Page 2 of 37
Re: ELV Max! Heating control system
Posted: Monday 20 January 2014 23:01
by gdekeijzer
- is the elv cube in control of the whole installation and does he automatically adjust the room temperature for a room when you want it to, or should one manually set the valves positions using max buddy and close them when some thermometer has reached the setpoint? Maybe said in an other way.. Do I change temperature set points or valve positions?
Hi, this depends on the system you use. Most installations in NL use a Boiler (english for CV-ketel) that uses an OpenTherm protocol between the livingroom thermostate and the boiler.
Its not just on/off but it sends how much the boiler must 'burn'.
The ELV!Max system does however can control your boiler if you turn it into an on/off boiler.
The Cube helps you manage all using the local valves. You can program a room which consist of one or more valves (and window sensors; window open -> temp=12C).
The valve is just open or close when temperature is reached.
- if the valves only report back their room temperatures if their valve positions are changed, how does the cube know the room temperature without a thermostat?
The valves report temperature back. If you use MAX!Buddy you can actually see the current temperature.
- when using the valves in combination with domoticz/max buddy, are the "+" editions of any use? Do they report back their temperature more often (since they are a valve combined with a thermostat?)
I'm not familiar with the + editions. I thought that they can be programmed without a cube (stand alone)
- if I have a room with multiple radiators. Should I combine these with a thermostat (using simple valves) and set the room temperature on the thermostat instead of the actual valves?
As stated above, multiple valves can be combined in one room. Mostly this i user in a livingroom where you can buy the extra room-thermostate (central console)
Hope you have some more info now.
Posted: Monday 20 January 2014 23:03
by maxtrash
my 2cts: at the same time I was typing this gdekeijzer also replied I see
with the ELV max cube software is included, and you can use the local software to setup a weekly schedule. There's also a webpage that allows remote access from outside the house. I did a quick google search and found this page (http://www.max-portal.elv.de/index.html#) and they mention demo account User: EcoHouseComfort
Pass: test1 there (http://ecohousecomfort.com/frequently-asked-questions)
Everything is done with setpoint temperatures in the software. And you don't need max buddy at all, it's just a independent program with some extra functionality (e.g. scripting, displaying the valve position)
Both the radiators and the thermostats have temperature sensors embedded. So the radiator will try to reach the setpoint temperature on it's own. If one or more radiators are in a room with a thermostat, temperature as measured by the thermostat will be used (which is more precise, since it's not as close to the radiator). If you have 3 devices in one room (e.g. 2 radiators and 1 thermostat) if you set the temperature on any of them it is replicated on the other ones.
You don't need the + versions, they have extra functionality for installations without a cube.
In the living room I think you should keep your regular central heating thermostat. Keep the radiators open there. Using the ELV radiators it's possible to heat the other rooms in a much better way than with these simple radiator thermostats (with numbers 1 to 5). And for instance if I want to watch a film in my attic, I can start heating the room while still being downstairs. And I use it to heat the bathrooms in the morning and not the whole day.
Controlling the central heating with a kaku switch is something you can add later, but as long as the living room keeps warm water flowing through the pipes the ELV-controlled rooms it might work reasonably well already.
Posted: Monday 20 January 2014 23:08
by maxtrash
it's a bit more sophisticated. It will open more or less depending on the difference between the measured and setpoint temperature.
Posted: Monday 20 January 2014 23:31
by gdekeijzer
A, that declares that i get readings in Domoticz stating the valve is op 93%
Thanx for that
Posted: Tuesday 21 January 2014 19:47
by Scheffie
Thank you for your information. I orderded a radiator valve, a cube and a "zwischenstecker".
I think I will modify the "zwischenstecker" to be able to replace my current room thermostat (24v) (or in the beginning connect it parallel). Then I'll activate the device when the cube opens the valves for more than xx%. I'll switch it of again when they are closed or almost closed. Since I always have some radiator valve (manual valve) fully open the CV-ketel/boiler can use that radiator to cool down preventing an overheated installation.
What I've seen on this forum it should be possible to set some fixed temperatures with domoticz using multiple dummy switches for 1 radiator.
