RollerTrol add manually
EdddieN
Domoticz version: 4.9700
Re: RollerTrol add manually
Post by EdddieN »
gizmocuz wrote:Hello David,
I have this implemented for the REAX devices, there are three buttons for these (up/stop/down)
With the rollertroll, if you press down, and then down again, it stops? Or does it needs an actual 'real' stop command?
(I mean, in RFXMngr appplication, is there a special stop command?), if yes, could you post a screenshot of your 'devices tab' with the rollertroll?
/Rob
I have REAX motors and all working fine. Did you find a why to get % working? I'm thinking about a virtual sensor plus some lua with a timer based on slider ratio.
I also was thinking of using a fibaro roller control but this will not work if someone uses the manual wall switch for the blinds.
Just wondering if there's a simpler solution for RFXComm % open/close control that I'm not aware.
11101101 - www.machinon.com
