[Python] Control Mitsubishi MAC-557IF-E airconditioning
bagnico
Re: [Perl] Control Mitsubishi MAC-557IF-E airconditioning
Post by bagnico »
Do you have some floor or area ?
Can you delete them ?
bran2000
Post by bran2000 »
My area is composed like this :
Home ==> Kitchen (the unit is here)
gysmo38
Post by gysmo38 »
First thank bagnico for the good work.
I understand the problem is because bran2000 use Areas.
There is different way to add device.
Building -> devices
Building -> areas -> devices
Building -> floors -> devices
I send PM to bran2000 with a version for Building -> areas -> devices.
I will update code to work with three ways.
bran2000
Post by bran2000 »
just one quick question, in the script v0.4, the switch seems display the status device, is there a way to have a switch which will turn on/off the airconditionning ? or a another switch will set the temperature ?
thanks
gysmo38
Post by gysmo38 »
I made a news version 0.5.
It should work in all cases now: floors, areas, devices.
It is possible to configure MELCloud login, password directly in domoticz using user variables
#!/usr/bin/perl
#Dependency: libwww-perl, libjson-perl
# Original script : gysmo38
# Modifications : bagnico
# Release notes
# Version 0.5:
# - MELCloud login, password can be define in domoticz using User variables : MEL_login (string) an MEL_pass (string)
# - debug can be define in domoticz using User variables: MEL_debug (int)
# - search units in Areas, Devices and Floors
# Version 0.4:
# - add vane option horizontal
# - Change report to domoticz for informations (MODE | T°C | TIME_NEXT_UPDATE)
# - Change split time (remove .xxx)
# Version 0.3:
# - setDomDeviceMode OK
# - Script works with no Areas
# - add 1 hours for uptime (for french)
# Version 0.2:
# - add 2 hours for uptime time (for french)
# - add mode option
# - add fan option
# - add vane option (only vertical)
# - add settemp option
# Version 0.1: First release (with very dirty code...)
# - switch on / off unit
# - report room temperature
# - report unit temperature set
# - report next unit update
use HTTP::Request::Common qw(POST GET);
use HTTP::Headers;
use LWP::UserAgent;
use JSON;
use Data::Dumper;
# Configuration
my $domIP = "192.168.1.1";         # Domoticz IP
my $domPORT = "8080";      # Domoticz PORT
#Define here or define user variables in domoticz
#MELCLOUD_login(string), MELCLOUD_pass(string) and MELCLOUD_debug(int)
my $Email = "exemple\@exemple.net";  # Email used to login to MELcloud
my $Password = "password";       # Password used lo login to MELcloud
my $debug = 1;                  # 0 = no debug, 1 = debug
my @devicesInfos;               # List of all devices. Add block for new devices
#Device 1
$devicesInfos{"Salle"}{"idx_status"} = "88";	# IDX of status device (type switch)
$devicesInfos{"Salle"}{"idx_temp"} = "90";		# IDX of temperature device (type temp)
$devicesInfos{"Salle"}{"idx_info"} = "92";	# IDX of update time device (type text)
$devicesInfos{"Salle"}{"idx_setTemp"} = "89";	# IDX of set temp device (type set point)
#Device n
#$devicesInfos{"Bib"}{"idx_status"} = "104";
#$devicesInfos{"Bib"}{"idx_temp"} = "97";
#$devicesInfos{"Bib"}{"idx_info"} = "112";
#$devicesInfos{"Bib"}{"idx_setTemp"} = "108";
#   Functions
sub debug {
      my ($msg) = @_;
      if ($debug) {
         print $msg."\n";
sub getConfDomoticz {
	  $debug = 1;
      my $url = "http://$domIP:$domPORT/json.htm?type=command&param=getuservariables";
      my $ua = LWP::UserAgent->new();