Using these switches it should be possible to create some logic:
1st On/off switch: on / off (17C)
2nd on/off switch: on (19C) / off (21C)
So when switch 1 is off it'll be 17C
Is switch 1 on and switch 2 on: 19C
Is switch 1 on and switch 2 off: 21C
With this I should be able to schedule my room temperature i think.
Greets
Bart
Posted: Monday 17 February 2014 22:22
by Zap
I have installed maxbuddy/maxstat on the pi as described in the link earlier. After activating the Domoticz script, two new devices appeared in devives list but only one is showing a actual value, I think it is the radiator temp. The other temp/hum. device is showing 0,;0;0.
Can someone give me a hint ?
btw. maxstat is showing all data in browser
Posted: Sunday 09 March 2014 19:25
by Skippiemanz
Can someone make a WiKi on how to install Maxbuddy on the Pi?
Or just a short guide? to point me in the right direction
I cant get out of the steps mentioned in the links and get several errors.
Thanks in advance
Posted: Thursday 13 March 2014 13:44
by Skippiemanz
No one here wo could help me out?
Posted: Thursday 13 March 2014 16:53
by maxtrash
Skippiemanz wrote:No one here wo could help me out?
which errors do you get?
Posted: Thursday 13 March 2014 19:38
by Skippiemanz
I followed the instructions from: http://bugs.maxbuddy.de/attachments/dow ... 3_1310.txt
But when installing the myphpadmin i goes wrong.
but do i really need al that just to make the maxbuddy work?
Posted: Monday 12 May 2014 18:04
by TinMan
Thanks MaxTrash for starting this thread and providing your script. Yay! It works :D
It was a long process installing MaxBuddy on the Raspberry and I had a few issues as Max have changed their version to 1.4.1, but I now have SetpointTemp, Valve position and current temp showing in Domoticz.
For the benefit of anyone else trying to do the install on Raspberry here are a few extra pointers.
1) As suggested I used the instructions by Nasdero to install MaxBuddy. It is in German but Google Translate does a good enough job if you need English. I started from the '### Install Java' line as the first steps are already done when installing Domoticz. You need to copy/paste instructions from the original language as google messes with the commands.
2) Stop nginx webserver before you begin else apache will not start as it can't bind to port 80 (or change the port). Domoticz doesn't use nginx.
sudo service nginx stop
and prevent it restarting on reboot.
sudo update-rc.d -f nginx disable
3) When you get to this part of the instructions:
# # I'm using the version 9:16
cd /usr/local/maxbuddy/
sudo wget http://download.maxbuddy.de/MAXBuddy-r9.16-linux.tgz
sudo tar xzvfp MAXBuddy-r9.16-linux.tgz
sudo rm MAXBuddy-r9.16-linux.tgz
Replace with this as the file name (version) has changed
# # I'm using the version 9.16.2
sudo wget http://download.maxbuddy.de/MAXBuddy-r9 ... nux.tar.gz
sudo tar xzvfp MAXBuddy-r9.16.2-linux.tar.gz
sudo rm MAXBuddy-r9.16.2-linux.tar.gz
4) When you do this:
## Start dan Maxbuddy once, then it creates the files in the home directory of Pi
./headless.sh
You will find you get a lot of errors, as the files it's trying to download are no longer on the Max site. You
need to do this:
a) be sure to run ./headless.sh as it creates directories you need
b) navigate to home/pi/.maxbuddy/ext-libs and edit links-916.xml and replace the content with this
<linklist>
<set checksums="https://dl.dropboxusercontent.com/u/578 ... digest.txt">
<ext>https://dl.dropboxusercontent.com/u/578 ... 1.jar</ext>
</set>
</linklist>
save it and make it read only
c) under the ext-libs directory create directories u/57840205/Libs1-4-1
d) manually download the three files in the xml above and put them in the Libs1-4-1 directory (it ought to do this itself on first run but fails checksum)
e) run ./headless.sh and it should find the cube
5) Only one program can connect to the cube at any time. If you have maxbuddy already running on windows, be sure to exit properly as it will continue to run minimised by default. I wasted a fair amount of time trying to work out why Raspberry got stuck at [DEBUG]: controller connect... when running headless.sh
6) To add the MaxTrash script, create a file in home/pi/.maxbuddy/scripts called Domoticz.js and paste in the script
7) In Domoticz I found the set point temperature was not coming through. I had to make a small change to MaxTrash script:
SetPointTemperature = SetPointTemperature.substring(0, SetPointTemperature.indexOf('º')).replace(',','.');
becomes
SetPointTemperature = SetPointTemperature.substring(0, SetPointTemperature.indexOf(',')+2).replace(',','.');
8) The valve and thermometer appear as RUBiCSON sub type in domoticz
Hope it helps
Posted: Wednesday 14 May 2014 14:56
by Skippiemanz
Tinman thanks!
