Logitech Media Server
Nautilus
Re: Logitech Media Server
Post by Nautilus »
simon_rb wrote:Is there a way to get volume status via a command. I read above there isn't using this plugin however I have seen other plugins able to get the volume data from the players. Wondered if its possible to get the volume data put into the /json.htm?type=devices&rid=IDX outpost. Then it could be used via edomoticz homebridge plugin. Could control the volume via iOS 10 HomeKit app and via Siri. We should be able to increase/decrease the volume however without knowing what the volume is to start with it may be difficult.
Cheers
Haven't verified this but check this post: viewtopic.php?f=28&t=7866&p=90351#p90351
and whether the json reply also includes the current volume level. Then you could at least check every minute the volume level for each player and store it to a dummy sensor etc...
simon_rb
Post by simon_rb »
Thanks mate, the JSON reply from my post above doesn't include the volume.. I'll check out that post! Thanks :)
Nautilus
Post by Nautilus »
simon_rb wrote:Thanks mate, the JSON reply from my post above doesn't include the volume.. I'll check out that post! Thanks :)
I checked it out of curiosity and yes, it returns field "mixer_volume: XX". Please note that this is json directly from the lms server. For the lua I needed to add some excape characters (\) to get it work:
file = assert(io.popen('curl \'lmsurl:lmsport/jsonrpc.js\' --data-binary \'{"id":1,"method":"slim.request","params":["player:mac:address",["status","-","1",""]]}\''))
to test via command line just use
curl 'lmsurl:lmsport/jsonrpc.js' --data-binary '{"id":1,"method":"slim.request","params":["player:mac:address",["status","-","1",""]]}'
(of course update with correct lms url and port and player mac address)
simon_rb
Post by simon_rb »
Nautilus
Excellent mate, I have never done LUA before in this depth. I guess create a file with the text above? Then it runs every minute to get the status? If I change the volume with the dummy switch will it change the volume on that player? Sorry for noob question regarding this - its very new to me
Cheers
Nautilus
Post by Nautilus »
simon_rb wrote:Nautilus
Cheers
Well, yes, you need to create a LUA time script (which automatically runs every minute). You can use the web interface for this as well (Event system, check wiki for more details).
Then part of the script should be something like:
json = (loadfile '/home/pi/domoticz/scripts/lua/json.lua')()
file = assert(io.popen('curl \'url:port/jsonrpc.js\' --data-binary \'{"id":1,"method":"slim.request","params":["player:mac:address",["status","-","1",""]]}\''))
raw = file:read('*all')
file:close()
deviceinfo = json:decode(raw)
volume = deviceinfo.result.mixer_volume
Then you have a variable "volume" in this script that holds the actual volume for the player. To update it to a dummy switch do something like (again, check wiki for more info):
commandArray['UpdateDevice'] = otherdevices_idx['Dummy Sensor Name'] .. '|0|' .. volume
(or use the idx number directly instead of otherdevices_idx['Dummy Sensor Name'] ==> commandArray['UpdateDevice'] = '123|0|' .. volume ) Also, you should add a condition that updates it only if it has changed.
For it to work the other way around as well you need to add another script that reacts to device changes (= device script). If the switch is a dimmer with 100 steps, each step would result to a call like (the svalue from the swith would be "setvolume" variable):
commandArray=['SqueezeBox Name] = 'Set Volume '..setvolume
simon_rb
Post by simon_rb »
Thanks, sounds simple but is a bit beyond me. I will try however as its the best way to learn.
Created a file called 'script_time_sqtouch.lua' with this:-
file = assert(io.popen('curl \'192.168.1.26:9000/jsonrpc.js\' --data-binary \'{"id":1,"method":"slim.request","params":["00:04:20:23:88:36",["status","-","1",""]]}\''))
file:close()
I haven't got a file called json.lua.. does that need creating or is that my script_time_sqtouch.lua?
Am I going in the right direction?
Nautilus
Post by Nautilus »
simon_rb wrote:I haven't got a file called json.lua.. does that need creating or is that my script_time_sqtouch.lua?
Yes, sorry forgot to mention about that. You need the file, I downloaded mine here: http://regex.info/code/JSON.lua. Then you need to refer to it's location in the beginning of the script (like json = (loadfile '/home/pi/domoticz/scripts/lua/json.lua')()). I'm using this for different purpose, but maybe the full example is better:
if devicechanged['Web radio'] == 'Off' and (otherdevices['SqueezeBox'] == 'On' or otherdevices['Squeezebox All'] == 'On') then
    file:close()
    nowplaying = deviceinfo.result.current_title
    if tostring(nowplaying:match('YLEX')) ~= 'nil' or tostring(nowplaying:match('SuomiP')) ~= 'nil' or tostring(nowplaying:match('Radio Rock')) ~= 'nil' or tostring(nowplaying:match('Loop')) ~= 'nil' and otherdevices['Harmony Power Off'] == 'Off' then
            commandArray['Harmony Power Off'] = 'On'
            print('Web radio was playing while the "Off" switch was pressed and SqueezeBox activity is on - turning off Media')
When you test it, add something like this to the end of the script:
print(deviceinfo)
print('SQTouch volume script has run, the current volume is '..volume)
The first line should print the whole json output to log (to see that json call works), the second should print the current volume (0-100). Then it is easy to go from there. The direction is right...:)
simon_rb
Post by simon_rb »
Cheers mate, won't be able to work in it till tomorrow. Hope your about haha :lol:
simon_rb
Post by simon_rb »
Can't figure it out at all.. even using google and the wiki I can't understand it.
file:close()
commandArray['UpdateDevice'] = 250 ['DenonVolume'] .. '|0|' .. volume
print(deviceinfo)
2016-10-22 02:14:00.020 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_sqtouch.lua: /home/pi/domoticz/scripts/lua/script_time_sqtouch.lua:7: unexpected symbol near '['
If I change it to this"-
file:close()
commandArray['UpdateDevice'] = otherdevices_idx['DenonVolume'] .. '|0|' .. volume
print(deviceinfo)
I get this
2016-10-22 02:23:00.426 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_sqtouch.lua: /home/pi/domoticz/scripts/lua/script_time_sqtouch.lua:6: attempt to index global 'deviceinfo' (a nil value)
Nautilus
Post by Nautilus »
The second script should work for the commandArray part, the first one has a fault. The error comes from not receiving a valid json reply. Please test with the command line first that you get some reply from the lms server...
simon_rb
Post by simon_rb »
Run from command? Run the lua script from command line..
