dtgbot - Domoticz TeleGram BOT
- corbin
Re: dtgbot - Domoticz TeleGram BOT
thanks for the answers, I've lost my previous telegram setup and about to add back in
I dont know if this is the logging from the time it didnt work, but the file contains the followingjvdz wrote:The dtgbot.log.errors file should contain the error encountered as described in the wiki: https://www.domoticz.com/wiki/Remote_Co ... log.errors
Have you checked that?
Jos
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
^M 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0^M100 292 100 231 100 61 2714 716 --:--:-- --:--:-- --:--:-- 2750
jq: error: Cannot iterate over null
/home/pi/dtgbot/bash//systemstatus.sh: line 48: [: : integer expression expected
/home/pi/dtgbot/bash//systemstatus.sh: line 52: [: : integer expression expected
/home/pi/dtgbot/bash//systemstatus.sh: line 56: [: : integer expression expected
^M 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0^M 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0^M100 566 100 345 100 221 3510 224$
/home/pi/dtgbot/bash//checkdomoticzupdate.sh: 21: [: -le: unexpected operator
/home/pi/dtgbot/bash//checkdomoticzupdate.sh: 26: [: -le: unexpected operator
^M 0 0 0 0 0 0 0 0 --:--:-- --:--:-- --:--:-- 0^M100 266 100 220 100 46 2214 463 --:--:-- --:--:-- --:--:-- 2222
- jvdz
- Domoticz version: 4.107
It looks to me this is the error log of a currently running dtgbot service instance as I don't see any hard errors that would make the service stop?
It seems you have done some bash commands here to request the system status and update status which both failed.
Could it be that there is an issue with the required variables definition required for dtgbot?
One other thing to do would be to set the variable TelegramBotLoglevel to 2 and start the dtgbot service. This should generate a more detailed dtg.log so you can see what is happening. You can share them with me via PM in case you have questions.
Jos
Jos
Hi All!
today faced the same issue -
/usr/bin/lua5.2: /home/domoticz/dtgbot/dtgbot.lua:549: attempt to index global 'msg' (a nil value)
stack traceback:
/home/domoticz/dtgbot/dtgbot.lua:549: in main chunk
[C]: in ?
on line 549 i have print_to_log(1,msg.text)
Is there any solution?
stack traceback:
[C]: in ?
- jvdz
I actually looked at this issue a few weeks ago when it was reported by G3rard. It turned out he was receiving channel messages which don't contain the message field information. To fix the issue just replace this portion of the code:
With:
This will avoid processing nil messages and simply continue with the next message in the queue.
Jos
print_to_log(1,'update_id ',tt.update_id)
TelegramBotOffset = tt.update_id + 1
print_to_log(1,'TelegramBotOffset '..TelegramBotOffset)
set_variable_value(TBOidx,TBOName,0,TelegramBotOffset)
-- Offset updated before processing in case of crash allows clean restart
on_msg_receive(msg)
-- print_to_log(1,msg.text)
if msg ~= nil and msg.text ~= nil then
on_msg_receive(msg)
Jos
- G3rard
- Target OS: -
- Domoticz version: No
That fix of Jos works like a charm.
Dtgbot is already running for some weeks now, where before this change the service used to stop frequently.
Not using Domoticz anymore
Got everythink working i think, no errors but i dont get any responds when i send a command like "systemstatus"
and this is the log:
Error_log is empty, Got any ideas? Thank you in advance!
root@Domoticzmainz:/etc/init.d# sudo service dtgbot status
● dtgbot.service - LSB: A Telegram bot designed to control Domoticz
Loaded: loaded (/etc/init.d/dtgbot)
Active: active (running) since Fri 2017-04-14 20:12:17 CEST; 8min ago
Process: 7474 ExecStart=/etc/init.d/dtgbot start (code=exited, status=0/SUCCESS)
CGroup: /system.slice/dtgbot.service
├─7481 /bin/sh /home/pi/dtgbot/dtgbot /var/run/dtgbot.pid
└─7482 /usr/bin/lua5.2 /home/pi/dtgbot/dtgbot.lua
Apr 14 20:12:17 Domoticzmainz dtgbot[7474]: Starting Telegram Bot for Domoti....
Apr 14 20:12:17 Domoticzmainz systemd[1]: Started LSB: A Telegram bot design....
