dcliff1
Post by dcliff1 »
corbin wrote:try updating to the latest beta - I've just had a pull request accepted. I don't think it will fix your problem but just to get you on the latest release.
If that doesn't work, are you able to compile from source? I could then do some troubleshooting.
Hey Corbin, its been a while since using Visual Studio but managed to get this:
2017-01-04 10:40:43.478 XiaomiGateway: Worker started...
2017-01-04 10:40:43.561 handle_receive starting:
2017-01-04 10:40:43.561 {"cmd":"iam","port":"9898","sid":"f0b429cc10e6","model":"gateway","ip":"192.168.1.2"}
2017-01-04 10:40:43.569 handle_receive starting:
2017-01-04 10:40:43.569 {"cmd":"get_id_list_ack","sid":"f0b429cc10e6","token":"32hIpaRsG3aB2B4j","data":"[\"158d000125519e\",\"158d000106c4e5\",\"158d000110a8c1\",\"158d000113b1f8\",\"158d00010df3cc\",\"158d0001185a1c\",\"158d00010e495b\",\"158d00012931f4\",\"158d000117f5f4\",\"158d00012d59e0\",\"158d0001106a9b\",\"158d0001185329\",\"158d000119d543\",\"158d00011854ab\",\"158d00010df43b\",\"158d000106c57c\",\"158d0001185779\",\"158d000113b1f2\",\"158d000111810a\",\"158d000108358c\",\"158d000106c3af\",\"158d0001062348\",\"158d000119
2017-01-04 10:40:43.569 Error: XiaomiGateway: error in handle_receive
I have around 20 devices, mostly window sensors but also a temp sensor and a switch (clicker). I wonder if its seeing something that it doesn't recognize?
corbin
Post by corbin »
dcliff1 wrote: I have around 20 devices, mostly window sensors but also a temp sensor and a switch (clicker). I wonder if its seeing something that it doesn't recognize?
I set the receive buffer too small!, I've updated it to 1024 - https://github.com/corbinmunce/domoticz ... iGateway.h
Update this line:
enum { max_length = 512 };
to
enum { max_length = 1024 };
dcliff1
Post by dcliff1 »
corbin wrote: I set the receive buffer too small!, I've updated it to 1024 - https://github.com/corbinmunce/domoticz ... iGateway.h
Update this line:
to
Nice work mate! Its now reporting all the devices. Thanks heaps for that.. really appreciate the good work. Now to go play!
corbin
Post by corbin »
That is a lot of devices, you should have some fun with that!. Are you getting any more? I think I read the limit is around 30 per gateway and would be good to know for sure.
dcliff1
Post by dcliff1 »
Yep, I'm getting another PIR and a camera.. I've set it up as my main security system and it works well with the app, but has some limitations that Domoticz appears to overcome. I'll report back once I have a few more devices and its all working.
Thanks again, i'm very impressed.
deennoo
Post by deennoo »
@corbin
Finally got mine !
Pir + switch + temp are ok
Got a magic Cube too : nothing come on domoticz log.
Is there any trick to listen on udp port ? (without domoticz of course
http://domo-attitude.fr
macieiks
Post by macieiks »
Hello guys,
I read yesterday for the first time article about Xiaomi Mi Smart House Kit and today I would like to ask you few question before final buy order ;)
1. How about acknowledgment of message and sensor's range, does it using repeater option like we can use in Z-wave protocol? I am asking because I am using Home Easy door sensors and sometimes "change" state is not being sent to RFlink or RFXtrx (tested in both houses, with good range).
2. How about sensor's status lag which was reporting to the Domoticz after 1 min (I read about this few pages before)?
3. Do you have any "trust" link to ebay / ali to get the "supported version with developer mode" ? On 5th page I found information I need to get atleast 2016 version v2.0 / Aquara to get it working.
4. Just for curiousity (I know developers here are making great great great job, asking this I do not want to make any pressure on them :D ) what is the current implementation stage of Xiaomi sensors, which ones are working from that kit, are there any additional?
