Simple LMS LUA volume dimmer
simon_rb
- Target OS: -
Re: Simple LMS LUA volume dimmer
Thanks mate but unfortunately that completely breaks it all haha!
Whats happening is its sending an on command every 10 seconds and when the volume dimmer sends an on command it sets the radios to 0% as I don't think it understands 'On'. Don't know why its doing this... Any ideas? Both the LMS Lounge switch and dimmer/volume switch keep saying 'On even when something is playing.. But can't hear anything as volume keeps going to 0%. The log on both say 'On' every 10 secs. Obviously a loop somewhere.. And I can't turn them off, soon as your turn either switch off they turn back on.. Whoops..
Any ideas on that? Cheers
Update:- I lied, the LMS switch log says normal playing (nothing about on or off) The Dimmer/Volume is turned on every second.
simon_rb
- Target OS: -
Coming back to another issue is with HomeKit itself.. If I say set Kitchen Radio to 50% It always sends an On command followed for the 50% which works fine on the Kitchen Radio, log shows a 2 sec delay between the commands. When I say the same for the bedroom radio it sends the commands at the same time and even though the log shows the 50% as send second on the log the switch stays with the On value and the radio volume goes to 0%. Don't know what can be done to get around this.. I'll ask more in the specific HomeKit forum but thought I'd ask just incase
Nautilus
Hmm, so it thinks that the first condition is true whenever something changes, I guess? You could try changing it from:simon_rb wrote:Thanks mate but unfortunately that completely breaks it all haha!
devicechanged['Lounge Touch'] ~= 'Off' and devicechanged['Lounge Touch'] ~= 'Disconnected' thenCode: Select all
devicechanged['Lounge Touch'] ~= 'Off' and devicechanged['Lounge Touch'] ~= 'Disconnected' and devicechanged['Lounge Touch'] ~= nil thenWhen the volume dimmer switch is turned on, it always sets volume to 0, even if you manually set it first to something else? That's something else to think about then but maybe try to get this "On" loop first sorted...
simon_rb
- Target OS: -
Hi mate,
Changing the script to the above turns the LMS player On/Off/On/Off in a loop..
Banging my head against a brick wall with this one. Well beyond my limited skills.
Cheers
Cheers
if devicechanged['Lounge Touch'] ~= 'Off' and devicechanged['Lounge Touch'] ~= 'Disconnected' and devicechanged['Lounge Touch'] ~= nil then
commandArray['Lounge Touch V'] = 'On'
elseif devicechanged['Lounge Touch'] == 'Off' or devicechanged['Lounge Touch'] == 'Disconnected' then
commandArray['Lounge Touch V'] = 'Off'
return commandArray-
simon_rb
- Target OS: -
Got it half working with the above. Only probs is it updates every couple of seconds.. So the log on the volume/dimmer is On On On On On every couple of seconds or Off Off Off Off.
What Im trying to do is turn the radios on and off from the dimmer volume and then if I turn the player on via iPeng or locally for example it reflects this in the Volume/Dimmer. Then I can not even look at the LMS switch within Domoticz..
simon_rb
- Target OS: -
Could we modify this to also set the dimmer/volume switch (Lounge Touch V) to on and off from the json file therefore completely by passing the LMS switch completely?
json = (loadfile '/home/pi/domoticz/scripts/lua/json.lua')()
file = assert(io.popen('curl \'http://192.168.1.26:9000/jsonrpc.js\' --data-binary \'{"id":1,"method":"slim.request","params":["00:04:20:23:88:36",["status","-","1",""]]}\''))
raw = file:read('*all')
file:close()
deviceinfo = json:decode(raw)
volume = deviceinfo.result["mixer volume"]
powerstatus = deviceinfo.result.power
switchVolume = otherdevices_svalues['Lounge Touch V']
if tonumber(volume) ~= tonumber(switchVolume) and tonumber(powerstatus) == 1 then
commandArray['OpenURL'] = 'http://127.0.0.1:8080/json.htm?type=command¶m=switchlight&idx=265&switchcmd=Set%20Level&level='..volume
Nautilus
Hmm, does not make sense why it goes like that. Probably a long shot but have you confirmed this you've set this up as "device" script, not "All" (provided you use the internal script editor? If you store the scripts to /home/pi/domoticz/scripts/lua you need to make sure the naming convention is followed ("device" in the script name).simon_rb wrote:Got it half working with the above. Only probs is it updates every couple of seconds.. So the log on the volume/dimmer is On On On On On every couple of seconds or Off Off Off Off.