      # Set our own user-agent string!
      $ua->agent("Domoticz Gysmo");
      require HTTP::Request;
      $req = HTTP::Request->new(GET => $url);
      # Fire the cannon now !
      my $res = $ua->request($req);
      # Get the error back from the server if any
      my $err = $res->status_line;
      # Get server body text, $_ used in regexp on next line
      $json = $res->decoded_content;
	  my $decoded = JSON->new->utf8(0)->decode($json);
	  my @user_variables = @{$decoded->{'result'}};
	  foreach my $user_variable ( @user_variables ) {
		if ($user_variable->{"Name"} eq "MEL_login") {
			$Email = $user_variable->{"Value"};
		elsif ($user_variable->{"Name"} eq "MEL_pass") {
			$Password = $user_variable->{"Value"};
		elsif ($user_variable->{"Name"} eq "MEL_debug") {
			$debug = $user_variable->{"Value"};
      if (/Illegal Operation/ig || $err != 200) {
         return "Server returned error: $err\n";
      else {
#         $result = $1 if /(?:Status\"\ :)+(.*?),/s;
#         debug("receive from domoticz: ".$decoded);
         return $result;
sub time_offset {
      my ($time,$offset) = @_;
      @split_time = split(/:/,$time);
     # debug("Time: ".$split_time[0]);
      if ($split_time[0] <= 22) {
            $split_time[0] = $split_time[0] + 1;
      elsif ($split_time[0] == 23) {
            $split_time[0] = 00;
     $result = join(":",$split_time[0],$split_time[1],$split_time[2]);
     @timeok = split(/\./,$result);
      return $timeok[0];
sub getDOMDeviceStatus {
      my ($idx) = @_;
      my $url = "http://$domIP:$domPORT/json.htm?type=devices&rid=".$idx;
      $_ = $res->decoded_content;
      else {
         debug("receive from domoticz: ".$result);
         return $result;
sub login {
   #Parameters
   my ($Email,$Password) = @_;
   #Variables
   my $AppVersion = "1.9.3.0";
   my $Language = "7";
   my $CaptchaChallenge = "";
   my $CaptchaResponse = "";
   my $Persist = "true";
   my $url = "https://app.melcloud.com/Mitsubishi.Wifi.Client/Login/ClientLogin";
   # set up the stuff
   # file.cgi should just return the data sent for this test
   # These seem to be like <input type=text name=A value=$A > off a form...
   my $req = POST $url, [
   AppVersion => "$AppVersion",
   CaptchaChallenge => "$CaptchaChallenge",
   CaptchaResponse => "$CaptchaResponse",
   Email => "$Email",
   Language => "$Language",
   Password => "$Password",
   Persist => "$Persist"
   elsif(/\"ErrorId\":1/ig) {
      return "Bad password\n";
   elsif(/\"ErrorId\":null/ig) {
      $result  = $1 if /(?:ContextKey\":\")+(.*?)\"/s;
      debug ("context ID: ".$result);
      return $result;
   else {
      return "Unknow error";
sub getMELBuildingID {
   #Parameters
   my ($ContextKey,$devicename) = @_;
   #Variables
   my $url = "https://app.melcloud.com/Mitsubishi.Wifi.Client/User/ListDevices";
   # set up the stuff
   $req->header("X-MitsContextKey" => $ContextKey);
   my $decoded = JSON->new->utf8(0)->decode($_);
   my $result = "0";
   foreach my $building (@$decoded) {
            @devices = @{$building->{'Structure'}{'Floors'}};
            foreach my $device (@devices) {
              if ( $device->{'DeviceName'} =~ $devicename) {
                $result =  $device->{'BuildingID'};
    debug("BuildingID: ".Dumper($result));
            @devices = @{$building->{'Structure'}{'Devices'}};
		@build = @{$building->{'Structure'}{'Areas'}};
		foreach my $area (@build) {
				@devices = @{$area->{'Devices'}};
   else {
   # debug("Building ID: ".Dumper($decoded));
      return "$result";
sub getMELDeviceID {
   #Parameters
   #Variables
   # set up the stuff
   my $result = "0";
                  $result =  $device->{'DeviceID'};
		debug("DeviceID: ".Dumper($result));
   else {
      # debug("Device ID: ".Dumper($decoded));
      return "$result";
sub listDevices {
