Mode-selector / multistate device
StanHD
Re: Mode-selector / multistate device
Post by StanHD »
We really like this:-
Made a Blockly to read the states:-
Works great, thanks Devs.
Merry Christmas Everyone :D
Python:- Broadlink RM2, Sonos
pepeEL
Post by pepeEL »
Hello all
I am beginner...
Please explaine me how i can write script or set to button level other function/command ?
For example as for command ON and OFF.
I want maybe use this to control my AV Reciver and i want have function:
1. ON/ OFF (it is ok i know how)
ON - http://DENON_IP/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FON
OFF - http://DENON_IP/MainZone/index.put.asp?cmd0=PutZone_OnOff%2FOFF
But when i select action ON and OFF icon button is not active... Only can OFF by leve name OFF
2. Select INPUT (defined by me)
also by http
3. Control volume up and down
also by http but must be not button than only PUSH BUTTON
Is any chance to correct it in domoticz to user by set level can also select type button:
Button ON/OFF
or
PUSH BUTTON
and correct also in Domoticz when user create level also with create can set command to this level action on (Should start with http:// or script://)
and add option to set display text as in virtual switch text ?? Please developer to add this features....
Please help
cgaudry
Post by cgaudry »
I'm still working on it :
- add a parameter to hide 'Off' "level" ;
- add an action to execute when a "level" is selected.
These features should be available next week.
remb0
Post by remb0 »
whats the lua coding for changing the selector?
The only code worked is: commandArray['Fan']='Off'
I have a selector 'Fan'
it had 4 states: off, _1 , _2, _3
What is the commandArray for changing my selector to _3 (value 30) ?
I can control them manually and check what the value is, but changing in a script doesn't work...
raym
Post by raym »
remb0 wrote:whats the lua coding for changing the selector?
I'm also curious to know this. I'd like to be able to set specific modes programmatically - LUA is OK but preferably with blocky.
bizziebis
Domoticz version: 3.8805
Post by bizziebis »
Set level 10, set level 20 etc.
raym
Post by raym »
bizziebis wrote:Set level 10, set level 20 etc.
Thanks. I'm sure I tried that but it didn't seem to work for me. I'll take another look...
remb0
Post by remb0 »
commandArray['Fan']= 'set level 30' doesn't work for me either. name of device is correct. and it had til level 40 so the level also exist.
in blocky it works. but lua don't (I hope I made an stupid fault)
raym
Post by raym »
Just re-tested in blocky and not working for me.
bizziebis
Post by bizziebis »
remb0 wrote:commandArray['Fan']= 'set level 30' doesn't work for me either. name of device is correct. and it had til level 40 so the level also exist.
That's strange, I use it like this and it works:
	commandArray['Selector']='Set Level 30'
raym
Post by raym »
Would you mind trying in blocky too please to confirm what I'm seeing?
cgaudry
Post by cgaudry »
Sorry for the delay but it is :
if (devicechanged['MyDeviceName'] == 'On') then
        commandArray['Test Selector']='Set Level: 20'
Where 20 is the level value, not the level name.
if (devicechanged['Test Selector''] == 'Level3') then
        commandArray['MyDeviceName']='Off'
Where Level3 is a level name.
cgaudry
Post by cgaudry »
It is the same in blockly :
mKotek
Post by mKotek »
SQ9MDD wrote:I'm confused, how can you did this?
I have a problem with selector cant add levels simply this button doesn't work, and after save dont have any option. :shock:
I have the same problem on V2.4123 version. Is there any additional step required in order to be able to define Levels for Selector?
At the moment, all I can get is a Selector with Off level.
Update: 2016/01/14 For the benefit of others - you cannot create a dummy switch from Devices tab. You need to do this (at least for the first one) via Manual switch on Switches tab. Only then, it will work as expected. I could not understand this when reading the thread :D
Michal 'Kotek', greetings from Poland. Zapraszam na mój blog o automatyce domowej po polsku: http://www.ukotka.com.
remb0
Post by remb0 »
a nice it's the :
cgaudry
Post by cgaudry »
You are right.
At this time you should avoid the following 4 characters : : ' | "
I will try to fix it or prevent the user to use these characters.
cgaudry
Post by cgaudry »
This issue has been fixed this morning in beta version.
Now the following characters will be simply removed from the level name while adding or renaming it : :;|<>
jcjames13009
Domoticz version: 2023.2
Post by jcjames13009 »
Now my heating system is managed using selector switch :D
But I can't see it in ImperiHome :( Hope it'll be available soon.
Thanks again to the developpers 8-)
JC
pepeEL
Post by pepeEL »
But in switch selector you dont have problem with action to level?
I assigned to level acction but swich selector wrong assigned. I add to level 10 but action was run on level 0 or when i add to level 20 action is run on level 10.
Wysłane z mojego SM-G920F przy użyciu Tapatalka
jcjames13009
No issue. I use "Level Name" in lua script to control selector switch.
Something like:
if (otherdevices[Heating] == 'Eco') then ...
if (otherdevices[Heating] == "Confort") then ...
if (otherdevices[Heating] == 'Off') then ...
JC
