[120] opentherm gateway
For OpenTherm-gateway related questions in Domoticz
gizmocuz
Re: [120] opentherm gateway
Post by gizmocuz »
Added the option to set timers on setpoint devices in latest beta
jvandenbroek
Post by jvandenbroek »
Installed the OTGW on my Remeha Calenta with iSense today, and I can read out many values :D. I know it's an known issue that setpoint doesn't work with this thermostat, but is there a workaround for it? Every time I try to change the Room setpoint, it jumps back to the old value within a minute. Also setting it to 0 or 0.0 and then some other value doesn't work. Quite annoying, since that's the whole point of using such GW :roll:
iSense doesn't seem to have a version number printed in information, only language version 18-1-2011?? :shock:
gizmocuz
Post by gizmocuz »
I think you should install the latest beta firmware on it.
I changed my iSense for an Honeywell
jvandenbroek
The latest stable release 4.0.1 is more recent than the latest beta? Or is there some 'private' beta somewhere? I really like to try that out! Anyway, I already had installed 4.0.1.
Which Honeywell do you have/recommend?
gizmocuz
Post by gizmocuz »
Does it work with the OpenTherm Monitor application ?
I also read that it could take 12 minutes before the setpoint is taken
jvandenbroek
No, also not with the monitor application. I see about every 30 sec a write-data and ack for room setpoint as set on the iSense. So it looks like that within 30 sec (if not sooner) my set value is overridden.
[edit]
It seems like I've found the solution :D I followed this instruction (Dutch) to activate remote control on the iSense and now it seems to stay at the set setpoint: http://www.homewizard.nl/kb/article/101 ... rmostaten/
I did already look for that 'remote control' function, but hadn't set the thermostat to extended/advanced mode! After that the option for remote control appeared, set it and now it stays this way 8-) It seems like it indeed take some time to get the new value, but that's totally fine with me.
[/edit]
DaaNMaGeDDoN
Post by DaaNMaGeDDoN »
Question: will it be possible to connect (and USE) an opentherm gateway when connected directly to the GPIO headers on a RPi and make that RPi a slave to an existing Domoticz server?
I plan to build my own OTgw, but drop the RS232 chip from the design, put in the wirebridge instead and instead of using a USB->TTL serial converter hook it up directly to some pins of the RPi GPIO.
Anybody that has experience with that?
Thanks in advance!
gerlo
Post by gerlo »
roblom
Post by roblom »
jvandenbroek wrote:Installed the OTGW on my Remeha Calenta with iSense today, and I can read out many values :D. I know it's an known issue that setpoint doesn't work with this thermostat, but is there a workaround for it? Every time I try to change the Room setpoint, it jumps back to the old value within a minute. Also setting it to 0 or 0.0 and then some other value doesn't work. Quite annoying, since that's the whole point of using such GW :roll:
The iSense needs to have version V19 (V17 doesn't work and V18 probably won't exists) you can find the version number in the iSense menu.
I've bought also a OTGW but as a do it yourself package so i need to solder it together. I've also have e Remeha Calenta with Isense, i will let you know when i have it up and running.
jvandenbroek
DaaNMaGeDDoN wrote:Question: will it be possible to connect (and USE) an opentherm gateway when connected directly to the GPIO headers on a RPi and make that RPi a slave to an existing Domoticz server?
Thanks in advance!
I think a logic level converter should work, will test this soon.
DaaNMaGeDDoN
Thanks in advance!
In parallel i already have confirmation RPi can be hooked up directly with the OTGW without the usb serial converter, but not in use with Domoticz. I guess it should not be that hard and if i beat you to it i'll post my findings.
BertB
Post by BertB »
I just completed the build and connection of my OTGW, via network, but I do have some irritating features:
Domoticz hangs after a couple of seconds and can only be woken-up by a reboot via putty.
I have RPI with Razberry and the usual networked Opentherm gateway with network adapter. My cv has a Remeha Avanta with a chronotherm modulation thermostat.
When it runs, I see only stuff like this:
2014-11-28 14:02:40 OTGW: connected to: 192.168.0.11:1001
2014-11-28 14:02:40 OTGW: 508,994,520,468,532,468,532,468,533,467,532,469,532,469,531,468,532,468,532,469,531,468,1019,499,502,994,1006,499,501,995,519,469,531,470,531,469,530,469,532,469,530,470,530,470,531,470,530,470,530,470,531,469,531,470,529,471,530,470,531,469,1017.
2014-11-28 14:02:41 OTGW: 510,498,502,994,520,468,532,469,531,468,531,469,532,468,532,468,532,468,532,468,532,468,1019,499,500,996,518,470,1017,995,519,469,531,469,530,470,532,468,531,470,530,470,531,469,531,469,530,471,530,469,531,469,531,470,530,470,530,470,530,471,1016.
2014-11-28 14:02:42 OTGW: 509,994,520,468,532,468,1019,994,520,468,532,469,530,470,531,470,530,470,530,469,532,469,530,471,530,469,530,470,1018,996,517,470,531,470,530,470,1017,996,1004,996,518,470,530,470,530,471,529,471,529,471,530,470,530,471,529,470,1017.
