Page 2 of 8
Re: Gigaset Elements Cli - domoticz support
Posted: Saturday 07 May 2016 13:20
by micbou
Appreciate the help Dynasticorpheus!
Your solution worked. After matching the sensor IDs w/ the IDX's I ran gigasetelements-cli.py -j -tt and got this:
root@raspberrypi:/home/pi/gigaset-elements# ./gigasetelements-cli.py -j -tt
Gigaset Elements - Command-line Interface
[-] Configuration | LOADED | /etc/gigasetelements-cli.conf
File "./gigasetelements-cli.py", line 12, in <module>
main()
File "/home/pi/gigaset-elements/gigasetelements/gigasetelements.py", line 678, in main
connect()
File "/home/pi/gigaset-elements/gigasetelements/gigasetelements.py", line 295, in connect
commit_data = restpost(URL_IDENTITY, payload)
File "/home/pi/gigaset-elements/gigasetelements/gigasetelements.py", line 273, in restpost
log('ERROR'.ljust(17) + ' | ' + 'UNKNOWN'.ljust(8) + ' | ' + str(time.strftime('%m/%d/%y %H:%M:%S')) + ' ' + str(e.message), 3, 1)
TypeError: __str__ returned non-string (type Error)
I know its something small in the .conf file but not sure what.
here's the .conf file:
[accounts]
# username (email) in use with my.gigaset-elements.com
username: XXXXXXX
# password in use with my.gigaset-elements.com
password: XXXXXXX
# add token to enable pushbullet notification (optional)
pbtoken:
[options]
# set modus {home,away,custom} (optional)
modus: home
# suppress urllib3 warnings {true,false} (optional)
nowarning: true
[domoticz]
# domoticz server ip address (required)
ip: 192.168.1.112
# domoticz server port (required)
port: 8080
# domoticz user name (optional)
username: XXXXXXX
# domoticz password (optional)
password: XXXXXXXX
# domoticz idx sensor pairing (required)
# 1. Go to Domoticz GUI
# 2. Add hardware - dummy
# 3. Create a virtual sensor - type Alert for basestation (remember the idx number)
# 4. Create a virtual sensor - type Manual Light/Switch for each motion/door/window/siren/plug/button/camera (remember their idx numbers)
# 5. Set Off Delay to 2 seconds for virtual sensors linked to motion, button or camera
# 6. Run "gigasetelements-cli -ss" to get sensor ids and match them with the their respective idx in domoticz
# 7. Run "gigasetelements-cli -a" to get camera sensor id. Use the 12 uppercase digits in stream url. This MAC address can also be found on the back of the camera.
# example motion/door/window/siren/plug
# 123FC4577H: 99
# example basestation id
# F32A76C4DHJ1B743A0E0D74EFD2375D1: 98
# example camera id
# 7C2G30873SED: 97
027C06E866: 10
E52C011F30C1BE84C86895D96C76D693: 11
Posted: Sunday 08 May 2016 8:52
by dynasticorpheus
No worries, it's cool to see people use my code :)
If you are indeed able to run
there is no need to run the program from source dir so let's try to run the command using the installed version
gigasetelements-cli -tt -j
Once it's working you can run it in the background and route all info to a log file
gigasetelements-cli -tt -j -l /tmp/gigasetelements-cli.log -D -ss
If it is still not working and you did not upgrade to the develop version yet please do so as it has better error handling/logging
pip install --upgrade https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
micbou wrote:Appreciate the help Dynasticorpheus!
main()
connect()
Posted: Sunday 08 May 2016 11:49
by micbou
I had it error free,but the sensor didn't seem to give any signal so I decided to install the develop version.