With the help of your post i've got it sorted out.
I've tried to make a tutorial/WikI
Maybe you can walk through it to check if everything is ok and then someone can make a wiki off it?
Install Max on rpi
Install Java
sudo apt-get install openjdk-7-jre-headless
Install Apache (Webserver), MySQL (Databaseserver), PhpMyAdmin and PHP.
sudo apt-get install apache2 libapache2-mod-php5 zendframework php5-mysql mysql-server phpmyadmin php5-xcache
- Enter a password for the >>root<< user(needs to be confirmed)
- “apache2” Leave as selected and press enter
- “Configure the database for phpmyadmin with dbconfig-common?” press enter
- Enter a password for the database admin(Suggested to use the same password as for the root user)
- Enter a password for phpmyadmin(Needs to be confirmed)(Suggested to use the same password as for the root user)
Now test the webserver by entering your Rpi adress in a web browser(example http://192.168.1.100), It should display a page that says “It Works”
Also test the PhpMyAdmin by entering your Rpi adress in a web browser(example http://192.168.1.100/phpmyadmin/), It should display a page that says “Welcome to My PHP Admin”(In fact in my case it didn’t show up but was still able to proceed)
Now set the database for Maxstats(in this example I’ve used the password “raspberry” for the root user)
sudo mysql --user=root --password=raspberry
CREATE USER 'maxstats'@'localhost';
SET PASSWORD FOR 'maxstats'@'localhost' = raspberry;
GRANT ALL ON maxstats.* TO 'maxstats'@'localhost' WITH GRANT OPTION;
CREATE DATABASE maxstats;
exit
Install Maxstats
sudo mkdir /home/pi/maxstats
cd maxstats/
sudo wget https://github.com/ifavo/MaxStats/archive/master.zip
sudo unzip master.zip
sudo mv MaxStats-master/* ./
sudo rm master.zip MaxStats-master/ -R
sudo chown www-data:www-data /home/pi/maxstats/public/ -R
sudo nano /home/pi/maxstats/application/configs/application.ini
Change the following rules:
#5: "UTC" => "Europe/Berlin"
#27: resources.db.params.username = ""  => resources.db.params.username = "maxstats"
#28: resources.db.params.password = "" => resources.db.params.password = "raspberry"
#29: resources.db.params.dbname = "" =>  resources.db.params.dbname = "maxstats"
Save and exit using CTRL-O, Enter, CTRL-X
sudo nano /etc/apache2/sites-available/default
Change the folowing rules:
#4: DocumentRoot /var/www =>  DocumentRoot /home/pi/maxstats/public
#7: AllowOverride None => AllowOverride FileInfo
#9: <Directory /var/www/> =>  <Directory /home/pi/maxstats/public>
#10: Options Indexes FollowSymLinks MultiViews =>  Options Indexes FollowSymLinks
#11: AllowOverride None => AllowOverride Fileinfo
Your file should like this:
## <VirtualHost *:80>
##         ServerAdmin webmaster@localhost
##         DocumentRoot /home/pi/maxstats/public
##         <Directory />
##                 Options FollowSymLinks
##                 AllowOverride FileInfo
##         </Directory>
##         <Directory /home/pi/maxstats/public>
##                 Options Indexes FollowSymLinks
##                 AllowOverride Fileinfo
##                 Order allow,deny
##                 allow from all
##         </Directory>
## The rest wil stay the same!
sudo a2enmod rewrite
sudo cp /etc/apache2/apache2.conf /etc/apache2/apache2.conf.org
sudo nano /etc/apache2/apache2.conf
Move all the way to the bottom and add the following line:
ServerName localhost
Without these changes you will see the following
sudo /etc/init.d/apache2 restart
## [....] Restarting web server: apache2apache2: Could not reliably determine the server's
## fully qualified domain name, using 127.0.1.1 for ServerName
After the changes you will see:
##"[ ok ] Restarting web server: apache2 ... waiting ."