You were spot on...
pi@raspberrypi:~$ sudo lua /home/pi/domoticz/scripts/lua/script_time_sqtouch.lua
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0curl: (52) Empty reply from server
lua: ...home/pi/domoticz/scripts/lua/script_time_sqtouch.lua:6: attempt to index global 'deviceinfo' (a nil value)
stack traceback:
...home/pi/domoticz/scripts/lua/script_time_sqtouch.lua:6: in main chunk
[C]: ?
simon_rb
Post by simon_rb »
This is as far as I have got.. still a nil value
100 892 100 807 100 85 61725 6501 --:--:-- --:--:-- --:--:-- 73363
lua: ...home/pi/domoticz/scripts/lua/script_time_sqtouch.lua:7: attempt to index global 'otherdevices_idx' (a nil value)
stack traceback:
...home/pi/domoticz/scripts/lua/script_time_sqtouch.lua:7: in main chunk
[C]: ?
pi@raspberrypi:~$
Script
file:close()
print(deviceinfo)
Nautilus
Post by Nautilus »
Just try the curl part from command line:
Do you get some reply?
simon_rb
Post by simon_rb »
I get this
pi@raspberrypi:~$ curl 'http://192.168.1.26:9000/jsonrpc.js'--data-binary '{"id":1,"method":"slim.request","params":["00:04:20:23:88:36",["status","-","1",""]]}'
curl: (3) [globbing] nested brace in column 42
Nautilus
Post by Nautilus »
Do you have a space before --data-binary part. From above it would seem you don't have it but there needs to be one (I think). Also there should be a space after it, this you might have, goes to the next line in your example... :)
simon_rb
Post by simon_rb »
Nautilus wrote:Do you have a space before --data-binary part. From above it would seem you don't have it but there needs to be one (I think). Also there should be a space after it, this you might have, goes to the next line in your example... :)
Got a reply from server including volume mixer info! I didn't have the space before --data so added the space and I got the reply. I did try -- data -binary and it came back with some strange stuff about my ISP lol. So only the one space needed. I shall transfer it to the script when I get to my PC. Cheers dude.
Update:-
Can't seem to get it into the script - still getting script errors (nil value). Obviously its my formatting when changing it to the script.. could you check.
Command works as
curl '192.168.1.26:9000/jsonrpc.js' --data-binary '{"id":1,"method":"slim.request","params":["00:04:20:23:88:36",["status","-","1",""]]}'
Returns
pi@raspberrypi:~$ curl '192.168.1.26:9000/jsonrpc.js' --data-binary '{"id":1,"method":"slim.request","params":["00:04:20:23:88:36",["status","-","1",""]]}'
{"method":"slim.request","params":["00:04:20:23:88:36",["status","-","1",""]],"id":1,"result":{"playlist mode":"off","playlist_tracks":1,"power":1,"remoteMeta":{"id":"-99860512","title":"Don't Wanna Know (feat. Kendrick Lamar)","artist":"Maroon 5","album":"Don't Wanna Know (feat. Kendrick Lamar) - Single","duration":214.320181405896},"time":203.603118486167,"playlist_timestamp":1477216186.95453,"remote":1,"current_title":"airplay://192.168.1.26:8001/9906525686379e928af67351e6dc368e_stream.wav","playlist_loop":[{"id":"-99860512","title":"Don't Wanna Know (feat. Kendrick Lamar)","album":"Don't Wanna Know (feat. Kendrick Lamar) - Single","artist":"Maroon 5","playlist index":0,"duration":214.320181405896}],"player_name":"Lounge Touch","playlist repeat":2,"player_connected":1,"mixer volume":30.07281355,"signalstrength":98,"digital_volume_control":1,"playlist shuffle":1,"rate":1,"playlist_cur_index":"0","seq_no":"2","player_ip":"192.168.1.93:35567","mode":"play","sync_slaves":"aa:aa:cd:49:13:58,aa:aa:f5:80:72:8b,00:04:20:27:5e:15,00:04:20:2c:fa:36,00:04:20:28:54:32,aa:aa:cd:39:86:eb","duration":214.320181405896,"sync_master":"00:04:20:23:88:36"}}
This is my script
file:close()
print(deviceinfo)
Returns
2016-10-23 10:55:00.363 Error: EventSystem: in /home/pi/domoticz/scripts/lua/script_time_sqtouch.lua: /home/pi/domoticz/scripts/lua/script_time_sqtouch.lua:7: attempt to concatenate global 'volume' (a nil value)
simon_rb
Post by simon_rb »
I have changed the volume = deviceinfo.result.mixer_volume to volume = deviceinfo.result.current_title to see if its the mixer_volume but its not reading that either. Could it be my json.lua file at fault? its here below
-- -*- coding: utf-8 -*-
-- Simple JSON encoding and decoding in pure Lua.
-- Copyright 2010-2016 Jeffrey Friedl
-- http://regex.info/blog/
-- Latest version: http://regex.info/blog/lua/json
-- This code is released under a Creative Commons CC-BY "Attribution" License:
-- http://creativecommons.org/licenses/by/3.0/deed.en_US
-- It can be used for any purpose so long as the copyright notice above,
-- the web-page links above, and the 'AUTHOR_NOTE' string below are
-- maintained. Enjoy.
local VERSION = 20160916.19 -- version history at end of file
local AUTHOR_NOTE = "-[ JSON.lua package by Jeffrey Friedl (http://regex.info/blog/lua/json) version 20160916.19 ]-"
-- The 'AUTHOR_NOTE' variable exists so that information about the source
-- of the package is maintained even in compiled versions. It's also
-- included in OBJDEF below mostly to quiet warnings about unused variables.
local OBJDEF = {
   VERSION      = VERSION,
   AUTHOR_NOTE  = AUTHOR_NOTE,
-- JSON definition: http://www.json.org/
--   JSON = assert(loadfile "JSON.lua")() -- one-time load of the routines
--   local lua_value = JSON:decode(raw_json_text)
--   local raw_json_text    = JSON:encode(lua_table_or_value)
--   local pretty_json_text = JSON:encode_pretty(lua_table_or_value) -- "pretty printed" version for human readability
-- DECODING (from a JSON string to a Lua table)
--   If the JSON text is for an object or an array, e.g.
--     { "what": "books", "count": 3 }
--   or
--     [ "Larry", "Curly", "Moe" ]
--   the result is a Lua table, e.g.
--     { what = "books", count = 3 }
--   or
--     { "Larry", "Curly", "Moe" }
--   The encode and decode routines accept an optional second argument,
--   "etc", which is not used during encoding or decoding, but upon error
--   is passed along to error handlers. It can be of any type (including nil).
-- ERROR HANDLING
--   With most errors during decoding, this code calls
--      JSON:onDecodeError(message, text, location, etc)
--   with a message about the error, and if known, the JSON text being
--   parsed and the byte count where the problem was discovered. You can
--   replace the default JSON:onDecodeError() with your own function.