My steps:
1. pip install --upgrade https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
2. cd gigasetelements-cli
3. python setup.py install --force
4. Checked if my /etc/gigasetelements-cli.conf was still in tact (which is true)
5. gigasetelements-cli -ss
The result
File "/usr/local/bin/gigasetelements-cli", line 9, in <module>
load_entry_point('gigasetelements-cli==1.4.0', 'console_scripts', 'gigasetelements-cli')()
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 678, in main
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 295, in connect
File "build/bdist.linux-armv7l/egg/gigasetelements/gigasetelements.py", line 273, in restpost
Ran the pip install --upgrade requests successfully, but still the same errors.
funny, because it does seem to be working (log below). The switches/utility (base station) don't seem to react
[Sun May 8 11:19:31 2016] Gigaset Elements | CLI | 1.5.0b1 | -tt -j -l /tmp/gigasetelements-cli.log -D -ss
[Sun May 8 11:19:31 2016] Run as background | DAEMON | /tmp/gigasetelements-cli.pid
[Sun May 8 11:19:31 2016] Configuration | LOADED | /etc/gigasetelements-cli.conf
[Sun May 8 11:19:34 2016] Identity | VERIFIED | User logged in successfully.
[Sun May 8 11:19:35 2016] Authentication | SUCCESS |
[Sun May 8 11:19:35 2016] Basestation | ONLINE | E52C011F30C1BE84C86895D96C76D693
[Sun May 8 11:19:35 2016] Status | RED | ENDNODE_OFFLINE | Modus set from HOME to HOME
[Sun May 8 11:19:35 2016] Michel's Thuis | ONLINE | firmware UP_TO_DATE
[Sun May 8 11:19:35 2016] Achterdeur | OFFLINE | firmware UP_TO_DATE
[Sun May 8 11:19:35 2016] woonkamer | ONLINE | firmware UP_TO_DATE
[Sun May 8 11:19:35 2016] Domoticz mode | STARTED | CTRL+C to exit
[Sun May 8 11:25:14 2016] 05/08/16 11:25:12 | ps02 | movement woonkamer
[Sun May 8 11:25:45 2016] 05/08/16 11:25:44 | ps02 | movement woonkamer
[Sun May 8 11:26:29 2016] 05/08/16 11:26:27 | ps02 | movement woonkamer
[Sun May 8 11:29:56 2016] 05/08/16 11:29:54 | ps02 | movement woonkamer
[Sun May 8 11:30:48 2016] 05/08/16 11:30:45 | ps02 | movement woonkamer
[Sun May 8 11:31:25 2016] 05/08/16 11:31:24 | ps02 | movement woonkamer
[Sun May 8 11:53:48 2016] 05/08/16 11:53:46 | ps02 | movement woonkamer
[Sun May 8 11:54:35 2016] 05/08/16 11:54:34 | ps02 | movement woonkamer
[Sun May 8 11:56:56 2016] 05/08/16 11:56:54 | ps02 | movement woonkamer
[Sun May 8 11:57:25 2016] 05/08/16 11:57:23 | ps02 | movement woonkamer
[Sun May 8 11:58:06 2016] 05/08/16 11:58:05 | ps02 | movement woonkamer
[Sun May 8 12:00:04 2016] 05/08/16 12:00:02 | ps02 | movement woonkamer
[Sun May 8 12:01:18 2016] 05/08/16 12:01:15 | ps02 | movement woonkamer
[Sun May 8 12:02:20 2016] 05/08/16 12:02:18 | ps02 | movement woonkamer
[Sun May 8 12:03:48 2016] 05/08/16 12:03:47 | ps02 | movement woonkamer
[Sun May 8 12:05:11 2016] 05/08/16 12:05:09 | ps02 | movement woonkamer
[Sun May 8 12:05:50 2016] 05/08/16 12:05:49 | ps02 | movement woonkamer
[Sun May 8 12:07:34 2016] 05/08/16 12:07:32 | ps02 | movement woonkamer
Again, I appreciate all the help.
Posted: Sunday 08 May 2016 21:28
by dynasticorpheus
Looking at your feedback it seems you are installing the develop version (1.5) in step 1 but downgrading to version 1.4 again by doing step 2 & 3. As you can see in the error message version 1.4 is mentioned and in the log the (working!) version 1.5.