Now test the maxstats by entering your Rpi adress in a web browser(example http://192.168.1.100), It should display a page that says “Cube(s)” and a button that says Load Cube
Now its time to install and configure Maxbuddy, we will use it without the userinterface and run it in the background(headless)
sudo mkdir maxbuddy
cd home/pi/maxbuddy/
sudo wget http://download.maxbuddy.de/MAXBuddy-r9.16.2-linux.tar.gz
Start Maxbuddy once, then it creates the files in the home directory of Pi
./headless.sh
You will find you get a lot of errors, as the files it's trying to download are no longer on the Max site. You need to do this:
<linklist>
<set checksums="https://dl.dropboxusercontent.com/u/57840205/Libs1-4-1/digest.txt">
<ext>https://dl.dropboxusercontent.com/u/57840205/Libs1-4-1/MaxEssentialsBackend-1.4.1.jar</ext>
<ext>https://dl.dropboxusercontent.com/u/57840205/Libs1-4-1/MaxLocalBackend-1.4.1.jar</ext>
</set>
</linklist>
Save it and make it read only
chmod 0444 *.xml
NOTE: Only one program can connect to the cube at any time. If you have maxbuddy already running on windows, be sure to exit properly as it will continue to run minimised by default. I wasted a fair amount of time trying to work out why Raspberry got stuck at [DEBUG]: controller connect... when running headless.sh
Add the MaxTrash script, create a file in home/pi/.maxbuddy/scripts called Domoticz.js and paste in the script and change the required parameters(ip/port)
    Domoticz.js
    2013-11-03
   script for Max!Buddy
   How to install: put it in the script-folder and enable the script in the Max!Buddy settings
   Public Domain.
    NO WARRANTY EXPRESSED OR IMPLIED. USE AT YOUR OWN RISK.
function getInfo(info) {
   info.name = 'Domoticz';
   info.description = 'Connector for Domoticz';
   info.interval = 30;
function run() {
   var toString = function(text) {
      return text + '';
   var h2d = function(h) {
      return parseInt(h,16);
   var   HID = '3',                                  //Hardware ID of dummy in Domoticz
      IP = '192.168.1.100',                         //IP address of Domoticz
      Port = '8080',                              //Port of Domoticz
      // for types please refer to http://sourceforge.net/p/domoticz/code/HEAD/tree/domoticz/main/RFXtrx.h
      // for Maxbuddy API please refer to http://bugs.maxbuddy.de/projects/maxbuddy/wiki/Buddy_API
      WMT_dtype1 = '80', WMT_subtype1 = '9',             //WallMountedThermostat Domoticz types for current temperature (temperature , RUBiCSON)
      HT_dtype1 = h2d('0x50'), HT_subtype1 = '9',             //HeatingThermostat Domoticz types for current temperature (temperature , RUBiCSON)
      HT_dtype2 = h2d('0x52'), HT_subtype2 = h2d('0xA'),          //HeatingThermostat Domoticz types for current temperature (temperature , RUBiCSON)
      SC_dtype1 = h2d('0x20'), SC_subtype1 = '01',               //ShutterContact
      einde;
   var startTime = new Date().getTime(),
      URL = java.net.URL,
      IOUtils = org.apache.commons.io.IOUtils,
      DataOutputStream = java.io.DataOutputStream,
      JSON = {},
      roomIDs = buddy.getRoomIDs(),
      SerialNumber, DomoticzDid, Temperature, SetPointTemperature, Valve, WindowOpen;
   var OpenUrl = function(did, dunit, dtype, dsubtype, nvalue, svalue, response) {
      var URLString;
      URLString = 'http://'+IP+':'+Port+ '/json.htm?type=command&param=udevice&hid='+HID+'&did='+did+'&dunit='+dunit+'&dsubtype='+dsubtype+
                     '&dtype='+dtype+'&nvalue='+nvalue+'&svalue='+svalue;
      debug( '   '+URLString);
      var url = new URL(   URLString),
         outputStream,
         out;
      connection = url.openConnection();
      connection.setRequestMethod('POST');
      connection.setReadTimeout(5000);
      connection.setDoOutput(true);
      connection.setRequestProperty('Content-type', 'application/json');
      try {
         outputStream = connection.getOutputStream();
         out = new DataOutputStream(outputStream);
