Dashticz - Module - Garbage collector Topic is solved
Trigun
Domoticz version: 4.10717
Re: Dashticz - [CHANGED IN BETA] Module - Garbage collector
Post by Trigun »
robgeerts wrote:"De door u opgegeven postcode valt niet in het werkgebied van Twente Milieu."
Sorry, gues you need my housenumber as Well.
Its 100
On the site of twentemilieu it works.
Thnx in advance!
robgeerts
Domoticz version: 3.7067
Post by robgeerts »
Sorry no source I could use.
Unless you add the data to a public ical (if you have some spare time.
In the meantime:
Added Best,Vianen and Waalre (NL)
robgeerts
Post by robgeerts »
Hold on, maybe I've found one...
Edit: Found! I'l fix it immediately!
robgeerts
Post by robgeerts »
Its 100
Thnx in advance!
Fixed TwenteMilieu!
Trigun
Post by Trigun »
Nice!!! Great work Rob, thnx a lot!
robgeerts
Post by robgeerts »
Added Goes and Uden (NL)
HansieNL
Re: Dashticz - [BETA] Module - Garbage collector
Post by HansieNL »
Hello Rob,
I get the text undefined in the garbage block after update.
Is there something changed in the configuration?
Blah blah blah
robgeerts
Post by robgeerts »
Could you send me your config.js? I'll fix this tomorrow morning!
HansieNL
Post by HansieNL »
robgeerts wrote:Could you send me your config.js? I'll fix this tomorrow morning!
PM sent.
Thx in advance.
Blah blah blah
HansieNL
Post by HansieNL »
PM sent.
Thx in advance.
FIXED. Missed the new config setting :?
Blah blah blah
kurniawan77
Post by kurniawan77 »
kurniawan77 wrote:is it possible to inculde http://www.omrin.nl/bij-mij-thuis/servi ... alkalender too?
kurniawan77 wrote:
Do you have an example zipcode for me?
Sure...
8431TG
Sent from my Nexus 6P using Tapatalk
Any luck?
robgeerts
Post by robgeerts »
Sorry, tried different ways but no luck..
avantwist
Post by avantwist »
Guys,
what am I doing wrong.
Added all the right info in the config.js but nothinh appears..
//Trash options
var trashcan = {}
trashcan.hvc = { trashapp: 'hvc', width:12, zipcode:'3319wc', housenumber:'2' }
var trashcolors = {}
trashcolors['Gft'] = 'Green';
trashcolors['Pmd'] = 'Orange';
columns[1]['blocks'] = [trashcan.hvc]
CONFIG.js
(2.67 KiB) Downloaded 174 times
robgeerts
Post by robgeerts »
Are you using the beta version or the master version?
avantwist
Post by avantwist »
robgeerts wrote:Are you using the beta version or the master version?
I think the master:
Version: 3.8153
Build Hash: 494fff7
Compile Date: 2017-07-30 12:19:41
robgeerts
Post by robgeerts »
First, you have to define the var 'columns', try this:
Replace:
With:
var columns = {}
columns[1] = {}
avantwist
Post by avantwist »
Got it working Rob, thanks.
Only problem now is that with adding this to my config I only see the gabrage in my screen and nothing else
/Trash options
var trashcan = {}
trashcan.hvc = { maxitems: 4, trashapp: 'hvc', width:6, zipcode:'3319wc', housenumber:'2' }
var trashnames = {}
trashnames['Rest'] = 'Grijze bak';
trashnames['Gft'] = 'Groene bak';
trashnames['Pmd'] = 'Plastic';
trashnames['Papier'] = 'Blauwe bak';
trashcolors['Rest'] = 'Grey';
trashcolors['Papier'] = 'Blue';
var columns = {}
columns[1] = {}
screen garbage.png (303.45 KiB) Viewed 3043 times
EdwinK
Post by EdwinK »
Can you post your complete config.js (minus the API-keys)
Use [ code ] and [/ code ] tags (remove spaces)
avantwist
Post by avantwist »
var _LANGUAGE 				= 'nl_NL'; //or: de_DE, en_US, fr_FR, hu_HU, it_IT, pt_PT, sv_SE
var _HOST_DOMOTICZ		  	= 'http://192.168.1.101:8080';
var _DOMOTICZ_REFRESH		= 5; //in seconds
var _DASHTICZ_REFRESH		= 30; //in minutes
var _THEME 					= 'default'; // default = dashticz default theme
var _APP_TITLE 				= 'Dashticz';
var _HOST_ZIGGO_HORIZON	  	= ''; //e.g. http://192.168.1.3/domoticz/switch_horizon.php';
var _APIKEY_WUNDERGROUND  	= '';
var _WEATHER_CITY 			= 'Dordrecht';
var _WEATHER_CITYNAME 		= ''; //show a different city name, leave empty if same as _WEATHER_CITY
var _WEATHER_COUNTRY 		= 'NL';
var _USE_AUTO_POSITIONING 	= true; //don't want to configure positions, use auto positioning
var _USE_FAVORITES			= true; //only used when using auto positioning
var _HIDE_SECONDS_IN_CLOCK  = false; //do not show the seconds in the clock
var _HIDE_TOPBAR			= false; //hide topbar with appname, clock and settings-icon
var _NEWS_RSSFEED			= 'http://www.nu.nl/rss/algemeen';
var _USE_FAHRENHEIT			= false;
var _USE_BEAUFORT 			= true; //Bft instead of m/s
var _TRANSLATE_SPEED 		= false; //windspeed, north northwest instead of NNW
var _STANDBY_AFTER_MINUTES  = false; //enter amount of minutes like: 5 (5 minutes)
var _IDXmoonpicture = 1; //index of the uservariabele MoonPicture
var _SCROLL_NEWS_AFTER 		= 7000; //milliseconds, so 7000 is 7 seconds
var _SHOW_LASTUPDATE 		= true;
var _LASTUPDATE_FORMAT 		= 'DD-MM-YY HH:mm';
var _SCREENSLIDER_EFFECT 	= 'slide'; //'slide' or 'fade' or 'cube' or 'coverflow' or 'flip'
var buttons = {}
buttons.buienradar = {width:12, isimage:true, image: 'http://api.buienradar.nl/image/1.0/RadarMapNL?w=285&h=256', url: 'http://www.weer.nl/verwachting/nederland/son/189656/'}
// buttons.nunl = {width:12, icon: 'fa-newspaper-o', title: 'Nu.nl', url: 'http://www.nu.nl'}
// buttons.moon= {width:12, isimage:true, refreshimage:60000, image: 'moon'}
//Trash options
var trashcan = {}
var trashnames = {}
// var columns = {}
// columns[1] = {}
// columns[1]['blocks'] = [trashcan.hvc]
Phantom
Domoticz version: 4.11652
Post by Phantom »
I have updated to the latest Beta, but now the trashcan gives and undefined message.
Here is what i got in the config.js
var trashnames = {}
var trashcan = {}
trashcan.afvalapp = { key:'afvalapp', maxitems: 5, trashapp: 'meerlanden', width:12,zipcode:'xxxxxx', housenumber:'xx', country:'NL' }
columns[3] = {}
columns[3]['blocks'] = ['clock','sunrise','currentweather_big',buttons.buienradar,trashcan.afvalapp]
What am i doing wrong? it was working with the beta that i had running on from 4 days ago.