Run below command which does a (forced) upgrade to version 1.5 and you should be fine.
pip install --upgrade --force-reinstall https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
You can even delete the gigasetelements-cli directory you mention in step 2&3 as you do not need it anymore as you have the program installed and accessible via the the gigasetelements-cli command.
Once you are back on version 1.5 can you share the output of of below command so we can check your config file
micbou wrote:I had it error free,but the sensor didn't seem to give any signal so I decided to install the develop version.
My steps:
Posted: Sunday 08 May 2016 22:00
by micbou
Deleted the folder, upgrade with the code you gave me and I am now on 1.5. Gigasetelements-cli -ss gives me
root@raspberrypi:/etc# gigasetelements-cli -ss
Gigaset Elements - Command-line Interface v1.5.0b1
    load_entry_point('gigasetelements-cli==1.5.0b1', 'console_scripts', 'gigasetelements-cli')()
  File "/usr/local/lib/python2.7/dist-packages/gigasetelements/gigasetelements.py", line 761, in main
    base()
  File "/usr/local/lib/python2.7/dist-packages/gigasetelements/gigasetelements.py", line 693, in base
    auth_time = authenticate()
  File "/usr/local/lib/python2.7/dist-packages/gigasetelements/gigasetelements.py", line 267, in authenticate
    commit_data = rest(POST, URL_IDENTITY, payload)
  File "/usr/local/lib/python2.7/dist-packages/gigasetelements/gigasetelements.py", line 250, in rest
    log('ERROR'.ljust(17) + ' | ' + 'UNKNOWN'.ljust(8) + ' | ' + str(error.message), 3, end)
Posted: Sunday 08 May 2016 22:26
by dynasticorpheus
Hmm weird can you share the output of
pip freeze
micbou wrote:Deleted the folder, upgrade with the code you gave me and I am now on 1.5. Gigasetelements-cli -ss gives me
    base()
Posted: Sunday 08 May 2016 23:04
by micbou
See below (what did I just do by the way?)
root@raspberrypi:/tmp# pip freeze
RPi.GPIO==0.6.2
Unidecode==0.04.19
argparse==1.2.1
chardet==2.3.0
colorama==0.3.2
daemonize==2.4.6
html5lib==0.999
ndg-httpsclient==0.3.2
numpy==1.8.2
pushbullet.py==0.10.0
pyOpenSSL==0.13.1
pyasn1==0.1.7
pyinotify==0.9.4
python-crontab==2.0.1
python-dateutil==2.5.3
python-magic==0.4.11
requests==2.4.3
six==1.8.0
urllib3==1.9.1
websocket-client==0.37.0
wheel==0.24.0
wsgiref==0.1.2
youtube-dl==2014.08.05
Posted: Monday 09 May 2016 8:28
by dynasticorpheus
This command shows all installed python packages including their version number. As you were getting the initial error again I was interested to see which version of requests you currently have installed. I can see you somehow still have the old version 2.4.3 installed which indeed has the bug I was referring to.
Can you please upgrade (again) by issuing below commands and share me the output?
pip install --upgrade --force-reinstall requests
pip freeze
Don't worry we'll get there :)
micbou wrote:See below (what did I just do by the way?)
RPi.GPIO==0.6.2
Unidecode==0.04.19
argparse==1.2.1
chardet==2.3.0
colorama==0.3.2
daemonize==2.4.6
html5lib==0.999
numpy==1.8.2
pyOpenSSL==0.13.1
pyasn1==0.1.7
pyinotify==0.9.4
requests==2.4.3
six==1.8.0
urllib3==1.9.1
wheel==0.24.0
wsgiref==0.1.2
Posted: Monday 09 May 2016 17:38
by micbou
The upgrade didn't do what we expected
root@raspberrypi:/home/pi# pip install --upgrade --force-reinstall requests
Downloading/unpacking requests
  Downloading requests-2.10.0-py2.py3-none-any.whl (506kB): 506kB downloaded
Installing collected packages: requests
  Found existing installation: requests 2.4.3
    Not uninstalling requests at /usr/lib/python2.7/dist-packages, owned by OS
Successfully installed requests
Cleaning up...