   #Parameters
   my ($ContextKey) = @_;
   #Variables
   # set up the stuff
   else {
      $result = $_;
      debug("list devices: ".$result);
      return "$result";
sub getAirConInfos {
   #Parameters
   my ($contextKey,$deviceID,$buildingID) = @_;
   debug("getairconinfos : ".$contextKey,$deviceID,$buildingID);
   #Variables
   my $url = 'https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/Get?id=' . $deviceID . '&buildingID=' . $buildingID;
   # debug("device status : ". $url);
   #return $url;
   # set up the stuff
   $req->header("X-MitsContextKey" => $contextKey);
   else {
      # debug("device status : ". $decoded);
      return $decoded;
sub setDomDeviceStatus {
   #Parameters
   my ($idDomDevice,$deviceInfos) = @_;
   #Variables
   $domStatus = getDOMDeviceStatus($idDomDevice);
   if ($deviceInfos->{'Power'} =~ /true/ && $domStatus =~ /"Off"/) {
      $switchcmd = "On";
   my $url = "http://$domIP:$domPORT/json.htm?type=command&param=switchlight&idx=".$idDomDevice."&switchcmd=".$switchcmd;
   debug("send to domoticz: ".$url);
   else {
      $result = $1 if /(?:status\"\ :)+(.*?),/s;
      return $result;
   elsif ($deviceInfos->{'Power'} =~ /false/ && $domStatus =~ /"On"/) {
      $switchcmd = "Off";
   else {
      return $result;
   else {
         debug("send to domoticz: nothing to send");
sub setDomDeviceTempRoom {
   #Parameters
   my $url = "http://$domIP:$domPORT/json.htm?type=command&param=udevice&idx=".$idDomDevice."&nvalue=0&svalue=".$deviceInfos->{'RoomTemperature'};
   else {
      return $result;
sub setDomDeviceInfo {
   #Parameters
   my $mode = $deviceInfos->{'OperationMode'};
   @timenextupdate = split(/T/,$deviceInfos->{'NextCommunication'});
   if ( $mode == 1) {
      $modeclim = 'MODE CHAUD';
   elsif ( $mode == 2) {
      $modeclim = 'MODE SECHAGE';
   elsif ( $mode == 3) {
      $modeclim = 'MODE FROID';
   elsif ( $mode == 7) {
      $modeclim = 'MODE VENTILATION';
   elsif ( $mode == 8) {
      $modeclim = 'MODE AUTO';
   my $url = "http://$domIP:$domPORT/json.htm?type=command&param=udevice&idx=".$idDomDevice."&nvalue=0&svalue=".$modeclim."%20|%20 ".$deviceInfos->{'SetTemperature'}."%20°C%20|%20".time_offset($timenextupdate[1],2);
   else {
      return $result;
sub setMELDevicePower {
   #Parameters
   my ($contextKey,$status,$deviceInfos,$idx) = @_;
   if($status =~ /on/ ) {
      $deviceInfos->{'Power'} = "true";
   elsif($status =~ /off/ ) {
      $deviceInfos->{'Power'} = "false";
   $deviceInfos->{'EffectiveFlags'} = "1";
   $deviceInfos->{'HasPendingCommand'} = "true";
   $json_device = JSON->new->utf8->encode($deviceInfos);
   #Variables
   my $url = 'https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/SetAta';
   #return $url;
   # set up the stuff
   $req = HTTP::Request->new(POST => $url);
   $req->header('content-type' => 'application/json');
   $req->content($json_device);
   debug($_);
      print "Server returned error: $err\n";
   else {
      debug("Update setMELDevicePower : OK");
sub setMELDeviceFan {
   #Parameters
   my ($contextKey,$temp,$deviceInfos,$idx) = @_;
   $deviceInfos->{'SetFanSpeed'} = $temp;
   $deviceInfos->{'EffectiveFlags'} = "8";
   #Variables
   # set up the stuff
   else {
      debug("Update setMELDeviceFan : OK");
sub setMELDeviceMode {
   #Parameters
   my ($contextKey,$mode,$deviceInfos,$idx) = @_;
   # Mode value : 1 warm, 2 dry, 3 cool, 7 vent, 8 auto
   if ($mode =~ warm) {
      $deviceInfos->{'OperationMode'} = 1;
   elsif ($mode =~ dry) {
      $deviceInfos->{'OperationMode'} = 2;
   elsif ($mode =~ cool) {
      $deviceInfos->{'OperationMode'} = 3;
   elsif ($mode =~ vent) {
      $deviceInfos->{'OperationMode'} = 7;
   elsif ($mode =~ auto) {
      $deviceInfos->{'OperationMode'} = 8;
   $deviceInfos->{'EffectiveFlags'} = "6";
   #Variables
