Re: Fibaro Universal Binary sensor wrong temperature, no out
Posted: Wednesday 02 September 2015 13:18
by Domosapiens
Elektrotek,
Looking at it, line by line, can you find any significant difference?
When you use the inputs 1 and/or 2, polling must be on.
Hope this helps
Domosapiens
Find below the code of one of my FGBS001 sensors as in my zwcfg_0xnnnnn.xml.Regarding my fibaro software, it shows exactly the same library, protocol and application version as yours.
- Spoiler: show
<Node id="5" name="" location="" basic="4" generic="32" specific="1" type="Routing Binary Sensor" listening="true" frequentListening="false" beaming="true" routing="true" max_baud_rate="40000" version="4" query_stage="Complete"> <Manufacturer id="010f" name="FIBARO System"> <Product type="0501" id="1002" name="FGBS001 Universal Binary Sensor" /> </Manufacturer> <CommandClasses> <CommandClass id="32" name="COMMAND_CLASS_BASIC" version="1" request_flags="5" after_mark="true" mapping="48" setasreport="true"> <Instance index="1" endpoint="1" /> <Instance index="2" endpoint="2" /> </CommandClass> <CommandClass id="43" name="COMMAND_CLASS_SCENE_ACTIVATION" version="1" request_flags="5" after_mark="true"> <Instance index="1" /> </CommandClass> <CommandClass id="48" name="COMMAND_CLASS_SENSOR_BINARY" version="1" request_flags="5"> <Instance index="1" endpoint="1" /> <Instance index="2" endpoint="2" /> <Value type="bool" genre="user" instance="1" index="0" label="Sensor" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="1" min="0" max="0" value="True" /> <Value type="bool" genre="user" instance="2" index="0" label="Sensor" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="1" min="0" max="0" value="False" /> <SensorMap index="0" type="85" /> <SensorMap index="0" type="86" /> <SensorMap index="0" type="169" /> <SensorMap index="0" type="170" /> </CommandClass> <CommandClass id="49" name="COMMAND_CLASS_SENSOR_MULTILEVEL" version="1"> <Instance index="1" endpoint="3" /> <Instance index="2" endpoint="4" /> <Instance index="3" endpoint="5" /> <Instance index="4" endpoint="6" /> <Value type="decimal" genre="user" instance="1" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="26.00" /> <Value type="decimal" genre="user" instance="2" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="29.00" /> <Value type="decimal" genre="user" instance="3" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="37.18" /> <Value type="decimal" genre="user" instance="4" index="1" label="Temperature" units="C" read_only="true" write_only="false" verify_changes="false" poll_intensity="2" min="0" max="0" value="25.18" /> </CommandClass> <CommandClass id="96" name="COMMAND_CLASS_MULTI_INSTANCE/CHANNEL" version="2" request_flags="1" mapping="endpoints"> <Instance index="1" /> </CommandClass> <CommandClass id="112" name="COMMAND_CLASS_CONFIGURATION" version="1" request_flags="5"> <Instance index="1" /> <Value type="short" genre="config" instance="1" index="1" label="IN1 Alarm Cancellation Delay" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="65535" value="0"> <Help>Input I alarm cancellation delay. Additional delay after an alarm from input IN1 has ceased. The parameter allows you to specify additional time, after which the input no. 1 alarm is cancelled once its violation has ceased. Default 0.</Help> </Value> <Value type="short" genre="config" instance="1" index="2" label="IN2 Alarm Cancellation Delay" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="65535" value="0"> <Help>Input II alarm cancellation delay. Additional delay after an alarm from input IN1 has ceased. The parameter allows you to specify additional time, after which the input no. 1 alarm is cancelled once its violation has ceased. Default 0.</Help> </Value> <Value type="list" genre="config" instance="1" index="3" label="Type of input no. 1" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1"> <Help>Type of input no. 1, what the input 1 will report if no contact is made. Default 1.</Help> <Item label="Input NO (Normal Open)" value="0" /> <Item label="Input NC (Normal Close)" value="1" /> <Item label="Input MONOSTABLE" value="2" /> <Item label="Input BISTABLE" value="3" /> </Value> <Value type="list" genre="config" instance="1" index="4" label="Type of input no. 2" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="1" size="1"> <Help>Type of input no. 2, what the input 2 will report if no contact is made. Default 1.