Page 2 of 29
Re: How to install Domoticz on a Synology NAS
Posted: Monday 23 November 2015 11:43
by greuh
jumbotroll wrote:
I don't have toolchain for DSM-4.2 for DS209, but for DMS-4.3.
I think DSM-4.3 will work, but you have to test.
domoticz_88f6281-4.3_2.0.3619-7.spk
I have compiled a test for you here:
http://jadahl.dscloud.me/sspks/packages ... 3619-7.spk
Jumbotroll
Thanks a lot
But how can I install DSM4.3 ? Synology does not provide it for DS209.
https://www.synology.com/support/download/DS209
Should I softmod mys DS209 to a DS211J as suggested Skippiemanz?
Posted: Monday 23 November 2015 13:39
by jumbotroll
Just do a manual install.
domoticz_88f6281-4.3_2.0.3619-7.spk is backward compatible to DSM-4.2.
Just download this :
http://www.jadahl.com/domoticz_beta/ and do a manual install.
Or softmod your DS209, it's your choice
Jumbotroll
Posted: Monday 23 November 2015 16:38
by greuh
http://jadahl.dscloud.me/sspks/packages ... 3619-7.spk and do a manual install.
Jumbotroll
Oh, I did not get
I did a manual installation and domoticz seems to be running.
However I need to go back home (I am at the office) to check it. Router is not yet configured to allow me to connect to it
I will then put the USB Zwave adapter and see if everything can work.
Thank you so much
Posted: Wednesday 02 December 2015 22:36
by nouch
I have a DS209++ and the same problem with DSM 4.2 being the last compatible version.
DS209++ seems not upgradable at all to DSM 5.X...
Would it be possible to compile a a 4.3 version for ppc ?
I managed to install synocomunity version but it's an old one with no rflink support.
tks,
Nouch.
Posted: Thursday 03 December 2015 11:12
by jumbotroll
nouch wrote:Hi,
tks,
Nouch.
I have already compiled a test for ppc853x 4.2 and 4.3 here:
http://www.jadahl.com/beta.html
Jumbotroll
Posted: Thursday 03 December 2015 19:49
by nouch
Thanks a lot !
I was able to install it, Domoticz is working properly.
I have nothing to plug in it at the moment, but I'll buy a rflink gateway and let you know if any issue.
Posted: Friday 04 December 2015 9:40
by greuh
On my side, I have received my AeonLab GEN5 USB device yesterday.
Hopefully I will be able to play with domoticz in the coming days
Posted: Saturday 05 December 2015 0:29
by greuh
Well, domoticz is running, but it does not see my Aeon labs GEN5 USB stick
No hardware is detected.
I also tried to add a new hardware manually, type= "OpenZwave USB", and tested for every USB port.
But each time, I have the following errors in my synology's log:
ERROR: Cannot open serial port /dev/ttyUSB0. error code 19
What am I supposed to do ?
Posted: Saturday 05 December 2015 12:17
by jumbotroll
greuh wrote:Well, domoticz is running, but it does not see my Aeon labs GEN5 USB stick
If I understand you correctly, OpenZWave USB does not appear in the dropdown menu?
Have you downloaded the latest version domoticz_88f6281-4.3_2.0.3771-7.spk
Jumbotroll
Posted: Saturday 05 December 2015 16:28
by greuh
jumbotroll wrote:greuh wrote:Well, domoticz is running, but it does not see my Aeon labs GEN5 USB stick
http://jadahl.dscloud.me/sspks/index.php?fulllist=true
Jumbotroll
The "type" dropdown menu from the hardware page shows the "OpenZWave USB" line. No problem with that.
But I tried every USB port that is suggested and results each time the same:
or
ERROR: Cannot open serial port /dev/ttyUSB3. error code 19
for USB3, obviously...
This log message are from the synology logs.
In domoticz, I have the following log:
2015-12-05 16:27:31.000 OpenZWave: Starting...