         out.writeBytes(response);
         out.flush();
         out.close();
         connection.connect();
         connection.getInputStream();
      catch(err) {
         debug(new Error('Could not connect to server: '));
         debug(err);
   debug('Start run()');
   for(var i=0; i < roomIDs.length; i++) {
      var room = buddy.getRoom(roomIDs[i]),
         mode = buddy.getRoomMode(roomIDs[i]),
         _devices = room.getDevices(),
         devices = [];
      debug('Room  = '+room.getName());
      debug('Mode  = '+mode.getMode());
      //debug('Param = '+mode.getParameters());
      for(var j=0; j < _devices.size(); j++) {
         var device = _devices.get(j),
            state = device.getState();
         debug('   Device = '+device.getName());
         SerialNumber = device.getSerialNumber();
         debug('   SerialNumber = '+SerialNumber);
         debug('');
         if(device.getDeviceType() == 'WallMountedThermostat') {
            DomoticzDid = toString(h2d(SerialNumber.substring(3)));
            Temperature = toString(state.getTemperature());
            debug('   Temperature = '+Temperature);
            OpenUrl(DomoticzDid, '1', WMT_dtype1, WMT_subtype1, '0',Temperature);
            debug('');
         if(device.getDeviceType() == 'HeatingThermostat') {
            // chop off first 3 characters (e.g. JEQ or KEQ). Then convert to decimal because domoticz will do dec to hex conversion
            // this way the ID in domoticz is the same as the SerialNumber
            Temperature = toString(state.getMeasuredTemperature());
            SetPointTemperature = toString(state.getSetPointTemperature());
            debug('   SetPointTmp = '+SetPointTemperature);
            Valve = toString(state.getValvePosition());
            debug('   Valve       = '+Valve);
            OpenUrl(DomoticzDid, '1', HT_dtype1, HT_subtype1, '0', Temperature);
            OpenUrl(DomoticzDid, '2', HT_dtype2, HT_subtype2, '0', SetPointTemperature+';'+Valve+';0');  // HumidityStatus = 0 ???
            debug('');
         if(device.getDeviceType() == 'ShutterContact') {
            DomoticzDid = toString(SerialNumber.substring(3));
            if (state.isWindowOpen() == true) {
               WindowOpen = 2;
            else {
               WindowOpen = 0;
            debug('   Window open = '+ WindowOpen);
            OpenUrl(DomoticzDid, '1', SC_dtype1, SC_subtype1, WindowOpen, '');
When added check the maxbuddy setting’s and adjust it to the sample below with your own parameters
#MAX!Buddy Settings File
#Wed May 14 13:44:54 CEST 2014
settings.version=1
connection.reconnect=55
script.enabled.Domoticz.js=true
connect.lastip=192.168.1.100
connect.lastport=62910
connection.disconnect=1
Now lets make Maxbuddy start @reboot/startup(NOTE: Do not use Sudo here!)
crontab -e
@reboot cd /home/pi/maxbuddy/ && screen -d -m -S max /home/pi/maxbuddy/headless.sh
Now restart the Rpi
sudo reboot
Now in your domoticz devices tab the The valve and thermometer appear as RUBiCSON sub type in domoticz
Posted: Monday 15 September 2014 20:52
by Derik
Is this hardware working without problems in Domoticz?
Or is this still in Beta/Alpha?
Posted: Saturday 20 September 2014 13:55
by Skippiemanz
All sensors are shown in domoticz but there is not yet a set temperature device.
Posted: Monday 01 December 2014 12:57
by ThaBoo
Hi Skippiemanz,
I followed your installation guide with 100% success (7 radiator thermostats and 1 wall thermostat being logged now the winter starts) so you can consider it as verified.
Thanx a lot!
Posted: Monday 01 December 2014 20:04
by Skippiemanz
Nice to hear! I personally don't have a wall thermostat. Are you able to make use of the setpoint feature?
Posted: Monday 01 December 2014 21:27
by Derik
It seems like a nice system.
But still some questions:
Can I use the system without the thermostat ELV?
How do I turn my CV on and off?
Can I attempt to use my sulfuric sensors to control an ELV?