</Help> <Item label="Input NO (Normal Open)" value="0" /> <Item label="Input NC (Normal Close)" value="1" /> <Item label="Input MONOSTABLE" value="2" /> <Item label="Input BISTABLE" value="3" /> </Value> <Value type="list" genre="config" instance="1" index="5" label="Type of transmitted control frame for association group 1" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="6" size="1"> <Help>Type of transmitted control frame for association group 1, activated via input IN1. The parameter allows to specify the type of alarm frame or to force transmission of control commands (BASIC_SET). Default 255 - BASIC SET.</Help> <Item label="ALARM GENERIC" value="0" /> <Item label="ALARM SMOKE" value="1" /> <Item label="ALARM CO" value="2" /> <Item label="ALARM CO2" value="3" /> <Item label="ALARM HEAT" value="4" /> <Item label="ALARM WATER" value="5" /> <Item label="BASIC_SET" value="255" /> </Value> <Value type="list" genre="config" instance="1" index="6" label="Type of transmitted control frame for association group 2" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="6" size="1"> <Help>Type of transmitted control frame for association group 2, activated via input IN1. The parameter allows to specify the type of alarm frame or to force transmission of control commands (BASIC_SET). Default 255 - BASIC SET.</Help> <Item label="ALARM GENERIC" value="0" /> <Item label="ALARM SMOKE" value="1" /> <Item label="ALARM CO" value="2" /> <Item label="ALARM CO2" value="3" /> <Item label="ALARM HEAT" value="4" /> <Item label="ALARM WATER" value="5" /> <Item label="BASIC_SET" value="255" /> </Value> <Value type="byte" genre="config" instance="1" index="7" label="Forced Level of Dimming group 1" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="255" value="255"> <Help>Value of the parameter specifying the forced level of dimming / opening sun blinds when comes "switch on" / "open" command to devices from association group no. 1. In the case of alarm frames the alarm priority is specified. Possible parameter settings: (1 – 99) and 255. Value of 255 makes it possible to activate the device when using the Dimmer module it means activating the device and setting it to the previous stored condition, e.g. when Dimmer is set to 30%, then deactivated, and then reactivated using command 255, it will automatically be set to the previous condition, i.e. 30%. Default 255.</Help> </Value> <Value type="byte" genre="config" instance="1" index="8" label="Forced Level of Dimming group 2" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="255" value="255"> <Help>Value of the parameter specifying the forced level of dimming / opening sun blinds when comes "switch on" / "open" command to devices from association group no. 2. In the case of alarm frames the alarm priority is specified. Possible parameter settings: (1 – 99) and 255. Value of 255 makes it possible to activate the device when using the Dimmer module it means activating the device and setting it to the previous stored condition, e.g. when Dimmer is set to 30%, then deactivated, and then reactivated using command 255, it will automatically be set to the previous condition, i.e. 30%. Default 255.</Help> </Value> <Value type="list" genre="config" instance="1" index="9" label="Deactivate transmission of frame cancelling alarm" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1"> <Help>Deactivating transmission of the frame cancelling the alarm or the control frame deactivating the device (Basic). It allows for disabling the deactivation function or the alarm cancellation function for devices associated with the appropriate input of the Fibaro Sensor. NOTE: Information concerning alarm violation or activation commands for devices from association groups are always sent. Default 0. ATTENTION: Information alarm triggered or command enabled for devices with associative groups are always sent. NOTE: Value "Group 1 not sent, Group 2 not sent" is only available in version 2.1 and up</Help> <Item label="Groups 1 and 2 sent" value="0" /> <Item label="Group 1 sent, Group 2 not sent." value="1" /> <Item label="Group 1 not sent, Group 2 sent." value="2" /> <Item label="Group 1 not sent, Group 2 not sent." value="3" /> </Value> <Value type="byte" genre="config" instance="1" index="10" label="Interval between successive readings of temperature sensors" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="1" max="255" value="20"> <Help>Interval between successive readings of temperature from all sensors connected to the device in seconds. Possible parameter settings: (1 – 255). Default 20. ATTENTION: taking temperature readings from the sensor does not result in sending a temperature condition report to the central hub.