How to update RFLink firmware
RidingTheFlow
Re: How to update RFLink firmware
Post by RidingTheFlow »
Make sure /dev/ACM0 is really the serial device for your RFLink. It may be a serial device, but just a wrong one so programmer can't communicate. You can do it e.g. via screen:
screen /dev/ACM0 57600
- you should get cleartext communication/build number banner from RFLink
The way udev assigns device links can be semi-random based on what USB devices you have and what ports they use.
Personally I use fixed etc/udev/rules.d/ to make sure device links are fixed, e.g.:
SUBSYSTEM=="tty", ATTRS{idVendor}=="1a86", ATTRS{idProduct}=="7523", SYMLINK+="ttyUSB-RFLink"
SUBSYSTEM=="tty", ATTRS{idVendor}=="0658", ATTRS{idProduct}=="0200", SYMLINK+="ttyUSB-ZStick"
Stuntteam wrote:Why the -D ?
-D (disable explicit erase) is needed in newer avrdude, because Arduino Mega will auto-erase on programming. Therefore explicit erasing is not needed - and will actually fail with error if you try without this switch.
jjansen
Post by jjansen »
remb0 wrote:i got now:
avrdude -v -p atmega2560 -c stk500 -P /dev/ACM0 -b 115200 -D -U flash:w:/home/pi/RFLink.cpp.hex:i
 Programmer Type : STK500V2
         Description     : Atmel STK500
         Programmer Model: Unknown
avrdude: stk500v2_ReceiveMessage(): timeout
avrdude: stk500v2_getsync(): timeout communicating with programmer
I got the same error. Therefore I stopped Domoticz with
sudo service domoticz.sh stop
Used the avrdude command
and than started domoticz again.
This worked very well.
marcojpolet
Post by marcojpolet »
jumbotroll wrote:How to update RFLink on Synology NAS:
1. Download and install avrdude.spk for your synology from my server: http://www.jadahl.com/synology/
2. Copy the newest RFLink.cpp.hex file to a folder on your NAS, for example /volume1/web
3. Go to Hardware settings in Domoticz and temporary disable (not delete) RFLink.
4. Telnet or ssh your NAS and type:
avrdude -v -p atmega2560 -c stk500 -P /dev/ttyUSB1 -b 115200 -D -U flash:w:/volume1/web/RFLink.cpp.hex:i
Remember to edit correct directory and USB port you using!
5. Go to Hardware settings in Domoticz and enable RFLink.
The end :-)
Hi Jumbotroll,
Great packages for the Synology, I use them, also the avrdude is working! Do you also have a serial terminal program I could run from my Synology available as package? This way I could see the debug output of the rflink from my Synology.
Regards,
Marco
jumbotroll
Post by jumbotroll »
marcojpolet wrote: Hi Jumbotroll,
Regards,
Marco
Sorry I have not compiled serial terminal program for Synology.
Do you have a suggestion source code for a cli serial terminal program that could do that work?
https://paypal.me/Jumbotroll
Jumbotroll
marcojpolet
Hi Jumbo,
No sorry, but from what I've read minicom or microcom are linux tools which could do that, perhaps that helps?
Regards,
Marco
jumbotroll
minicom v2.7-1.spk for Synology.
Minicom, a terminal program for Linux and other unix-like systems.
Log in with telnet or ssh and start minicom with minicom -s for setting.
For meny type: CTRL-A and use letter A-Z for option.
To exit minicom, type CTRL-A and then type Q.
If you have DSM6.0 beta, type sudo minicom -s
http://www.jadahl.com/synology/index.php?fulllist=true
Jumbotroll
marcojpolet
It's working! Woohooo!
CTRL-A Z for help | 115200 8N1 | NOR | Minicom 2.7 | VT102 | Offline | ttyACM0
NAS> minicom -s
Welcome to minicom 2.7
OPTIONS: I18n
Compiled on Mar 19 2016, 19:39:25.