--   The default onDecodeError() merely augments the message with data
--   about the text and the location if known (and if a second 'etc'
--   argument had been provided to decode(), its value is tacked onto the
--   message as well), and then calls JSON.assert(), which itself defaults
--   to Lua's built-in assert(), and can also be overridden.
--   For example, in an Adobe Lightroom plugin, you might use something like
--          function JSON:onDecodeError(message, text, location, etc)
--             LrErrors.throwUserError("Internal Error: invalid JSON data")
--          end
--   or even just
--          function JSON.assert(message)
--             LrErrors.throwUserError("Internal Error: " .. message)
--          end
--   If JSON:decode() is passed a nil, this is called instead:
--      JSON:onDecodeOfNilError(message, nil, nil, etc)
--   and if JSON:decode() is passed HTML instead of JSON, this is called:
--      JSON:onDecodeOfHTMLError(message, text, nil, etc)
--   The use of the fourth 'etc' argument allows stronger coordination
--   between decoding and error reporting, especially when you provide your
--   own error-handling routines. Continuing with the the Adobe Lightroom
--   plugin example:
--             local note = "Internal Error: invalid JSON data"
--             if type(etc) = 'table' and etc.photo then
--                note = note .. " while processing for " .. etc.photo:getFormattedMetadata('fileName')
--             end
--             LrErrors.throwUserError(note)
--          end
--          for i, photo in ipairs(photosToProcess) do
--               local data = JSON:decode(someJsonText, { photo = photo })
--          end
-- DECODING AND STRICT TYPES
--   Because both JSON objects and JSON arrays are converted to Lua tables,
--   it's not normally possible to tell which original JSON type a
--   particular Lua table was derived from, or guarantee decode-encode
--   round-trip equivalency.
--   However, if you enable strictTypes, e.g.
--      JSON = assert(loadfile "JSON.lua")() --load the routines
--      JSON.strictTypes = true
--   then the Lua table resulting from the decoding of a JSON object or
--   JSON array is marked via Lua metatable, so that when re-encoded with
--   JSON:encode() it ends up as the appropriate JSON type.
--   (This is not the default because other routines may not work well with
--   tables that have a metatable set, for example, Lightroom API calls.)
-- ENCODING (from a lua table to a JSON string)
--   local custom_pretty    = JSON:encode(lua_table_or_value, etc, { pretty = true, indent = "|  ", align_keys = false })
--   On error during encoding, this code calls:
--     JSON:onEncodeError(message, etc)
--   which you can override in your local JSON object.
--   The 'etc' in the error call is the second argument to encode()
--   and encode_pretty(), or nil if it wasn't provided.
-- ENCODING OPTIONS
--   An optional third argument, a table of options, can be provided to encode().
--       encode_options =  {
--           -- options for making "pretty" human-readable JSON (see "PRETTY-PRINTING" below)
--           pretty         = true,
--           indent         = "   ",
--           align_keys     = false,
--           -- other output-related options
--           null           = "\0",   -- see "ENCODING JSON NULL VALUES" below
--           stringsAreUtf8 = false,  -- see "HANDLING UNICODE LINE AND PARAGRAPH SEPARATORS FOR JAVA" below
--       json_string = JSON:encode(mytable, etc, encode_options)
-- For reference, the defaults are:
--           pretty         = false
--           null           = nil,
-- PRETTY-PRINTING
--   Enabling the 'pretty' encode option helps generate human-readable JSON.
--     pretty = JSON:encode(val, etc, {
--                                       pretty = true,
--                                       indent = "   ",
--   encode_pretty() is also provided: it's identical to encode() except
--   that encode_pretty() provides a default options table if none given in the call:
--       { pretty = true, align_keys = false, indent = "  " }
--   For example, if
--      JSON:encode(data)
--   produces:
--      {"city":"Kyoto","climate":{"avg_temp":16,"humidity":"high","snowfall":"minimal"},"country":"Japan","wards":11}
--   then
--      JSON:encode_pretty(data)
--   produces:
--        "city": "Kyoto",
--        "climate": {
--          "avg_temp": 16,
--          "humidity": "high",
--          "snowfall": "minimal"
--        "country": "Japan",
--        "wards": 11
--   The following three lines return identical results:
--       JSON:encode_pretty(data, nil, { pretty = true, align_keys = false, indent = "  " })
--       JSON:encode       (data, nil, { pretty = true, align_keys = false, indent = "  " })
--   An example of setting your own indent string:
--     JSON:encode_pretty(data, nil, { pretty = true, indent = "|    " })
--   produces:
--      |    "city": "Kyoto",
--      |    "climate": {
--      |    |    "avg_temp": 16,
--      |    |    "humidity": "high",
--      |    |    "snowfall": "minimal"
--      |    "country": "Japan",
--      |    "wards": 11
--   An example of setting align_keys to true:
--     JSON:encode_pretty(data, nil, { pretty = true, indent = "  ", align_keys = true })
--   produces:
--           "city": "Kyoto",
--        "climate": {
--                     "avg_temp": 16,
--          "wards": 11
--   which I must admit is kinda ugly, sorry. This was the default for
--   encode_pretty() prior to version 20141223.14.
--  HANDLING UNICODE LINE AND PARAGRAPH SEPARATORS FOR JAVA
--    If the 'stringsAreUtf8' encode option is set to true, consider Lua strings not as a sequence of bytes,
--    but as a sequence of UTF-8 characters.
--    Currently, the only practical effect of setting this option is that Unicode LINE and PARAGRAPH
--    separators, if found in a string, are encoded with a JSON escape instead of being dumped as is.
--    The JSON is valid either way, but encoding this way, apparently, allows the resulting JSON
--    to also be valid Java.
--  AMBIGUOUS SITUATIONS DURING THE ENCODING
--   During the encode, if a Lua table being encoded contains both string
--   and numeric keys, it fits neither JSON's idea of an object, nor its
--   idea of an array. To get around this, when any string key exists (or
--   when non-positive numeric keys exist), numeric keys are converted to
--   strings.
--   For example,
--     JSON:encode({ "one", "two", "three", SOMESTRING = "some string" }))
--   produces the JSON object
--     {"1":"one","2":"two","3":"three","SOMESTRING":"some string"}
--   To prohibit this conversion and instead make it an error condition, set
--      JSON.noKeyConversion = true
-- ENCODING JSON NULL VALUES
--   Lua tables completely omit keys whose value is nil, so without special handling there's
--   no way to get a field in a JSON object with a null value.  For example
--      JSON:encode({ username = "admin", password = nil })
--   produces
--      {"username":"admin"}
--   In order to actually produce
--      {"username":"admin", "password":null}
--   one can include a string value for a "null" field in the options table passed to encode()....
--   any Lua table entry with that value becomes null in the JSON output:
--      JSON:encode({ username = "admin", password = "xyzzy" }, nil, { null = "xyzzy" })
--   produces
--   Just be sure to use a string that is otherwise unlikely to appear in your data.
