Page 2 of 2
Re: better hue integration?
Posted: Friday 08 January 2016 9:13
by prein
I am using the lua script posted above to check the hue status directly from the bridge. This is done every minute.
This is still a workaround. Can I be of some help somewhere?
Posted: Friday 08 January 2016 21:46
by florabora
I read this thread and love the workaround for status update and I want to take the challenge even one step further...
How would one be able to use coca switches to trigger a Hue and set a dim state?
Background; I would like to reuse my already mounted wireless 433mhz coca wall switches to trigger the Hue.
Currently they are triggering a coca dimmer built-in in the wall and I am using regular light bulbs right now.
I want to change them to Hue lamps
Posted: Saturday 09 January 2016 0:01
by JustME125
I use kaku (coco) stuff all the time in combination with HUE. Simply detect the coco events and trigger Hue lights or scenes with domoticz. Using dimmers would be harder I think (I don't have any dimmers so I can't test it). I control various lighting scenes with coco remote through domoticz.
Greets!
Verstuurd vanaf mijn HTC One_M8 met Tapatalk
Posted: Saturday 09 January 2016 11:05
by Kjakan
florabora wrote:I read this thread and love the workaround for status update and I want to take the challenge even one step further...
I use Nexa LYCT-705 remote to control my Hue scenes. Guessing this is similar to Kaku, Coco?
Don't have any dimmers so I don't know what kind of values you get from the dimmer, but if you get percentage like 10, 20, 30 and so on this could be done with a little work.
Take a look at my scripts below, maybe you can use something there.
Had an issue with my Hue hub and needed to reset the hub and lost all my scenes. To prevent that in the future I wanted to have the most common Hue scenes values stored in Domoticz.
Also use this common scenes from different scripts so I wanted the scenes values in one place. This is how I did it.
-- ~/domoticz/scripts/lua/functions.lua
local b = {}
-- Philips Hue bridge settings
local HueBridgeIP = "192.168.X.X"
local HueBridgeAPI = "XXXXXX"
-- Philips Hue light ID settings
	function b.PhilipsHueID(light_id)
			if light_id == "LivingRoom1" then light_id = 1 end
			if light_id == "LivingRoom2" then	light_id = 2 end
			if light_id == "LivingRoom3" then	light_id = 3 end
			if light_id == "LivingRoom4" then	light_id = 4 end
			if light_id == "WorkRoom1" then light_id = 5 end
			if light_id == "WorkRoom2" then light_id = 6 end
			if light_id == "WorkRoom3" then light_id = 7 end
			if light_id == "Hall1" then light_id = 8 end
			if light_id == "Kitchen" then light_id = 10 end
			if light_id == "AlertWorkRoom" then light_id = 13 end
			if light_id == "AlertLivingRoom" then light_id = 14 end
			return light_id
	--Function for scene values
	--light_id, 	state, bri, hue, 	sat, 	alert, colorType, colorTypeValue, effect
	function b.PhilipsHueScenes(room, scene)
			if (room == "Livingroom") then
					if (scene == "Max") then
							b.PhilipsHue("LivingRoom1", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
							b.PhilipsHue("LivingRoom2", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
							b.PhilipsHue("LivingRoom3", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
							b.PhilipsHue("LivingRoom4", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
					elseif (scene == "Relax") then
							b.PhilipsHue("LivingRoom1", "true", 159, 10376, 201, "none", "xy", "[0.5282,0.3963]", "none")
							b.PhilipsHue("LivingRoom2", "true", 159, 10376, 201, "none", "xy", "[0.5282,0.3963]", "none")
							b.PhilipsHue("LivingRoom3", "true", 159, 10376, 201, "none", "xy", "[0.5282,0.3963]", "none")
							b.PhilipsHue("LivingRoom4", "true", 159, 10376, 201, "none", "xy", "[0.5282,0.3963]", "none")
					elseif (scene == "MovieMode") then
							b.PhilipsHue("LivingRoom1", "true", 29, 12205, 250, "none", "xy", "[0.5455,0.4148]", "none")
							b.PhilipsHue("LivingRoom2", "true", 29, 12205, 250, "none", "xy", "[0.5455,0.4148]", "none")
							b.PhilipsHue("LivingRoom3", "true", 6, 5249, 115, "none", "xy", "[0.4891,0.3702]", "none")
							b.PhilipsHue("LivingRoom4", "true", 6, 5249, 115, "none", "xy", "[0.4891,0.3702]", "none")
							commandArray['Movie mode']='On'	--Movie mode switch
					elseif (scene == "Off") then
							b.PhilipsHue("LivingRoom1", "false")
							b.PhilipsHue("LivingRoom2", "false")
							b.PhilipsHue("LivingRoom3", "false")
							b.PhilipsHue("LivingRoom4", "false")
					--Turn off "Movie mode" if On and other than Movie mode selected
					if (otherdevices['Movie mode'] == 'On' and scene ~= "MovieMode") then
							commandArray['Movie mode']='Off'
							print("Turn Off Movie mode")
			elseif room == "Workroom" then
							b.PhilipsHue("WorkRoom1", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
							b.PhilipsHue("WorkRoom2", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
							b.PhilipsHue("WorkRoom3", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none")
