Page 2 of 2
Re: BH1750 lux sensor: reading 54612 lux???
Posted: Wednesday 28 October 2015 21:34
by ThinkPad
0 lux.
For today it was like this, see attachment.
Posted: Thursday 29 October 2015 9:43
by thecosmicgate
Dubbel post
Posted: Thursday 29 October 2015 9:53
by ThinkPad
I deleted two of your messages, it looked like something went wrong :lol:
But like i said, just exchange the BH1750 for a different one, that will probably fix it.
Posted: Thursday 29 October 2015 10:36
by thecosmicgate
ThinkPad wrote:I deleted two of your messages, it looked like something went wrong Image
Already changed the BH1750 to one other , but still this low lux measurement's
Sent from my MotoG3 using Tapatalk
Posted: Thursday 29 October 2015 15:19
by ThinkPad
Then i would say: check the wiring (connected to analog pin instead of digital pin by accident)? Or maybe the sketch has changed and some calculation is different... Try with a BH1750 example sketch to see what readings you get.
It should definately read more than 72 lux, my Aeon multisensor tops out at 1k lux at day, it sits in my livingroom with no direct sunlight at it.
Posted: Thursday 29 October 2015 18:52
by thecosmicgate
ThinkPad wrote:Then i would say: check the wiring (connected to analog pin instead of digital pin by accident)? Or maybe the sketch has changed and some calculation is different... Try with a BH1750 example sketch to see what readings you get.
I used this example sketch :) is there one other ? Maybe try that one .
I already checked the wiring 10times and already changed this to eliminate that.
I soldered the wires direct on the arduino instead of using the breadboard debont wires
Posted: Thursday 29 October 2015 18:53
by ThinkPad
I don't know either then...
Posted: Saturday 31 October 2015 20:28
by thecosmicgate
ThinkPad wrote:I don't know either then...
I think i solved the problem lux measurement's are higher then >1000 today
Posted: Sunday 29 November 2015 15:37
by D'rMorris
How did you solve the problem? I have the same issue as you, currently reading 19lux :(.
Any help is highly appreciated :).
Posted: Sunday 29 November 2015 15:56
by thecosmicgate
Changed the sensor , and put it directly on the window.
If you measure today the weather is that bad that the lux is very low (maybe that's all:-) )
Posted: Sunday 29 November 2015 21:13
by D'rMorris
Didn't put it on the window indeed, just inside with lights on. Still, I think that 19 lux is too low. What were your readings today?
Posted: Sunday 29 November 2015 21:43
by ThinkPad
Mine was around 800 during mid-day, and around 200 lux when it started to get a bit dark (~16:30).
Sensor is working really good in my situation. Faced south, behind matte window foil.
I wish i could help, but i already mentioned the things you could try (check pinout, change sensor etc).
Posted: Sunday 14 January 2018 20:34
by sincze
Unfortunately today I had the same issue.
However before re-flashing the sensor was working perfectly.
With that in mind I tried several different BH1750 libraries that I could find on the web and finally found one that worked.
So instead of the sensor being broken.. an 'incompatible' library can also cause problems.
From now on I keep the library with the sketch. :D :lol:
Posted: Thursday 05 April 2018 8:19
by Mandet376
This website was designed as a component of the administration initiatives Panchayat Guru is Electronic Register and Monitoring System to finalize the annual strategy; review strategy application.