--   The string "\0" (a string with one null byte) may well be appropriate for many applications.
--   The "null" options also applies to Lua tables that become JSON arrays.
--      JSON:encode({ "one", "two", nil, nil })
--   produces
--      ["one","two"]
--   while
--      NULL = "\0"
--      JSON:encode({ "one", "two", NULL, NULL}, nil, { null = NULL })
--   produces
--      ["one","two",null,null]
-- HANDLING LARGE AND/OR PRECISE NUMBERS
--   Without special handling, numbers in JSON can lose precision in Lua.
--   For example:
--      T = JSON:decode('{  "small":12345, "big":12345678901234567890123456789, "precise":9876.67890123456789012345  }')
--      print("small:   ",  type(T.small),    T.small)
--      print("big:     ",  type(T.big),      T.big)
--      print("precise: ",  type(T.precise),  T.precise)
--   produces
--      small:          number  12345
--      big:            number  1.2345678901235e+28
--      precise:        number  9876.6789012346
--   Precision is lost with both 'big' and 'precise'.
--   This package offers ways to try to handle this better (for some definitions of "better")...
--   The most precise method is by setting the global:
--      JSON.decodeNumbersAsObjects = true
--   When this is set, numeric JSON data is encoded into Lua in a form that preserves the exact
--   JSON numeric presentation when re-encoded back out to JSON, or accessed in Lua as a string.
--   (This is done by encoding the numeric data with a Lua table/metatable that returns
--   the possibly-imprecise numeric form when accessed numerically, but the original precise
--   representation when accessed as a string. You can also explicitly access
--   via JSON:forceString() and JSON:forceNumber())
--   Consider the example above, with this option turned on:
--   This now produces:
--      small:          table   12345
--      big:            table   12345678901234567890123456789
--      precise:        table   9876.67890123456789012345
--   However, within Lua you can still use the values (e.g. T.precise in the example above) in numeric
--   contexts. In such cases you'll get the possibly-imprecise numeric version, but in string contexts
--   and when the data finds its way to this package's encode() function, the original full-precision
--   representation is used.
--   Even without using the JSON.decodeNumbersAsObjects option, you can encode numbers
--   in your Lua table that retain high precision upon encoding to JSON, by using the JSON:asNumber()
--   function:
--      T = {
--         imprecise = 123456789123456789.123456789123456789,
--         precise   = JSON:asNumber("123456789123456789.123456789123456789")
--      print(JSON:encode_pretty(T))
--   This produces:
--         "precise": 123456789123456789.123456789123456789,
--         "imprecise": 1.2345678912346e+17
--   A different way to handle big/precise JSON numbers is to have decode() merely return
--   the exact string representation of the number instead of the number itself.
--   This approach might be useful when the numbers are merely some kind of opaque
--   object identifier and you want to work with them in Lua as strings anyway.
--   This approach is enabled by setting
--      JSON.decodeIntegerStringificationLength = 10
--   The value is the number of digits (of the integer part of the number) at which to stringify numbers.
--   Consider our previous example with this option set to 10:
--   This produces:
--      big:            string  12345678901234567890123456789
--   The long integer of the 'big' field is at least JSON.decodeIntegerStringificationLength digits
--   in length, so it's converted not to a Lua integer but to a Lua string. Using a value of 0 or 1 ensures
--   that all JSON numeric data becomes strings in Lua.
--   Note that unlike
--   this stringification is simple and unintelligent: the JSON number simply becomes a Lua string, and that's the end of it.
--   If the string is then converted back to JSON, it's still a string. After running the code above, adding
--      print(JSON:encode(T))
--   produces
--      {"big":"12345678901234567890123456789","precise":9876.6789012346,"small":12345}
--   which is unlikely to be desired.
--   There's a comparable option for the length of the decimal part of a number:
--      JSON.decodeDecimalStringificationLength
--   This can be used alone or in conjunction with
--   to trip stringification on precise numbers with at least JSON.decodeIntegerStringificationLength digits after
--   the decimal point.
--   This example:
--      JSON.decodeDecimalStringificationLength =  5
--  produces:
--      precise:        string  9876.67890123456789012345
-- SUMMARY OF METHODS YOU CAN OVERRIDE IN YOUR LOCAL LUA JSON OBJECT
--    assert
--    onDecodeError
--    onDecodeOfNilError
--    onDecodeOfHTMLError
--    onEncodeError
--  If you want to create a separate Lua JSON object with its own error handlers,
--  you can reload JSON.lua or use the :new() method.
local default_pretty_indent  = "  "
local default_pretty_options = { pretty = true, align_keys = false, indent = default_pretty_indent  }
local isArray  = { __tostring = function() return "JSON array"         end }  isArray.__index  = isArray
local isObject = { __tostring = function() return "JSON object"        end }  isObject.__index = isObject
function OBJDEF:newArray(tbl)
   return setmetatable(tbl or {}, isArray)
function OBJDEF:newObject(tbl)
   return setmetatable(tbl or {}, isObject)
local function getnum(op)
   return type(op) == 'number' and op or op.N
local isNumber = {
   __tostring = function(T)  return T.S        end,
   __unm      = function(op) return getnum(op) end,
   __concat   = function(op1, op2) return tostring(op1) .. tostring(op2) end,
   __add      = function(op1, op2) return getnum(op1)   +   getnum(op2)  end,
   __sub      = function(op1, op2) return getnum(op1)   -   getnum(op2)  end,
   __mul      = function(op1, op2) return getnum(op1)   *   getnum(op2)  end,
   __div      = function(op1, op2) return getnum(op1)   /   getnum(op2)  end,
   __mod      = function(op1, op2) return getnum(op1)   %   getnum(op2)  end,
   __pow      = function(op1, op2) return getnum(op1)   ^   getnum(op2)  end,
   __lt       = function(op1, op2) return getnum(op1)   <   getnum(op2)  end,
   __eq       = function(op1, op2) return getnum(op1)   ==  getnum(op2)  end,
   __le       = function(op1, op2) return getnum(op1)   <=  getnum(op2)  end,
isNumber.__index = isNumber
function OBJDEF:asNumber(item)
   if getmetatable(item) == isNumber then
      -- it's already a JSON number object.
      return item
   elseif type(item) == 'table' and type(item.S) == 'string' and type(item.N) == 'number' then
      -- it's a number-object table that lost its metatable, so give it one
      return setmetatable(item, isNumber)
      -- the normal situation... given a number or a string representation of a number....
      local holder = {
         S = tostring(item), -- S is the representation of the number as a string, which remains precise
         N = tonumber(item), -- N is the number as a Lua number.
