Page 2 of 4
Re: PHP Floorplan, cron script and Google Calendar
Posted: Wednesday 06 January 2016 13:56
by maomanna
I did not set all the variables, because i dont have an apple device or account.
Also i dont have an smsuser or telegram, so these variables are as you set them.
So I only set my domoticzurl and HWurl
Posted: Wednesday 06 January 2016 14:07
by Egregius
Do you see an error on the screen? Or is it just blank? Or just the floorplan image?
Is the PHP server running on the same server as Domoticz?
Is the ip address of the PHP server in the 'local network' settings from Domoticz (to disable authentication)?
Posted: Wednesday 06 January 2016 14:24
by maomanna
it is running on another machine, but the settings are right.
No errors at all, just a blank floorplan.
Posted: Wednesday 06 January 2016 15:30
by Egregius
Can you post the complete code of floorplan.php in a code block please?
Posted: Wednesday 06 January 2016 17:19
by maomanna
<!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN" "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd"><html xmlns="http://www.w3.org/1999/xhtml">
<head><title>Floorplan</title>
<meta http-equiv="Content-Type" content="text/html;charset=UTF-8" />
<meta name="HandheldFriendly" content="true" /><meta name="apple-mobile-web-app-capable" content="yes"><meta name="apple-mobile-web-app-status-bar-style" content="black">
<meta name="viewport" content="width=device-width,height=device-height,user-scalable=yes,minimal-ui" />
<link rel="icon" type="image/png" href="images/domoticzphp48.png">
<link rel="shortcut icon" href="images/domoticzphp48.png" /><link rel="apple-touch-startup-image" href="images/domoticzphp450.png">
<link rel="apple-touch-icon" href="images/domoticzphp48.png" />
<meta name="msapplication-TileColor" content="#ffffff">
<meta name="msapplication-TileImage" content="images/domoticzphp48.png">
<meta name="msapplication-config" content="browserconfig.xml">
<meta name="mobile-web-app-capable" content="yes"><link rel="manifest" href="manifest.json">
<meta name="theme-color" content="#ffffff">
<link href="floorplan.css" rel="stylesheet" type="text/css" />
</head><body>
<?php $start=microtime(true);$time=$_SERVER['REQUEST_TIME'];$offline=$time-300;$eendag=$time-82800;include "secure/functions.php";
if($authenticated){
if(isset($_POST['Schakel'])){if(Schakel($_POST['Schakel'],$_POST['Actie'])=='ERROR') echo '<div id="message" class="balloon">'.$_POST['Naam'].' '.$_POST['Actie'].'<br/>ERROR</div>';if($_POST['Schakel']==572){$mc->set('Heating',2);}}
else if(isset($_POST['Setpoint'])){foreach($_POST as $key=>$value){$value=round($value,0);if(substr($key,0,5)=="Actie"){if(Udevice($_POST['Setpoint'],0,$value)=='ERROR') echo '<div id="message" class="balloon">'.$_POST['Naam'].' '.$value.'<br/>ERROR</div>';else $mc->set('setpoint'.$_POST['Setpoint'],2);}}}
else if(isset($_POST['Udevice'])){if(Udevice($_POST['Udevice'])=='ERROR') echo '<div id="message" class="balloon">'.$_POST['Naam'].' '.$_POST['Actie'].'<br/>ERROR</div>'; }
else if(isset($_POST['dimmer'])){