   # set up the stuff
   else {
      debug("Update setMELDeviceMode : OK");
sub setMELDeviceVaneVertical {
   #Parameters
   my ($contextKey,$vane,$deviceInfos,$idx) = @_;
   $deviceInfos->{'VaneVertical'} = $vane;
   $deviceInfos->{'EffectiveFlags'} = "16";
   #Variables
   # set up the stuff
   else {
      debug("Update setMELDeviceVaneVertical : OK");
sub setMELDeviceVaneHorizontal {
   #Parameters
   $deviceInfos->{'VaneHorizontal'} = $vane;
   #Variables
   # set up the stuff
   else {
      debug("Update setMELDeviceVaneHorizontal : OK");
sub setMELDeviceTemp {
   #Parameters
   $deviceInfos->{'SetTemperature'} = $temp;
   $deviceInfos->{'EffectiveFlags'} = "4";
   #Variables
   # set up the stuff
   else {
      debug("Update setMELDeviceTemp : OK");
sub init_mel {
   #Parameters
   my ($search_name) = @_;
   $contextID = login($Email,$Password);
   foreach my $name (keys %devicesInfos)  {
      if ( $name =~ $search_name ) {
         $buildingID = getMELBuildingID($contextID,$name);
         $deviceID = getMELDeviceID($contextID,$name);
# Main program
#Get conf from Domoticz
getConfDomoticz();
# Arguments
if ($ARGV[0] =~ /report/) {
      debug("############################");
      debug("# Reporting device: " . $name ." #");
      $infosAirCon = getAirConInfos($contextID,$deviceID,$buildingID);
      setDomDeviceTempRoom($devicesInfos{$name}{"idx_temp"},$infosAirCon);
      setDomDeviceStatus($devicesInfos{$name}{"idx_status"},$infosAirCon);
      setDomDeviceInfo($devicesInfos{$name}{"idx_info"},$infosAirCon);
elsif ($ARGV[0] =~ /test/) {
   init_mel($ARGV[1]);
   debug("Send command to building:" . $buildingID);
   debug("Send command to device:" . $deviceID);
elsif ($ARGV[0] =~ /temp/ && exists $devicesInfos{$ARGV[2]}{'idx_status'}) {
   init_mel($ARGV[2]);
   @temp = split(/:/,$ARGV[1]);
   setMELDeviceTemp($contextID,$temp[0],$infosAirCon,$devicesInfos{$ARGV[2]}{'idx_update'});
elsif ($ARGV[0] =~ /fan/ && exists $devicesInfos{$ARGV[2]}{'idx_status'}) {
   init_mel($ARGV[2]);
   debug("Send commande to device:" . $buildingID);
   setMELDeviceFan($contextID,$ARGV[1],$infosAirCon,$devicesInfos{$ARGV[2]}{'idx_update'});
elsif ($ARGV[0] =~ /power/ && exists $devicesInfos{$ARGV[2]}{'idx_status'}) {
   init_mel($ARGV[2]);
   setMELDevicePower($contextID,$ARGV[1],$infosAirCon,$devicesInfos{$ARGV[2]}{'idx_update'});
elsif ($ARGV[0] =~ /mode/ && exists $devicesInfos{$ARGV[2]}{'idx_status'}) {
   init_mel($ARGV[2]);
   setMELDeviceMode($contextID,$ARGV[1],$infosAirCon,$devicesInfos{$ARGV[2]}{'idx_update'});
elsif ($ARGV[0] =~ /vanevertical/ && exists $devicesInfos{$ARGV[2]}{'idx_status'}) {
   init_mel($ARGV[2]);
   setMELDeviceVaneVertical($contextID,$ARGV[1],$infosAirCon,$devicesInfos{$ARGV[2]}{'idx_update'});
elsif ($ARGV[0] =~ /vanehorizontal/ && exists $devicesInfos{$ARGV[2]}{'idx_status'}) {
   init_mel($ARGV[2]);
   setMELDeviceVaneHorizontal($contextID,$ARGV[1],$infosAirCon,$devicesInfos{$ARGV[2]}{'idx_update'});
elsif ($ARGV[0] =~ /help/) {
   print "-------------------------- MELCLOUD PERL FOR DOMOTICZ v0.5 --------------------------\n";
   print "report: send status of devices to domoticz. Use it for crontab\n";
   print "power on/off DEVICENAME: power on or off a device.\n";
   print "mode modename DEVICENAME: choose mode warm,dry,cool,vent or auto\n";
   print "temp T° DEVICENAME: set temperature device. \n";
   print "fan FAN_SPEED DEVICENAME: set fan speed of the device. \n";
   print "vanevertical VANE_POS DEVICENAME: set van position to 1 - 5, 0 to auto and 7 to move . \n";
   print "vanehorizontal VANE_POS DEVICENAME: set van position to 1 - 5, 0 to auto and 12 to move . \n";
   print "more to come...\n";
else {
   print "Nothing to do. Type help for help ;)\n";
bran2000
Post by bran2000 »
hi,
i confirm it works perfectly !