      return setmetatable(holder, isNumber)
-- Given an item that might be a normal string or number, or might be an 'isNumber' object defined above,
-- return the string version. This shouldn't be needed often because the 'isNumber' object should autoconvert
-- to a string in most cases, but it's here to allow it to be forced when needed.
function OBJDEF:forceString(item)
   if type(item) == 'table' and type(item.S) == 'string' then
      return item.S
      return tostring(item)
-- return the numeric version.
function OBJDEF:forceNumber(item)
   if type(item) == 'table' and type(item.N) == 'number' then
      return item.N
      return tonumber(item)
local function unicode_codepoint_as_utf8(codepoint)
   -- codepoint is a number
   if codepoint <= 127 then
      return string.char(codepoint)
   elseif codepoint <= 2047 then
      -- 110yyyxx 10xxxxxx         <-- useful notation from http://en.wikipedia.org/wiki/Utf8
      local highpart = math.floor(codepoint / 0x40)
      local lowpart  = codepoint - (0x40 * highpart)
      return string.char(0xC0 + highpart,
                         0x80 + lowpart)
   elseif codepoint <= 65535 then
      -- 1110yyyy 10yyyyxx 10xxxxxx
      local highpart  = math.floor(codepoint / 0x1000)
      local remainder = codepoint - 0x1000 * highpart
      local midpart   = math.floor(remainder / 0x40)
      local lowpart   = remainder - 0x40 * midpart
      highpart = 0xE0 + highpart
      midpart  = 0x80 + midpart
      lowpart  = 0x80 + lowpart
      -- Check for an invalid character (thanks Andy R. at Adobe).
      -- See table 3.7, page 93, in http://www.unicode.org/versions/Unicode5.2.0/ch03.pdf#G28070
      if ( highpart == 0xE0 and midpart < 0xA0 ) or
         ( highpart == 0xED and midpart > 0x9F ) or
         ( highpart == 0xF0 and midpart < 0x90 ) or
         ( highpart == 0xF4 and midpart > 0x8F )
      then
         return "?"
         return string.char(highpart,
                            midpart,
                            lowpart)
      -- 11110zzz 10zzyyyy 10yyyyxx 10xxxxxx
      local highpart  = math.floor(codepoint / 0x40000)
      local remainder = codepoint - 0x40000 * highpart
      local midA      = math.floor(remainder / 0x1000)
      remainder       = remainder - 0x1000 * midA
      local midB      = math.floor(remainder / 0x40)
      local lowpart   = remainder - 0x40 * midB
      return string.char(0xF0 + highpart,
                         0x80 + midA,
                         0x80 + midB,
                         0x80 + lowpart)
function OBJDEF:onDecodeError(message, text, location, etc)
   if text then
      if location then
         message = string.format("%s at char %d of: %s", message, location, text)
         message = string.format("%s: %s", message, text)
   if etc ~= nil then
      message = message .. " (" .. OBJDEF:encode(etc) .. ")"
   if self.assert then
      self.assert(false, message)
OBJDEF.onDecodeOfNilError  = OBJDEF.onDecodeError
OBJDEF.onDecodeOfHTMLError = OBJDEF.onDecodeError
function OBJDEF:onEncodeError(message, etc)
   if etc ~= nil then
   if self.assert then
local function grok_number(self, text, start, options)
   -- Grab the integer part
   local integer_part = text:match('^-?[1-9]%d*', start)
                     or text:match("^-?0",        start)
   if not integer_part then
      self:onDecodeError("expected number", text, start, options.etc)
   local i = start + integer_part:len()
   -- Grab an optional decimal part
   local decimal_part = text:match('^%.%d+', i) or ""
   i = i + decimal_part:len()
   -- Grab an optional exponential part
   local exponent_part = text:match('^[eE][-+]?%d+', i) or ""
   i = i + exponent_part:len()
   local full_number_text = integer_part .. decimal_part .. exponent_part
   if options.decodeNumbersAsObjects then
      return OBJDEF:asNumber(full_number_text), i
   -- If we're told to stringify under certain conditions, so do.
   -- We punt a bit when there's an exponent by just stringifying no matter what.
   -- I suppose we should really look to see whether the exponent is actually big enough one
   -- way or the other to trip stringification, but I'll be lazy about it until someone asks.
   if (options.decodeIntegerStringificationLength
       and
      (integer_part:len() >= options.decodeIntegerStringificationLength or exponent_part:len() > 0))
       or
      (options.decodeDecimalStringificationLength
       and
       (decimal_part:len() >= options.decodeDecimalStringificationLength or exponent_part:len() > 0))
   then
      return full_number_text, i -- this returns the exact string representation seen in the original JSON
   local as_number = tonumber(full_number_text)
   if not as_number then
      self:onDecodeError("bad number", text, start, options.etc)
   return as_number, i
local function grok_string(self, text, start, options)
   if text:sub(start,start) ~= '"' then
      self:onDecodeError("expected string's opening quote", text, start, options.etc)
   local i = start + 1 -- +1 to bypass the initial quote
   local text_len = text:len()
   local VALUE = ""
   while i <= text_len do
      local c = text:sub(i,i)
      if c == '"' then
         return VALUE, i + 1
      if c ~= '\\' then
         VALUE = VALUE .. c
         i = i + 1
      elseif text:match('^\\b', i) then
         VALUE = VALUE .. "\b"
         i = i + 2
      elseif text:match('^\\f', i) then
         VALUE = VALUE .. "\f"
         i = i + 2
      elseif text:match('^\\n', i) then
         VALUE = VALUE .. "\n"
         i = i + 2
      elseif text:match('^\\r', i) then
         VALUE = VALUE .. "\r"
         i = i + 2
      elseif text:match('^\\t', i) then
         VALUE = VALUE .. "\t"
         i = i + 2
         local hex = text:match('^\\u([0123456789aAbBcCdDeEfF][0123456789aAbBcCdDeEfF][0123456789aAbBcCdDeEfF][0123456789aAbBcCdDeEfF])', i)
         if hex then
            i = i + 6 -- bypass what we just read
            -- We have a Unicode codepoint. It could be standalone, or if in the proper range and
            -- followed by another in a specific range, it'll be a two-code surrogate pair.
            local codepoint = tonumber(hex, 16)
            if codepoint >= 0xD800 and codepoint <= 0xDBFF then
               -- it's a hi surrogate... see whether we have a following low
               local lo_surrogate = text:match('^\\u([dD][cdefCDEF][0123456789aAbBcCdDeEfF][0123456789aAbBcCdDeEfF])', i)
               if lo_surrogate then
                  i = i + 6 -- bypass the low surrogate we just read
                  codepoint = 0x2400 + (codepoint - 0xD800) * 0x400 + tonumber(lo_surrogate, 16)
                  -- not a proper low, so we'll just leave the first codepoint as is and spit it out.