These are only things I can think of to explain the behavior. But yeah, stop the behavior you can add another condition:
if otherdevices['Lounge Touch V'] == 'Off' then
if otherdevices['Lounge Touch V'] == 'On' then
return commandArrayCode: Select all
if devicechanged['Lounge Touch'] == 'On' or devicechanged['Lounge Touch'] == Playing' then
Nautilus
Sure, if I understand correctly, you'd just addsimon_rb wrote:Could we modify this to also set the dimmer/volume switch (Lounge Touch V) to on and off from the json file therefore completely by passing the LMS switch completely?
file:close()
if tonumber(powerstatus) == 0 then
simon_rb
- Target OS: -
Cheers mate I shall take a look! Appreciate all your patience. I am learning too so thanks again buddy.
And the script was setup as a device script.
simon_rb
- Target OS: -
All I ideally want to do is have the one dimmer switch turn on and off the corresponding radio and the dimmer change the volume. The button also has feedback from the players so if the volume is changed on the player or player is turned on locally then thats reflected.
I'm getting lost in it all now lol.
Still testing and finding odd consistencies. Will post back when Ive had a proper test. Cheers bud
Edit:-
Working at the mo, although when the Lounge Touch V turns on its always 'On' first off which sets the volume to 0%. Is there a way of it ignoring the 'On' when updating the volume for the dimmer? So if its on it ignores it?
Edit:-
Nautilus
You can experiment the the other option to change the sValue state with json, the syntax is:
'http://127.0.0.1:8080//json.htm?type=co ... ='..volume
with nvalue=0 it will switch off.
simon_rb
- Target OS: -
Eh? LOLNautilus wrote:You can experiment the the other option to change the sValue state with json, the syntax is:
Its working with the script below and set the Lounge Touch V switch to turn on the radio directly when turning on.. Only thing I'd like to do is to get the script to ignore the 'On' when comparing the volume number because if it detects its 'On' with no value the radio volume goes to zero. Or if you set volume via Siri sometimes the Lounge Touch V goes to 'On' rather than a '%' so then again the volume goes to zero. Is there a way to do that? If there is then the script below is perfect and I can leave you in peace and move on to another project
Cheers Dude
file:close()
Nautilus
Yes, maybe I'm a bit lost as well on what do we actually have there now - as far as it comes to the scripts - and thus why the behavior is as you describesimon_rb wrote: Its working with the script below and set the Lounge Touch V switch to turn on the radio directly when turning on.. Only thing I'd like to do is to get the script to ignore the 'On' when comparing the volume number because if it detects its 'On' with no value the radio volume goes to zero. Or if you set volume via Siri sometimes the Lounge Touch V goes to 'On' rather than a '%' so then again the volume goes to zero. Is there a way to do that? If there is then the script below is perfect and I can leave you in peace and move on to another projectSo if the Lounge Touch V = On then update value from the radio so then it goes back to being a '%'. It seems to be if it detects 'On' it tries to send that to the radio.. Does that make sense? The script is running every minute which is fine for me..
I also do not understand why I saw fit to add that extra 'On' command there, the json above it should be enough. Maybe the optimal way would be (only the on / playing part here):
if tonumber(powerstatus) == 1 then
elseif otherdevices['Lounge Touch V'] == 'On' and tonumber(volume) ~= tonumber(switchVolume) then
endSo what are the scripts that you have for this whole setup now, this and...?
simon_rb
- Target OS: -
Brilliant, I am away from my house for a couple of hours lol. So turning on Lounge Touch V dimmer switch turns player on by sending when 'On Command' http://192.168.1.26:9000/status.html?p0 ... 2.168.1.93
Then turning the Lounge Touch V off it turns the player off (using one of the scripts below). It all appears to be working fine other than when the dimmer says On instead of % it makes the volume go to 0 on the player
Hope thats made it clear
The two scripts are:-
file:close()
DomDevice = 'Lounge Touch V';
if devicechanged[DomDevice] then
if(devicechanged[DomDevice]=='Off') then
commandArray['Lounge Touch']='Off';
commandArray['Lounge Touch']='On';
DomValue = otherdevices_svalues[DomDevice];
CalcValue = (DomValue);
commandArray['Lounge Touch']='Set Volume '..CalcValue;
Nautilus
Ok, I guess I'd try something like this to avoid the unnecessary 'On' commands:
With the way you have it now, any change in the "volume dimmer" other than "Off" will trigger both "On" and "Set Volume XXX" commands. And when they are to same device, I think only the second is executed anyway (or the first, not sure
) The above method will execute both. Although, if this part was working then maybe just leave it as it was. Anyhow, if player already is in some other state than "Off", then no need to send any additional "On"...
if devicechanged['Lounge Touch V'] then
targetvolume = otherdevices_svalues['Lounge Touch V']
if devicechanged['Lounge Touch V'] == 'Off' and otherdevices['Lounge Touch'] ~= 'Off' then
commandArray['Lounge Touch'] = 'Off'
elseif devicechanged['Lounge Touch V'] == 'On' and otherdevices['Lounge Touch'] == 'Off' then
commandArray[#commandArray+1]={['Lounge Touch'] = 'On'}
commandArray[#commandArray+1]={['Lounge Touch'] = 'Set Volume '..targetvolume}
commandArray['Lounge Touch'] = 'Set Volume '..targetvolume
end-
simon_rb
- Target OS: -
I'm getting confused with what scripts I'm changing now haha. Also sometimes you can't help the dimmer switch from saying 'On'. Is there a way for the script to realise its On and not %, maybe like if its a string then updated Lounge Touch V from the player to get the % back.. Or is that not an possible?
