Idiots guide to Raspberry Pi Installation
TheBod
Re: Idiots guide to Raspberry Pi Installation
Post by TheBod »
By the way, how do I load the Domoticz screen on the Pi rather than through the pc?
Westcott
Post by Westcott »
jvdz wrote:
Westcott wrote: Thanks, but that also only has Windows setup files.
Just follow the Wiki i linked in one of the previous posts, which also has the info for the RPI image.
Jos
Thanks Jos.
Are you saying that
domoticz-raspberrypi-sdcard-3530.7z 2015-11-01 248.6 MB
is the one to use?
TheBod
Post by TheBod »
That is the one that I used. The image file is 2,078,277,632 bytes
TheBod
Post by TheBod »
Extract the zip file and there is a file in there called "domoticz-raspberrypi-sdcard-3530.img". This is what you need to copy to the SD Card
Westcott
Post by Westcott »
Thanks all!
Bit of a steep learning curve there, I'd never seen a .7z file before.
It's now written to the sd card, which got renamed 'Boot' by Win23DiskImager.
Where did most of the 2Gb image go, I can only see a few Mb-sized files on the sd?
jvdz
Domoticz version: 4.107
Post by jvdz »
TheBod wrote:By the way, how do I load the Domoticz screen on the Pi rather than through the pc?
I am using the RPI just as the server without any GUI type interface.
I connect to the CLI using Putty and am using SAMBA to access the data on the RPI with my Windows computer to allow for easy access to config files.
Jos
NietGiftig
Domoticz version: V3.6224
Post by NietGiftig »
Westcott wrote: Where did most of the 2Gb image go, I can only see a few Mb-sized files on the sd?
To a second partition (Linux format) on your card that you windows computer cannot see
RPI-2 + SSD / ESPEasy Sensors & Switches / Sonoff / RFLink / Action Switches / TP-Link switch / Node-Red / Reacticz
Micrit431
Post by Micrit431 »
Checkout my blog about creating a simple zwave home automation network on the PI www.ComputerTrail.net
Sent from my SM-T530 using Tapatalk
