Geofence for Domoticz
thecosmicgate
Domoticz version: newest
Re: Geofence for Domoticz
Post by thecosmicgate »
The domofence app was running fine, till I updated my galaxy S7 to the new nougat OS.
Now domofence doesnt send / trigger the off signal to the IDX in domoticz.
The application itself tells me nicely : entered or exited the zones but nothing happen in the domoticz dashboard.
When I test the app it nicely set the switch to : on .
But after this ... Nothing
Anybody who can help me with this ?
It's nice to be important, but it's more important to be nice
Scooter ;)
EdwinK
Post by EdwinK »
Trying this, and it seems to work. Tomorrow will be te real test. Now I'm not leaving my zone ;)
Appesteijn
Post by Appesteijn »
thecosmicgate wrote:The domofence app was running fine, till I updated my galaxy S7 to the new nougat OS.
I haven't heard that Android 7 breaks anything, but I'll look in to this.
Misterik
Post by Misterik »
Yep...i have also the same problem. I had not noticed yet, so thanks for mention this.
UPDATE : More apps where not working. But after a reboot off my phone it worked again, including domofence.
RPI-3 : RFLink + Zigbee2MQTT + Shelly + MySensors + Milight
thecosmicgate
I already did some 5 reboots with the phone's but still it doesn't respond
Scooter ;)
Appesteijn
thecosmicgate wrote:I already did some 5 reboots with the phone's but still it doesn't respond
Yesterday I created a new version with the latest geofence-ing library from Google, you can test it here: https://play.google.com/apps/testing/co ... .domofence
Please, let me know if it helps! You might need to remove and re-add your geofence.
thecosmicgate
Re: RE: Re: Geofence for Domoticz
Sure, installed this and will keep you posted
Scooter ;)
thecosmicgate
Installed the Béta, but the same problem still exists.
Also rebooted the smartphone but nothing.
Domofence doesnt send the on - off to the IDX ;(
Scooter ;)
Appesteijn
thecosmicgate wrote:Installed the Béta, but the same problem still exists.
Weird, if it really never sends any signals then something else might be the problem. Could you try to reinstall the app?
And the 'test button' does work right?
thecosmicgate
Un-installed en re-installed but the problem is still there
The test button is working fine
Scooter ;)
Appesteijn
thecosmicgate wrote:Un-installed en re-installed but the problem is still there
OK I think I know what the issue is. Android 7.0 doesn't let apps listen to network changes. DomoFence did this to send cached geofence transitions.
So when you crossed a geofence but didn't have a dataconnection available, DomoFence cached the transition and would send it when you did have a data connection available.
I just released a beta in which I build the app for Android 6.0 so it should work on 7.0 with the old functionality.
Could you please try the beta (2.7.2) and see if this works? If it does, I will implement a good solution, but that will take a lot more work.
thecosmicgate
I installed the latest beta .
So i can test this changes, hopefully this is the solution .
Scooter ;)
thecosmicgate
With the latest beta it seems to work fine !
Is it also possible to request some app features using this topic ;)
Scooter ;)
Appesteijn
thecosmicgate wrote:With the latest beta it seems to work fine !
Ok good to hear! You can request anything as long as I can say 'No' :)
thecosmicgate
Is there some possibilitie to select / use 2 ports or servers ? This because i use different ports for internal and external acces
Scooter ;)
Appesteijn
thecosmicgate wrote:Is there some possibilitie to select / use 2 ports or servers ? This because i use different ports for internal and external acces
Can't you just use your external ip from within your internal network?
thecosmicgate
Nope , i also use a name instead of a IP
Scooter ;)
lordsidney
Post by lordsidney »
Hi Guys
I am trying to use domofence, but I get an error when using the test button...
The iPhone and port are OK.
But it seems it cannot connect to my server.
Have you an idea?
Appesteijn
lordsidney wrote:Hi Guys
Have you an idea?
Does it work when you are on the local network (and use you internal server ip)?
What happens if you use that url in your browser?
Check if you have 'Basic auth':
Screen Shot 2017-04-14 at 08.22.22.png (134.55 KiB) Viewed 3559 times
thecosmicgate
Okay back again : domofence was working for a fews days (i think) but at the moment when we entered the zone , it doesn't send the "on" signal.
When we manually press the "test connection" it is working fine ;(
Sent from my SM-G935F using Tapatalk
Scooter ;)