Hint: Some lines were ellipsized, use -l to show in full.
2017-04-14 20:12:17 - DomoticzIP: XXXXXXXX:[email protected]
2017-04-14 20:12:17 - DomoticzPort: 8080
2017-04-14 20:12:17 - BotHomePath: /home/pi/dtgbot/
2017-04-14 20:12:17 - BotLuaScriptPath: /home/pi/dtgbot/lua/
2017-04-14 20:12:17 - BotBashScriptPath: /home/pi/dtgbot/bash/
2017-04-14 20:12:17 - TelegramBotToken: XXXXXXXXXXXXXXXXXXXXXXXX
2017-04-14 20:12:17 - TelegramBotOffset: TelegramBotOffset
2017-04-14 20:12:17 - -----------------------------------------
2017-04-14 20:12:17 - Starting Telegram api Bot message handler
2017-04-14 20:12:17 - Domoticz returned getuservariables after 1 attempts
2017-04-14 20:12:17 - dtgbotLogLevel set to: 0
2017-04-14 20:12:17 - Loading command modules...
2017-04-14 20:12:17 - Loading module <utility>
2017-04-14 20:12:17 - found command <refresh>
2017-04-14 20:12:17 - Loading module <dtgmenu>
2017-04-14 20:12:17 - define LastCommand
2017-04-14 20:12:17 - found command <dtgmenu>
2017-04-14 20:12:17 - Loading module <list>
2017-04-14 20:12:17 - found command <dump>
2017-04-14 20:12:17 - found command <list>
2017-04-14 20:12:17 - Loading module <devices>
2017-04-14 20:12:17 - found command <scenes>
2017-04-14 20:12:17 - found command <devices>
2017-04-14 20:12:17 - Loading module <flick>
2017-04-14 20:12:17 - found command <flick>
2017-04-14 20:12:17 - Loading module <nflick>
2017-04-14 20:12:17 - found command <nflick>
2017-04-14 20:12:17 - Loading module <on>
2017-04-14 20:12:17 - found command <off>
2017-04-14 20:12:17 - found command <on>
2017-04-14 20:12:17 - Loading module <battery>
2017-04-14 20:12:17 - found command <batteries>
2017-04-14 20:12:17 - found command <battery>
2017-04-14 20:12:17 - Loading module <help>
2017-04-14 20:12:17 - found command <start>
2017-04-14 20:12:17 - found command <help>
2017-04-14 20:12:17 - Loading module <temperature>
2017-04-14 20:12:17 - found command <temperatures>
2017-04-14 20:12:17 - found command <temperature>
2017-04-14 20:12:17 - found command <tempall>
2017-04-14 20:12:17 - Decoded On
2017-04-14 20:12:18 - WLidx 10
2017-04-14 20:12:18 - Decoded 34492***
2017-04-14 20:12:18 - WLString: 34492***
2017-04-14 20:12:18 - dtgbotLogLevel set to: 0
2017-04-14 20:12:18 - Getting TelegramBotOffset the previous Telegram bot message offset from Domoticz
2017-04-14 20:12:18 - Decoded 1
RPI 3b+, PiFace 2, RFcom, Aeon Zwave USB, Aeon Home Energy Meter Gen 5, several Shelly switches, several ESP8266 sensors.
Ok, thanks to jvdz i managed to get it to work! Really great he could help me.
I made a couple of stupd mistakes which I will explain here so maybe other people will benefit from it:
First: when making the DomoticzData.sh you will have to fill in your token. DO NOT begin with " bot" like this:
export TelegramBotToken="bot12345678:token_tokentokentokentoken"
It has to be made like this:
export TelegramBotToken="12345678:token_tokentokentokentoken"
And when all fails, and you need to make a logfile, make a uservariable with the name:
(notice the capital letters!)
TelegramBotLoglevel
Integer
2
This will make the DTG.log much bigger and this way you can dig deeper into errors.
TelegramBotLoglevel
Integer
2
mmm...
tried installing dtgbot on 2 machines (a x64 ubuntu server 16.04 and a pi with x86 ubuntu 14.04) by following the Wiki
both failed.
on both machines:
With sudo service dtgbot start, it gives in the server:
In the Pi it says
But the bot is unable to connect domoticz.
on both systems the file DomoticzData.sh is like:
on the ubuntu server, the error log gives:
The Pi dont have any errors, but cannot connect to Domoticz.
