!
Jan-
Post by Jan- »
thanks for the great app!!
I bought also the premium version.
Bugs:
- Camera problems: pictures are not available
- Dimmer function is difficult to work with and resulting in bugs.
Regards,
Jan.
Whatsek
Domoticz version: Latest B
Post by Whatsek »
Request: option to disable the "Are you sure you want to exit" notification.
SQ9MDD
Post by SQ9MDD »
premium @ house...
GREAT JOB! guys ;)
patoo77
Post by patoo77 »
Congratz to the app team on shipping V1!
App looks very feature-packed :)
Wish I had an android phone to try it out!
Cheers from a fellow developer~
dofhus
Post by dofhus »
RoadXY wrote:
dofhus wrote:Hey,
Thank you for all the work you guys have put in, a really great app! Happy to support you with the premium version.
One thing that I'm not sure if it's a error or not is that when I configure the server settings and try so set different server address for the local connection, then I'm not able to select the local wifi SSID's when i tap it the screen just goes slightly darker is if there was supposed to happen something.
Best regards,
Daniel
A screenshot or, even better, an movie would really help understand.
Attached is a screenshot, the local wifi SSID's is grey and i'm not able to select anything, I've tried both with and without the wifi on.
/Daniel
Alle
Post by Alle »
Purchased the Domoticz App and it's working very well!
Does it support the security panel? Can't seem find it.
ESXi/Ubuntu - Z-wave.me USB Stick - Domoticz Beta - EvoHome - Nest Protect - Logitech Media Server - Netatmo Weather Station - Everspring - Aeonlabs
Jango
Post by Jango »
Hello developers,
Is it possible to generate separate graphs for temperature, humidity and barometer?
The ranges off the graphs are also very wide. If they are smaller you can see the fluctuations better.
Verstuurd vanaf mijn E6853 met Tapatalk
remb0
Post by remb0 »
This weekend I will filter all issues, wishes on this topic.
alfred_j_kwak
Domoticz version: 2.3530
Post by alfred_j_kwak »
In that case I'd like to ask is it possible to get also Dark-theme?
jorns
Post by jorns »
Very nice app. Bought the p version.
But i cant make the ip cam stream. It works in Dromotica, but freeze in this app...
Agrippa
Post by Agrippa »
I'm still on the lite vershion, trying to see how 'zonnescherm' (reverse blinds) can be paused halfway..
Nevertheless: Goed werk!
locogek
Post by locogek »
Found another big problem in the app. All the dimmers won't work. App crashes sometimes and sometimes it go back to the dashboard. Purchased the full version to support you guys! Good luck with the further app improvements!
Verstuurd vanaf mijn ONE A2003 met Tapatalk
galadril
Domoticz version: latest
Post by galadril »
Jango wrote:Hello developers,
You can zoom in via pinch...
Verstuurd vanaf mijn Nexus 5 met Tapatalk
locogek
Post by locogek »
Yes I have the same issue. You can zoom in with pinch but then the x-axis will also zoom in so you can only look for a small time span.
Jango
Post by Jango »
I agree ;)
Brutus
Post by Brutus »
I also bought the Premium version not that I am going to use the extra options but to support the work.
I like the extra options like: Plans, Log, Events, user variables and the option to see the day, month or year rapports for example the energie or gas.
Known Bugs to me:
- Sliding switches like dimmers and screens let the app crash.
- Can't "yet" switch the events on or off.
- Camera tab shows me only a litle white bar not my camera.
- Can't get rapport (day, month of year) for Lux
Keep up the good work!
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
salvation
Post by salvation »
I'd like the app very much as mentioned before. Although two feature requests so far:
- Option to show switches in the order set in Domoticz (not by alphabetic order) by default
- Option to open the app with a specific roomplan (would make the app very girlfriend proof ;-) )
