I'm assuming commenting out these lines will stop the IDLE totally
url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command¶m=udevice&idx=" + domoticz_PlexStatus + "&nvalue=0&svalue=IDLE")
urllib.urlopen(url)
Isn't it possible to add "variable=1" when IDLE is send for the first time and let the lines only be executed when "variable=0"
and when something starts playing that the "variable=0" is set?
Plex Status
- Domoticz version: Stable
Re: Plex Status
Over 50 Z-Wave Devices (Fibaro and Neo), 4xLogitech Hub, 2xPhilips Hue Bridge+55 Lights, 1x Nest Thermostat, 2xNetatmo Weather Station, 1xSkybell v1 Doorbell, 3 Kwikset KEVO Doorlocks and Domoticz running on a Intel NUC
Re: Plex Status
if domoticz have a password?
galadril wrote: ↑Wednesday 09 September 2015 14:36 But with these script, you get the status of your Plex Media Server
Prepare Domoticz
If you don't know how to create a virtual sensor chances are you have never done this before.
- Go to "Hardware"
- Fill in the name field with a desired name (like "Virtual")
- Choose for type the "Dummy, does nothing, use for virtual switches only"
- Click on "Add"
- The added hardware is now added to the hardware list. In the same row there is a "Create virtual sensor" button shown. Click on it.
Hardware
Now you are ready to create virtual devices.
- Go to "Hardware"
- Press "Create virtual sensor".
- Fill in the name field with a name like 'Plex'
Devices
Now you are ready to create a virtual device.
- Go to "Hardware"
Plex script
Config the parameters in the Plex script:Code: Select all
#config plex url plexURL = '<plex ip>:<plex port>' #base url (default port = 32400) #domoticz settings domoticz_host = '' domoticz_port = '' domoticz_url = 'json.htm' #domoticz idx domoticz_PlexStatus = '' #idx of device
Put the script under /domoticz/scripts and make the script executable:
"sudo chmod +x /home/pi/domoticz/scripts/plex.py"
Test
Run the script by calling:
"sudo python /home/pi/domoticz/scripts/plex.py"
If Plex Server is not playing anything, this is the result:
Create the Cronjob
Now all ingredients are available to read the data from the portal and insert them into Domoticz.
- execute "sudo crontab -e"
- add the following line "*/10 * * * * /home/pi/domoticz/scripts/plex.py"
- exit crontab. Now everything should be working for you.
Scripts
plex.pyCode: Select all
#!/usr/bin/python import urllib, urllib2, hashlib from xml.etree import ElementTree as ET #config plex url plexURL = '<plex ip>:<plex port>' #base url (default port = 32400) #domoticz settings domoticz_host = '' domoticz_port = '' domoticz_url = 'json.htm' #domoticz idx domoticz_PlexStatus = '' #idx of device #building url requestURL = 'http://'+plexURL+'/status/sessions' print requestURL try: #call session url test = urllib.urlopen(requestURL).read() print test root = ET.XML(test) print root.tag videotitle = root.find('Video').attrib['title'] print 'Video Playing: ' + videotitle urllib.urlopen("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command¶m=addlogmessage&message=Video Playing: " + videotitle) #uploading values to domoticz url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command¶m=udevice&idx=" + domoticz_PlexStatus + "&nvalue=0&svalue=Playing: " + videotitle) urllib.urlopen(url) except Exception: print 'IDLE' #uploading values to domoticz url = ("http://" + domoticz_host + ":" + domoticz_port + "/" + domoticz_url+ "?type=command¶m=udevice&idx=" + domoticz_PlexStatus + "&nvalue=0&svalue=IDLE") urllib.urlopen(url) pass
Re: Plex Status
For you who still have intrest in plex status for home users.