Posted: Monday 09 May 2016 17:46
by dynasticorpheus
Can you run below 3 commands? One of the first two might fail but that is ok
apt-get --purge remove requests
sudo apt-get --purge remove requests
micbou wrote:The upgrade didn't do what we expected
Cleaning up...
Posted: Monday 09 May 2016 17:54
by micbou
root@raspberrypi:/home/pi# apt-get --purge remove requests
Reading package lists... Done
Building dependency tree
Reading state information... Done
E: Unable to locate package requests
root@raspberrypi:/home/pi# sudo apt-get --purge remove requests
Cleaning up...
Posted: Monday 09 May 2016 17:57
by dynasticorpheus
Ok I guess it's installed via pip using sudo so let's also try to upgrade using sudo:
sudo pip install --upgrade --force-reinstall requests
micbou wrote::(
Cleaning up...
Posted: Monday 09 May 2016 18:04
by micbou
ugh
man, thanks for your patience! I owe you a virtual beer after we got this fixed
root@raspberrypi:/home/pi# sudo pip install --upgrade --force-reinstall requests
Cleaning up...
Posted: Monday 09 May 2016 18:12
by dynasticorpheus
I think I forgot to add pyton- in my previous suggestion so ... let's try:
sudo apt-get --purge remove python-requests
micbou wrote:ugh
Cleaning up...
Posted: Monday 09 May 2016 18:28
by micbou
I think we're close
root@raspberrypi:/home/pi# sudo apt-get --purge remove python-requests
The following packages were automatically installed and are no longer required:
  python-chardet python-colorama python-distlib python-html5lib
  python-ndg-httpsclient python-openssl python-pyasn1 python-six
  python-urllib3 python-wheel
Use 'apt-get autoremove' to remove them.
The following packages will be REMOVED:
  python-pip* python-requests*
0 upgraded, 0 newly installed, 2 to remove and 55 not upgraded.
After this operation, 977 kB disk space will be freed.
Do you want to continue? [Y/n] Y
(Reading database ... 58048 files and directories currently installed.)
Removing python-pip (1.5.6-5) ...
Removing python-requests (2.4.3-6) ...
Processing triggers for man-db (2.7.0.2-5) ...
sudo: pip: command not found
Posted: Monday 09 May 2016 18:34
by dynasticorpheus
Yes almost there I think ... let's cleanup, reinstall pip and finally do a complete reinstall of gigasetelements-cli:
sudo apt-get -y autoremove
sudo apt-get -y install python-pip
sudo pip install --upgrade --force-reinstall https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
micbou wrote:I think we're close
Posted: Monday 09 May 2016 18:47
by micbou
:oops:
root@raspberrypi:/home/pi# sudo apt-get -y autoremove
0 upgraded, 0 newly installed, 10 to remove and 55 not upgraded.
After this operation, 3,107 kB disk space will be freed.
(Reading database ... 57942 files and directories currently installed.)
Removing python-chardet (2.3.0-1) ...
Removing python-colorama (0.3.2-1) ...
Removing python-distlib (0.1.9-1) ...
Removing python-html5lib (0.999-3) ...
Removing python-ndg-httpsclient (0.3.2-1) ...
Removing python-openssl (0.13.1-2) ...
Removing python-pyasn1 (0.1.7-1) ...
Removing python-urllib3 (1.9.1-3) ...
Removing python-six (1.8.0-1) ...
Removing python-wheel (0.24.0-1) ...