thanks for your work
tobox
Post by tobox »
Thanks for the code! I took the necessary parts from it and connected my FHEM installation to our Mitsubishi airconditionings. Only setting the horizontal vane did not work properly. The settings were updated in melcloud, but not in the actual air conditioning. I used the firefox debugger to peek into the communication to find the differences: after changing
to
   $deviceInfos->{'EffectiveFlags'} = "256";
in setMELDeviceVaneHorizontal, everything is working as expected.
Regards,
Thomas
wetzeljipi
Post by wetzeljipi »
Hello
I install your script in V0.5 but when I execute the script. I obtain an error.
2016-08-15 13:40:29.342 Executing script: /home/pi/domoticz/scripts/melcloud.pl
2016-08-15 13:40:29.457 Error: Error executing script command (/home/pi/domoticz/scripts/melcloud.pl). returned: 32256
I also verify the login melcloud, the ip adress and port and the index of the devices.
I have domoticz in a raspberry pi.
Best regard
Jean-Paul
gysmo38
Post by gysmo38 »
How do you use the script?
The script needs parameters to work. You can try to execute it in a shell to test it.
For exemple try melcloud.pl report. That will report the status of all devices in melcloud.
Best regards
Fred
wetzeljipi
hello,
I obtain this
pi@raspberrypi ~ $ perl /home/pi/domoticz/scripts/melcloud.pl report
malformed JSON string, neither array, object, number, string or atom, at character offset 0 ( before "Can't connect to 192...") at /home/pi/domoticz/scripts/melcloud.pl line 93
gysmo38
Post by gysmo38 »
Ok can you send me the line code 93?
Because the line number depend the number of device that you define.
Do you use auth for domoticz? Do you use SSL(https)?
Because now, it only work with http and no auth.
wetzeljipi
gysmo38 wrote:Ok can you send me the line code 93?
Line 93 "my $decoded = JSON->new->utf8(0)->decode($json);"
I use auth but not in local only with a public adress and I don't use SSL
gysmo38
Post by gysmo38 »
Sorry for the delay.
I have got the same error if i put wrong ip address in configuration.
Can you check that you have the right ip addresse in $domIP ?
Put your local IP address not the public.
Example: $domIP = "192.168.1.1";
Check to have to space in it.
I am preparing a new version with seperate file for configuration and a message for this error.
Loops
Post by Loops »
Hi !
Just a little message to say you a big thank's for this script ! It is working perfectly in my DZ !
(and sorry for my poor english)
JC
steppi
Post by steppi »
Hello everyone!
I installed your script I named melcloud.pl but unfortunately I get these errors:
"Raspberry Pi pi @: ~ $ ./melcloud.pl report
unexpected end of string while parsing JSON string, character at offset 5 (before "uccess: false, Error ...") at ./melcloud.pl line 230 "
Line 230:
Do you have any idea of how it can solve? Thank you!
gysmo38
Post by gysmo38 »
Have you sure to put correct login and password for melcloud?