							b.PhilipsHue("WorkRoom1", "true", 126, 14130, 179, "none", "xy", "[0.4845,0.4144]", "none")
							b.PhilipsHue("WorkRoom2", "true", 126, 14130, 179, "none", "xy", "[0.4845,0.4144]", "none")
							b.PhilipsHue("WorkRoom3", "false")
							b.PhilipsHue("WorkRoom1", "false")
							b.PhilipsHue("WorkRoom2", "false")
			elseif room == "Kitchen" then
							b.PhilipsHue("Kitchen", "true", 254, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none") -- Kitchen max
							b.PhilipsHue("Kitchen", "true", 130, 14920, 144, "none", "xy", "[0.4595,0.4105]", "none") -- Kitchen Relax
							b.PhilipsHue("Kitchen", "false")
	--Turn on/off Philips Hue Scene lights
	function b.PhilipsHue(light_id, state, bri, hue, sat, alert, colorType, colorTypeValue, effect)
		if state == "false" then
				os.execute ('curl -X PUT -d "{\\"on\\":false}" http://'..HueBridgeIP..'/api/'..HueBridgeAPI..'/lights/'..b.PhilipsHueID(light_id)..'/state')
		elseif state == "true" then
				os.execute ('curl -X PUT -d "{\\"on\\": '..state..', \\"bri\\": '..bri..', \\"hue\\": '..hue..', \\"sat\\": '..sat..', \\"alert\\": \\"'..alert..'\\",\\"'..colorType..'\\": '..colorTypeValue..', \\"effect\\": \\"'..effect..'\\"}" http://'..HueBridgeIP..'/api/'..HueBridgeAPI..'/lights/'..b.PhilipsHueID(light_id)..'/state')
-- Function for checking Philips Hue On/Off state
	function b.GetHueState(light_id)
			local json = require ("dkjson")
			local tmpfile = '/tmp/hueLight_'..b.PhilipsHueID(light_id)..'.txt'
			os.execute('curl -s http://'..HueBridgeIP..'/api/'..HueBridgeAPI..'/lights/'..b.PhilipsHueID(light_id)..' > '..tmpfile)
			local file = io.open(tmpfile)
			local content = file:read()
			local obj, pos, err = json.decode (content, 1, nil)
			if err then
				print ("Error:", err)
				hue_state=(obj.state.on)
			file:close()
			os.execute('rm -f '..tmpfile..'')
			--print (content)
			return (hue_state)
-- Function for Alarm lights
	function b.AlarmLights(status)
			if status == "RedAlert" then
					b.PhilipsHue("AlertWorkRoom", "true", 254, 65527, 253, "lselect", "xy", "[0.6736,0.3221]", "none")
					b.PhilipsHue("AlertLivingRoom", "true", 254, 65527, 253, "lselect", "xy", "[0.6736,0.3221]", "none")
					commandArray['Variable:AlarmLights-RedAlert']='1'
					print("AlarmLights: Red Alert")
		-- Timelapse alert. Only active between kl. 7:00 - 23:45
			elseif (status == "Timelapse" and uservariables["AlarmLights-RedAlert"] == 0 and minutesnow >= 420 and minutesnow <= 1425) then
					b.PhilipsHue("AlertWorkRoom", "true", 1, 44554, 224, "select", "hs", "[0.2175,0.1298]", "none")
					b.PhilipsHue("AlertLivingRoom", "true", 1, 44554, 224, "select", "hs", "[0.2175,0.1298]", "none")
					print("AlarmLights: Timelapse")
			elseif status == "Off" then
					b.PhilipsHue("AlertWorkRoom", "false")
					b.PhilipsHue("AlertLivingRoom", "false")
					print("AlertLights: Turned off")
							if uservariables["AlarmLights-RedAlert"] == 1 then
									commandArray['Variable:AlarmLights-RedAlert']='0'
-- Function for time difference
	function b.timedifference(s)
		year = string.sub(s, 1, 4)
		month = string.sub(s, 6, 7)
		day = string.sub(s, 9, 10)
		hour = string.sub(s, 12, 13)
		t1 = os.time()
		return difference
return b
-- ~/domoticz/scripts/lua/script_device_Lights.lua
package.path = package.path .. ';' .. '/home/pi/domoticz/scripts/lua/?.lua'
b = require('functions')
	-- Living room: On (MAX)
	if (devicechanged['$SceneLivingRoom_1-1']  == 'On') then	-- Nexa LYCT-705 remote
			b.PhilipsHueScenes("Livingroom", "Max")	--Set scene "Max" in living room
			print('Set scene "Max" in living room')
	-- living room: Off
	if (devicechanged['$SceneLivingRoom_1-1']  == 'Off') then
			b.PhilipsHueScenes("Livingroom", "Off")
			print('Turn Off lights in living room')
	-- Living room: Relax
	if (devicechanged['$SceneLivingRoom_1-2']  == 'On') then
			b.PhilipsHueScenes("Livingroom", "Relax")
			print('Set scene "Relax" in living room')
	-- Living room: Movie mode
	if (devicechanged['$SceneLivingRoom_1-2']  == 'Off') then
			b.PhilipsHueScenes("Livingroom", "MovieMode")
					if (otherdevices['IsDark'] == 'On') and (otherdevices['Night mode'] == 'Off') then
							b.PhilipsHueScenes("Kitchen", "Relax")
			print("Turn On Movie mode")
	-- Workroom: Max
	if (devicechanged['$SceneWorkroom_1-1']  == 'On') then
			b.PhilipsHueScenes("Workroom", "Max")
			print('Set scene "Max" in workroom')
		-- Workroom: Off
	if (devicechanged['$SceneWorkroom_1-1']  == 'Off') then
			b.PhilipsHueScenes("Workroom", "Off")
			print('Turn Off lights in workroom')
	-- Workroom: Relax
	if (devicechanged['$SceneWorkroom_1-2']  == 'On') then
			b.PhilipsHueScenes("Workroom", "Relax")
			print('Set scene "Relax" in workroom')
Posted: Saturday 09 January 2016 12:51
by florabora
Thought about it some more and maybe it's possible to work with user var in domoticz and some kind of a foreach statement in a script in order to change between a couple of presets?