Thanks guys and one more time big beer for developers 8-)
RPI2 + RFLink + PiFace D2 + Aeon Z-Wave Gen5 + Foscams FI9821P&R2 + MySensors + UPS APC Back-UPS 950VA
RPI2 + RFXtrx433e + Foscams FI9821P + MySensors + UPS APC Back-UPS 950VA
RPIB+ + TP-Link MR3420 + Huawei E173 GarageDomoticz :)
ben53252642
Post by ben53252642 »
macieiks wrote:Hello guys,
Read here:
https://www.domoticz.com/wiki/Xiaomi_Gateway_(Aqara)
It uses Zigbee protocol, google to learn about it.
Last edited by ben53252642 on Wednesday 04 January 2017 21:04, edited 1 time in total.
Derik
Post by Derik »
deennoo
Post by deennoo »
Left to get compatibel :
- Magic Cube : playing with this remote is fun !
- LED on the gateway
- Be able to lunch some sound who are stored on the gateway
Need to be tested :
- 230v wall switch
- batterie wall switch
Not domoticz dependante :
- change chinese radio to all internet radio
- change chinese voice for a english one (or french or german, or spanish or dutch)
ben53252642
Is there any backup / restore functionality for the Xiaomi gateway, either cloud based (backs up settings and Zigbee) or manual?
Has anyone tested this?
Considering how many sensors I may invest in, backup / restore of some sort would be essential.
icibt
Post by icibt »
I have just built domoticz from your git fork (on Ubuntu 16.04) and I can see all of my devices, but when I click to turn on a power switch I get the error "Problem sending switch command"
From log:
2017-01-04 13:24:48.515  User: Admin initiated a switch command (6/Xiaomi Smart Plug/Off)
2017-01-04 13:24:48.515  010F8D72
2017-01-04 13:24:48.515  Error: WebServer PO exception occurred : 'Invalid argument'
Besides that, I was wondering why is there no Password or Port setting for the Linux build (and everything works) but there is one on Windows Beta build (where I am unable to find a single device - Windows 10 x64).
Anyways.... very good job on adding this to Domoticz... kudos :)
corbin
Post by corbin »
deennoo wrote:@corbin
Finally got mine !
Cool, hope it works well in your setup!
Try this program to listen on udp - https://packetsender.com/, maybe in combination with WireShark.
corbin
Post by corbin »
icibt wrote: Besides that, I was wondering why is there no Password or Port setting for the Linux build (and everything works) but there is one on Windows Beta build (where I am unable to find a single device - Windows 10 x64).
Password is mainly needed for controlling the smart plug, and is in the Linux version (they are the same web files) - you need to clear your browser cache to see the extra fields.
corbin
Post by corbin »
ben53252642 wrote:Is there any backup / restore functionality for the Xiaomi gateway, either cloud based (backs up settings and Zigbee) or manual?
The app is linked to my Xiaomi Mi account, but I don't have another android device to test a backup/restore with.
corbin
Post by corbin »
Read here:
To add to what is on the wiki -
The motion sensor will detect motion then go to sleep for 1 minute - there is no lag at all. This works very well for me and also helps with battery life.
Best to contact the gateway seller to confirm a v2.
ben53252642
Just ordered:
1x Xiaomi Gateway V2
6x Motion Sensors
2x Smart Push Buttons
1x Door Sensor
Total $177.18 AUD ($129 USD)... WOW! :D
deennoo
Post by deennoo »
Remeber one thing !
How does battery run?
Got an example that for a pir on a house of 4 personnes, place on a living room only live 1 mounth.
Second exemple a temp sensor run only 4 mounth on a place where temp/hum range got a lot of variation.
I already notice that temp sensor looks sending data only if value change.
ben53252642
deennoo, yep I read about that. I've decided to buy a bunch of the sensors so I can do some testing and will report back.
Other places I've read the battery should last 2 years so we will soon find out. :)
deennoo
Post by deennoo »
Main question is how many device a gateway can accepte ?
Got a big project for it.