I have made a script in python that do the following
1. Check status on plexserver - current streams
2. Check a domoticz variable if the State for home users is changed
3. If variables is changed it updates domoticz switch and Variable with new state
4. Sends info of the change to influxDB to track usage history
#!/usr/bin/python
import requests
import json
import urllib
import urllib2
import hashlib
#config plex url
plexURL = '192.168.15.23:32400' #base url (default port = 32400)
#domoticz settings
domoticz_user = 'user' #Ange den användare i domoticz som ska användas
domoticz_pwd = 'password' #Lösenordet för ovan användare
domoticz_host = '192.168.15.25'
domoticz_port = '8080'
domoticz_url = "http://" + domoticz_user + ":" + domoticz_pwd + "@" + domoticz_host + ":" + domoticz_port + "/json.htm"
influxDB_host = "192.168.15.21:8086"
#domoticz idx
#building url
print requestURL
def skickaData(videotitle, playinguser, playingstate):
#Check plex_usernamne
if playinguser == "Plexuser1":
domoticz_SwitchIDX = 313 #domoticz SwitchIDX för Plexuser1
domoticzvariableIDX = 1 #VariableIDX för user 1
domoticzvariablename = "variable1" #Domoticz Variable Namn user 1
elif playinguser == "Plexuser2":
domoticz_SwitchIDX = 325
domoticzvariableIDX = 2
domoticzvariablename = "variable2"
elif playinguser == "Plexuser1":
domoticz_SwitchIDX = 326
domoticzvariableIDX = 3
domoticzvariablename = "variable3"
domoticz_SwitchIDX = 327
domoticzvariableIDX = 4
domoticzvariablename = "variable4"
else:
result = -1
#Check variable for specific user in domoticz and parse the json result
varurl = (domoticz_url+ "?type=command¶m=getuservariable&idx=" + str(domoticzvariableIDX))
variablestaterequest=urllib.urlopen(varurl).read()
#Parse Json result
variable_json_object = json.loads(variablestaterequest)
print "variablState for:",playinguser ,": ", variable_json_object["result"][0]["Value"]
#Check if playing state has changed according to variable in domoticz
if playingstate != variable_json_object["result"][0]["Value"]:
#Update variable in domoticz
print "Update domoticz with new state for user", playinguser
updateVarUrl = (domoticz_url + "?type=command¶m=updateuservariable&vname=" + domoticzvariablename + "&vtype=2&vvalue=" + playingstate)
urllib.urlopen(updateVarUrl).read()
#Update log in domoticz
urllib.urlopen(domoticz_url+ "?type=command¶m=addlogmessage&message=User: " + playinguser + " Changed Plex Status -- Film: " + videotitle + "-- State: " + playingstate)
#Update switch in Domoticz
switchurl = (domoticz_url+ "?type=command¶m=udevice&idx=" + str(domoticz_SwitchIDX) + "&nvalue=0&svalue=Film: " + videotitle + "-- State: " + playingstate)
urllib.urlopen(switchurl)
#Update influxDB
if (playingstate == "playing") or (playingstate == "paused"):
statusnumber = 1
else:
statusnumber = 0
influxurl = "http://" + influxDB_host + "/write?db=domoticzDB" # --data-binary plexStatus" + playinguser + ",host=plexserver value=" + statusnumber)
headers = {'Content-Type': 'application/x-www-form-urlencoded'}
payload = "plexStatus" + playinguser + ",host=plexserver,region=us-west value=" + str(statusnumber)
r = requests.post(influxurl, data=payload, headers=headers)
print "Updated state for", playinguser, "to influxdb"
return
try:
activeUserArray=["a"]
#call session url
#Parse XML response from Plexsession
root = ET.XML(test)
print "Root size is: ",root.get('size')
if root.get('size') != "0":
#"XML Parsing"
for element in root:
title = element.get('title')
for item in element.iterfind('User'):
plexuser = item.get('title')
activeUserArray.append(plexuser)
print plexuser, "is playing:", title
for item in element.iterfind('Player'):
state = item.get('state')
#print "The state is:", state
skickaData(title, plexuser, state)
print "Check Idle users"
if not ("plexuser1" in activeUserArray):
skickaData(" ", "plexuser1", "Idle")
if not ("plexuser2" in activeUserArray):
skickaData(" ", "plexuser2", "Idle")
if not ("plexuser3" in activeUserArray):
skickaData(" ", "plexuser3", "Idle")
if not ("plexuser4" in activeUserArray):
skickaData(" ", "plexuser4", "Idle")
except Exception:
print 'Error'
raise
Re: Plex Status
Hi Peter,
Can you make an HowToInstall your script?
Especially the Plexusername part.
And the influxDB, do I need it?
Im not a very experienced user
Thx for the effort
Cheers
R
Thx for the effort
Cheers
R
Re: Plex Status
I can try to explain it in more detail.
In plex you can set the server to be a "home server" see https://support.plex.tv/articles/204234 ... ome-setup/ for how to set it up if you havn't done that yet.
Plexuser:
In my script you just replace "Plexuser1" with the name (username in plex, that you have set up according to the link above)
What this does is that when the script checks the status of your plexserver it will match the name of the plexuser and see if that user is currently streaming from the server.
In domotics:
You need to setup 2 things
1. setup a virtual switch, then you need to set "domoticz_SwitchIDX = " to the IDX number of that switch. This switch should be of the type "text"
2. setup a User Variable, the Variables IDX need to be set to "domoticzvariableIDX =", And "domoticzvariablename =" needs to be set to the name of the varable in domoticz
You don't need the influx part unless you want to send the data to a influx database. I use it to create graphs for usage
I run this script on a Raspberry pi 3 and then schedule it to run every 5 minutes with crontab (I dont need the info more frequently)
I hope this might make it a little bit easier
Get back to me if you have any maore questions
/Peter
Plexuser:
In domotics:
/Peter