	if(isset($_POST['dimlevelon_x'])) {if(Dim($_POST['dimmer'],100)=='ERROR') echo '<div id="message" class="balloon">Dimmer '.$_POST['Naam'].' level '.$_POST['dimlevel'].'<br/>ERROR</div>';$mc->set('dimtime'.$_POST['Naam'],$time);$mc->set('dimmer'.$_POST['Naam'],0);}
	else if(isset($_POST['dimleveloff_x'])) {if(Dim($_POST['dimmer'],0)=='ERROR') echo '<div id="message" class="balloon">Dimmer '.$_POST['Naam'].' level '.$_POST['dimlevel'].'<br/>ERROR</div>';$mc->set('dimtime'.$_POST['Naam'],$time);$mc->set('dimmer'.$_POST['Naam'],0);}
	else if(isset($_POST['dimsleep_x'])) {$mc->set('dimmer'.$_POST['Naam'],1);}
	else if(isset($_POST['dimwake_x'])) {if(Dim($_POST['dimmer'],$_POST['dimwakelevel']+1)=='ERROR') echo '<div id="message" class="balloon">Dimmer '.$_POST['Naam'].' level '.$_POST['dimlevel'].'<br/>ERROR</div>';$mc->set('dimmer'.$_POST['Naam'],2);}
	else {if(Dim($_POST['dimmer'],$_POST['dimlevel'])=='ERROR') echo '<div id="message" class="balloon">Dimmer '.$_POST['Naam'].' level '.$_POST['dimlevel'].'<br/>ERROR</div>';$mc->set('dimtime'.$_POST['Naam'],$time);$mc->set('dimmer'.$_POST['Naam'],0);}
else if(isset($_POST['Scene'])){if(Scene($_POST['Scene'])=='ERROR') echo '<div id="message" class="balloon">Scene '.$_POST['Naam'].' activeren'.'<br/>ERROR</div>';if($_POST['Scene']==5) $mc->set('dimtimeEettafel',$time);}
if(isset($_POST['denon'])){$denon_address='http://192.168.0.2';$ctx=stream_context_create(array('http'=>array('timeout'=>2,)));
	$denonmain=simplexml_load_string(file_get_contents($denon_address.'/goform/formMainZone_MainZoneXml.xml?_='.$time,false,$ctx));
	$denonmain=json_encode($denonmain);$denonmain=json_decode($denonmain,TRUE);usleep(10000);
	if($denonmain){
		$denonmain['MasterVolume']['value']=='--'?$setvalue=-80:$setvalue=$denonmain['MasterVolume']['value'];
		$_POST['denon']=='up'?$setvalue=$setvalue+3:$setvalue=$setvalue-3;
		if($setvalue>-10) $setvalue=-10;if($setvalue<-80) $setvalue=-80;
		file_get_contents($denon_address.'/MainZone/index.put.asp?cmd0=PutMasterVolumeSet/'.$setvalue.'.0');}}
$domoticz=json_decode(file_get_contents($domoticzurl.'type=devices&used=true&plan=2'),true);$domotime=microtime(true)-$start;
if($domoticz){
	foreach($domoticz['result'] as $dom) {
		(isset($dom['Type'])?$Type=$dom['Type']:$Type='None');
		(isset($dom['SwitchType'])?$SwitchType=$dom['SwitchType']:$SwitchType='None');
		(isset($dom['SubType'])?$SubType=$dom['SubType']:$SubType='None');
		$name=$dom['Name'];
		if($Type=='Temp + Humidity'||$Type=='Temp'){${'T'.$name}=$dom['Temp'];${'TI'.$name}=$dom['idx'];${'TT'.$name}=strtotime($dom['LastUpdate']);}
		else if($SwitchType=='Dimmer'){${'DI'.$name}=$dom['idx'];$dom['Status']=='Off'?${'D'.$name}='Off':${'D'.$name}='On';$dom['Status']=='Off'?${'Dlevel'.$name}=0:${'Dlevel'.$name}=$dom['Level'];${'DT'.$name}=strtotime($dom['LastUpdate']);}
		else if($Type=='Usage'&&$dom['SubType']=='Electric') ${'P'.$name}=substr($dom['Data'],0,-5);
		else if($Type=='Radiator 1'||$Type=='Thermostat') {${'RI'.$name}=$dom['idx'];${'R'.$name}=$dom['Data'];${'RT'.$name}=strtotime($dom['LastUpdate']);}
		else {
			if(substr($dom['Data'],0,2)=='On') ${'S'.$name}='On';
			else if(substr($dom['Data'],0,3)=='Off') ${'S'.$name}='Off';