Port /dev/ttyACM0, 11:19:10
Press CTRL-A Z for help on special keys
20;E6;Slave;ID=000301;METER=00000050;
20;E7;Slave;ID=000301;METER=00000020;
Took a bit figuring out the settings (57K6, 8N1), this can be set from the menu, not directly, but there are keys in the menu to use next/prev speed, which can do 57K6.
I can now debug and flash directly from the NAS. Now just a way to switch the 10uF capacitor (prevent reset) from software.
Thanks Jumbotroll, great work!!
Regards,
Marco
marcojpolet
Note; I use 'synopkg stop Domoticz' and start to stop and start Domoticz, otherwise the port is not accebible.
Hmmm update; stoppping works, starting not yet, I'll find out :-)
jumbotroll
@marcojpolet
about the 10uF capacitor to prevent reset you can test this:
killall synousbmodemd
Do this before you connect the device and check if that work for you.
Remember to remove the 10uF capacitor first :-)
Jumbotroll
jumbotroll
OPTIONS: I18n
Compiled on Mar 19 2016, 19:27:24.
Port /dev/ttyUSB1, 12:03:12
20;70;Xiron;ID=A301;TEMP=005e;HUM=41;BAT=OK;
20;71;PONG;
20;72;Prologue;ID=96a1;TEMP=00e8;BAT=LOW;
20;73;XT200;ID=005f;TEMP=8080;BA20;74;Xiron;ID=A301;TEMP=005f;HUM=41;BAT=OK;
20;75;XT200;ID=00e1;TEMP=0030;BAT=LOW;
20;76;PONG;
20;77;Prologue;ID=96a1;TEMP=00e8;BAT=LOW;
20;78;XT200;ID=005f;TEMP=8080;BAT=OK;
20;79;Alecto V3;ID=0087;TEMP=80a20;7A;FineOffset;ID=045c;TEMP=00e1;
20;7B;Xiron;ID=A301;TEMP=005e;HUM=41;BAT=OK;
I don't have to stop domoticz or disable RFLink from domoticz. Just started minicom and it's up and running :-)
BTW I use Arduino Mega clone with CH341 driver on ttyUSB1
Jumbotroll
RidingTheFlow
I recommend you stop domoticz for flashing.
You don't want domotics trying to communicate with Arduino when flashing is in progress.
jumbotroll
RidingTheFlow wrote:I recommend you stop domoticz for flashing.
Yes, I always stop before flash, but does not when logging.
Jumbotroll
jumbotroll
I have build some packages for DSM 6.0
avrdude, minicom, mochad, netcat, usbutils and (UsbSerialDrivers for non domoticz users)
http://www.jadahl.com/synology6/
http://www.jadahl.com/synology6/index.php?fulllist=true
Jumbotroll
bassie127
Post by bassie127 »
Where can I find the RFlink software, including the RFlinkloader.exe?
The URL mentioned in the first post does not work
http://sourceforge.net/projects/rflink/ ... urce=files
bassie127
Post by bassie127 »
OK I found it on https://drive.google.com/file/d/0BwEYW5 ... lFd3c/view
The strange thing is that Google drive indicaties that rflinkloader.exe is present in the zip file, but when I download en open the zip file in Windows, that file is not present.
Solution for me was to extract the zip file with the cloud app suggested by Google drive, which extracts the zip file to my Google Drive.
bassie127
Post by bassie127 »
sorry, my virusscanner always deletes this file
bassie127
Post by bassie127 »
Is it possible to run RFlinkloader software on Raspberry/linux in stead of on windows? Because on my work laptop the virusscanner keeps deleten rflinkloader.exe
Or do you have any other ideas?
Stuntteam
Post by Stuntteam »
rflinkloader is a windows only front end program.
It calls avrdude for the actualy flashing of the Arduino (one of the reasons that some poor anti virus programs report a virus)
You can use avrdude on a Pi to do the flashing. You can follow jumbotrolls synology explanations as the avrdude command is the same.
bassie127
Post by bassie127 »
Thanks. I will try avrdude onder Windows. Only rflinkloader.exe is remover by virus scanner
woody4165
Post by woody4165 »
How can I check which fw is loaded into RFLink?
I just got one, I presume it's latest one, but os there a way to check it?