It works flawlessly, or I sit sometimes in the cold by taps not listen?
Some pictures of the interface, etc etc?
Posted: Monday 19 January 2015 18:34
by Derik
No one ..
Some info please...
I wil try this... Only ....................
Posted: Tuesday 24 February 2015 10:18
by l0gic
Hi guys,
I've been looking for a heating control system to better control / zone my house and came across this.
I have a friend who uses the older FS20 system units all controlled by Fhem.
Fhem could replace the Domoticz system but looks too unwieldy for my requirements, especially as I have Domoticz set up and running very reliably for lighting control.
So, I'll probably go with the Max! set up using the cube and Max Buddy and use MaxTrash's script to populate the units in Domoticz.
Question;
looking at the script from MaxTrash (great work by the way) it seems to be 'one way' cube -> Domoticz.
Max Buddy does have commands to actively change the cube configuration, for example
buddy.setRoomMode (roomid, " MANUAL " , new Array ( " OFF " ));
buddy.setRoomMode (roomid, " MANUAL " , new Array ( " ON " ));
buddy.setRoomMode (roomid, " MANUAL " , new Array ( " 25.5 " ));
buddy.setRoomMode (roomid, " AUTO_TEMPERATURE " , new Array ( " OFF " ));
buddy.setRoomMode (roomid, " AUTO_TEMPERATURE " , new Array ( " 25.5 " ));
So I'm guessing that it could be made two way, for example person detected in room (PIR perhaps) turn on heating for that room.
Has anyone looked at this so far?
I'm not clear yet how you would get Domoticz to pass the command back to Max Buddy. Does it use JSON? Can it be used? I'm not sure, still working my way around the Max Buddy site.
Perhaps drop a file into the Max Buddy directory with latest command(s) and have a script which parses this and passes it into Max Buddy?
If anyone is ahead of me with this could you let me know. It will save some abortive work on my behalf.
I don't plan to pick up the Max! system until the summer as I will not make any changes to my heating system until the heating season is over.
Thoughts welcome!
All the best
Kevin
Posted: Sunday 01 March 2015 1:55
by Skippiemanz
Hi All,
With the new movements around the smartware valves i give this another go after my fresh SD install.
First off all i've cleaned up the needed parts.
Here is the install Wiki
sudo mkdir maxbuddy
./headless.sh
You will find you get a lot of errors, as the files it's trying to download are no longer on the Max site. Heres how we gonna fix that
cd home/pi/.maxbuddy/ext-libs
Where gonna edit the content of links-916.xml
nano links-916.xml
Replace content with following:
<linklist>
</set>
</linklist>
chmod 0444 *.xml
Next we need to create some new directories:
mkdir u
cd u
mkdir 57840205
cd 57840205
mddir Libs1-4-1
cd Libs1-4-1
Next manually download the three files in the xml above and put them in the Libs1-4-1 directory (it ought to do this itself on first run but fails checksum)
wget https://dl.dropboxusercontent.com/u/57840205/Libs1-4-1/digest.txt
wget https://dl.dropboxusercontent.com/u/57840205/Libs1-4-1/MaxEssentialsBackend-1.4.1.jar
wgethttps://dl.dropboxusercontent.com/u/57840205/Libs1-4-1/MaxLocalBackend-1.4.1.jar
Run ./headless.sh and it should find the cube
 ./headless.sh
    Domoticz.js
    2013-11-03
   Public Domain.
   info.interval = 30;
function run() {
      return text + '';
      einde;
      URL = java.net.URL,
      JSON = {},
      var URLString;
         outputStream,
         out;
      try {
         out.flush();
         out.close();
      catch(err) {
         debug(err);
         devices = [];
         debug('');
            debug('');
            debug('');
               WindowOpen = 2;
            else {
               WindowOpen = 0;
When added check the maxbuddy setting’s(/home/pi/./maxbuddy/) and adjust it to the sample below with your own parameters
settings.version=1
crontab -e
Now restart the Rpi
sudo reboot
When youve allowed new devices in your settings you will see the valve and thermometer appear as RUBiCSON sub type in domoticz.
Unfortunetly the setpoint doesnt appear as setpoint. I hope someone her can fix that in the Domoticz.js script.
any help would be apreciated offcourse!