			else if(substr($dom['Data'],0,4)=='Open') ${'S'.$name}='Open';
			else ${'S'.$name}=$dom['Data'];${'SI'.$name}=$dom['idx'];${'ST'.$name}=strtotime($dom['LastUpdate']);${'SB'.$name}=$dom['BatteryLevel'];}
	unset($domoticz,$dom);
	if($_POST['Schakel']==6||$_POST['Schakel']==48){
		if($SRaamLiving=='Open') echo '<script language="javascript">alert("WARNING:Raam living open!")</script>';
		if($SAchterdeur=='Open') echo '<script language="javascript">alert("WARNING:Achterdeur open!")</script>';
		if($Spoort=='Open') echo '<script language="javascript">alert("WARNING:Poort open!")</script>';
echo '<div style="position:absolute;top:5px;left:278px;width:130px;text-align:right;"><a href="" style="padding:4px 4px;font-size:33px;font-weight:500;text-align:right;letter-spacing:-2px" title="refresh">'.strftime("%k:%M:%S",$time).'</a></div>
<div class="box" style="top:0px;height:306px;" >
<div class="box2" style="top:240px;left:11px;" ><img src="images/'.$mc->get('weatherimg').'.png"/ width="60px" height="auto"></div>
<div class="box2" style="top:290px;left:13px;background:rgba(222,222,222,0.8);" >'.$mc->get('averagerain').'</div>
<div class="box" style="top:319px;height:505px;">
<form method="POST"><input type="hidden" name="denon" value="up"><input type="image" src="images/arrowup.png" width="48px" height="48px"></form>
<br/><form method="POST"><input type="hidden" name="denon" value="down"><input type="image" src="images/arrowdown.png" width="48px" height="48px"></form>
<br/><form action="denon.php" method="POST"><input type="image" src="images/denon.png" width="48px" height="48px"></form>
<br/><form method="POST"><input type="hidden" name="Scene" value="2"><input type="hidden" name="Naam" value="Radio luisteren"><input type="image" src="images/Amp_On.png" width="48px" height="48px"></form>
<br/><form method="POST"><input type="hidden" name="Scene" value="3"><input type="hidden" name="Naam" value="TV Kijken"><input type="image" src="images/TV_On.png" width="48px" height="48px"></form>
<br/><form method="POST"><input type="hidden" name="Scene" value="4"><input type="hidden" name="Naam" value="Kodi kijken"><input type="image" src="images/kodi.png" width="48px" height="48px"></form>
<br/><form method="POST"><input type="hidden" name="Scene" value="5"><input type="hidden" name="Naam" value="Eten"><input type="image" src="images/eten.png" width="48px" height="48px"></form>
<a href="#" onclick="toggle_visibility(\'Plus\');" style="text-decoration:none"><img src="images/plus.png" width="60px" height="60px"/></a>
</div>';
Dimmer('Lamp keuken',40,420,130); //kamer Tobi
Dimmer('Zithoek',48,125,130);
Dimmer('Eettafel',48,125,270);
Dimmer('Kamer',40,550,350);
Dimmer('Tobi',40,575,190); //kamer Julius
Schakelaar('TV','TV',48,44,88);
Schakelaar('Denon','Amp',48,44,144);
Schakelaar('Kodi','Kodi',36,50,196);
Schakelaar('iMac','imac',40,50,235);
Schakelaar('DiskStation','nas',16,28,267);
Schakelaar('Kristal','Light',36,8,98);
Schakelaar('TVLed','Light',36,8,158);
Schakelaar('Lamp_Bureel','Light',36,8,214);
Schakelaar('Licht_Inkom','Light',40,60,360);
Schakelaar('Keuken','Light',48,157,390);
Schakelaar('Wasbak','Light',30,150,340); //gootsteen
