Domoticz logging the output of a Kostal Piko inverter
twosteps
Re: Domoticz logging the output of a Kostal Piko inverter
Post by twosteps »
niki_lauda wrote: Sunday 09 September 2018 10:36
twosteps wrote: Thursday 23 August 2018 7:48 Hi all,
I have a noob question regarding the connection to the Kostal Inverter:
On my Piko device, I have both Ethernet and RS485 (RJ45 both) connections.
To retrieve the data using the script, do I have to connect to RS485 or ethernet..?
I have a rapberry Pi 3. If RS485 is needed, I guess I need to connect to my Pi using a RS485 card, right?
Many thanks for your help and again sorry for this basic question
Herve
If you reply to an message you will get an bnotification. I accendentally stumbled over your message.
I connected the PIKO via an Ethernet cable.
Don't excuse yourself for asking a question. Only by asking an question you can learn.
You're right, I forgot to reply to the message.
Thanks for your answer. I think the problem is that my inverter is a piko 3.0 MP and the webinterface is different than for the other versions (piko MP 5.5 for instance)
Kostal Piko 3.0 MP web.png (55.19 KiB) Viewed 3978 times
I'm not an expert but it's like a "picture" (frame?) of the screen of the inverter instead of a simple table of values.
So I guess it's not possible to retrieve data from my inverter...?
bjornp
Post by bjornp »
I rewrote the script using the new dzVents format so you can change the interval (here it is 5 minutes).
It does not use a temporary file anymore and the counters are fetched even if the number of digits change.
    -- Get the actual data from a Kostal Piko Inverter
    -- Uses Piko.py  http://sourceforge.net/projects/piko/files/
    -- Example output of piko.py:
    -- Total energy    : 11651331 Wh
    -- Today energy    : 13104 Wh
	-- DC Power        : 1454 W
	-- AC Power        : 1342 W
	-- Efficiency      : 92.3%
    on      =   {   timer   = { "every 5 minutes"}},
    execute = function(dz)
        local inverter = dz.devices("DEVICE_NAME_IN_DOMOTICZ")
		local inverter_ip = "X.X.X.X"
        local f = assert(io.popen("python /home/pi/domoticz/scripts/piko.py --host=" .. inverter_ip .. " -p -i -d", 'r'))
        local s = assert(f:read('*a'))
        f:close()
        power=s:match('AC Power.-:(.-)W') -- in W
        energy=s:match('Total energy.-:(.-)Wh') -- in Wh
		inverter.updateElectricity(power,energy)
niki_lauda
Post by niki_lauda »
Nice!
bjornp
Post by bjornp »
I wrote a new DzVents based event so you do not need the extra Python script and (http)errors are handled better. The inverter needs current firmware version (>6.0?) so you can use the API to get JSON data directly.
Just fill in the inverter IP and the device name.
		timer = {
			'every 5 minutes'
		httpResponses = {
			'trigger' -- must match with the callback passed to the openURL command
		if (item.isTimer) then
			domoticz.openURL({
				url = 'http://INVERTER-IP-ADDRESS/api/dxs.json?dxsEntries=67109120&dxsEntries=251658753', -- 67109120 = current power W and 251658753 = lifetime total kWh
				method = 'GET',
				callback = 'trigger',
		if (item.isHTTPResponse) then
			if (item.statusCode == 200) then
			    local json = domoticz.utils.fromJSON(item.data) -- Convert to JSON because Piko does not specify it as json in header
			    if json.dxsEntries[1]['dxsId'] == 67109120 and json.dxsEntries[2]['dxsId'] == 251658753 then
			        local current = json.dxsEntries[1]['value']
			        local lifetime = json.dxsEntries[2]['value']
			        print('Piko - Current power: ' .. domoticz.utils.round(current,0) .. ' W | Lifetime total: ' .. domoticz.utils.round(lifetime,3) .. ' kWh')
			        local inverter = domoticz.devices("Kostal PIKO Virtual device name")
			        inverter.updateElectricity(current,(domoticz.utils.round(lifetime,3)*1000)) -- lifetime needs to be in Wh (not kWh)
		            print('Entries not found or incorrect entries found in table')
				domoticz.log('There was a problem handling the request', domoticz.LOG_ERROR)
				domoticz.log(item, domoticz.LOG_ERROR)
Bruno67
Post by Bruno67 »
Hi Bjornp,
Thanks for sharing this!
