Page 2 of 2
Re: Ikea Ansluta remote (2.4GHz)
Posted: Tuesday 11 October 2016 12:09
by Stuntteam
You need the module from the second link.. that one is 868mhz.. the first one is probably 433mhz.. maybe that can be used later..
Note that this topic is about Ikea Ansluta.. which needs a CC2500 as it is 2.4 Ghz.
Posted: Tuesday 11 October 2016 12:56
by Btje
Correct sorry for the pollution
Posted: Sunday 30 October 2016 17:11
by Bigted
I need a little help
I have purchased the RFLink board and Arduino from Nodo Shop and I have a CC2500 but I'm not sure how to connect it all up
Do I build the kit as supplied and then add the CC2500 directly to the Arduino, do I also need a level shifter between the CC2500 and the Arduino?
Posted: Sunday 30 October 2016 17:43
by Stuntteam
Yes, you can build the kit and then add the CC2500 seperately using a level shifter and some wires (or a breadboard)
Posted: Monday 31 October 2016 12:15
by Bigted
Thanks, just what I needed to know
Posted: Friday 15 December 2017 21:14
by tjabas
Hi!
i also have the ikea ansluta in my kitchen, is there an easy way to be able to control it with domoticz?
i dont have any solder skills, isnt there any usb device that an be plugged in the raspberry pi?
Posted: Sunday 17 December 2017 9:26
by Varazir
Can this hardware replace a Tellstick usb device ?
Posted: Sunday 07 January 2018 22:32
by tjabas
tjabas wrote: Friday 15 December 2017 21:14
Hi!
Anyone knows if there is a finished device, just to plug in the raspberry pi and Domoticz?
Posted: Tuesday 13 February 2018 15:35
by sabpfeiffer
Folks are trying to duplicate the Ansluta signal using a Pi and java:
https://github.com/mdeverdelhan/Ansluta ... eplication
Just tested: it's not working but maybe it's worth diving into it.
Posted: Tuesday 08 January 2019 16:58
by tjabas
Hi!
is there any progress with this ikea ansluta remote?
does anyone know if its possible to use a conbee to simulate the ansluta remote?
or is there possible to hack the ansluta remote and use a conbee z-wave stick to control the ansluta lights?
Posted: Friday 03 May 2019 9:47
by frostwork
hi,
I have some livingcolors gen1 lights which I'd like to control with rflink.
I don't want to solder those tiny little cc2500 chips so I bought one of those:
https://aliexpress.com/item/CC2500-modu ... 68247.html
it doesn't work yet and I'm not sure if I'm doing anything wrong or if the device simply doesn't work with the rflink.
tried this setup:
On CC2500
VCC -> 3.3 V on MEGA
SI -> D51 (via levelshifter to 3.3V)
SCLK -> D52 (via levelshifter to 3.3V)
SO -> D50 (via levelshifter to 3.3V)
GD02 -> Not connected
GND -> Mega GND
G003 -> Not connected
Csn ->D47 (Via levelshifter to 3.3V)
PIN6 on MEGA to Ground on MEGA
(shamelessly stolen from
https://www.letscontrolit.com/forum/vie ... php?t=5909 )
not sure if the RFLinkLoader is supposed to work 100% via wine (I don't use windows), but flashing works. the toggle buttons are all greyed out though. so I flashed it again with avrdude (just to be sure) and tried to enable livingcolors via moserial. the device replied that the cc2500 isn't found though.
- do I have to put any other pins than those above into the levelshifter? (f.e. what about vcc?)
- should the "ready-soldered" cc2500 even work?
would be nice if someone had some hints for me
btw:
I just found this minimal project here. haven't tried it, but maybe you have some use for it:
https://github.com/matlen67/ansluta-control
edit: just also found this device:
https://www.ebay.de/itm/CC2500-2-4GHz-M ... 2966744730
