Here the log.
2026-02-03 17:45:47.022 Error: somfy: Call to function 'onStart' failed, exception details:
2026-02-03 17:45:47.119 Error: somfy: Traceback (most recent call last):
2026-02-03 17:45:47.119 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 198, in _new_conn
2026-02-03 17:45:47.119 Error: somfy: sock = connection.create_connection(
2026-02-03 17:45:47.120 Error: somfy: (self._dns_host, self.port),
2026-02-03 17:45:47.120 Error: somfy: ...<2 lines>...
2026-02-03 17:45:47.120 Error: somfy: socket_options=self.socket_options,
2026-02-03 17:45:47.120 Error: somfy: )
2026-02-03 17:45:47.120 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/util/connection.py", line 60, in create_connection
2026-02-03 17:45:47.120 Error: somfy: for res in socket.getaddrinfo(host, port, family, socket.SOCK_STREAM):
2026-02-03 17:45:47.120 Error: somfy: ~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-02-03 17:45:47.121 Error: somfy: File "/usr/lib/python3.13/socket.py", line 977, in getaddrinfo
2026-02-03 17:45:47.121 Error: somfy: for res in _socket.getaddrinfo(host, port, family, type, proto, flags):
2026-02-03 17:45:47.121 Error: somfy: ~~~~~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-02-03 17:45:47.121 Error: somfy: socket.gaierror: [Errno -2] Name or service not known
2026-02-03 17:45:47.121 Error: somfy: The above exception was the direct cause of the following exception:
2026-02-03 17:45:47.122 Error: somfy:
2026-02-03 17:45:47.122 Error: somfy: Traceback (most recent call last):
2026-02-03 17:45:47.122 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 787, in urlopen
2026-02-03 17:45:47.122 Error: somfy: response = self._make_request(
2026-02-03 17:45:47.122 Error: somfy: conn,
2026-02-03 17:45:47.122 Error: somfy: ...<10 lines>...
2026-02-03 17:45:47.122 Error: somfy: **response_kw,
2026-02-03 17:45:47.123 Error: somfy: )
2026-02-03 17:45:47.123 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 488, in _make_request
2026-02-03 17:45:47.123 Error: somfy: raise new_e
2026-02-03 17:45:47.123 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 464, in _make_request
2026-02-03 17:45:47.123 Error: somfy: self._validate_conn(conn)
2026-02-03 17:45:47.123 Error: somfy: ~~~~~~~~~~~~~~~~~~~^^^^^^
2026-02-03 17:45:47.123 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 1093, in _validate_conn
2026-02-03 17:45:47.124 Error: somfy: conn.connect()
2026-02-03 17:45:47.124 Error: somfy: ~~~~~~~~~~~~^^
2026-02-03 17:45:47.124 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 704, in connect
2026-02-03 17:45:47.124 Error: somfy: self.sock = sock = self._new_conn()
2026-02-03 17:45:47.124 Error: somfy: ~~~~~~~~~~~~~~^^
2026-02-03 17:45:47.124 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connection.py", line 205, in _new_conn
2026-02-03 17:45:47.124 Error: somfy: raise NameResolutionError(self.host, self, e) from e
2026-02-03 17:45:47.125 Error: somfy: urllib3.exceptions.NameResolutionError: <urllib3.connection.HTTPSConnection object at 0x7f6a6b8410>: Failed to resolve '0811-6250-3860.local' ([Errno -2] Name or service not known)
2026-02-03 17:45:47.125 Error: somfy: The above exception was the direct cause of the following exception:
2026-02-03 17:45:47.125 Error: somfy: Traceback (most recent call last):
2026-02-03 17:45:47.125 Error: somfy: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 667, in send
2026-02-03 17:45:47.126 Error: somfy: resp = conn.urlopen(
2026-02-03 17:45:47.126 Error: somfy: method=request.method,
2026-02-03 17:45:47.126 Error: somfy: ...<9 lines>...
