Page 2 of 7
Re: RFLink - USB Gateway - Introduction
Posted: Monday 14 September 2015 21:32
by sincze
Stuntteam wrote:868mhz support is planned but there is no hardware for it yet. Currently some modules are being tested and a selection has to be made.
Note that this will not be ZWave, it is aimed at commercial sensors operating at 868 mhz in a similar way as the 433mhz versions..
eg. temp, rain, wind sensors, wall switches etc.
Promissing indeed, maybe 868 mhz sensors like the ones used in home security can be supported?
http://www.jablotron.com/nl/
Posted: Friday 25 September 2015 10:19
by MatthijsPH
I would like to hook my Visonic Powermax alarmsystem up to Domoticz, or at least use the many sensors (motion/door/smoke/etc). Should I wait for full RFLink 868 support, or can I order some stuff ahead and give it a try myself? I can order some Arduino equipment (eg. as found on mysensors.org), but one of the problems is I don't know wich 868 transceiver may work and wich ones will never work.
I'm definitely not an expert but I'm willing to take a chance and invest some time.
Posted: Saturday 10 October 2015 22:55
by Moppersmurf
Does RF Link work on my Synology NAS? I've got Domoticz running on my DS214PLAY.
Posted: Saturday 10 October 2015 23:07
by jumbotroll
Moppersmurf wrote:Does RF Link work on my Synology NAS? I've got Domoticz running on my DS214PLAY.
Yes, I have included ch341 drivers for "china" Arduino and acm drivers for "real" Arduino in my Synology builds
This is my RFLink, with "china" Arduino with ch341 chip:
http://www.jadahl.com/rflink.html
Jumbotroll
Posted: Sunday 11 October 2015 15:40
by alexsh1
Hello
Can you use any other Arduino with RFLink? Nano? - I like the size.
Or does it only have to be Mega?
Posted: Sunday 11 October 2015 18:22
by richardtrip
alexsh1 wrote:Hello
If you use the source and disable a lot of plugins that is possible. Be aware that the latest source is not up to date.
Posted: Wednesday 14 October 2015 13:41
by alexsh1
richardtrip wrote:alexsh1 wrote:Hello
In this case, I have to invest in Mega
Posted: Tuesday 20 October 2015 12:27
by rednas
Does this also work on XPEnology? I already installed the Domoticz package.
Posted: Tuesday 20 October 2015 13:40
by Stuntteam
Yes, as long as you have drivers for the Arduino.
Posted: Tuesday 20 October 2015 13:42
by rednas
Do I need to add them manually or are they already included?
Posted: Tuesday 20 October 2015 17:56
by jumbotroll
rednas wrote:Do I need to add them manually or are they already included?
If you use my build, all drivers are included.
Jumbotroll
Posted: Wednesday 21 October 2015 9:38
by rednas
I have it installed, so it should work.
Do I have in this configuration the reset problem with the Arduino?
Posted: Wednesday 21 October 2015 12:22
by Stuntteam
It probably depends on the Arduino board.
If you do experience reset issues, you can take a 10 uF capacitor and connect between reset and ground on the Arduino.
Simply stick the pins of the capacitor in the power connector socket...
Posted: Wednesday 21 October 2015 20:48
by SweetPants
Stuntteam wrote:I will pick up an impuls set from a friend and re-test again.
Any progress? Just bought the RFLink, but it won't switch my Impuls switches while the RFXcom does.
Posted: Thursday 22 October 2015 12:16
by Stuntteam
Check PM..
Posted: Tuesday 27 October 2015 16:03
by asg
Great project! I'm very happy with this!
Anyone any idea when a 868MHz-compatible version of this board will be available?
Posted: Sunday 01 November 2015 20:55
by Backbone
@ Stuntteam, thanks for creating this piece of code for 433 support.
Maybe stupid newbie question.
I build me an RF-LINK on the Mega with the code.
How do I control in Domoticz (DMZ) a 433 RF switch which has for example the code 751245 for ON and 751244 for OFF which is a Eurodomest (Action) switch.
Do I need to create a switch and add on the ON action and the OFF action line the code?
How can I trap the RF action in DMZ that is produced by the hand held remote that is sending the same ON and OFF code?
I like DMZ to syncronize the actions/status from the hand held remote and the DMZ actions.
Thanks, Paco
Posted: Monday 02 November 2015 8:18
by Stuntteam
RFlink will auto-detect the Eurodomest remote.
If Domoticz accepts new hardware devices it will automatically appear in your device list.
20;00;Nodo RadioFrequencyLink - RFLink Gateway V1.1 - R34;
10;version;
20;01;VER=1.1;REV=34;BUILD=07;
20;02;Eurodomest;ID=03696b;SWITCH=00;CMD=ON;
20;03;Eurodomest;ID=03696b;SWITCH=00;CMD=OFF;
20;04;Alecto V4;ID=5828;TEMP=00bf;HUM=17;
Posted: Monday 02 November 2015 11:32
by Backbone
Stunteam,
Thanks for the receipt section.
I asume you view this in the LOG section of DMZ.
Still one question remains as I could not find this info...
When I create a switch should I use: Eurodomest;ID=03696b;SWITCH=00;CMD=ON; in the ON and OFF action of the switch where you should place HTTP or script code?
Paco
Posted: Monday 02 November 2015 12:00
by Stuntteam
No, the log data above is what is actually forwarded to Domoticz.
Domoticz stores this info and uses it when you change the state of a switch.
How it works with auto detected devices:
- you press a button on the remote
- the rflink gateway catches the RF Radio signal, translates it in readable form and gives that to Domoticz
- Domoticz stores the info and creates a device in your device list
- In the device list view you select the green Arrow, give the switch a name and it gets added to the switches tab
- In the switches tab, Whenever you click on the lamp bulb Domoticz will instruct the rflink gateway to send an RF signal.
There is no need to know anything about the command structure and also no need to put data like a device number in any field.
Obviously the above is only valid the first time you press a button on the remote.
Once Domoticz has learned the button it will simply update the status when you turn a device on or off.
