Foscam ImageUrl FI9803p v2
Skippiemanz
Domoticz version: 4.10233
Re: Foscam ImageUrl FI9803p v2
Post by Skippiemanz »
I suffered the same as you.
I fixed the problem by just upgrading the firmware to the latest version.
This version includes the patch
It can be downloaded here:
http://www.foscam.nl/index.php/producta ... _Firmware/
mvveelen
Post by mvveelen »
Ah, ok.
I was already using the latest version: FosIPC_E_app_ver2.x.2.33.bin
Next problem I'm facing is the fact that the camera won't work in Surveillance Station on my Synology DS414. I get connected, but after that it tells me it is disconnected.....
Skippiemanz
Hmmm,
I got it running on my surveillance station DS 13+ flawless after the FW Upgrade.
mvveelen
Post by mvveelen »
I'm using:
Surveillance Station 7.1-4141
Foscam FI9803P V2 with firmware 2.54.2.33
I tried the default settings: no go. Then I tried to set the Bitrate to constant: no result.
Video settings: 1280x720, FPS 25
I'm lost....
Skippiemanz
Try setting it to tcp only.
And is the camera inside your lan? Or external?
Verstuurd vanaf mijn SM-G925F met Tapatalk
mvveelen
Post by mvveelen »
Tried that too. With 640x480.
The camera is in my network. With the camera software I have no problems. Even when I use the browser, I see streaming video without any problems.
I also tried the FI9803P settings instead of the FI9803P V2 settings. Same results: nada
Skippiemanz
I have firmware 2.54.2.5 on the camera....
Here is the download link: http://www.euport.nl/index.php/producta ... re=english
And system firmware 1.9.1.12
Here are my settings in SS:
General
General
Video
Video
Transport
Transport
mvveelen
Post by mvveelen »
This is what I have:
System Firmware Version: 1.9.3.16
Application Firmware Version: 2.54.2.33
Plug-In Version: 3.3.0.19
These versions seem newer than yours. Downgrading isn't possible.....
Edit:
Using ONVIF settings, I managed to get it working. But....it should be able to work with the FI9803P V2 settings, right? How come it doesn't work??