Schakelaar('Kookplaat','Light',30,115,375); //fornuis
Schakelaar('Werkblad','Light',30,216,420); //werkblad
Schakelaar('LichtBadkamer1','Light',40,440,368); //badkamer
Schakelaar('LichtBadkamer2','Light',20,480,348); //badkamer
Schakelaar('Licht_Voordeur','Light',40,60,441);
Schakelaar('Licht_Hall','Light',42,416,252);
Schakelaar('Licht_Hall_Auto','Clock',36,420,299);
Schakelaar('Licht_Garage','Light',48,305,209);
Schakelaar('ZolderG','Light',30,315,140);
Schakelaar('Licht_Garage_Auto','Clock',36,312,299);
Schakelaar('Pluto','Laptop',25,370,217);
Schakelaar('Thuis','Home',48,268,428);
Schakelaar('Slapen','Sleepy',48,335,428);
Schakelaar('Terras','Light',48,13,15);
Schakelaar('Terras','Light',48,77,15);
Schakelaar('Brander','Fire',48,765,260);
Schakelaar('Kerstboom','Kerstboom',48,164,88);
Schakelaar('Licht_Zolder','Light',48,705,260);
Schakelaar('Bureel_Tobi','Plug',36,780,380);
Thermometer('Buiten',110,140,17);
Thermometer('Living',70,178,232);
Thermometer('Badkamer',70,432,447);
Thermometer('Kamer',65,578,447);
Thermometer('KamerTobi',65,470,137);
Thermometer('KamerJulius',65,578,137);
Thermometer('Zolder',70,707,135);
Setpoint('Living',40,189,190);
Setpoint('Badkamer',40,443,405);
Setpoint('Kamer',40,586,405);
Setpoint('KamerTobi',40,479,95);
Setpoint('KamerJulius',40,586,95);
//Radiator('LivingZZ',-90,221,77);
//Radiator('BadkamerZ',0,403,349);
//Radiator('KamerTobiZ',-90,463,77); //tobi
//Radiator('KamerJuliusZ',-90,583,77); //julius
//Radiator('KamerZ',90,542,456); //kamer
echo '<div id="Plus" class="dimmer" style="display:none;">';
Schakelaar('Meldingen','Alarm',48,180,80);
Schakelaar('Heating','Fire',48,265,80);
echo '<div style="position:absolute;top:5px;right:5px;z-index:1000;"><a href=""><img src="images/close.png" width="72px" height="72px"/></a></div></div>';
if($SThuis=='Off'||$SSlapen=='On'){Secured(52,88,250,196);Secured(50,345,129,57);Secured(255,88,316,141);}
if($SThuis=='Off'){Secured(404,212,129,65);Secured(469,214,45,66);}
if($SPIR_Living!='Off') Motion(52,88,250,196);
if($SPIR_Inkom!='Off') Motion(50,345,129,57);
if($SPIR_Garage!='Off') Motion(255,88,316,141);
if($SPIR_Hall!='Off'){Motion(404,212,129,65);Motion(469,214,45,66);}
if($STDeurbel>$eendag) Timestamp('Deurbel',-90,17,462);
if($STPIR_Garage>$eendag) Timestamp('PIR_Garage',0,255,216);
if($STPIR_Living>$eendag) Timestamp('PIR_Living',0,233,120);
if($STPIR_Inkom>$eendag) Timestamp('PIR_Inkom',0,92,395);
if($STPIR_Hall>$eendag) Timestamp('PIR_Hall',0,403,215);
if($STAchterdeur>$eendag) Timestamp('Achterdeur',-90,280,79);
if($STpoort>$eendag) Timestamp('poort',90,315,381);
if($STBrander>$eendag) Timestamp('Brander',0,812,265);
if($STLicht_Zolder>$eendag) Timestamp('Licht_Zolder',0,688,266);
if($STBureel_Tobi>$eendag) Timestamp('Bureel_Tobi',0,782,433);
if($Spoort!='Closed') echo '<div style="position:absolute;top:262px;left:404px;width:25px;height:128px;background:rgba(255,0,0,1);z-index:-10;"></div>';
if($SAchterdeur!='Closed') echo '<div style="position:absolute;top:264px;left:81px;width:30px;height:48px;background:rgba(255,0,0,1);z-index:-10;"></div>';