Processing triggers for python-support (1.0.15) ...
root@raspberrypi:/home/pi# sudo apt-get -y install python-pip
The following extra packages will be installed:
  python-ndg-httpsclient python-openssl python-pyasn1 python-requests
  python-six python-urllib3 python-wheel
Suggested packages:
  python-genshi python-lxml python-openssl-doc python-openssl-dbg doc-base
Recommended packages:
  python-dev-all
The following NEW packages will be installed:
  python-ndg-httpsclient python-openssl python-pip python-pyasn1
  python-requests python-six python-urllib3 python-wheel
0 upgraded, 12 newly installed, 0 to remove and 55 not upgraded.
Need to get 0 B/903 kB of archives.
After this operation, 4,084 kB of additional disk space will be used.
Selecting previously unselected package python-chardet.
(Reading database ... 57513 files and directories currently installed.)
Preparing to unpack .../python-chardet_2.3.0-1_all.deb ...
Unpacking python-chardet (2.3.0-1) ...
Selecting previously unselected package python-colorama.
Preparing to unpack .../python-colorama_0.3.2-1_all.deb ...
Unpacking python-colorama (0.3.2-1) ...
Selecting previously unselected package python-distlib.
Preparing to unpack .../python-distlib_0.1.9-1_all.deb ...
Unpacking python-distlib (0.1.9-1) ...
Selecting previously unselected package python-six.
Preparing to unpack .../python-six_1.8.0-1_all.deb ...
Unpacking python-six (1.8.0-1) ...
Selecting previously unselected package python-html5lib.
Preparing to unpack .../python-html5lib_0.999-3_all.deb ...
Unpacking python-html5lib (0.999-3) ...
Selecting previously unselected package python-openssl.
Preparing to unpack .../python-openssl_0.13.1-2_armhf.deb ...
Unpacking python-openssl (0.13.1-2) ...
Selecting previously unselected package python-ndg-httpsclient.
Preparing to unpack .../python-ndg-httpsclient_0.3.2-1_all.deb ...
Unpacking python-ndg-httpsclient (0.3.2-1) ...
Selecting previously unselected package python-urllib3.
Preparing to unpack .../python-urllib3_1.9.1-3_all.deb ...
Unpacking python-urllib3 (1.9.1-3) ...
Selecting previously unselected package python-requests.
Preparing to unpack .../python-requests_2.4.3-6_all.deb ...
Unpacking python-requests (2.4.3-6) ...
Selecting previously unselected package python-pip.
Preparing to unpack .../python-pip_1.5.6-5_all.deb ...
Unpacking python-pip (1.5.6-5) ...
Selecting previously unselected package python-pyasn1.
Preparing to unpack .../python-pyasn1_0.1.7-1_all.deb ...
Unpacking python-pyasn1 (0.1.7-1) ...
Selecting previously unselected package python-wheel.
Preparing to unpack .../python-wheel_0.24.0-1_all.deb ...
Unpacking python-wheel (0.24.0-1) ...
Setting up python-chardet (2.3.0-1) ...
Setting up python-colorama (0.3.2-1) ...
Setting up python-distlib (0.1.9-1) ...
Setting up python-six (1.8.0-1) ...
Setting up python-html5lib (0.999-3) ...
Setting up python-openssl (0.13.1-2) ...
Setting up python-ndg-httpsclient (0.3.2-1) ...
Setting up python-urllib3 (1.9.1-3) ...
Setting up python-requests (2.4.3-6) ...
Setting up python-pip (1.5.6-5) ...
Setting up python-pyasn1 (0.1.7-1) ...
