Air quality sensor not added
- gizmocuz
Re: Air quality sensor not added
I dont think you understand what i am suggesting:
- first, instead of co2-ppm on the axis, this is your ug/m3, i know it is not nice, but the values should be correct
Now, when we can not use ug/m3 but ppm for also the dust sensor then:
- we can rename the air quality sensor as 'air sensor', this is only the type, you can give it 'any' name you want, like 'dust'
- we could rename the y-axis 'co2/ppm' to 'ppm' only
What sensor are you using for dust ?
is it the one like:
http://www.aliexpress.com/item/PM2-5-Du ... 81bcfe3710
is it the one like:
Flopp
- Target OS: -
Yes, my values are correct.
"Problem" is the axis label(unit) and legend on bottom.
Yes, I have named it Dust but at bottom is says co2.
Is it not possible to create a new type of sensor which is storing data when I use CHILD_ID_DUST, V_LEVEL?
See my attached pitures.
Light level, this is set by me and desrcribe the localtion of sensor. Lux Last 7 Days set by system, left and bottom Lux as Unit. Good
Dust, set by me should be location but I only have one at the moment but later I will rename this to Dust_garage. Air Quality Last 7 Days this is what type of sensor it is. Left says co2(ppm) not correct for this sensor should have been ug/m3 in my case, bottom co2, should have been Dust
Left side can remove co2() so it only tell you the unit, rest is OK
CO2 is correct but not Dust. Type Air quailty is correct but after that it should say Dust
This is my Rain sensor, Regn means Rain, i only have one so i called it Regn.
I dont want to be a pain in the as and I dont decide how Domoticz shall be, I just inform how I see it.
I am using a Sharp GP2Y1010AU
https://www.sparkfun.com/datasheets/Sen ... 10au_e.pdf
https://www.sparkfun.com/products/9689
https://www.sharpsde.com/products/optoe ... Y1010AU0F/
Flopp
- Target OS: -
I am using Domoticz 2.4440 on Windows 7
- gizmocuz
Why you use a voltage sensor as rain sensor ?
I will add an Dust sensor (ug/m3)
Flopp
- Target OS: -
I have also a Rain where I see mm.
Above graph is for showing how other graphs works and I am measuring voltage on all my nodes, I also send voltage % but I want to be able to plot volt from each nodes as well
Thanks, I think that is a good idea to create a new Dust sensor.
- gizmocuz
Okey, i did not create a new dust sensor......
i created a new 'custom sensor' .... this is very alpha! But it should work...
I also modified the mysensors code, the dust sensor will create now a new custom sensor
New beta version #4937
Hope all works... the only thing i did not test was the mysensors part
Make sure 'accept new hardware' is enabled in the settings
After adding the new 'dust/custom' sensor, you can edit the sensor and select a custom icon
If possible, please give some feedback here if it's working
D'rMorris
I'm having issues with my gateway as well. My nodes all work perfecly (according to Arduino monitor), but my gateway just stops working for some reason. Did you find a solution? I'm on the latest beta version. On stable version 2.xxxx everything was solid as a rock. If I can't find a solution I'm reverting back to that I think.epierre wrote:
The flat parts are usb issues I'm getting at the moment with the arduino as gateway... I may find a way to disable/discover the arduino on the kernel level to correct this... maybe the arduino will dye by itself anyway...
Raspberry Piet
How can i update this custom sensor through API/JSON?gizmocuz wrote:Okey, i did not create a new dust sensor......
I tried with examples from the wiki but it doesn't update the sensor.
Although result in cli shows me:
"status" : "OK",
"title" : "Update Device- gizmocuz
You can update it like any device... The svalue is the value (float)
Raspberry Piet
Hmm... strange.
I tried:
the value of the custom sensor still shows 0.00 and Last seen time stays at time the sensor was added.
I tried:
curl -s "http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=2601&svalue=123"
curl -s "http://127.0.0.1:8080/json.htm?type=command¶m=udevice&idx=2601&nvalue=0&svalue=123"- gizmocuz
Did I mention it is in very alpha stage
I will check what's going on....
It might be you got a new sensor/device
- gizmocuz
New beta version in 15 minutes (#4938), now udevice should work
Raspberry Piet
Thanks! It is working now!
Is it somehow also possible to adjust the zero's behind the decimal?
Edit: what i meant was this:
But after update today it works how i want:
Thanks again!
Thanks again!
Last edited by Raspberry Piet on Friday 11 March 2016 21:47, edited 1 time in total.
- gizmocuz
We are going a bit of topic here, but what do you mean, but next version #4939 will go up to 4 digits (if you provide up to 4 digits)Raspberry Piet wrote:Thanks! It is working now!
- gizmocuz
I put a lot of effort into thisFlopp wrote:...
It would be nice if you can tell me if all my work was for nothing, or that it is working now ?
Flopp
- Target OS: -
Sorry, I did the update now to 3.4958. Now it says ppm but it is still Volcraft and in graphs it says co2(ppm)
- gizmocuz
should not be, you should get a new device
- gizmocuz
Hope to receive my dust sensor in 2 weeks...
Flopp
- Target OS: -
Ok, now I saw that it has not reported since I upgrade. I will restart dust sensor and see what happens
- gizmocuz
Make sure 'accept new devices' is enabled in the settings, and after restart of the dust sensor, check the devices tab for new devices