What to do?
edit:
After rebooting the Pi it gives a few error lines
I have rooms defined in domoticz, but it seems that it cannot find any?
both failed.
on both machines:
ubuntu@ubuntu:~/apps/dtgbot$ sudo lua dtgbot.lua
2017-05-10 20:23:30 - DomoticzIP not found check /etc/profile.d/DomoticzData.sh
2017-05-10 20:23:30 - DomoticzPort not found check /etc/profile.d/DomoticzData.sh
2017-05-10 20:23:30 - BotHomePath not found check /etc/profile.d/DomoticzData.sh
2017-05-10 20:23:30 - BotLuaScriptPath not found check /etc/profile.d/DomoticzData.sh
2017-05-10 20:23:30 - TempFileDir not found check /etc/profile.d/DomoticzData.sh
2017-05-10 20:23:30 - BotBashScriptPath not found check /etc/profile.d/DomoticzData.sh
2017-05-10 20:23:30 - TelegramBotToken not found check /etc/profile.d/DomoticzData.sh
2017-05-10 20:23:30 - TelegramBotOffset not found check /etc/profile.d/DomoticzData.sh
lua: dtgbot.lua:69: attempt to concatenate global 'DomoticzPort' (a nil value)
stack traceback:
dtgbot.lua:69: in main chunk
[C]: in ?
Loaded: loaded (/etc/init.d/dtgbot; bad; vendor preset: enabled)
Active: active (exited) since Wed 2017-05-10 18:07:09 CEST; 2h 34min ago
Docs: man:systemd-sysv-generator(8)
Process: 18676 ExecStop=/etc/init.d/dtgbot stop (code=exited, status=0/SUCCESS)
Process: 18692 ExecStart=/etc/init.d/dtgbot start (code=exited, status=0/SUCCESS)
May 10 18:07:09 centraalpunt systemd[1]: Starting LSB: A Telegram bot designed to control Domoticz...
May 10 18:07:09 centraalpunt dtgbot[18692]: Starting Telegram Bot for Domoticz ... Done.
May 10 18:07:09 centraalpunt systemd[1]: Started LSB: A Telegram bot designed to control Domoticz.
* dtgbot is running
#!/bin/bash
# Variables to avoid having to set local system information in individual automation scripts
#I can't get the next line to work during start-up so have gone to 127 instead
# export DomoticzIP=$(hostname -I|sed 's/[ ]*$//')
export DomoticzIP="192.168.88.2"
export DomoticzPort="8000"
export TempFileDir="/var/tmp/"
export BotHomePath="/home/user/apps/dtgbot/"
export BotBashScriptPath=$BotHomePath"bash/"
export BotLuaScriptPath=$BotHomePath"lua/"
export BotLuaLog=$TempFileDir"dtb.log"
export TelegramChatId="my_chat_id"
export TelegramBotToken="my_bot_ID:My_bot_token"
export TelegramBotOffset="TelegramBotOffset"
export EmailTo="[email protected]"
/usr/bin/lua5.2: error loading module 'socket.core' from file '/usr/local/lib/lua/5.2/socket/core.so':
/usr/local/lib/lua/5.2/socket/core.so: wrong ELF class: ELFCLASS32
stack traceback:
[C]: in ?
[C]: in function 'require'
/usr/local/share/lua/5.2/socket.lua:12: in main chunk
/usr/local/share/lua/5.2/socket/http.lua:10: in main chunk
/home/user/apps/dtgbot/dtgbot.lua:93: in main chunk
[C]: in ?
What to do?
edit:
dtg_domoticz.lua:178: attempt to index field 'result'( a nil value)
/dtg_domoticz.lua:178: in funtion 'devinfo_from_name'
/dtgmenu:433: in funtion 'MakeRoomMenus'
/dtgmenu:382: in funtion 'PopulateMenuTab'
/dtgbot.lua:211 in function 'dtg_initialise'
/dtgbot.lua:230 in main chunk
- jvdz
It seems there is a problem with the LUA setup on Ubuntu and am not sure what is needed there as I don't have that setup available.