2015-12-05 16:27:31.000 OpenZWave: Version: 1.3-565-gec4efa6
2015-12-05 16:27:31.000 OpenZWave: using config in: /usr/local/domoticz/Config/
2015-12-05 16:27:51.043 Error: OpenZWave: Driver Failed!!
I was using domoticz_88f6281-4.3_2.0.3619-7.spk, I have just tested with the latest domoticz_88f6281-4.3_2.0.3771-7.spk with the same results
Posted: Sunday 06 December 2015 0:28
by jumbotroll
Hmm strange, maybe some USB driver problem with DSM-4.3 and my package.
Try to install my latest UsbSerialDriver additionally and see if that helps.
http://jadahl.dscloud.me/sspks/packages ... _3.0.5.spk
Jumbotroll
Posted: Sunday 06 December 2015 18:48
by greuh
Thanks.
Synology tells me that there is nothing for DSM4.2 in this USB package.
Has it been compiled for it?
Posted: Sunday 06 December 2015 21:56
by jumbotroll
greuh wrote:
Thanks.
What version of DSM 4.2 do you have?
DSM4.2-3203?
If you have DSM4.2-3255, you can try this: UsbSerialDrivers_3.0.6.spk:
http://jadahl.dscloud.me/sspks/packages ... _3.0.6.spk
Jumbotroll
Posted: Sunday 06 December 2015 23:07
by greuh
Indeed, I have DSM4.2-3255.
Installation of 3.0.5 went wrong, but it seems that something has been installed.
The installation of the 3.0.6 needs the desinstallation of the 3.0.5.
But I cannot uninstall 3.0.5 !
Just a pop-up window saying it could not uninstall.
The system log has only a single line about it:
Failed to uninstall package [USB Serial Drivers].
Yaaaaaaargh !
Posted: Sunday 06 December 2015 23:14
by jumbotroll
greuh wrote:Indeed, I have DSM4.2-3255.
Yaaaaaaargh !
You have to stop domoticz before you uninstall the UsbSerialDrivers, if that not work, you have to log in to your synology with WinSCP or similar software and manually remove the old UsbSerialDriver package. location is /volume1/@appstore/UsbSerialDriver.
Jumbotroll
Posted: Sunday 06 December 2015 23:21
by greuh
Failed even when domoticz was stopped.
I logged with ssh and removed the directory /volume1/@appstore/Usbserialdrivers
Now the installation of 3.0.6 tells me that it could not install it because it is already present.
I indeed see a package which status is "error", but I still cannot uninstall it...
ps: There a 4 usb drivers, which one should I enable when I install it? I tried to select all, I guess it is preferable.
Posted: Sunday 06 December 2015 23:28
by jumbotroll
greuh wrote:Failed even when domoticz was stopped.
Yes you can select all drivers.
Did you try to reboot your Synology before you installed new package?
I have never had any problem remove the old package with SSH, but I have a different synology with x86 cpu.
With SSH:
From the command line you can just remove the directory 'rm -rf /var/packages/UsbSerialDrivers' and/or /volume1/@appstore/UsbSerialDrivers
Jumbotroll
Posted: Sunday 06 December 2015 23:34
by greuh
With SSH:
Jumbotroll
Great !
I had indeed to remove also /var/packages/UsbSerialDrivers
Thanks a lot.
I am now trying to see if I can use domoticz with my Aeotec USB stick.
Should it be detected automatically ?
Posted: Sunday 06 December 2015 23:36
by jumbotroll
I have compiled a 4.2 package you can test if you want.
I don't think it does matter if it is for 4.2 or 4.3, but as a last try you can test if you want.
domoticz_88f6281-4.2_2.0.3780-7.spk
Jumbotroll
Posted: Sunday 06 December 2015 23:38
by greuh
jumbotroll wrote:I have compiled a 4.2 package you can test if you want.
Jumbotroll
Thanks again
I will test it soon.
(It is late here, I won't last long... )
