BH1750 lux sensor: reading 54612 lux???
ThinkPad
Re: BH1750 lux sensor: reading 54612 lux???
Post by ThinkPad »
0 lux.
For today it was like this, see attachment.
thecosmicgate
Domoticz version: newest
Post by thecosmicgate »
Dubbel post
Last edited by thecosmicgate on Thursday 29 October 2015 9:50, edited 2 times in total.
It's nice to be important, but it's more important to be nice
Scooter ;)
ThinkPad
Post by ThinkPad »
I deleted two of your messages, it looked like something went wrong :lol:
But like i said, just exchange the BH1750 for a different one, that will probably fix it.
thecosmicgate
ThinkPad wrote:I deleted two of your messages, it looked like something went wrong Image
Already changed the BH1750 to one other , but still this low lux measurement's
Sent from my MotoG3 using Tapatalk
Scooter ;)
ThinkPad
Post by ThinkPad »
Then i would say: check the wiring (connected to analog pin instead of digital pin by accident)? Or maybe the sketch has changed and some calculation is different... Try with a BH1750 example sketch to see what readings you get.
It should definately read more than 72 lux, my Aeon multisensor tops out at 1k lux at day, it sits in my livingroom with no direct sunlight at it.
thecosmicgate
ThinkPad wrote:Then i would say: check the wiring (connected to analog pin instead of digital pin by accident)? Or maybe the sketch has changed and some calculation is different... Try with a BH1750 example sketch to see what readings you get.
I used this example sketch :) is there one other ? Maybe try that one .
I already checked the wiring 10times and already changed this to eliminate that.
I soldered the wires direct on the arduino instead of using the breadboard debont wires
Scooter ;)
ThinkPad
Post by ThinkPad »
I don't know either then...
thecosmicgate
ThinkPad wrote:I don't know either then...
I think i solved the problem lux measurement's are higher then >1000 today
Scooter ;)
D'rMorris
Post by D'rMorris »
How did you solve the problem? I have the same issue as you, currently reading 19lux :(.
Any help is highly appreciated :).
thecosmicgate
Changed the sensor , and put it directly on the window.
If you measure today the weather is that bad that the lux is very low (maybe that's all:-) )
Scooter ;)
D'rMorris
Post by D'rMorris »
Didn't put it on the window indeed, just inside with lights on. Still, I think that 19 lux is too low. What were your readings today?
ThinkPad
Post by ThinkPad »
Mine was around 800 during mid-day, and around 200 lux when it started to get a bit dark (~16:30).
Sensor is working really good in my situation. Faced south, behind matte window foil.
I wish i could help, but i already mentioned the things you could try (check pinout, change sensor etc).
sincze
Domoticz version: 2024.4
Post by sincze »
Unfortunately today I had the same issue.
However before re-flashing the sensor was working perfectly.
With that in mind I tried several different BH1750 libraries that I could find on the web and finally found one that worked.
So instead of the sensor being broken.. an 'incompatible' library can also cause problems.
From now on I keep the library with the sketch. :D :lol:
Pass2php
USB: RFXCom, ZWave, Sonoff 3
MQTT: ZIgbee2MQTT,
ZWAVE: Zwave-JS-UI
Solar: Omnik, PVOutput
Sensors: You name it I got 1.
Mandet376
Post by Mandet376 »
This website was designed as a component of the administration initiatives Panchayat Guru is Electronic Register and Monitoring System to finalize the annual strategy; review strategy application.
