Domoticz and robot vacuum cleaners
- Brutus
Re: Domoticz and robot vacuum cleaners
Can someone explain or tell me how I can make this work in LUA? I don't understand the languages used to talk with the API.
I would like to start the robot at given times and conditions from Domoticz. So the only command I would send is the start command.
1x Aeon Labs USB Z-Stick S2
1x P1 Smart Meter USB
28x Fibaro Modules
SMA Solar System
Daikin Airco / Heating
Denon DHT-S716H & DSW-1H
28x Fibaro Modules
SMA Solar System
Of course Neato is also the best option you can go for.
And I hope this will help you: http://domoticz.com/forum/viewtopic.php?f=31&t=103
Hello @Awst6000 I think it's too late for the reply, but I think it will help others Because people are looking for domoticz monitorization. And as you said you are thinking about going for a Neato XV Signature Pro. Yeah, It's great....But hold on, if are more concerned for monitoring your robot vacuum with domoticz. I highly recommend going for a Roomba 650.
Reasons:
- Roomba is from Irobot, the reputable brand. They will help you whatever problem is without any pay.
- And another thing is there are so many helpful sources on this domoticz forum alone which will make you help to monitor. Check out this once...http://www.domoticz.com/forum/viewtopic.php?f=23&t=6195
- And the last but the most important, such a high equipped robot vacuum cleaner with an affordable price tag (just under 300$) robot vacuum.
And Roomba 980 is also the best option for domoticz monitorization. But it is a bit pricey robot vacuum cleaner. So If you are with full packed wallet It's better to go for it, otherwise, 650 is an ideal option.
Hope this message useful to you.
I have the Roomba 650 and ordered the roowifi module. This should make it possible to control and monitor the Roomba with Domoticz.
http://www.roowifi.com/
If I have it I will share my findings.
- Brutus
Hi, unfortunately the link you provided does not worksam329 wrote: ↑Tuesday 05 September 2017 8:53 Of course Neato is also the best option you can go for.
I hope you can tell me more because I like to include my Neato in Domoticz.
Greetings Brutus
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
- Target OS: OS X
I mostly use iRobot vacuum, and its brand new 980 Roomba model blows my mind. But it's too much expensive. So, I'm going to buy Roomba 960 for now. its also have wifi connectivity.
- Target OS: OS X
Roomba is one of the best brand for vacuum cleaners. They have got some good models of robotic vacuum cleaners.
sam329 wrote: ↑Tuesday 05 September 2017 9:22Hello @Awst6000 I think it's too late for the reply, but I think it will help others Because people are looking for domoticz monitorization. And as you said you are thinking about going for a Neato XV Signature Pro. Yeah, It's great....But hold on, if are more concerned for monitoring your robot vacuum with domoticz. I highly recommend going for a Roomba 650.
Reasons:
Roomba 650 could be helpful for someone you have several pets in their home. I helps to pick up very tiny hair and dust. It will create a report after cleaning and controlled remotely.So it is suitable to those who want to keep clean their room when they are at office.
Here is more information with some reviews regarding the Roomba 650: https://www.robotvacuumarea.com/irobot-roomba-650/
Anything to report after all those years ;-P?roblom wrote: ↑Wednesday 13 September 2017 20:25 I have the Roomba 650 and ordered the roowifi module. This should make it possible to control and monitor the Roomba with Domoticz.
I had it working a bit with a lua script but it doesn't work anymore so I'm trying to make it work again with a Dzvents script. The script was able to read out the values.
- Brutus
Thnx to the Pybotvac API I am able to integrate my Neato D5 Connected Vacuum cleaner.
https://github.com/stianaske/pybotvac
I am able to send the following commands:
- Start
- Stop
- Pause
- Dock
- Spot
I am able te retreive the following information:
- Battery %
- Robot Status (Idle, cleaning..)
- Robot Modus (Turbo, Normal)
- Robot Error message (Stuck..)
- Robot Alert message (Clean dustbin)
I have it running for like 3 months now and its working great.
- Start
- Stop
- Pause
- Dock
- Spot
- Battery %
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
I hope you can help me out a little bit, i installed the pybotvac script from Github no problem.Brutus wrote:Thnx to the Pybotvac API I am able to integrate my Neato D5 Connected Vacuum cleaner.
- Start
- Stop
- Pause
- Dock
- Spot
- Battery %
But then? On github I see some code but I do not know how to use. Do I need to put it in a python script?
Verzonden vanaf mijn iPad met Tapatalk
- Brutus
Hi Krizzz,krizzz wrote: ↑Sunday 15 September 2019 21:43I hope you can help me out a little bit, i installed the pybotvac script from Github no problem.Brutus wrote:Thnx to the Pybotvac API I am able to integrate my Neato D5 Connected Vacuum cleaner.
- Start
- Stop
- Pause
- Dock
- Spot
- Battery %
Indeed you need te make some Python scripts. You can then pull them with virtual swithes and a LUA script.
Example Script to start Cleaning:
import sys
from pybotvac import Robot
if sys.version_info[0] < 3:
input = raw_input
robot = Robot('Secret Key XXXXXXXXX', 'Robot Name XXXXX')
print(robot)
robot.start_cleaning()
import sys
input = raw_input
print(robot)
robot.stop_cleaning()
28x Fibaro Modules
SMA Solar System
28x Fibaro Modules
SMA Solar System
I use iRobot Roomba Vacuum and it gives a powerful cleaning to my entire home. Compact Size and Self Sufficiency which comes with this vacuum makes it a great cleaning aid.
- Domoticz version: 2020.1
hi, i have a D7 and would like to intergrate with domoticz please can you explain how you set this up?Brutus wrote: ↑Friday 13 September 2019 18:14 Thnx to the Pybotvac API I am able to integrate my Neato D5 Connected Vacuum cleaner.
- Start
- Stop
- Pause
- Dock
- Spot
- Battery %
- Domoticz version: 4.10717
Greetings,
Was looking whether there are plans to support PureClean models (like PUCRC95, for instance)?
I guess though it'd be much easier to switch to another vac, but hope dies last. So thanks anyway.
- Pete
I just created a plugin for Neato Botvac
https://github.com/gilmrt/Domoticz-Botvac-Plugin
I have recently migrated from a rasberry pi to windows based domoticz do you know how i install on windows?Bob123bob wrote: ↑Saturday 02 May 2020 11:09 I just created a plugin for Neato Botvac