Edit: A quick search of the forum revealed this post: http://www.domoticz.com/forum/viewtopic ... S32#p54112
As to the RPI issue: How have you identified it can't connect to domoticz? What is shown in the dtg log files when you start it?
Jos
Jos
editted my post above
By using dtgbot, it seems that my domoticz is crashing
- jvdz
It helps when you set the loglevel to 2 and then supply me with the dtg.log file so we can exactly see what is happening ( as defined in the Wiki).
I don't know why domoticz could be crashing as it only does json calls, but maybe the error you see and the crash are related.
Jos
Jos
Seems like i have the same problem as maomanna described on my raspberry pi3, I think something broke after i updated the kernel of my pi because before that everything was working fine.
My dtb.errors.log
My dtblog (dtgbotloglevel2.removed telegrambottoken)
My dtb.errors.log
/usr/bin/lua5.2: /home/pi/dtgbot//dtg_domoticz.lua:178: attempt to index field 'result' (a nil value)
stack traceback:
/home/pi/dtgbot//dtg_domoticz.lua:178: in function 'devinfo_from_name'
/home/pi/dtgbot/lua//dtgmenu.lua:433: in function 'MakeRoomMenus'
/home/pi/dtgbot/lua//dtgmenu.lua:382: in function 'PopulateMenuTab'
/home/pi/dtgbot/dtgbot.lua:211: in function 'dtgbot_initialise'
/home/pi/dtgbot/dtgbot.lua:230: in main chunk
[C]: in ?
2017-05-11 23:44:12 - DomoticzIP: 192.168.1.27
2017-05-11 23:44:12 - DomoticzPort: 8080
2017-05-11 23:44:12 - BotHomePath: /home/pi/dtgbot/
2017-05-11 23:44:12 - BotLuaScriptPath: /home/pi/dtgbot/lua/
2017-05-11 23:44:12 - TempFileDir: /var/tmp/
2017-05-11 23:44:12 - BotBashScriptPath: /home/pi/dtgbot/bash/
2017-05-11 23:44:12 - TelegramBotToken: -
2017-05-11 23:44:12 - TelegramBotOffset: TelegramBotOffset
2017-05-11 23:44:12 - -----------------------------------------
2017-05-11 23:44:12 - Starting Telegram api Bot message handler
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=command¶m=getuservariables>
2017-05-11 23:44:12 - Domoticz returned getuservariables after 1 attempts
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=devices&order=name&used=true>
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=scenes&order=name&used=true>
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=plans&order=name&used=true>
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=command¶m=getlanguage>
2017-05-11 23:44:12 - dtgbotLogLevel set to: 2
2017-05-11 23:44:12 - Loading command modules...
2017-05-11 23:44:12 - Loading module <utility>
2017-05-11 23:44:12 - found command <refresh>
2017-05-11 23:44:12 - function: 0x793b60
2017-05-11 23:44:12 - Loading module <dtgmenu>
2017-05-11 23:44:12 - define LastCommand
2017-05-11 23:44:12 - found command <dtgmenu>
2017-05-11 23:44:12 - function: 0x7a3b80
2017-05-11 23:44:12 - Loading module <list>
2017-05-11 23:44:12 - found command <dump>
2017-05-11 23:44:12 - function: 0x7a01c8
2017-05-11 23:44:12 - found command <list>
2017-05-11 23:44:12 - Loading module <devices>
2017-05-11 23:44:12 - found command <devices>
2017-05-11 23:44:12 - function: 0x7aa040
2017-05-11 23:44:12 - found command <scenes>
2017-05-11 23:44:12 - Loading module <flick>
2017-05-11 23:44:12 - found command <flick>
2017-05-11 23:44:12 - function: 0x7a9c50
2017-05-11 23:44:12 - Loading module <nflick>
2017-05-11 23:44:12 - found command <nflick>
2017-05-11 23:44:12 - function: 0x7acb98
2017-05-11 23:44:12 - Loading module <on>
2017-05-11 23:44:12 - found command <on>
2017-05-11 23:44:12 - function: 0x7aee50
2017-05-11 23:44:12 - found command <off>
2017-05-11 23:44:12 - Loading module <battery>
2017-05-11 23:44:12 - found command <batteries>