if($SRaamLiving!='Closed') echo '<div style="position:absolute;top:46px;left:81px;width:8px;height:165px;background:rgba(255,0,0,1);z-index:-10;"></div>';
if($SRaamKamerTobi!='Closed') echo '<div style="position:absolute;top:449px;left:81px;width:7px;height:43px;background:rgba(255,0,0,1);z-index:-10;"></div>';
if($SRaamKamerJulius!='Closed') echo '<div style="position:absolute;top:569px;left:81px;width:7px;height:43px;background:rgba(255,0,0,1);z-index:-10;"></div>';
if($SRaamKamer!='Closed') echo '<div style="position:absolute;top:586px;left:481px;width:7px;height:43px;background:rgba(255,0,0,1);z-index:-10;"></div>';
if($SDeurBadkamer!='Closed') echo '<div style="position:absolute;top:421px;left:341px;width:7px;height:46px;background:rgba(255,0,0,1);z-index:-10;"></div>';
if($SBureel_Tobi!='Off') echo'<div style="position:absolute;top:800px;left:425px;width:50px;cursor:pointer;text-align:center;">'.$PP_Bureel_Tobi.'</div>';
$execution= microtime(true)-$start;$phptime=$execution-$domotime;echo '<div style="position:absolute;top:652px;left:90px;width:400px;text-align:left;font-size:12px" >D'.round($domotime,3).'|P'.round($phptime,3).'|T'.round($execution,3).'<br/>';print_r($_POST);echo '</div>';
} else echo '<div style="background:#ddd;"><a href="">Geen verbinding met Domoticz</a></div>';
} else {header("Location:index.php");die("Redirecting to:index.php");}
<script type="text/javascript">
function toggle_visibility(id){var e=document.getElementById(id);if(e.style.display=='inherit') e.style.display='none';else e.style.display='inherit';}
setTimeout('window.location.href=window.location.href;',5850);
</script>
</body></html>
this is mine
Posted: Wednesday 06 January 2016 17:51
by Egregius
I would first say:
try adding
$authenticated = true;
just before
if($authenticated){
But, if that was the problem you should be redirected to index.php
Also, when the domoticz url isn't good it should drop a line 'Geen verbinding met Domoticz'.
You should delete all other switches or place // in front of them. You'll get tons of errors.
Posted: Wednesday 06 January 2016 18:04
by maomanna
nah still nothing.
I deleted all witches etc and added the authenticated line.
Also I see a double line in Functions.php about authenticated?
Posted: Wednesday 06 January 2016 19:51
by Egregius
Is there a line like 'error_reporting(E_ALL);ini_set("display_errors", "on");' in secure/functions.php and it's not commented out?
Indeed, in the github version of functions.php there are 2 lines of authenticated, on false and one true. The true line is in my version replaced with my own usersystem wich I don't like to share.
Posted: Wednesday 06 January 2016 21:22
by maomanna
Indeed it was uncommented.
But even when I remove the // it still gives me no errors...
kinda strange if you ask me.
Seems that I have php 5.2.0
Posted: Wednesday 06 January 2016 21:45
by Egregius
PHP 5.2 is already 5 years end of life...
Posted: Wednesday 06 January 2016 22:40
by maomanna
I was wrong,
it is PHP Version 5.5.9-1ubuntu4.14
Posted: Wednesday 06 January 2016 23:46
by Egregius
And Apache or Nginx as server?
Just because I wanted to give nginx a try and I get a white page. Trying to figure it out...