I'm new to DzVents and also to LUA so forgive my ignorance :)
I tried out your script replacing the URL and device name but I get an error message in the log:
2020-06-17 19:00:10.463 Status: dzVents: Info: Handling httpResponse-events for: "trigger
2020-06-17 19:00:10.463 Status: dzVents: Info: ------ Start internal script: Kostal 1: HTTPResponse: "trigger"
2020-06-17 19:00:10.463 Status: dzVents: Error (2.4.19): There was a problem handling the request
2020-06-17 19:00:10.464 Status: dzVents: Error (2.4.19): {["isTimer"]=false, ["ok"]=false, ["data"]="", ["isDevice"]=false, ["isSecurity"]=false, ["isGroup"]=false, ["trigger"]="trigger", ["isJSON"]=false, ["isScene"]=false, ["statusText"]="Timeout was reached", ["statusCode"]=28, ["callback"]="trigger", ["baseType"]="httpResponse", ["protocol"]="HTTP/1.1", ["isVariable"]=false, ["headers"]={}, ["isHTTPResponse"]=true, ["_contentType"]=""}
2020-06-17 19:00:10.464 Status: dzVents: Info: ------ Finished Kostal 1
2020-06-17 19:00:10.349 Error: Error opening url: http://192.168.0.50/api/dxs.json?dxsEnt ... =251658753
Any idea of what I did wrong?
Below the script:
timer = {
'every 5 minutes'
httpResponses = {
domoticz.openURL({
url = 'http://192.168.0.50/api/dxs.json?dxsEnt ... =251658753', -- 67109120 = current power W and 251658753 = lifetime total kWh
method = 'GET',
local inverter = domoticz.devices('Kostal')
WimTh
Post by WimTh »
Hi guys,
Thanks for sharing all of this information. I've been trying to get this working on my Domoticz, but to no avail.
I have the used the LUA and Python scripts from the start of this topic (the downloadable py script) and they give no error in my command line.
My problem is that I have no clue on how to get the Piko device in my Domoticz interface. Is there a tutorial which starts by adding the Piko device to domoticz? After that I should be able to use the scripts in this topic, I guess?
Best regards and thanks in advance!
Wim
niki_lauda
WimTh wrote: Sunday 31 January 2021 15:34 Hi guys,
Wim
Which Piko do you have?
Mine is an PIKO 3.6 https://www.kostal-solar-electric.com/e ... oad/archiv#
WimTh
Post by WimTh »
niki_lauda wrote: Sunday 31 January 2021 19:05
Wim
I have a Kostal Piko 4.2 MP. https://www.dutchsolarsystems.com/kosta ... iko-4-2-mp
Regards, Wim
niki_lauda
WimTh wrote: Sunday 31 January 2021 20:13
Wim
Regards, Wim
Hoi Wim
Make a new dummy device zonnepanelen type elektra
I think with this inverter you should use the dzvents script.
Change the following lines
url = 'http://INVERTER-IP-ADDRESS/api/dxs.json ... =251658753', -- 67109120 = current power W and 251658753 = lifetime total kWh
Maybe then it works
Hans
WimTh
Post by WimTh »
niki_lauda wrote: Sunday 31 January 2021 20:40
Regards, Wim
Hoi Wim
Maybe then it works
Hans
Hello Hans,
Can you send me a link to the right script?
Kind Regards Wim
niki_lauda
I use this script. It makes use of home/pi/domoticz/scripts/piko.py see attachement
    on      =   {   timer   = { "every 10 minutes"}},
        local inverter = dz.devices("KostalDZ")
        --- local invtotal = dz.devices("Zonneenergie")
		local inverter_ip = "10.0.0.2"
        local f = assert(io.popen("/usr/bin/python2.7 /home/pi/domoticz/scripts/piko.py --host=10.0.0.2 -p -i -d", 'r'))
        f:close()
        --print("Device is On")
        --print(s)
        energy=s:match('Today energy.-:(.-)Wh') -- in Wh
        total =s:match('Total energy.-:(.-)Wh') -- in Wh
       -- print (power)
       -- print (total)
        if dz.time.matchesRule("between sunrise and sunset") then
		    inverter.updateElectricity(power+1,energy)
		-- invtotal.updateElectricity(total)
piko.py.txt
(21.3 KiB) Downloaded 133 times