Setting up python-wheel (0.24.0-1) ...
root@raspberrypi:/home/pi# sudo pip install --upgrade --force-reinstall https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
Downloading/unpacking https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
  Downloading develop
  Running setup.py (path:/tmp/pip-chQV0L-build/setup.py) egg_info for package from https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
Downloading/unpacking requests (from gigasetelements-cli==1.5.0b1)
Downloading/unpacking pushbullet.py (from gigasetelements-cli==1.5.0b1)
  Downloading pushbullet.py-0.10.0-py2.py3-none-any.whl
Downloading/unpacking unidecode (from gigasetelements-cli==1.5.0b1)
  Downloading Unidecode-0.04.19.tar.gz (204kB): 204kB downloaded
  Running setup.py (path:/tmp/pip-build-3y2lJ0/unidecode/setup.py) egg_info for package unidecode
Downloading/unpacking colorama (from gigasetelements-cli==1.5.0b1)
  Downloading colorama-0.3.7-py2.py3-none-any.whl
Downloading/unpacking python-crontab (from gigasetelements-cli==1.5.0b1)
  Downloading python-crontab-2.0.1.tar.gz
  Running setup.py (path:/tmp/pip-build-3y2lJ0/python-crontab/setup.py) egg_info for package python-crontab
Downloading/unpacking daemonize (from gigasetelements-cli==1.5.0b1)
  Downloading daemonize-2.4.6-py2.py3-none-any.whl
Downloading/unpacking websocket-client (from pushbullet.py->gigasetelements-cli==1.5.0b1)
  Downloading websocket_client-0.37.0.tar.gz (194kB): 194kB downloaded
  Running setup.py (path:/tmp/pip-build-3y2lJ0/websocket-client/setup.py) egg_info for package websocket-client
Downloading/unpacking python-magic (from pushbullet.py->gigasetelements-cli==1.5.0b1)
  Downloading python-magic-0.4.11.tar.gz
  Running setup.py (path:/tmp/pip-build-3y2lJ0/python-magic/setup.py) egg_info for package python-magic
Downloading/unpacking python-dateutil (from python-crontab->gigasetelements-cli==1.5.0b1)
  Downloading python_dateutil-2.5.3-py2.py3-none-any.whl (201kB): 201kB downloaded
Downloading/unpacking six (from websocket-client->pushbullet.py->gigasetelements-cli==1.5.0b1)
  Downloading six-1.10.0-py2.py3-none-any.whl
Installing collected packages: requests, pushbullet.py, unidecode, colorama, python-crontab, daemonize, gigasetelements-cli, websocket-client, python-magic, python-dateutil, six
  Found existing installation: pushbullet.py 0.10.0
    Uninstalling pushbullet.py:
      Successfully uninstalled pushbullet.py
  Found existing installation: Unidecode 0.04.19
    Uninstalling Unidecode:
      Successfully uninstalled Unidecode
  Running setup.py install for unidecode
    Installing unidecode script to /usr/local/bin
  Found existing installation: colorama 0.3.2
    Not uninstalling colorama at /usr/lib/python2.7/dist-packages, owned by OS
  Found existing installation: python-crontab 2.0.1
    Uninstalling python-crontab:
      Successfully uninstalled python-crontab
  Running setup.py install for python-crontab
  Found existing installation: daemonize 2.4.6
    Uninstalling daemonize:
      Successfully uninstalled daemonize
  Found existing installation: gigasetelements-cli 1.5.0b1
    Uninstalling gigasetelements-cli:
      Successfully uninstalled gigasetelements-cli
  Running setup.py install for gigasetelements-cli
    Installing gigasetelements-cli script to /usr/local/bin
  Found existing installation: websocket-client 0.37.0
    Uninstalling websocket-client:
      Successfully uninstalled websocket-client
  Running setup.py install for websocket-client
    changing mode of build/scripts-2.7/wsdump.py from 644 to 755
    changing mode of /usr/local/bin/wsdump.py to 755
  Found existing installation: python-magic 0.4.11
    Uninstalling python-magic:
      Successfully uninstalled python-magic
  Running setup.py install for python-magic
  Found existing installation: python-dateutil 2.5.3
    Uninstalling python-dateutil:
      Successfully uninstalled python-dateutil
  Found existing installation: six 1.8.0
    Not uninstalling six at /usr/lib/python2.7/dist-packages, owned by OS
Successfully installed requests pushbullet.py unidecode colorama python-crontab daemonize gigasetelements-cli websocket-client python-magic python-dateutil six
Cleaning up...