            VALUE = VALUE .. unicode_codepoint_as_utf8(codepoint)
            -- just pass through what's escaped
            VALUE = VALUE .. text:match('^\\(.)', i)
            i = i + 2
   self:onDecodeError("unclosed string", text, start, options.etc)
local function skip_whitespace(text, start)
   local _, match_end = text:find("^[ \n\r\t]+", start) -- [http://www.ietf.org/rfc/rfc4627.txt] Section 2
   if match_end then
      return match_end + 1
      return start
local grok_one -- assigned later
local function grok_object(self, text, start, options)
   if text:sub(start,start) ~= '{' then
      self:onDecodeError("expected '{'", text, start, options.etc)
   local i = skip_whitespace(text, start + 1) -- +1 to skip the '{'
   local VALUE = self.strictTypes and self:newObject { } or { }
   if text:sub(i,i) == '}' then
      return VALUE, i + 1
      local key, new_i = grok_string(self, text, i, options)
      i = skip_whitespace(text, new_i)
      if text:sub(i, i) ~= ':' then
         self:onDecodeError("expected colon", text, i, options.etc)
      i = skip_whitespace(text, i + 1)
      local new_val, new_i = grok_one(self, text, i, options)
      VALUE[key] = new_val
      -- Expect now either '}' to end things, or a ',' to allow us to continue.
      if c == '}' then
         return VALUE, i + 1
      if text:sub(i, i) ~= ',' then
         self:onDecodeError("expected comma or '}'", text, i, options.etc)
   self:onDecodeError("unclosed '{'", text, start, options.etc)
local function grok_array(self, text, start, options)
   if text:sub(start,start) ~= '[' then
      self:onDecodeError("expected '['", text, start, options.etc)
   local i = skip_whitespace(text, start + 1) -- +1 to skip the '['
   local VALUE = self.strictTypes and self:newArray { } or { }
   if text:sub(i,i) == ']' then
      return VALUE, i + 1
   local VALUE_INDEX = 1
      local val, new_i = grok_one(self, text, i, options)
      -- can't table.insert(VALUE, val) here because it's a no-op if val is nil
      VALUE[VALUE_INDEX] = val
      VALUE_INDEX = VALUE_INDEX + 1
      -- Expect now either ']' to end things, or a ',' to allow us to continue.
      if c == ']' then
         return VALUE, i + 1
         self:onDecodeError("expected comma or '['", text, i, options.etc)
   self:onDecodeError("unclosed '['", text, start, options.etc)
grok_one = function(self, text, start, options)
   -- Skip any whitespace
   start = skip_whitespace(text, start)
   if start > text:len() then
      self:onDecodeError("unexpected end of string", text, nil, options.etc)
   if text:find('^"', start) then
      return grok_string(self, text, start, options.etc)
   elseif text:find('^[-0123456789 ]', start) then
      return grok_number(self, text, start, options)
   elseif text:find('^%{', start) then
      return grok_object(self, text, start, options)
   elseif text:find('^%[', start) then
      return grok_array(self, text, start, options)
   elseif text:find('^true', start) then
      return true, start + 4
   elseif text:find('^false', start) then
      return false, start + 5
   elseif text:find('^null', start) then
      return nil, start + 4
      self:onDecodeError("can't parse JSON", text, start, options.etc)
function OBJDEF:decode(text, etc, options)
   -- If the user didn't pass in a table of decode options, make an empty one.
   if type(options) ~= 'table' then
      options = {}
   -- If they passed in an 'etc' argument, stuff it into the options.
   -- (If not, any 'etc' field in the options they passed in remains to be used)
   if etc ~= nil then
      options.etc = etc
   if type(self) ~= 'table' or self.__index ~= OBJDEF then
      OBJDEF:onDecodeError("JSON:decode must be called in method format", nil, nil, options.etc)
   if text == nil then
      self:onDecodeOfNilError(string.format("nil passed to JSON:decode()"), nil, nil, options.etc)
   elseif type(text) ~= 'string' then
      self:onDecodeError(string.format("expected string argument to JSON:decode(), got %s", type(text)), nil, nil, options.etc)
   if text:match('^%s*$') then
      return nil
   if text:match('^%s*<') then
      -- Can't be JSON... we'll assume it's HTML
      self:onDecodeOfHTMLError(string.format("html passed to JSON:decode()"), text, nil, options.etc)
   -- Ensure that it's not UTF-32 or UTF-16.
   -- Those are perfectly valid encodings for JSON (as per RFC 4627 section 3),
   -- but this package can't handle them.
   if text:sub(1,1):byte() == 0 or (text:len() >= 2 and text:sub(2,2):byte() == 0) then
      self:onDecodeError("JSON package groks only UTF-8, sorry", text, nil, options.etc)
   -- apply global options
   if options.decodeNumbersAsObjects == nil then
      options.decodeNumbersAsObjects = self.decodeNumbersAsObjects
   if options.decodeIntegerStringificationLength == nil then
      options.decodeIntegerStringificationLength = self.decodeIntegerStringificationLength
   if options.decodeDecimalStringificationLength == nil then
      options.decodeDecimalStringificationLength = self.decodeDecimalStringificationLength
   local success, value = pcall(grok_one, self, text, 1, options)
   if success then
      return value
      -- if JSON:onDecodeError() didn't abort out of the pcall, we'll have received the error message here as "value", so pass it along as an assert.
      if self.assert then
         self.assert(false, value)
      -- and if we're still here, return a nil and throw the error message on as a second arg
      return nil, value
local function backslash_replacement_function(c)
   if c == "\n" then
      return "\\n"
   elseif c == "\r" then
      return "\\r"
   elseif c == "\t" then
      return "\\t"
   elseif c == "\b" then
      return "\\b"
   elseif c == "\f" then
      return "\\f"
   elseif c == '"' then
      return '\\"'
   elseif c == '\\' then
      return '\\\\'
      return string.format("\\u%04x", c:byte())
local chars_to_be_escaped_in_JSON_string
   ..    '"'    -- class sub-pattern to match a double quote
   ..    '%\\'  -- class sub-pattern to match a backslash
   ..    '%z'   -- class sub-pattern to match a null
   ..    '\001' .. '-' .. '\031' -- class sub-pattern to match control characters
local LINE_SEPARATOR_as_utf8      = unicode_codepoint_as_utf8(0x2028)
local PARAGRAPH_SEPARATOR_as_utf8 = unicode_codepoint_as_utf8(0x2029)
local function json_string_literal(value, options)
   local newval = value:gsub(chars_to_be_escaped_in_JSON_string, backslash_replacement_function)
   if options.stringsAreUtf8 then
      -- This feels really ugly to just look into a string for the sequence of bytes that we know to be a particular utf8 character,
      -- but utf8 was designed purposefully to make this kind of thing possible. Still, feels dirty.
