Page 2 of 3
Re: [513] Google Nest Protect (Smoke + CO sensor) support
Posted: Saturday 02 January 2016 2:48
by gizmocuz
yes, its a on/off state, you can edit the switch, set it to another type, or provide your own icon for it
Posted: Tuesday 19 January 2016 21:14
by spamajor
Can you make it possible to split the one on/off state switch into two switches? One for the smoke sensor and one for the CO? This way you can initiate different actions like:
- Windows closes when smoke alarm
- Windows open when CO alarm
And maybe one for notification purposes like battery fail etc.
Looking forward to your quality work. Thanx en regards.
Posted: Wednesday 20 January 2016 8:56
by gizmocuz
there are more alarm settings, don't know if they work, but you might tell me...
component_speaker_test_passed
component_smoke_test_passed
component_heat_test_passed
component_us_test_passed
component_temp_test_passed
component_co_test_passed
component_hum_test_passed
Posted: Wednesday 20 January 2016 11:00
by spamajor
Morning,
I assume you derive those from the Nest platform API (https://developer.nest.com/documentation/api-reference). You refer to more components than the api mentions (?) but CO and smoke are the ones in question that are the most valuable. Is it possible to split those into two switches? 3-ways switches are not possible so in my opinion the value "warning" should trigger the switch / alarm.
For you reference:
The nest website reports some basic info, see attachments. Discription from Nest platform API:
CO alarm
co_alarm_state
Is normally "ok"
When Nest Protect starts to warn the user of rising CO levels, the value will be "warning"
When the user should exit the home, value will change to "emergency"
Smoke alarm
smoke_alarm_state
Is normally "ok"
When Nest Protect starts to warn the user of rising smoke levels, the value will be "warning"
"smoke_co_alarms": {
"RTMTKxsQTCxzVcsySOHPxKoF4OyCifrs": {
"device_id": "RTMTKxsQTCxzVcsySOHPxKoF4OyCifrs",
"locale": "en-US",
"software_version": "1.01",
"structure_id": "VqFa...",
"name": "Hallway (upstairs)",
"name_long": "Hallway Protect (upstairs)",
"last_connection": "2015-12-31T23:59:59.000Z",
"is_online": true,
"battery_health": "ok",
"co_alarm_state": "ok",
"smoke_alarm_state": "ok",
"is_manual_test_active": true,
"last_manual_test_time": "2015-12-31T23:59:59.000Z",
"ui_color_state": "gray",
"where_id": "UNCBGUnN24..."
Posted: Friday 22 January 2016 8:30
by spamajor
Hello, I just burned a newspaper for 1,5 minute and the switch in domoticz doesn't flip.
Posted: Wednesday 27 January 2016 20:59
by Derik
Dear,
Is there some one that have pictures how NEST is acting in Domoticz?
What are the graphs?
Sirene?
Values?
Can i set settings?
Etc..
xxx
Posted: Sunday 31 January 2016 9:51
by gmccarthy
Just bought a Nest Protect and added it to Domoticz. Its appearing as a single switch - is this correct?
Just wondering if its possible to monitor battery/smoke/co/test status?
Posted: Sunday 31 January 2016 10:15
by Derik
gmccarthy wrote:Just bought a Nest Protect and added it to Domoticz. Its appearing as a single switch - is this correct?
That is something i like to now to... :D ;)
And is there a option that i can see when the night light is on? or can i manual switch this light?
Motion @ night switch nest on
Posted: Wednesday 17 February 2016 15:06
by DarkCinema
Just wondering if it is possible to add the Proximity and light sensor from the Nest Protect 2.
Saves me in buying separate sensors.
Posted: Saturday 09 April 2016 20:53
by Clemen
The nest protect domoticz switch is ALWAYS off in my setup, even if i burn a paper or something.
Posted: Wednesday 06 July 2016 21:38
by barryknobel
Anybody knows how to control / use the NEST protect in Domoticz? Devices install without any problem, but i cannot figure out how to use them.
by barryknobel
Posted: Thursday 07 July 2016 18:11
by Derik
What are the graphs the nest shows in Domoticz?
I mean by the Co sensor?
Or just alarm when the value i to high..
Posted: Tuesday 02 August 2016 18:00
by kllngtme
Not sure on the best forum post and where to note this. I was looking for the official Nest forum post but didn't find it.
Is it possible the Nest Thermostat and Protect could be separate devices? When it shows up on the list of devices it just shows as Nest so you can't distinguish really which entries are for the thermostat and which ones are for the Protect.
Also, I'm not sure if anyone has noticed this, but the Nest just recently has flooded my Device list. It was never like this before. I have 1 thermostat and 1 Protect. There are over 200 entries that are labeled under Nest. They all have different IDX's but may be showing the same result in multiple instances. Naming the hardware as separate devices would really help though IMO with organizing/understand the devices table better.
Posted: Friday 06 January 2017 16:23
by mvveelen
I have 4 Nest Protect added to Domoticz. The Nest system works and I receive a message on my iPhone when the alarm triggers. But, in Domoticz nothing happens. What do I have to do to receive also a message from Domoticz or trigger a light switch when one of the Nest Protect devices sounds the alarm?
I also see nothing in the log file.....
Posted: Monday 27 February 2017 13:25
by Derik
Is the nest fully support or not???
I like to order one..
only ....when it is not working in Domoticz :-(
Posted: Monday 27 February 2017 13:31
by mvveelen
Nope. It's recognized in Domoticz, but you can't do anything with it unfortunately.
Posted: Monday 27 February 2017 13:33
by Derik
Only in the hardware list is the protect. Vissible.... Did you remove and add againg???
Strange...
Posted: Monday 27 February 2017 13:47
by mvveelen
Derik wrote:Only in the hardware list is the protect. Vissible.... Did you remove and add againg???
Strange...
Whut ?!
Wat do you mean, what is your question?
Posted: Monday 27 February 2017 14:29
by Derik
When it is in the hardwarelist...
It should work..