root@raspberrypi:/home/pi# gigasetelements-cli -ss
    base()
Request is also still requests==2.4.3
Posted: Monday 09 May 2016 19:03
by dynasticorpheus
This thing is making me look stupid but never give up as they say :)
No idea why python-pip and python-requests are linked but let's install pip from source so we avoid the automatic re-install of the outdated requests version:
sudo apt-get -y --purge remove python-pip python-requests
curl -O https://bootstrap.pypa.io/get-pip.py
sudo python get-pip.py
micbou wrote::oops:
Suggested packages:
  python-dev-all
  Downloading develop
Cleaning up...
    base()
Posted: Monday 09 May 2016 19:14
by micbou
BEER! (right?)
would you mind explaning what we did here? (and why pip freeze doesnt work anymore now)
(and trust me, I look way more stupid ;) )
Now lets see if I can get the utility and switches working
root@raspberrypi:/home/pi# sudo apt-get -y --purge remove python-pip python-requests
root@raspberrypi:/home/pi# curl -O https://bootstrap.pypa.io/get-pip.py
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100 1487k  100 1487k    0     0  4442k      0 --:--:-- --:--:-- --:--:-- 4452k
root@raspberrypi:/home/pi# sudo python get-pip.py
Collecting pip
  Downloading pip-8.1.1-py2.py3-none-any.whl (1.2MB)
    100% |████████████████████████████████| 1.2MB 203kB/s
Collecting wheel
  Downloading wheel-0.29.0-py2.py3-none-any.whl (66kB)
    100% |████████████████████████████████| 71kB 1.2MB/s
Installing collected packages: pip, wheel
Successfully installed pip-8.1.1 wheel-0.29.0
Collecting https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
  Downloading https://github.com/dynasticorpheus/gigasetelements-cli/zipball/develop
     | 30kB 214kB/s
Collecting requests (from gigasetelements-cli==1.5.0b1)
    100% |████████████████████████████████| 512kB 454kB/s
Collecting pushbullet.py (from gigasetelements-cli==1.5.0b1)
Collecting unidecode (from gigasetelements-cli==1.5.0b1)
    100% |████████████████████████████████| 204kB 304kB/s
Collecting colorama (from gigasetelements-cli==1.5.0b1)
Collecting python-crontab (from gigasetelements-cli==1.5.0b1)
Collecting daemonize (from gigasetelements-cli==1.5.0b1)
Collecting python-magic (from pushbullet.py->gigasetelements-cli==1.5.0b1)
Collecting websocket-client (from pushbullet.py->gigasetelements-cli==1.5.0b1)
    100% |████████████████████████████████| 194kB 631kB/s
Collecting python-dateutil (from python-crontab->gigasetelements-cli==1.5.0b1)
    100% |████████████████████████████████| 204kB 737kB/s
Collecting six (from websocket-client->pushbullet.py->gigasetelements-cli==1.5.0b1)
Building wheels for collected packages: unidecode, python-crontab, python-magic, websocket-client
  Running setup.py bdist_wheel for unidecode ... done
  Stored in directory: /root/.cache/pip/wheels/72/da/8f/64e7de75111e143339d331011b56b3a8186e2eb07b0b5e383b
  Running setup.py bdist_wheel for python-crontab ... done
  Stored in directory: /root/.cache/pip/wheels/64/8d/fb/bb281503710d9de2d193a378c7e9b5d0cdb8367aec3587f1ed
  Running setup.py bdist_wheel for python-magic ... done
  Stored in directory: /root/.cache/pip/wheels/65/ab/71/40c6c38a050ce64fcbda7e3e8ee3096d5a6302ad4dab28ba8c
  Running setup.py bdist_wheel for websocket-client ... done
  Stored in directory: /root/.cache/pip/wheels/e4/20/12/48d6732b88733a0a8f98ee1a5b2f59b64b27011d5c34c4f98c
