Python Plugin: Shelly MQTT
josemi
Re: Python Plugin: Shelly MQTT
Post by josemi »
Does anybody have working long push in a Shelly 2.5 working as roller mode?
I enable debug option in plugin, but only short push is shown. No longpush device is created in domoticz either.
Gerwin
Post by Gerwin »
hello ,
thanks a lot for these nice plugin ,
everything is working except the temperature addon for the shelly 1
is there an opportunity that this addon also available coming in this plugin ??
Gerwin
bewo
Domoticz version: 2021.1
Post by bewo »
Individual projects:
Domoticz on a Intel Xeon Server | AeonLabs Z-Wave Gen.5 | RFXCOM RFXtrx433E USB | ESP-Wifi-Modules | Shellys
Wall-mounted 22" Touch Control Display (self construct) | LUA wind monitor| LUA heating control | and many many more :)
Gerwin
Post by Gerwin »
@bewo
Gerwin
djac
Post by djac »
Trying to update Plugin but get:
"error: Your local changes to the following files would be overwritten by merge:
plugin.py
Please, commit your changes or stash them before you can merge."
Any suggestions?
Domoticz on Rpi, Z-wave, Hue with Philips and Ikea bulbs
Geitje
Post by Geitje »
If you Google it, you find some answers, I warns you probably to prevent to overwrite your local changes. You can solve it. Check out for example:
https://stackoverflow.com/questions/157 ... you-can-me
Zwave, Zigate, RFlink etc.
Gerwin
Post by Gerwin »
hello
i have seen that the themperature addon is implemented how can i update ?
can someone explain step by step how to do this
i have a lot of shelly's
Gerwin
Gerwin
Post by Gerwin »
Gerwin wrote: Wednesday 25 March 2020 11:59 hello
Gerwin
I know how to do
works great
Gerwin
fabry91
Domoticz version: 2022.2
Post by fabry91 »
Hello guys,
I'm trying to get it work, I have a Shelly 1 V3, successfully installed and started the Shelly plugin.
Problem is that I cannot make it work the on/off switch from domoticz to the shelly 1 relay, I'm attaching the configuration of tasmota flashed firmware on my shelly 1 and the logs result when I tried to switch on the mqtt switch created itself by domoticz.
Thank you in advance and stay safe ;)
besix
Post by besix »
Hello
The Shelly plugin requires the original soft Shelly.
If you have Tasmota, this is only the mqtt broker but without the Shelly plugin
fabry91
Post by fabry91 »
besix wrote: Monday 30 March 2020 19:41 Hello
Thank you very much besix, I didn't understood that It was only for the stock shelly firmware.
I have now successfully started the MQTT Client Gateway and I am now controlling the shelly1 relay!
Thanks!!!
Derik
Post by Derik »
I now strange only i ask this here..
Is there perhaps some one that have shelly with Domoticz working without a plugin?
It looks to me that shely and Domotiz talk mqtt, this must be possible without a plugin?
Just a nodered or something?
for 1 shely a plugin, that's the point
LouiS22
Post by LouiS22 »
Derik wrote: Sunday 10 May 2020 10:18 I now strange only i ask this here..
Just below this post at python's topic :)
viewtopic.php?f=65&t=32616
mattley30
Post by mattley30 »
Hi Guys,
I'm trying a scelly 1 with the additional external temperature sensor. inside the shelly1 I regularly display the temperature of 25.8 ° while on Domoticz the component created "LaCrosse TX3" with a value of "0". but I see that the update comes every minute.
Yet doing a dubug the message mqtt arrives.
2020-07-02 20: 05: 44.499 (Shelly Actuators) MQTT message: shellies / shelly1-8CAAB505BBAC / ext_temperature / 0: 25.88
2020-07-02 20: 05: 44.509 (Shelly Actuators) MQTT message: shellies / shelly1-8CAAB505BBAC / ext_temperature_f / 0: 78.58
do you know what it could be?
Mattely30
mattley30
Post by mattley30 »
Hello again
problem returned I realized that there was a shelly1 firmware update to do, once updated the temperature sensor data arrived, sorry.
Mattley30
niekbruggeman
Post by niekbruggeman »
I can confirm that the new shelly dimmer 2 works correct with Domoticz.
I use the native firmware of the Shelly, and the Shelly MQTT plugin for Domoticz 2020.2.
Pascal1978
Post by Pascal1978 »
I don't know if i'm posting it on the right place here, but i want to control my RGBW2 Shelly device with automatic color change.
i want to setup a sunrise color which flow over to daylight and at a specifick time to sunset and then to moonlight.
I have tried to set it with dzvents, but i don't know the right codes to set the colors let alone how to set it at different times and how to gradient
i want to use it for my aquarium lights.
can anyone help me out or point me in the right direction
thnx
Gerwin
Post by Gerwin »
The Shelly button is that one impemented ???
does someone knows that
Gerwin
Gerwin
Post by Gerwin »
Pascal1978 wrote: Friday 24 July 2020 22:55 Hello,
thnx
you can make groups for each collor you want
Delfuego
Post by Delfuego »
thnx
Hi Pascal,
You can send a switch command directly to you Shelly RGBW2 device using DzVentz:
		devices = {'Switch to call this script'},
        domoticz.openURL({url = 'http://192.168.0.50/color/0?turn=on&red=255&green=86&blue=112&white=0'})
The gradient effect you have to code yourself I think by sending an updated color to your device every second or so until you reach your desired color.
Also check the following links to Shelly documentation:
https://shelly.cloud/documents/develope ... cation.pdf
https://shelly-api-docs.shelly.cloud/?f ... y-overview
Kind regards,
Luuk
