OsiDark theme for smartphone, tablet and desktop [v0.5]
osiris
Re: OsiDark theme for smartphone, tablet and desktop [v0.3]
Post by osiris »
@Timmit are you using v0.3? Since the menu should not show any gradients at all. Which Android device are you using? A tablet or phone?
TimmiT
Post by TimmiT »
I am, didn't even noticed that but it's fixed now i think it was a cache problem.
The issues remain the same.
osiris
Post by osiris »
Ok thanks!
Currently I am working on a fluent build system for the theme. It takes some time to build the theme, deploy it etc. So I first fix this workflow and will then look into the bugs.
Derik
Post by Derik »
Please
Send all the themes in a complete ZIP with a printscreen [ JPG] and a how to document,to:
[email protected]
When i do have time, i will place them online.....
Or when it is work in progress on a site like Github, i will place the link.
osiris
Post by osiris »
@Derik where are you going to post these themes?
Derik
Post by Derik »
osiris wrote:@Derik where are you going to post these themes?
On the Gmail drive, the same like the icons page..
https://drive.google.com/folderview?id= ... sp=sharing
osiris
Post by osiris »
That means I have to send a new zip for every update. In my opinion it is way better to check out the theme on your server directly via Git instead of Google Drive. This keeps you up to date by just updating your checkout. Would be a nice feature for future Domoticz releases to just keep a list of Git repositories and show an install button. When pressed it checks out the repo and you're done.
Derik
Post by Derik »
mmmm
I do not now how git is working......
Perhaps that is a better option only i am not a pro... :-(
I will give it a try..
remb0
Post by remb0 »
Yes github is the way to go. Easy to push and for the users easynto pull. ( possible with an virtual button that starts an script.
osiris
Post by osiris »
Exactly. Derik lets contact via Skype of phone (I see you're Dutch as well) so I can explain how stuff works. Saves us both a lot of time and trouble :)
chudepohl
Post by chudepohl »
Really like the work you did!
I'm currently working on an new version of the theme, first looks:
osiris
Post by osiris »
Quite some time went by, but today I fixed some bugs in the theme.
You can now download v0.4 from https://github.com/basvdijk/domoticz-osidark-theme/
l00pz
Re: OsiDark theme for smartphone, tablet and desktop [v0.4]
Post by l00pz »
Thanks! The Theme looks very nice, and I can't wait until you release you're custom Icon Pack :D
osiris
Post by osiris »
Just released v0.5 with most changes on the desktop view.
  • Moved the favourite star in front of the title
  • Created a toolbar at the bottom of the widgets
  • Removed background color from widget buttons (log, edit, notifications etc.) to save space.
  • Fixed navigation menu icon alignment
Grab v0.5 from https://github.com/basvdijk/domoticz-osidark-theme
rron
Re: OsiDark theme for smartphone, tablet and desktop [v0.5]
Post by rron »
I wanted to update to the latest version of Osidark and I did the following:
wget https://raw.githubusercontent.com/basvdijk/domoticz-osidark-theme/master/src/OsiDark/custom.css -O www/styles/osi-dark/custom.css
After I have cleared the browser but nothing seemded to be happend. The version is still V.03
Did I forget something?
rron
Post by rron »
osiris wrote:Just released v0.5 with most changes on the desktop view.
i have also tried the above link but the result is still V0.3. What went wrong?
osiris
Post by osiris »
Have you tried to select another theme and then back to OsiDark? My guess is that Domoticz only updates the version number when a theme is changed via the settings. The wget overwrites the current css file but Domoticz is not triggered to read the file again for version number changes.
rron
Post by rron »
Yes I did try another theme and when I switched back nothing changed. The V0.3 is still there. I have only one custom.css file in the dir , is that ok?
ps if I download it directly from Github and unzip the file you get 3 dir's nl dist,screenshots and src. Is that correct?
osiris
Post by osiris »
rron wrote:Yes I did try another theme and when I switched back nothing changed. The V0.3 is still there. I have only one custom.css file in the dir , is that ok?
Weird, it looks like Domoticz isn't updating the version number. Can you open the custom.css and check what version number is mentioned?
If you download directly form Github you'll get indeed the three dirs of the repo. You only need the custom.css directly in the theme folder.
Clemen
Post by Clemen »
In the code from GitHub V.0.3 is still present on the frontpage and copyright line 421 and 434
#appversion:after {
    con[b]tent: " (OsiDark v0.3)";[/b]
#copyright {
    font-size: 0.7rem;
    padding: 10px 0;
#copyright p {
    font-family: "Open Sans";
#copyright p:after {
    content[b]: " | theme OsiDark v0.3";[/b]