      -- I'd rather decode the byte stream into a character stream, but it's not technically needed so
      -- not technically worth it.
      newval = newval:gsub(LINE_SEPARATOR_as_utf8, '\\u2028'):gsub(PARAGRAPH_SEPARATOR_as_utf8,'\\u2029')
   return '"' .. newval .. '"'
local function object_or_array(self, T, etc)
   -- We need to inspect all the keys... if there are any strings, we'll convert to a JSON
   -- object. If there are only numbers, it's a JSON array.
   -- If we'll be converting to a JSON object, we'll want to sort the keys so that the
   -- end result is deterministic.
   local string_keys = { }
   local number_keys = { }
   local number_keys_must_be_strings = false
   local maximum_number_key
   for key in pairs(T) do
      if type(key) == 'string' then
         table.insert(string_keys, key)
      elseif type(key) == 'number' then
         table.insert(number_keys, key)
         if key <= 0 or key >= math.huge then
            number_keys_must_be_strings = true
         elseif not maximum_number_key or key > maximum_number_key then
            maximum_number_key = key
         self:onEncodeError("can't encode table with a key of type " .. type(key), etc)
   if #string_keys == 0 and not number_keys_must_be_strings then
      -- An empty table, or a numeric-only array
      if #number_keys > 0 then
         return nil, maximum_number_key -- an array
      elseif tostring(T) == "JSON array" then
         return nil
      elseif tostring(T) == "JSON object" then
         return { }
         -- have to guess, so we'll pick array, since empty arrays are likely more common than empty objects
         return nil
   table.sort(string_keys)
   local map
      -- If we're here then we have either mixed string/number keys, or numbers inappropriate for a JSON array
      -- It's not ideal, but we'll turn the numbers into strings so that we can at least create a JSON object.
      if self.noKeyConversion then
         self:onEncodeError("a table with both numeric and string keys could be an object or array; aborting", etc)
      -- Have to make a shallow copy of the source table so we can remap the numeric keys to be strings
      map = { }
      for key, val in pairs(T) do
         map[key] = val
      table.sort(number_keys)
      -- Throw numeric keys in there as strings
      for _, number_key in ipairs(number_keys) do
         local string_key = tostring(number_key)
         if map[string_key] == nil then
            table.insert(string_keys , string_key)
            map[string_key] = T[number_key]
            self:onEncodeError("conflict converting table with mixed-type keys into a JSON object: key " .. number_key .. " exists both as a string and a number.", etc)
   return string_keys, nil, map
-- Encode
-- 'options' is nil, or a table with possible keys:
--    pretty         -- If true, return a pretty-printed version.
--    indent         -- A string (usually of spaces) used to indent each nested level.
--    align_keys     -- If true, align all the keys when formatting a table.
--    null           -- If this exists with a string value, table elements with this value are output as JSON null.
--    stringsAreUtf8 -- If true, consider Lua strings not as a sequence of bytes, but as a sequence of UTF-8 characters.
--                      (Currently, the only practical effect of setting this option is that Unicode LINE and PARAGRAPH
--                       separators, if found in a string, are encoded with a JSON escape instead of as raw UTF-8.
--                       to also be valid Java.)
local encode_value -- must predeclare because it calls itself
function encode_value(self, value, parents, etc, options, indent, for_key)
   -- keys in a JSON object can never be null, so we don't even consider options.null when converting a key value
   if value == nil or (not for_key and options and options.null and value == options.null) then
      return 'null'
   elseif type(value) == 'string' then
      return json_string_literal(value, options)
   elseif type(value) == 'number' then
      if value ~= value then
         -- NaN (Not a Number).
         -- JSON has no NaN, so we have to fudge the best we can. This should really be a package option.
         return "null"
      elseif value >= math.huge then
         -- Positive infinity. JSON has no INF, so we have to fudge the best we can. This should
         -- really be a package option. Note: at least with some implementations, positive infinity
         -- is both ">= math.huge" and "<= -math.huge", which makes no sense but that's how it is.
         -- Negative infinity is properly "<= -math.huge". So, we must be sure to check the ">="
         -- case first.
         return "1e+9999"
      elseif value <= -math.huge then
         -- Negative infinity.
         -- JSON has no INF, so we have to fudge the best we can. This should really be a package option.
         return "-1e+9999"
         return tostring(value)
   elseif type(value) == 'boolean' then
   elseif type(value) ~= 'table' then
      self:onEncodeError("can't convert " .. type(value) .. " to JSON", etc)
   elseif getmetatable(value) == isNumber then
      -- A table to be converted to either a JSON object or array.
      local T = value
         options = {}
      if type(indent) ~= 'string' then
         indent = ""
      if parents[T] then
         self:onEncodeError("table " .. tostring(T) .. " is a child of itself", etc)
         parents[T] = true
      local result_value
      local object_keys, maximum_number_key, map = object_or_array(self, T, etc)
      if maximum_number_key then
         -- An array...
         local ITEMS = { }
         for i = 1, maximum_number_key do
            table.insert(ITEMS, encode_value(self, T[i], parents, etc, options, indent))
         if options.pretty then
            result_value = "[ " .. table.concat(ITEMS, ", ") .. " ]"
            result_value = "["  .. table.concat(ITEMS, ",")  .. "]"
      elseif object_keys then
         -- An object
         local TT = map or T
            local KEYS = { }
            local max_key_length = 0
            for _, key in ipairs(object_keys) do
               local encoded = encode_value(self, tostring(key), parents, etc, options, indent, true)
               if options.align_keys then
                  max_key_length = math.max(max_key_length, #encoded)
               table.insert(KEYS, encoded)
            local key_indent = indent .. tostring(options.indent or "")
            local subtable_indent = key_indent .. string.rep(" ", max_key_length) .. (options.align_keys and "  " or "")
            local FORMAT = "%s%" .. string.format("%d", max_key_length) .. "s: %s"
            local COMBINED_PARTS = { }
            for i, key in ipairs(object_keys) do
               local encoded_val = encode_value(self, TT[key], parents, etc, options, subtable_indent)
               table.insert(COMBINED_PARTS, string.format(FORMAT, key_indent, KEYS[i], encoded_val))
            result_value = "{\n" .. table.concat(COMBINED_PARTS, ",\n") .. "\n" .. indent .. "}"
            local PARTS = { }
               local encoded_val = encode_value(self, TT[key],       parents, etc, options, indent)
               local encoded_key = encode_value(self, tostring(key), parents, etc, options, indent, true)
               table.insert(PARTS, string.format("%s:%s", encoded_key, encoded_val))
            result_value = "{" .. table.concat(PARTS, ",") .. "}"
         -- An empty array/object... we'll treat it as an array, though it should really be an option
         result_value = "[]"
      parents[T] = false
      return result_value
function OBJDEF:encode(value, etc, options)
      OBJDEF:onEncodeError("JSON:encode must be called in method format", etc)
      options = {}
   return encode_value(self, value, {}, etc, options)
function OBJDEF:encode_pretty(value, etc, options)
      OBJDEF:onEncodeError("JSON:encode_pretty must be called in method format", etc)
   -- If the user didn't pass in a table of decode options, use the default pretty ones
      options = default_pretty_options
function OBJDEF.__tostring()
   return "JSON encode/decode package"
OBJDEF.__index = OBJDEF
function OBJDEF:new(args)
   local new = { }
   if args then
      for key, val in pairs(args) do
         new[key] = val
   return setmetatable(new, OBJDEF)
return OBJDEF:new()
-- Version history:
--   20160916.19   Fixed the isNumber.__index assignment (thanks to Jack Taylor)
--   20160730.18   Added JSON:forceString() and JSON:forceNumber()
--   20160728.17   Added concatenation to the metatable for JSON:asNumber()
--   20160709.16   Could crash if not passed an options table (thanks jarno heikkinen <[email protected]>).