You need an escape charater for login: exemple $Email = "exemple\@exemple.net";
Do not delete \ before the @
gysmo38
Post by gysmo38 »
I make a new version to separate the script and confguration.
I think, it will be easier to help people.
So the script have two files.
Config file:
#!/usr/bin/perl
# Configuration
$domIP = "X.X.X.X";         # Domoticz IP
$Email = "EMAIL";  # Email used to login to MELcloud
$Password = "PASSWORD";       # Password used lo login to MELcloud
#Define here or define virtuals devices like this
# Power unit: type: switch; name: MEL Power NAMEDEVICE
# Mode unit: type: selector; name: MEL Mode NAMEDEVICE
#		-> Check hide off level
#		-> Level 10 : Warm   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl mode warm NAMEDEVICE
#		-> Level 20 : Cool   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl mode cool NAMEDEVICE
#		-> Level 30 : Vent   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl mode vent NAMEDEVICE
#		-> Level 40 : Dry   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl mode dry NAMEDEVICE
#		-> Level 50 : Auto   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl mode auto NAMEDEVICE
# Fan speed unit: type: selector; name: MEL Fan NAMEDEVICE
#		-> Level 10 : Level 1   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl fan 1 NAMEDEVICE
#		-> Level 20 : Level 2   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl fan 2 NAMEDEVICE
#		-> Level 30 : Level 3   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl fan 3 NAMEDEVICE
#		-> Level 40 : Level 4   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl fan 255 NAMEDEVICE
#		-> Level 50 : Silence   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl fan 0 NAMEDEVICE
#		-> Level 60 : Auto   Script Commande: script:///home/pi/domoticz/scripts/melcloud.pl fan auto NAMEDEVICE
# Temp unit report: type:  name: MEL Temp NAMEDEVICE
# Set temp unit: type:  name: MEL Therm NAMEDEVICE
# Infos unit: type: text name: MEL Infos NAMEDEVICE
#Device 1
$devicesInfos{"Salle"}{"idx_mode"} = "151";	# IDX of status device (type selector Off=0, Hot=10, Cold=20, Vent=30, Dry=40, Auto=50)
#Device 2
#Device 3
$devicesInfos{"Maxime"}{"idx_status"} = "103";
$devicesInfos{"Maxime"}{"idx_temp"} = "96";
$devicesInfos{"Maxime"}{"idx_info"} = "111";
$devicesInfos{"Maxime"}{"idx_setTemp"} = "107";
#Device 4
$devicesInfos{"Simon"}{"idx_status"} = "102";
$devicesInfos{"Simon"}{"idx_temp"} = "95";
$devicesInfos{"Simon"}{"idx_info"} = "110";
$devicesInfos{"Simon"}{"idx_setTemp"} = "106";
#Device 5
$devicesInfos{"Parents"}{"idx_status"} = "101";
$devicesInfos{"Parents"}{"idx_temp"} = "94";
$devicesInfos{"Parents"}{"idx_info"} = "109";
$devicesInfos{"Parents"}{"idx_setTemp"} = "105";
Script file:
#!/usr/bin/perl
# Release notes
# Version 0.6:
# - seperate configuration in config.pl (more easy to help people)
# - add use strict and use warnings
# - clean code to have no errors with strict and warnings
# - for using selector swictch in domoticz, add power on command when change mode
# Version 0.5:
# Version 0.4:
# Version 0.3:
# Version 0.2:
# - add mode option
# - add fan option
use strict;
use warnings;
use HTTP::Headers;
use LWP::UserAgent;
use JSON;
use Data::Dumper;
# Include config variables
require 'config.pl';
our $domIP;
our $domPORT;
our $Email;
our $Password;
our $debug;
our @devicesInfos;
our %devicesInfos;
#  Variables
my $version = "0.6";
my $contextID;
my $infosAirCon;
my $buildingID;
my $deviceID;
my @temp;
#   Functions
sub debug {
      my ($msg) = @_;
      if ($debug) {
         print $msg."\n";
sub domSendJSON {
	  my ($params) = @_;
