Page 2 of 2
Re: PiFace 2 - Sensor/Counter not working
Posted: Tuesday 04 August 2015 11:13
by macieiks
@bizziebiz,
I can confirm it too, I am running V2.2563 (stable) and I can see update each 10 sec in logs (even if there is no impulse from S0 meter). However my counter's stats does not increase and states all the time 0.000kWh as I mentioned before. Which version of domoticz (stable / beta) should I run and test to get it working?
Posted: Tuesday 04 August 2015 15:17
by NickHead
I went here and did some of the examples.
Mine wouldn't count, now it does, not sure if correct yet.
I was fed up of hearing other had the same problem as me and I searched for ages and came up with this,
http://www.element14.com/community/mess ... face#93804
also put this in my PI2, something to do with RPI Update.
sudo apt-get --reinstall install libraspberrypi-bin libraspberrypi-dev libraspberrypi-doc libraspberrypi0 raspberrypi-bootloader
sudo reboot
Make sure you backup/be safe before any modifications.
I take no responsibility for doing this, however, I did do it and restored faith in my PiFace Digital 2.
Hope it helps.
Posted: Tuesday 10 November 2015 9:19
by cwiekol
This one seems to solve my problem. Before i had only 4 inputs visible in devices section of domoticz, now i see all inputs and outputs.. Will test in the evening if they are acting as they should. Thanks NickHead.
sudo reboot
Posted: Tuesday 10 November 2015 17:39
by NickHead
Yes, it did with mine for a while, then it went wrong.
I am using a different approach now, so not sure on the status of this fix.
Nick
Posted: Thursday 12 November 2015 6:52
by MrFrankie
Oh good to see that there is a solution. It was so frustrating that it was not working correct.
At this moment I don't use the PiFace. I converted everything to MySensors and EasyESP. It's a bit more portable and easier to debug in my opinion. But who knows...
Thanks NickHead for the solution.
Posted: Saturday 21 November 2015 10:21
by cwiekol
last thing which i have done like ten days ago was also disabling device tree:
sudo raspi-config
8 advanced options
A5 Device Tree
and reboot..
Now i'm on
Linux raspberrypi 4.1.7+ #817 PREEMPT Sat Sep 19 15:25:36 BST 2015 armv6l GNU/Linux
and
2015-11-21 10:20:29.822 Domoticz V2.3566 (c)2012-2015 GizMoCuz
2015-11-21 10:20:29.823 Build Hash: 332f2d5, Date: 2015-11-09 19:00:36
2015-11-21 10:20:29.825 System: Raspberry Pi
and piFace is working all right..
hope that helps...
Posted: Friday 05 February 2016 18:11
by badz
I have been struggling big time with my Piface2 in domoticz.
After doing this fix, I have everything working smoothly.
https://github.com/domoticz/domoticz/pull/426
try it and tell me
PS: This is has been already merged in master on github .. just "git pull;make" to get the latest when using source code
Posted: Friday 05 August 2016 16:25
by nigels0
Still having probems with this - setting the first parameter (enabled) in piface.conf to true sets the device up as Lighting 1 - putting it as false and I get no devices. What is the correct value for the piface.conf for a watermeter?
Posted: Tuesday 09 August 2016 0:40
by Sine
From my config:
piface.0.input.7.enabled=false
piface.0.input.7.pin_type=level
piface.0.input.7.count_enabled=true
piface.0.input.7.count_update_interval_sec=10
Posted: Wednesday 10 August 2016 0:01
by nigels0
Thanks. Tried that but still don't get the utility come up in the devices. Wonder what the difference is?
Posted: Friday 12 August 2016 16:35
by Jan Jansen
Wich kernel are you running? Today i did a rpi-update (new kernel 4.4.?). After that update my piface did not work anymore. After then i installed kernel 4.1.18+ again, everything worked as desired. I hope that history does not repeat (kernel related to driver piface)
Posted: Monday 15 August 2016 1:47
by nigels0
I'm using 4.4.13+ Maybe that's the problem. I'll try with 4.1.18+. ........
I tried it with 3.10.25+ and it still didn't work! So maybe not the kernel.
Posted: Monday 15 August 2016 7:50
by Jan Jansen
At the moment my Pi B (2 Pifaces connected) is running 4.4.13+. Setting raspi-config > Advanced options > SPI enable.
Running 4.1.18+ Setting raspi-config > Advanced options > Device tree > disable.
The crux for me was setting the Raspi -config.
Perhaps you 've seen it : WIKI > Piface > General notes and connecting the SO bus.
Posted: Saturday 20 August 2016 23:38
by nigels0
My Piface is working... Just not the devices showing in Domoticz.
Posted: Saturday 27 August 2016 12:07
by Sine
You set domoticz to allow for new devices right?
I don't exactly know how this is handled, but I suspect it needs to see a few pules when it is in "allow new devices mode"
Posted: Monday 29 August 2016 19:55
by nigels0
No I didn't! I'll try that next.
Posted: Saturday 15 October 2016 12:01
by nigels0
Unfortunately no change
Posted: Friday 21 October 2016 0:07
by NickHead
from time import sleep
import pifacedigitalio
pifacedigitalio.init()
pifacedigital = pifacedigitalio.PiFaceDigital()
pifacedigital.leds[7].toggle()
sleep(0.5)
try running this on the pi and see if it kickstarts the piface
P.S. It is a python script
Posted: Sunday 03 September 2017 0:34
by Piacco
I use my piface to register my watermeter. What i noticed is that the RXFmeter only updates when i'am using water. When i'am not using any water for a while the RFXmeter becomes red. I thought the RFXmeter was updated every 10sec (count_update_interval_sec=10 in the piface.conf file).
In the hardware setting i have the data timeout for the piface board disabled, is this normal behavior?
Posted: Sunday 03 September 2017 7:35
by Jan Jansen
Yes it is normal behavior.