Successfully built unidecode python-crontab python-magic websocket-client
Installing collected packages: requests, python-magic, six, websocket-client, pushbullet.py, unidecode, colorama, python-dateutil, python-crontab, daemonize, gigasetelements-cli
  Found existing installation: requests 2.10.0
    Uninstalling requests-2.10.0:
      Successfully uninstalled requests-2.10.0
    Uninstalling python-magic-0.4.11:
      Successfully uninstalled python-magic-0.4.11
  Found existing installation: six 1.10.0
    Uninstalling six-1.10.0:
      Successfully uninstalled six-1.10.0
    Uninstalling websocket-client-0.37.0:
      Successfully uninstalled websocket-client-0.37.0
    Uninstalling pushbullet.py-0.10.0:
      Successfully uninstalled pushbullet.py-0.10.0
  Found existing installation: Unidecode 0.4.19
    Uninstalling Unidecode-0.4.19:
      Successfully uninstalled Unidecode-0.4.19
  Found existing installation: colorama 0.3.7
    Uninstalling colorama-0.3.7:
      Successfully uninstalled colorama-0.3.7
    Uninstalling python-dateutil-2.5.3:
      Successfully uninstalled python-dateutil-2.5.3
    Uninstalling python-crontab-2.0.1:
      Successfully uninstalled python-crontab-2.0.1
    Uninstalling daemonize-2.4.6:
      Successfully uninstalled daemonize-2.4.6
    Uninstalling gigasetelements-cli-1.5.0b1:
      Successfully uninstalled gigasetelements-cli-1.5.0b1
  Running setup.py install for gigasetelements-cli ... done
Successfully installed colorama-0.3.7 daemonize-2.4.6 gigasetelements-cli-1.5.0b1 pushbullet.py-0.10.0 python-crontab-2.0.1 python-dateutil-2.5.3 python-magic-0.4.11 requests-2.10.0 six-1.10.0 unidecode-0.4.19 websocket-client-0.37.0
root@raspberrypi:/home/pi# pip freeze
bash: /usr/bin/pip: No such file or directory
[-] Identity          | VERIFIED | User logged in successfully.
[-] Authentication    | SUCCESS  |
[-] Basestation       | ONLINE   | E52C011F30C1BE84C86895D96C76D693
[-] Status            | RED      | ENDNODE_OFFLINE | Modus set from HOME to HOME
[-] Michel's Thuis    | ONLINE   | firmware UP_TO_DATE
[-] Achterdeur        | OFFLINE  | firmware UP_TO_DATE | battery OK | position UNKNOWN | 027C06E864
[-] woonkamer         | ONLINE   | firmware UP_TO_DATE | battery OK | 027C06E866
Posted: Monday 09 May 2016 19:44
by dynasticorpheus
Going forward just put sudo in front of your pip commands:
sudo pip freeze
apt-get and pip are similar tools however pip is limited to installing python packages only but has the advantage it will always install the latest version of a certain module. If you use apt-get you will get the version that is shipped with your current OS release. As you can see that almost always means you get an outdated version.
What we did was:
remove pip and requests installed via apt-get
cleanup by uninstalling other modules which were installed to make the above two work (but are now no longer needed)
Install pip from source so we avoid the auto install of python-requests 2.4.3 when installing python-pip
Do a complete reinstall of gigasetelements-cli so we are 100% sure all dependencies are installed.
Please read the my opening post of this thread as I have updated my instruction and made hopefully more clear, needless to say you can skip step 6 which shows how to install the gigasetelements-cli :D
Don't forget step 5 !!!
micbou wrote:BEER! (right?)
Collecting pip
Collecting wheel
     | 30kB 214kB/s
