Re: Danfoss Living Connect LC03 with Aeon Z-Stick Gen5
Posted: Monday 11 July 2016 17:38
Open source Home Automation System
https://forum.domoticz.com/
2016-11-17 06:40:59.175 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:00.226 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:01.454 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:02.694 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:03.563 (P1) P1 Smart Meter (Elektriciteit)\
2016-11-17 06:41:03.924 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:05.164 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:06.394 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:07.634 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:08.864 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:10.094 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:11.334 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:12.567 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:13.663 (P1) P1 Smart Meter (Elektriciteit)\
2016-11-17 06:41:13.804 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:15.034 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 06:41:16.274 (Z-stick) Thermostat (Verwarming keuken - klein)\
2016-11-17 20:09:44.617 Detail, Node002, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x80, 0x03, 0x3a, 0x4a
2016-11-17 20:09:44.617 Info, Node002, Received Battery report from node 2: level=58
2016-11-17 20:09:44.617 Detail, Node002, Refreshed Value: old value=58, new value=58, type=byte
2016-11-17 20:09:44.617 Detail, Node002, Changes to this value are not verified
2016-11-17 20:09:44.617 Detail, Node002, Notification: ValueChanged
2016-11-17 20:09:44.638 Detail, Node002, Received: 0x01, 0x0c, 0x00, 0x04, 0x00, 0x02, 0x06, 0x43, 0x03, 0x01, 0x42, 0x08, 0x34, 0xcc
2016-11-17 20:09:44.638 Detail, Node002, Refreshed Value: old value=21.00, new value=21.00, type=decimal
2016-11-17 20:09:44.638 Detail, Node002, Changes to this value are not verified
2016-11-17 20:09:44.638 Info, Node002, Received thermostat setpoint report: Setpoint Heating 1 = 21.00C
2016-11-17 20:09:44.638 Detail, Node002, Notification: ValueChanged
2016-11-17 20:09:44.639 (Controller) Thermostat (Heating 1)
2016-11-17 20:09:44.659 Detail, Node002, Received: 0x01, 0x0a, 0x00, 0x04, 0x00, 0x02, 0x04, 0x46, 0x08, 0x00, 0x7f, 0xc6
2016-11-17 20:09:44.659 Info, Node002, Received climate control schedule override report:
2016-11-17 20:09:44.659 Info, Node002, Override State: None:
2016-11-17 20:09:44.659 Detail, Node002, Refreshed Value: old value=0, new value=0, type=list
2016-11-17 20:09:44.659 Detail, Node002, Changes to this value are not verified
2016-11-17 20:09:44.659 Detail, Node002, Refreshed Value: old value=127, new value=127, type=byte
2016-11-17 20:09:44.659 Detail, Node002, Notification: ValueChanged
2016-11-17 20:09:44.679 Detail, Node002, Received: 0x01, 0x08, 0x00, 0x04, 0x00, 0x02, 0x02, 0x84, 0x07, 0x70
2016-11-17 20:09:44.679 Info, Node002, Received Wakeup Notification from node 2
2016-11-17 20:09:44.679 Info, Node002, Node 2 has been marked as awake
2016-11-17 20:09:44.679 Detail, Node002, Queuing (WakeUp) WakeUpCmd_NoMoreInformation (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x84, 0x08, 0x25, 0xaa, 0xe6
2016-11-17 20:09:44.679 Detail, Node002, Notification: Notification - Node Awake
2016-11-17 20:09:44.679 Info, Node002, Sending (WakeUp) message (Callback ID=0xaa, Expected Reply=0x13) - WakeUpCmd_NoMoreInformation (Node=2): 0x01, 0x09, 0x00, 0x13, 0x02, 0x02, 0x84, 0x08, 0x25, 0xaa, 0xe6
2016-11-17 20:09:44.687 Detail, Node002, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2016-11-17 20:09:44.687 Detail, Node002, ZW_SEND_DATA delivered to Z-Wave stack
2016-11-17 20:09:44.705 Detail, Node002, Received: 0x01, 0x07, 0x00, 0x13, 0xaa, 0x00, 0x00, 0x02, 0x43
2016-11-17 20:09:44.705 Detail, Node002, ZW_SEND_DATA Request with callback ID 0xaa received (expected 0xaa)
2016-11-17 20:09:44.705 Info, Node002, Request RTT 26 Average Request RTT 26
2016-11-17 20:09:44.705 Info, Node002, Node 2 has been marked as asleep
2016-11-17 20:09:44.705 Detail, Expected callbackId was received
2016-11-17 20:09:44.705 Detail, Expected reply was received
2016-11-17 20:09:44.705 Detail, Message transaction complete
2016-11-17 20:09:44.705 Detail, Node002, Removing current message
2016-11-17 20:09:44.705 Detail, Node002, Notification: Notification - Node Asleep
2016-11-17 20:09:45.720 Detail, Node002, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x02, 0x03, 0x80, 0x03, 0x3a, 0x4a
2016-11-17 20:09:45.721 Detail,
Version 3.xxxx (December xth 2016)
- Implemented: Blockly/Lua Set SetPoint option
It turned out the unit was defective; I returned it and got a new one.L2v2P wrote: It seems that the LC-13 continuously sends its settings (setpoint for example) to the controller for some odd reason. Is the LC-13 malfunctioning?
Hmmm.... running current beta haven't seen that option, yet in Blockly. I'll have a look whether I can find it. Thanks for the hint!L2v2P wrote:It has been implemented in the current beta:
Source: https://github.com/domoticz/domoticz/bl ... istory.txtCode: Select all
Version 3.xxxx (December xth 2016) [...] - Implemented: Blockly/Lua Set SetPoint option [...]