--                 Made JSON:asNumber() a bit more resilient to being passed the results of itself.
--   20160526.15   Added the ability to easily encode null values in JSON, via the new "null" encoding option.
--                 (Thanks to Adam B for bringing up the issue.)
--                 Added some support for very large numbers and precise floats via
--                 Added the "stringsAreUtf8" encoding option. (Hat tip to http://lua-users.org/wiki/JsonModules )
--   20141223.14   The encode_pretty() routine produced fine results for small datasets, but isn't really
--                 appropriate for anything large, so with help from Alex Aulbach I've made the encode routines
--                 more flexible, and changed the default encode_pretty() to be more generally useful.
--                 Added a third 'options' argument to the encode() and encode_pretty() routines, to control
--                 how the encoding takes place.
--                 Updated docs to add assert() call to the loadfile() line, just as good practice so that
--                 if there is a problem loading JSON.lua, the appropriate error message will percolate up.
--   20140920.13   Put back (in a way that doesn't cause warnings about unused variables) the author string,
--                 so that the source of the package, and its version number, are visible in compiled copies.
--   20140911.12   Minor lua cleanup.
--                 Fixed internal reference to 'JSON.noKeyConversion' to reference 'self' instead of 'JSON'.
--                 (Thanks to SmugMug's David Parry for these.)
--   20140418.11   JSON nulls embedded within an array were being ignored, such that
--                     ["1",null,null,null,null,null,"seven"],
--                 would return
--                     {1,"seven"}
--                 It's now fixed to properly return
--                     {1, nil, nil, nil, nil, nil, "seven"}
--                 Thanks to "haddock" for catching the error.
--   20140116.10   The user's JSON.assert() wasn't always being used. Thanks to "blue" for the heads up.
--   20131118.9    Update for Lua 5.3... it seems that tostring(2/1) produces "2.0" instead of "2",
--                 and this caused some problems.
--   20131031.8    Unified the code for encode() and encode_pretty(); they had been stupidly separate,
--                 and had of course diverged (encode_pretty didn't get the fixes that encode got, so
--                 sometimes produced incorrect results; thanks to Mattie for the heads up).
--                 Handle encoding tables with non-positive numeric keys (unlikely, but possible).
--                 If a table has both numeric and string keys, or its numeric keys are inappropriate
--                 (such as being non-positive or infinite), the numeric keys are turned into
--                 string keys appropriate for a JSON object. So, as before,
--                         JSON:encode({ "one", "two", "three" })
--                 produces the array
--                         ["one","two","three"]
--                 but now something with mixed key types like
--                 instead of throwing an error produces an object:
--                 To maintain the prior throw-an-error semantics, set
--   20131004.7    Release under a Creative Commons CC-BY license, which I should have done from day one, sorry.
--   20130120.6    Comment update: added a link to the specific page on my blog where this code can
--                 be found, so that folks who come across the code outside of my blog can find updates
--                 more easily.
--   20111207.5    Added support for the 'etc' arguments, for better error reporting.
--   20110731.4    More feedback from David Kolf on how to make the tests for Nan/Infinity system independent.
--   20110730.3    Incorporated feedback from David Kolf at http://lua-users.org/wiki/JsonModules:
--                   * When encoding lua for JSON, Sparse numeric arrays are now handled by
--                     spitting out full arrays, such that
--                        JSON:encode({"one", "two", [10] = "ten"})
--                     returns
--                        ["one","two",null,null,null,null,null,null,null,"ten"]
--                     In 20100810.2 and earlier, only up to the first non-null value would have been retained.
--                   * When encoding lua for JSON, numeric value NaN gets spit out as null, and infinity as "1+e9999".
--                     Version 20100810.2 and earlier created invalid JSON in both cases.
--                   * Unicode surrogate pairs are now detected when decoding JSON.
--   20100810.2    added some checking to ensure that an invalid Unicode character couldn't leak in to the UTF-8 encoding
--   20100731.1    initial public release
Nautilus
Post by Nautilus »
Yes I meant a space is needed both before and after "--data-binary" - not there in the middle :)
Now that I looked the json reply more carefully I noticed there is space in the "mixer volume" key. Also, forgot that the field probably needs to be made to a string with tostring(). I can get the volume printed to my log with this:
    file = assert(io.popen('curl \'http://url:port/jsonrpc.js\' --data-binary \'{"id":1,"method":"slim.request","params":["xx:yy:zz:aa:bb:cc",["status","-","1",""]]}\''))
    file:close()
    volume = deviceinfo.result["mixer volume"]
    print(tostring(volume))
In the log I see:
2016-10-23 20:16:01.467 LUA: 70
simon_rb
Post by simon_rb »
I have replaced the script with the one above and got this
pi@raspberrypi:~$ lua /home/pi/domoticz/scripts/lua/script_time_sqtouch.lua
100 899 100 814 100 85 65266 6815 --:--:-- --:--:-- --:--:-- 67833
30.6757968
pi@raspberrypi:~$
30.6757968 is the correct volume. No I have to try and add that to my Dummy dimmer within domoticz..
simon_rb
Post by simon_rb »
This is my script. It turns the switch off every minute, even if I don't change it. What do I have to add for the If device changes you mentioned earlier and that it only turns it off. Doesn't actually change the percentage on the device. Appreciate all your help with this!
    file = assert(io.popen('curl \'http://192.168.1.26:9000/jsonrpc.js\' --data-binary \'{"id":1,"method":"slim.request","params":["00:04:20:23:88:36",["status","-","1",""]]}\''))
    file:close()
    commandArray['UpdateDevice'] = '265|0|' .. volume