2026-02-03 17:45:47.126 Error: somfy: chunked=chunked,
2026-02-03 17:45:47.126 Error: somfy: )
2026-02-03 17:45:47.126 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/connectionpool.py", line 841, in urlopen
2026-02-03 17:45:47.126 Error: somfy: retries = retries.increment(
2026-02-03 17:45:47.127 Error: somfy: method, url, error=new_e, _pool=self, _stacktrace=sys.exc_info()[2]
2026-02-03 17:45:47.127 Error: somfy: )
2026-02-03 17:45:47.127 Error: somfy: File "/usr/lib/python3/dist-packages/urllib3/util/retry.py", line 519, in increment
2026-02-03 17:45:47.127 Error: somfy: raise MaxRetryError(_pool, url, reason) from reason # type: ignore[arg-type]
2026-02-03 17:45:47.127 Error: somfy: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-02-03 17:45:47.127 Error: somfy: urllib3.exceptions.MaxRetryError: HTTPSConnectionPool(host='0811-6250-3860.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/events/register (Caused by NameResolutionError("<urllib3.connection.HTTPSConnection object at 0x7f6a6b8410>: Failed to resolve '0811-6250-3860.local' ([Errno -2] Name or service not known)"))
2026-02-03 17:45:47.128 Error: somfy: During handling of the above exception, another exception occurred:
2026-02-03 17:45:47.128 Error: somfy: Traceback (most recent call last):
2026-02-03 17:45:47.128 Error: somfy: File "/home/julien/domoticz/plugins/somfy/plugin.py", line 764, in onStart
2026-02-03 17:45:47.128 Error: somfy: _plugin.onStart()
2026-02-03 17:45:47.128 Error: somfy: ~~~~~~~~~~~~~~~^^
2026-02-03 17:45:47.128 Error: somfy: File "/home/julien/domoticz/plugins/somfy/plugin.py", line 253, in onStart
2026-02-03 17:45:47.129 Error: somfy: self.setup_and_sync_devices(pin)
2026-02-03 17:45:47.129 Error: somfy: ~~~~~~~~~~~~~~~~~~~~~~~~~~~^^^^^
2026-02-03 17:45:47.129 Error: somfy: File "/home/julien/domoticz/plugins/somfy/plugin.py", line 276, in setup_and_sync_devices
2026-02-03 17:45:47.129 Error: somfy: self.tahoma.register_listener()
2026-02-03 17:45:47.129 Error: somfy: ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~^^
2026-02-03 17:45:47.129 Error: somfy: File "/home/julien/domoticz/plugins/somfy/tahoma_local.py", line 252, in register_listener
2026-02-03 17:45:47.129 Error: somfy: response = self.listener.register_listener(self.base_url_local + "/events/register", headers=self.headers_with_token, verify=False)
2026-02-03 17:45:47.130 Error: somfy: File "/home/julien/domoticz/plugins/somfy/listener.py", line 42, in register_listener
2026-02-03 17:45:47.130 Error: somfy: response = requests.post(url, headers=headers, verify=verify, timeout=timeout)
2026-02-03 17:45:47.130 Error: somfy: File "/usr/lib/python3/dist-packages/requests/api.py", line 115, in post
2026-02-03 17:45:47.130 Error: somfy: return request("post", url, data=data, json=json, **kwargs)
2026-02-03 17:45:47.130 Error: somfy: File "/usr/lib/python3/dist-packages/requests/api.py", line 59, in request
2026-02-03 17:45:47.130 Error: somfy: return session.request(method=method, url=url, **kwargs)
2026-02-03 17:45:47.131 Error: somfy: ~~~~~~~~~~~~~~~^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2026-02-03 17:45:47.131 Error: somfy: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 589, in request
2026-02-03 17:45:47.131 Error: somfy: resp = self.send(prep, **send_kwargs)
2026-02-03 17:45:47.131 Error: somfy: File "/usr/lib/python3/dist-packages/requests/sessions.py", line 703, in send
2026-02-03 17:45:47.131 Error: somfy: r = adapter.send(request, **kwargs)
2026-02-03 17:45:47.131 Error: somfy: File "/usr/lib/python3/dist-packages/requests/adapters.py", line 700, in send
2026-02-03 17:45:47.131 Error: somfy: raise ConnectionError(e, request=request)
2026-02-03 17:45:47.131 Error: somfy: requests.exceptions.ConnectionError: HTTPSConnectionPool(host='0811-6250-3860.local', port=8443): Max retries exceeded with url: /enduser-mobile-web/1/enduserAPI/events/register (Caused by NameResolutionError("<urllib3.connection.HTTPSConnection object at 0x7f6a6b8410>: Failed to resolve '0811-6250-3860.local' ([Errno -2] Name or service not known)"))