For instance.
Default = 0
Switch on = var+1 = preset hue #1
Switch on = var+1 = preset hue #2
Switch on = var+1 = preset hue #3
Switch off = var-1 = preset hue #2
Switch off = var-1 = preset hue #1
Switch off = var-1 = preset hue #0
Would that be possible you think?
Posted: Saturday 09 January 2016 16:49
by JustME125
I did something like that in the past with a coco wall switch. Kept a variable with the number of the active scene and used the wall switch to do the +/-1 trick. All scenes also updated this variable in case I changed a scene through domoticz to keep track of the active scene. I abandoned that solution when my pi crashed and I didn't have a backup.
Posted: Friday 05 February 2016 10:24
by MatthijsPH
For anyone who is interested my script to check the status of all hue lights by looping until no more lights are found.
-- script to check Philips Hue light status (on/off)
-- m.hagenaars
-- feb. 2016
-- you'll need to install socket library & dkjson, more info can be found here:
-- http://www.domoticz.com/wiki/Upload_energy_data_to_PVoutput#Install_socket_library
-- http://dkolf.de/src/dkjson-lua.fsl/home
-- both need to end up in /usr/local/lib/lua/5.2
-- this time based script wil use the HUE api to check the current status of your lights as reported by the HUE bridge
-- the script starts with light #1 and checks if the status reported by your bridge corresponds with the status in Domoticz
-- if HUE state is not equal to Domoticz state then the script will correct the status in Domoticz
-- the script will keep looping until there are no more lights to check and will then stop
-- in order for the script to work it is important that the names of each light are exactly equal in both your bridge & domoticz
-- I suppose you know the names of the HUE switches in Domoticz, you can check the names in your bridge with the HUE app
-- more info on Philips HUE api and how to get/change your username can be found here:
-- http://www.developers.meethue.com/documentation/getting-started
-- configure Hue Bridge
local hueBridgeIP = 'your IP here'
local hueBridgeAPI = 'your username here'
-- do not change beyond this line
-- this part will get the Hue status
function getHueLight(id)
   local http = require('socket.http')
   local ltn12 = require('ltn12')
   local json = require('dkjson')
   t = {}
   local url = string.format("http://%s/api/%s/lights/%s", hueBridgeIP, hueBridgeAPI, id)
   b, c, h = http.request{url=url, sink = ltn12.sink.table(t), method='GET'}
   huestring = tostring(table.concat(t))
   local hue, pos, err = json.decode(huestring, 1, nil)
   if (hue.name) then
      hue_name = (hue.name)
      hue_state = (hue.state.on)
      stop = true
   return hue_name, hue_state, stop
-- now check Hue state & correct Domoticz if needed
i = 1
repeat
    local hue = getHueLight(i)
    if hue_state == true and otherdevices[hue_name] == 'Off' then
       commandArray[hue_name] = 'On'
	   print(string.format("Status %s corrigeren", hue_name))
    elseif hue_state == false and otherdevices[hue_name] ~= 'Off' then
	   commandArray[hue_name] = 'Off'
    i = i + 1
until(stop)
Posted: Friday 26 February 2016 10:15
by arjanw
The latest beta should now trigger on/off actions if Hue lights are switched outside of Domoticz.
Posted: Friday 26 February 2016 11:13
by wmn79
That would be great! I'll try and see if I can test it this weekend. Will this also update the logs off the switches themselves when lights are switched outside of domoticz? Really appreciate your effort.
Posted: Friday 26 February 2016 14:20
by arjanw
Yes, the logs should also be updated.
Posted: Thursday 14 April 2016 22:14
by tcorneillie
can something like this be done for Niko Home Control lights too? I'm new to Lua, so i need some help...
thanks in advance
Kind regs,
Tom