So what will my two scripts look like now? As you know I have a device one and a time one.. confused what should be in each now lol
I was trying to move away from the LMS (Lounge Touch) as a reference for power by using the power state from the json file. Does any of this make sense now because it doesn't to me lol
simon_rb
- Target OS: -
Getting a headache now LOL.
For some reason the scripts above are now updating the switch even when its off so every minute it gets sent an OFF command even though its off. Don't know whats changed since last night.. Damn this thing lol!
Nautilus
Well, the previous would be the device script controlling the state of the actual player switch. Something like this should work:
1. Device script
2. Time script:
I have to admit it is quite hard to follow what is going on there at your end
I think you need to invest a bit more on debugging and for example add print commands if you are unsure what part of the script is causing which action. I think though that you should pretty much have all the pieces together now to make this work. Just need to remember that the system is always doing what you are telling it to do, no more, no less. Even if some behavior in unexpected it is just result from thinking some part a bit wrong and then making the necessary corrections...
1. Device script
file:close()
if tonumber(powerstatus) == 1 and otherdevices['Lounge Touch V'] == 'Off' then
if tonumber(powerstatus) == 0 and otherdevices['Lounge Touch V'] ~= 'Off' then
simon_rb
- Target OS: -
You have the patience of a saint. This is working except for the On command. If you say set to 20% for example it will send an On command which can't be helped (HomeKit thing). But when the scripts tries to send 'On' the volume goes to zero. Is there a way to ignore the On and after the minute the script will get the current volume state from the player and everything is fine. Its hit and miss when you use Siri to set the volume sometimes the on command is sent first and sometimes second - its when its sent second it becomes a problem as it leaves the switch with 'On' then the script tries to send 'On' and the dimmer is set to 0. Maybe its more of a domoticz thing..
Thanks for all your help and patience!
simon_rb
- Target OS: -
I may have thought of a way around it.. Instead of getting the "Data" or "Status" from the JSON could we not grab the "Level" instead? As you can see the Data says "On" and the level is still showing 19... If we can grab the level rather than the Data from the JSON then we are completely sorted!
"ActTime" : 1478396660,
"ServerTime" : "2016-11-06 01:44:20",
"Sunrise" : "07:07",
"Sunset" : "16:23",
"result" : [
"AddjMulti" : 1.0,
"AddjMulti2" : 1.0,
"AddjValue" : 0.0,
"AddjValue2" : 0.0,
"BatteryLevel" : 255,
"CustomImage" : 0,
"Data" : "On",
"Description" : "",
"Favorite" : 0,
"HardwareID" : 3,
"HardwareName" : "Dummy",
"HardwareType" : "Dummy (Does nothing, use for virtual switches only)",
"HardwareTypeVal" : 15,
"HaveDimmer" : true,
"HaveGroupCmd" : true,
"HaveTimeout" : false,
"ID" : "00014158",
"Image" : "Light",
"IsSubDevice" : false,
"LastUpdate" : "2016-11-06 01:44:16",
"Level" : 19,
"LevelInt" : 19,
"MaxDimLevel" : 100,
"Name" : "Lounge Touch V",
"Notifications" : "false",
"PlanID" : "4",
"PlanIDs" : [ 4 ],
"Protected" : false,
"ShowNotifications" : true,
"SignalLevel" : "-",
"Status" : "On",
"StrParam1" : "aHR0cDovLzE5Mi4xNjguMS4yNjo5MDAwL3N0YXR1cy5odG1sP3AwPWJ1dHRvbiZwMT1wb3dlcl9vbiZwbGF5ZXI9MTkyLjE2OC4xLjkz",
"StrParam2" : "",
"SubType" : "Switch",
"SwitchType" : "Dimmer",
"SwitchTypeVal" : 7,
"Timers" : "false",
"Type" : "Light/Switch",
"TypeImg" : "dimmer",
"Unit" : 1,
"Used" : 1,
"UsedByCamera" : false,
"XOffset" : "0",
"YOffset" : "0",
"idx" : "265"
"status" : "OK",
"title" : "Devices"