	  my $result;
      my $url = "http://$domIP:$domPORT/json.htm?$params";
      my $req = HTTP::Request->new(GET => $url);
      my $json = $res->decoded_content;
	  if ($err =~ /200 OK/) {
        return $json;
      else {
		print "Domoticz connection fail. Check configuration.\n";
		print "Error message : $err\n";
		exit;
sub melSendJSON {
	  my ($contextKey,$url) = @_;
	  my $result;
        return $json;
      else {
		print "MEL connection fail. Check configuration.\n";
		exit;
	  my $result;
	  my $json = domSendJSON("type=command&param=getuservariables");
      return $result;
sub time_offset {
      my $result;
      my @split_time = split(/:/,$time);
      my @timeok;
      return $timeok[0];
      my ($idx) = @_;
      my $result;
      my $req;
       if ($err =~ "Illegal Operation") {
      else {
         return $result;
sub login {
   #Parameters
   #Variables
   my $result;
   my $Language = "7";
   # set up the stuff
   Email => "$Email",
      return $result;
   else {
   #Parameters
   #Variables
   my @devices;
   my $req;
   # set up the stuff
   my $result = "0";
 #   debug("BuildingID: ".Dumper($result));
    #debug("BuildingID: ".Dumper($result));
		my @build = @{$building->{'Structure'}{'Areas'}};
   else {
      return "$result";
   #Parameters
   #Variables
   # set up the stuff
   my $result = "0";
            my @devices = @{$building->{'Structure'}{'Floors'}};
	#	debug("DeviceID: ".Dumper($result));
            my @devices = @{$building->{'Structure'}{'Devices'}};
				my @devices = @{$area->{'Devices'}};
   else {
      return "$result";
sub listDevices {
   #Parameters
   #Variables
   # set up the stuff
   else {
      my $result = $_;
      return "$result";
# Get ALL Devices IDX to make update
sub getDOMDevicesIDX {
	  $debug = 1;
      else {
         return my $result;
sub melGetAirConInfos {
   #Parameters
   my $url = "https://app.melcloud.com/Mitsubishi.Wifi.Client/Device/Get?id=$deviceID&buildingID=$buildingID";
   my $json = melSendJSON($contextKey,$url);
   #debug ("Infos AC: $decoded->{'RoomTemperature'}");
   #debug("device status : ". $decoded);
   return $decoded;
   #Parameters
   #Variables
   my $domStatus = getDOMDeviceStatus($idDomDevice);
      my $switchcmd = "On";
   else {
      my $result = $1 if /(?:status\"\ :)+(.*?),/s;
      return $result;
   elsif ($deviceInfos->{'Power'} =~ /false/ && my $domStatus =~ /"On"/) {
      my $switchcmd = "Off";
   else {
      return $result;
   else {
   #Parameters
   my $result = domSendJSON("type=command&param=udevice&idx=$idDomDevice&nvalue=0&svalue=$deviceInfos->{'RoomTemperature'}") if /(?:status\"\ :)+(.*?),/s;
   return $result;
   #Parameters
   my @timenextupdate = split(/T/,$deviceInfos->{'NextCommunication'});
   my $modeclim;
   print "MODE: $mode\n";
   if ( $mode eq "1") {
   elsif ( $mode eq "2") {
   else {
      return $result;
   #Parameters
   my $json_device = JSON->new->utf8->encode($deviceInfos);
   #Variables
   #return $url;
   # set up the stuff
   my $req = HTTP::Request->new(POST => $url);
   my $result = $res->decoded_content;
 #  debug($result);
   else {
   #Parameters
   #Variables
   # set up the stuff
   else {
   #Parameters
   if ($mode =~ 'warm') {
   elsif ($mode =~ 'dry') {
   elsif ($mode =~ 'cool') {
   elsif ($mode =~ 'vent') {
   elsif ($mode =~ 'auto') {
   #Variables
   # set up the stuff
   else {
   #Parameters
   #Variables
   # set up the stuff
   else {
   #Parameters
   #Variables
   # set up the stuff
   else {
   #Parameters
   #Variables
   # set up the stuff
   else {
sub init_mel {
   #Parameters