2017-05-11 23:44:12 - function: 0x7b69e0
2017-05-11 23:44:12 - found command <battery>
2017-05-11 23:44:12 - Loading module <help>
2017-05-11 23:44:12 - found command <start>
2017-05-11 23:44:12 - function: 0x7b5b08
2017-05-11 23:44:12 - found command <help>
2017-05-11 23:44:12 - Loading module <temperature>
2017-05-11 23:44:12 - found command <tempall>
2017-05-11 23:44:12 - function: 0x7b9980
2017-05-11 23:44:12 - found command <temperature>
2017-05-11 23:44:12 - found command <temperatures>
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=command¶m=getuservariable&idx=139>
2017-05-11 23:44:12 - Decoded On
2017-05-11 23:44:12 - #### Start populating menuarray
2017-05-11 23:44:12 - Submenu table including buttons defined in menu.cfg: (1) 1 (2)
2017-05-11 23:44:12 - => (1) Misc (2) (3) n (4) 3
2017-05-11 23:44:12 - ==> start devinfo_from_name (2) refresh
2017-05-11 23:44:12 - !!!! found device (1) (2) 0
2017-05-11 23:44:12 - --< devinfo_from_name: (1) 0 (2) 9999 (3) (4) command (5) command (6) command (7)
2017-05-11 23:44:12 - static -> (1) Misc (2) refresh (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2017-05-11 23:44:12 - ==> start devinfo_from_name (2) tempall
2017-05-11 23:44:12 - static -> (1) Misc (2) tempall (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2017-05-11 23:44:12 - ==> start devinfo_from_name (2) battery
2017-05-11 23:44:12 - static -> (1) Misc (2) battery (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2017-05-11 23:44:12 - ==> start devinfo_from_name (2) batteries
2017-05-11 23:44:12 - static -> (1) Misc (2) batteries (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2017-05-11 23:44:12 - ==> start devinfo_from_name (2) systemstatus
2017-05-11 23:44:12 - static -> (1) Misc (2) systemstatus (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2017-05-11 23:44:12 - ==> start devinfo_from_name (2) dtgmenu
2017-05-11 23:44:12 - static -> (1) Misc (2) dtgmenu (3) (4) 9999 (5) command (6) command (7) command (8) 100 (9)
2017-05-11 23:44:12 - Creating Room Menus: (1) 1 (2)
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=command¶m=getplandevices&idx=2&order=name&used=true>
2017-05-11 23:44:12 - For room woonkamer got some devices and/or scenes
2017-05-11 23:44:12 - - Plan record: (1) Verlichting woonkamer (2) 13 (3) 0
2017-05-11 23:44:12 - --> device record
2017-05-11 23:44:12 - ==> start devinfo_from_name (1) 13 (2)
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=devices&rid=13>
2017-05-11 23:44:12 - device (1) (2) Verlichting woonkamer (3) 13 (4) 13
2017-05-11 23:44:12 - !!!! found device (1) Verlichting woonkamer (2) Verlichting woonkamer (3) 13 (4) 13
2017-05-11 23:44:12 - !!!! found device (1) Verlichting woonkamer (2) 13
2017-05-11 23:44:12 - --< devinfo_from_name: (1) 1 (2) 13 (3) Verlichting woonkamer (4) devices (5) Light/Switch (6) On/Off (7) Off
2017-05-11 23:44:12 - Dynamic -> (1) woonkamer (2) Verlichting_ (3) Verlichting woonkamer (4) 13 (5) devices (6) Light/Switch (7) On/Off (8) 100 (9) Off
2017-05-11 23:44:12 - - Plan record: (1) Energy meter (2) 72 (3) 0
2017-05-11 23:44:12 - ==> start devinfo_from_name (1) 72 (2)
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=devices&rid=72>
2017-05-11 23:44:12 - device (1) (2) Energy meter (3) 72 (4) 72
2017-05-11 23:44:12 - !!!! found device (1) Energy meter (2) Energy meter (3) 72 (4) 72
2017-05-11 23:44:12 - !!!! found device (1) Energy meter (2) 72
2017-05-11 23:44:12 - - Plan record: (1) Gas (2) 11 (3) 0
2017-05-11 23:44:12 - ==> start devinfo_from_name (1) 11 (2)
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=devices&rid=11>