</Help> </Value> <Value type="byte" genre="config" instance="1" index="11" label="Interval between forcing to send report concerning the temperature conditions" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="200"> <Help>Interval between forcing to send report concerning the temperature conditions. The forced report is sent immediately after the next reading of temperature from the sensor, irrespective of the settings of parameter no. 12. Value 0 = Deactivates the function. Default 200. ATTENTION: Frequent sending of temperature condition reports is reasonable when the sensor is located somewhere where can occure rapid changes of ambient temperature. In other cases it is recommended to leave the parameter set to the default value.</Help> </Value> <Value type="byte" genre="config" instance="1" index="12" label="Insensitiveness to temperature changes." units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="255" value="8"> <Help>Insensitiveness to temperature changes. This is the maximum acceptable difference between the last reported temperature and the current temperature taken from the sensor. If the temperatures differ by the set value or more, then a report with the current temperature value is sent to the device assigned to association group no. 3. Intervals between taking readings from sensors are specified by parameter no. 10. Possible parameter settings:0 – 255 [0oC to 16oC] [0 oF – 28.8oF] In order to set the appropriate value of the parameter, the following formula should be used: x = delta T x 16 - for Celsius x = delta T x 80 / 9 - for Fahrenheit x – parameter value delta T – maximum acceptable temperature gradient in Celsius or Fahrenheit If the value is set to 0, then information about the temperature will be sent every time, immediately once the readings have been taken from the sensor. Default 8.</Help> </Value> <Value type="list" genre="config" instance="1" index="13" label="Transmitting the alarm or control frame broadcast mode" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1"> <Help>Transmitting the alarm or control frame in "broadcast" mode (i.e. to all devices within range), information sent in this mode is not repeated by the mesh network. Default 0. ATTENTION: If the broadcast mode of information transmission is activated for a given channel, then transmission of information in singlecast mode to devices assigned to the association group of this channel is deactivated.</Help> <Item label="Sensor 1 and 2 Broadcast inactive" value="0" /> <Item label="Sensor 1 broadcast mode active, Sensor 2 broadcast mode inactive" value="1" /> <Item label="Sensor 1 broadcast mode inactive, Sensor 2 broadcast mode active" value="2" /> <Item label="Sensor 1 and 2 broadcast mode active" value="3" /> </Value> <Value type="list" genre="config" instance="1" index="14" label="Scene activation" units="" read_only="false" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" vindex="0" size="1"> <Help>Enable/Disable scene functionality. The device offers the possibility of sending commands compatible with Command class scene activation. Information is sent to devices assigned to association group no. 3. Default 0.</Help> <Item label="Scenes disabled" value="0" /> <Item label="Scenes enabled" value="1" /> </Value> </CommandClass> <CommandClass id="114" name="COMMAND_CLASS_MANUFACTURER_SPECIFIC" version="1" request_flags="5"> <Instance index="1" /> </CommandClass> <CommandClass id="133" name="COMMAND_CLASS_ASSOCIATION" version="2" request_flags="4"> <Instance index="1" /> <Associations num_groups="3"> <Group index="1" max_associations="5" label="Input IN1" auto="true"> <Node id="1" /> </Group> <Group index="2" max_associations="5" label="Input IN2" auto="true"> <Node id="1" /> </Group> <Group index="3" max_associations="1" label="Temperature Sensor(s)" auto="true"> <Node id="1" /> </Group> </Associations> </CommandClass> <CommandClass id="134" name="COMMAND_CLASS_VERSION" version="1" request_flags="5"> <Instance index="1" /> <Value type="string" genre="system" instance="1" index="0" label="Library Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3" /> <Value type="string" genre="system" instance="1" index="1" label="Protocol Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="3.52" /> <Value type="string" genre="system" instance="1" index="2" label="Application Version" units="" read_only="true" write_only="false" verify_changes="false" poll_intensity="0" min="0" max="0" value="2.01" /> </CommandClass> <CommandClass id="142" name="COMMAND_CLASS_MULTI_INSTANCE_ASSOCIATION" version="2" request_flags="5"> <Instance index="1" /> </CommandClass> <CommandClass id="156" name="COMMAND_CLASS_SENSOR_ALARM" version="1" request_flags="2"> <Instance index="1" endpoint="1" /> <Instance index="2" endpoint="2" /> </CommandClass> </CommandClasses> </Node>
Hope this helps
Domosapiens
