Page 2 of 2
Re: Music in the bathroom
Posted: Saturday 16 January 2016 22:25
by BarryT
Derik wrote:What speakers do you use???
With Bluetooth or WiFi?
And how do you set this in Domoticz?
The easy way?
Well, you could setup a (remote) switch that powers on a raspberry, player or amplifier with auto play (on hardware).
You can also set a (kaku/rfxcom supported) switch equal with the lights, that will power on the lights and music at the same time.
But, if you want it the way i like the most, you could use a (rfxcom supported) infrared motion detector.
That will switch on the light and audio at the same time while, and as long you are in the shower with a timer of 10/15 minutes for example..
I used bose (waterproof) speakers in that sauna, with external amplifier.
Posted: Sunday 17 January 2016 9:07
by Derik
Mmm great idea with a rpi..
Only how can i play music whit a rpi
And how can i shutdown and reboot the rpi without making my sd corrupt.
Power off linux...
Posted: Sunday 17 January 2016 12:21
by Skippiemanz
I use a rpi 2 with a hifiberry amp+ addon bord. The rpi is running picore player. Witch can be controlled bij the Logitech squeezebox server. Works perfectly for me.
https://sites.google.com/site/picoreplayer/home
Verstuurd vanaf mijn SM-G925F met Tapatalk
Posted: Sunday 17 January 2016 14:46
by Derik
Skippiemanz wrote:I use a rpi 2 with a hifiberry amp+ addon bord. The rpi is running picore player. Witch can be controlled bij the Logitech squeezebox server. Works perfectly for me.
Looks realy great think this should be my option to...
Only how do you act and set things in Domoticz?
What hardware do i need....
Wifi adapter for what do in need?
Can you connect the speakers with Bluetooth?
MMM
Hard to get it in a short time...
can i run the LMS on the sae rpi?
And can i add NL radio streams to the LMS?
When you have time.... a wiki please.
Posted: Monday 18 January 2016 0:02
by Boots33
Posted: Wednesday 14 September 2016 21:36
by BarryT
Sorry for the late reaction... been very busy building in our new house..
Take a look here,
http://raspberrypi.stackexchange.com/qu ... io-streams and use a rpi as mediaplayer.
The speakers are from an amplifier, that is connected to the rpi.
Posted: Wednesday 14 September 2016 22:25
by BarryT
Derik wrote:Mmm great idea with a rpi..
Power off linux...
Make a virtual switch with a json url and state off >>
(Http://domoticzurl:port/json.htm?type=command¶m=system_shutdown
Turn off (or on) this command 10 seconds after you turn the audio or the lights off.
You can even poweroff the raspberry then, with an (timer)relais for example.
That relais will also power the raspberry back on when you turn on the lights or from another switch..
Posted: Wednesday 30 November 2016 21:10
by KateZapp
Hi there! In my case i use the
Waterproof IPX7. I use it duing few monthes and it's good as for me. I place it in my bathroom, but you can do it near your waterpool.
So as for me all marks of waterproof speakers are good - basically Sony! It is the best!
Posted: Saturday 25 February 2017 16:50
by AlleyCat
Hi There,
I have a question about pulling the MPC status and conditioning scripts of the MPC. Would anyone know how I can find a script sample that will pull the MPC status and activate a dummy switch?
Thank you,
AlleyCat