2017-05-11 23:44:12 - device (1) (2) Gas (3) 11 (4) 11
2017-05-11 23:44:12 - !!!! found device (1) Gas (2) Gas (3) 11 (4) 11
2017-05-11 23:44:12 - !!!! found device (1) Gas (2) 11
2017-05-11 23:44:12 - - Plan record: (1) Keuken verlichting (2) 31 (3) 0
2017-05-11 23:44:12 - ==> start devinfo_from_name (1) 31 (2)
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=devices&rid=31>
2017-05-11 23:44:12 - device (1) (2) Keuken verlichting (3) 31 (4) 31
2017-05-11 23:44:12 - !!!! found device (1) Keuken verlichting (2) Keuken verlichting (3) 31 (4) 31
2017-05-11 23:44:12 - !!!! found device (1) Keuken verlichting (2) 31
2017-05-11 23:44:12 - --< devinfo_from_name: (1) 1 (2) 31 (3) Keuken verlichting (4) devices (5) Light/Switch (6) On/Off (7) Off
2017-05-11 23:44:12 - Dynamic -> (1) woonkamer (2) Keuken_verlichting (3) Keuken verlichting (4) 31 (5) devices (6) Light/Switch (7) On/Off (8) 100 (9) Off
2017-05-11 23:44:12 - - Plan record: (1) Tv huiskamer (2) 84 (3) 0
2017-05-11 23:44:12 - ==> start devinfo_from_name (1) 84 (2)
2017-05-11 23:44:12 - JSON request <http://192.168.1.27:8080/json.htm?type=devices&rid=84>
2017-05-11 23:44:12 - device (1) (2) Tv huiskamer (3) 84 (4) 84
2017-05-11 23:44:12 - !!!! found device (1) Tv huiskamer (2) Tv huiskamer (3) 84 (4) 84
2017-05-11 23:44:12 - !!!! found device (1) Tv huiskamer (2) 84
2017-05-11 23:44:12 - --< devinfo_from_name: (1) 1 (2) 84 (3) Tv huiskamer (4) devices (5) Light/Switch (6) On/Off (7) On
2017-05-11 23:44:12 - Dynamic -> (1) woonkamer (2) Tv_huiskamer (3) Tv huiskamer (4) 84 (5) devices (6) Light/Switch (7) On/Off (8) 100 (9) On
2017-05-11 23:44:12 - - Plan record: (1) Kodi (2) 36 (3) 0
2017-05-11 23:44:12 - ==> start devinfo_from_name (1) 36 (2)
2017-05-11 23:44:13 - JSON request <http://192.168.1.27:8080/json.htm?type=devices&rid=36>
@JvdZ and I working on a solution.
Hopefully we have one soon. When founded, we'll post it.
On my ubuntu server, i have a different problem. Cause it is a x64 system, i dont have the right lua library. The sudo apt-get install lua5.2 is installed, but it looks like that dtgbot isn't pointed to that dirs
- G3rard
- Target OS: -
I have dtgbot working on my Ubuntu server. It took some extra steps which I think I have written down. Will have a look at it this weekend and share the steps here.
but do you have a x86 or x64 ubuntu server?G3rard wrote:I have dtgbot working on my Ubuntu server. It took some extra steps which I think I have written down. Will have a look at it this weekend and share the steps here.
- jvdz
I am working with maomanna in PM on his issue, but it seems his PI issue is due to the fact that a JSON call doesn't return a RESULT section, hence causing the nil issue in lua.DennisD wrote:Seems like i have the same problem as maomanna described on my raspberry pi3, I think something broke after i updated the kernel of my pi because before that everything was working fine.
Could you post the result of that last JSON call from the log to see whether you have the same issue?
That was it, no more entries after that. That was the last line of the log.
If i copy and paste the url in my browser i do get a result so the device is there and the json call works.
- jvdz
Sorry, I was trying to ask you to put that exact line in your browser, hit enter and show me the result returned.
Jos
Jos
Sorry just edited my post , but here is the outcome of the json call:"
"ActTime" : 1494575660,
"ServerTime" : "2017-05-12 09:54:20",
"Sunrise" : "05:54",
"Sunset" : "21:24",
"status" : "OK",
"title" : "Devices"
"Sunset" : "21:24",
"status" : "OK",
"title" : "Devices"