# Main program
# Arguments
if ( !defined($ARGV[0]) ) {
elsif ($ARGV[0] =~ /report/) {
   getConfDomoticz();
      $infosAirCon = melGetAirConInfos($contextID,$deviceID,$buildingID);
      setDomDeviceTempRoom($devicesInfos{$name}{'idx_temp'},$infosAirCon);
      setDomDeviceStatus($devicesInfos{$name}{'idx_status'},$infosAirCon);
      setDomDeviceInfo($devicesInfos{$name}{'idx_info'},$infosAirCon);
elsif ($ARGV[0] =~ /check/) {
   getConfDomoticz();
   print("############################\n");
   print("# Check configuration:     #\n");
   print("Connection to domoticz");
   print(" [OK]\n");
   print("Configuration MEL Cloud");
   print(" [DOMOTICZ]\n");
   print("Connection to MEL Cloud");
   print(" [OK]\n");
   print "TEST: $devicesInfos{'Salle'}{'idx_temp'}\n";
elsif ($ARGV[0] =~ /temp/) {
getConfDomoticz();
   if (!defined($ARGV[1]) || !defined($ARGV[2])) {
		print "use temp and device name\n";
   else {
	init_mel($ARGV[2]);
elsif ($ARGV[0] =~ /fan/) {
getConfDomoticz();
		print "use fan and device name\n";
   else {
	init_mel($ARGV[2]);
elsif ($ARGV[0] =~ /power/) {
   getConfDomoticz();
		print "use on or off and device name\n";
   else {
		init_mel($ARGV[2]);
elsif ($ARGV[0] =~ /mode/) {
   getConfDomoticz();
		print "use cool,warm,vent and device name\n";
   else {
	   	init_mel($ARGV[2]);
	    setMELDevicePower($contextID,'on',$infosAirCon,$devicesInfos{$ARGV[2]}{'idx_update'});
elsif ($ARGV[0] =~ /vanevertical/) {
   getConfDomoticz();
		print "use vanevertical and device name\n";
   else {
	init_mel($ARGV[2]);
elsif ($ARGV[0] =~ /vanehorizontal/) {
		print "use vanehorizontal and device name\n";
   else {
	init_mel($ARGV[2]);
   print "-------------------------- MELCLOUD PERL FOR DOMOTICZ v$version --------------------------\n";
   print "conf: domoticz user variables conf\n";
   print "check: check config\n";
else {
	print "Wrong arguments. Use help\n";
You can define MELCloud login and pasword in Domoticz. Just create user variables MEL_login, MEL_pass and MEL_debug.
artpol5
Post by artpol5 »
I create two different files in blocky in LUA.
I changed in the first SCRIPT file from version 0.6:
$domIP = "192.******"; # Domoticz IP
$Email = "email****; # Email used to login to MELcloud
$Password = "motdepasse***"; # Password used lo login to MELcloud
$devicesInfos{"Gainable"}{"idx_mode"} = "151"; # IDX of status device (type selector Off=0, Hot=10, Cold=20, Vent=30, Dry=40, Auto=50)
$devicesInfos{"Gainable"}{"idx_temp"} = "90"; # IDX of temperature device (type temp)
$devicesInfos{"Gainable"}{"idx_info"} = "92"; # IDX of update time device (type text)
$devicesInfos{"Gainable"}{"idx_setTemp"} = "89"; # IDX of set temp device (type set point)
I have changed nothing in the file CONFIGURATION
I have the following errors that appear in the LOG;
2016-10-16 10:30:41.293 Error: EventSystem: in clim: [string "#!/usr/bin/perl ..."]:1: unexpected symbol near '#'
2016-10-16 10:30:41.300 Error: EventSystem: in clim2: [string "#!/usr/bin/perl ..."]:1: unexpected symbol near '#'
an idea of ​​this error?
gysmo38
Post by gysmo38 »
This is not a LUA script but a Perl script.
Please change only config file.
You have to put script file un directory script under domoticz install dir.
In the begin of thread, you can find explanation on how to install it.
artpol5
Post by artpol5 »
Merci Gysmo38 !
I created the 2 files but the temperature is not displayed:
Here are the details of my operations
pi@raspberrypi:~$ sudo nano /home/pi/domoticz/scripts/melcloud.pl (SCRIPT)
pi@raspberrypi:~$ sudo nano /home/pi/domoticz/scripts/melcloud1.pl (configuration) don't touch