Posted: Thursday 07 January 2016 21:35
by maomanna
Apache, Apache/2.4.7 (Ubuntu)
with thse loaded modules:
core mod_so mod_watchdog http_core mod_log_config mod_logio mod_version mod_unixd mod_access_compat mod_alias mod_auth_basic mod_authn_core mod_authn_file mod_authz_core mod_authz_groupfile mod_authz_host mod_authz_user mod_autoindex mod_cgi mod_deflate mod_dir mod_env mod_filter mod_mime prefork mod_negotiation mod_php5 mod_rewrite mod_setenvif mod_status
cURL enabled, version 7.35.0
json enabled, version 1.3.2
mySQL version 5.5.46
Posted: Thursday 07 January 2016 22:01
by Egregius
Do you already have other php files on that server?
What about phpinfo? Does it run?
<?php
phpinfo();
Posted: Thursday 07 January 2016 22:56
by maomanna
Yes it runs, using that file I got the versions mentioned above.
It shows floorplan.php, so apache and php works fine.
Maybe the connection to domoticz fails??
Posted: Thursday 07 January 2016 23:11
by Egregius
If that's the case you should see an error about it:
Guess you'll have to start with a small part of the page and built it up peace by peace.
<?php
$domoticz=json_decode(file_get_contents($domoticzurl.'json.htm?type=devices&used=true'),true);
if($domoticz){
		$name=$dom['Name'];
		else {
echo '<pre>';print_r(get_defined_vars());echo '</pre>';
} else echo 'No connection with domoticz';
That should give you a nice list with all switches and stuff:
Posted: Friday 08 January 2016 17:36
by Egregius
Try it this way:
Code from below, added part by part in a testfile. Split it at each //split line
<?php
include('secure/functions.php');
echo '<h2>Plain text of json</h2>';
echo file_get_contents($domoticzurl.'json.htm?type=devices&used=true');
echo '<hr>';
//split
echo '<h2>JSON decode</h2>';
print_r(json_decode(file_get_contents($domoticzurl.'json.htm?type=devices&used=true'),true));
echo '<hr>';
//split
echo '<h2>In a nice printed array</h2><pre>';
print_r($domoticz);
echo '</pre><hr>';
//split
echo '<h2>Looping thru the array and put everything in vars</h2><pre>';
		isset($dom['Type'])?$Type=$dom['Type']:$Type='None';
		isset($dom['SwitchType'])?$SwitchType=$dom['SwitchType']:$SwitchType='None';
		isset($dom['SubType'])?$SubType=$dom['SubType']:$SubType='None';
		$name=$dom['Name'];
		if($Type=='Temp'){${'T'.$name}=$dom['Temp'];${'TI'.$name}=$dom['idx'];${'TT'.$name}=strtotime($dom['LastUpdate']);}
		else {
		echo "Name = $name\n";
//split
echo '<h2>Print all vars</h2><pre>';
echo '</pre>';
Posted: Saturday 09 January 2016 20:47
by maomanna
Parse error: syntax error, unexpected end of file in /var/www/floorplan/secure/functions.php on line 233
After putting
at the end it was fixed.
Since then i get:
Fatal error: Class 'Memcached' not found in /var/www/floorplan/secure/functions.php on line 22
Memcached installed in Ubuntu but did solve that error.
Now I see the "test"page and see.
Notice: Undefined index: result in /var/www/floorplan/test.php on line 18
Warning: Invalid argument supplied for foreach() in /var/www/floorplan/test.php on line 18
Now i dont know how to fix that!
Posted: Saturday 09 January 2016 22:59
by Egregius
The ?> is closing tag for php. Must be a setting in php.ini. I read in several places that it's better not to close.
I'll put the code back in a testfile to see line 18 again, on mobile now and of to bed, will be something for tomorrow.
Posted: Sunday 10 January 2016 7:07
by Egregius
What was under the heading 'In a nice printed array'?
Edit: Oh, I rememberd you sent me a link.
You removed the lines above that. So $domoticz isn't set anymore.