2014-11-28 14:02:43 OTGW: 511,498,502,994,520,468,532,469,532,468,532,467,532,469,532,468,532,468,532,468,532,468,532,469,532,467,532,469,531,469,532,468,532,468,532,468,532,468,532,469,532,468,532,469,1018,995,518,470,531,469,531,469,532,468,532,470,530,470,530,470,531,469,1017.
2014-11-28 14:03:32 OTGW:
Is this some problem with the OTGW?
Set 1= RPI 3B, latest Beta, RFLink USB, RFLINK WIFI, Zwave
Set 2= RPI 2B, Latest Beta, OTGW (USB), SBFSpot (Bluetooth)
BertB
Post by BertB »
The diagnostic firmware was still loaded on the controller. After putting the gateway on it, it's beginning to look like something.
I still have a problem which is a bit disturbing. I see this:
2014-11-28 15:20:35 OTGW: connected to: 192.168.0.11:1001
2014-11-28 15:20:36 (OTG1) Temp (Control Setpoint)
2014-11-28 15:20:36 (OTG1) Thermostat (Room Setpoint)
2014-11-28 15:20:36 (OTG1) Temp (Room Temperature)
2014-11-28 15:20:36 (OTG1) Temp (Boiler Water Temperature)
2014-11-28 15:20:36 (OTG1) Temp (DHW Temperature)
2014-11-28 15:20:36 (RazBerry) Temp (FGBS1T1)
2014-11-28 15:20:36 (OTG1) Temp (Outside Temperature)
2014-11-28 15:20:36 (OTG1) Temp (Return Water Temperature)
2014-11-28 15:20:36 (OTG1) Thermostat (DHW Setpoint)
2014-11-28 15:20:36 (OTG1) Thermostat (Unknown)
2014-11-28 15:20:37 (RazBerry) Temp (FGBS1T2)
2014-11-28 15:20:52 Error: OTGW: Error: End of file
Furthermore, Domoticz or the webserver is crashing very often.
BertB
Post by BertB »
The activation of the Opentherm Gateway hardware generates a lot of lines in the log. The messages of the other hardware are sort of suppressed.
Especially these lines are no longer visible:
2014-11-28 22:09:46 (RazBerry) Temp (FGBS1T2)
2014-11-28 22:10:01 (Wunderground) Temp + Humidity + Baro (WGTHB)
2014-11-28 22:10:04 (Wunderground) Wind (WGWind)
2014-11-28 22:10:04 (Wunderground) UV (WGUV)
2014-11-28 22:10:05 (Wunderground) Rain (WGRain)
2014-11-28 22:10:05 (Wunderground) General/Visibility (WGVisability)
2014-11-28 22:10:05 (Wunderground) General/Solar Radiation (WGSolar)
Does this imply that the messages are not handled by Domoticz software while Opentherm is activated?
Could this mean that the RPI is a little bit too small for Razberry and Opentherm gateway?
BertB
Post by BertB »
Because I have some more questions, that may be out of bounds here, I created a new topic here.
BertB
Post by BertB »
On the screen of my thermostat, I see a numbers of flames to represent the burner intensity.
What OTGW device is representing that?
Blueone
Post by Blueone »
I have a little problem with the opentherm gateway, I'm not sure if it's a domoticz thing or an opentherm gateway error. The switches Flameon/DHZ on etc aren't active any more, the last seen date is a few weeks ago. The temperature sensors from the OTG are still work so there is a connection. Does someone recognize this problem? I already tried to delete the hardware and adding it again.
I also get this error in the log: 14-11-28 15:20:52 Error: OTGW: Error: End of file, I have this error already from the beginning.
BertB
Post by BertB »
Blueone wrote:I have a little problem with the opentherm gateway, I'm not sure if it's a domoticz thing or an opentherm gateway error. The switches Flameon/DHZ on etc aren't active any more, the last seen date is a few weeks ago. The temperature sensors from the OTG are still work so there is a connection. Does someone recognize this problem? I already tried to delete the hardware and adding it again.
I do not recognize your problem, but I also had the End of file error. That one was gone after I connected the OTGW through USB. I think there is a problem somewhere with the socket connection.
vaanja
Post by vaanja »
dear friends,
I have OTGW USB version connected to raspberry pi running domoticz and everything works very well.
from time to time I would like to connect to OTGW using otmonitor.exe in windows, but I don't know what to do on raspi side to enable this activity.
can somebody post step-by-step instructions how to set-up ser2lan on raspi running domoticz to have domoticz and otmonitor running in parallel?
many thanks in advance.
kind regards,
vaanja
rdebruijn
Post by rdebruijn »
Below fix has removed the "Error: OTGW: Error: End of file" error message in the Domoticz log, for my WiFi version of OTGW. (USB -> TP-Link WR703N):
Disable the timeout in the ser2net config in the TP-Link OpenWRT firmware.
Login to OpenWrt on the TP-Link, menu 'System' --> 'Startup' .
In the 'Local Startup' textfield at the lower part of this screen:
Change the timeout parameter in the ser2net configuration string (in green / bold) from the current value to zero, save and reboot the TP-Link.
# Put your custom commands here that should be executed once
# the system init finished. By default this file does nothing.
opkg update
opkg install kmod-usb-serial-pl2303
opkg install ser2net
echo "1001:raw:0:/dev/ttyUSB0:9600,NONE,1STOPBIT,8DATABITS" > /etc/ser2net.conf
ser2net
exit 0
