Help! GPio, 8 relays...
sallytech0103
Re: Help! GPio, 8 relays...
Post by sallytech0103 »
I had a same problem in my project. I resolved it from this discussion thanks.
Some information about relays.
guantolento
Domoticz version: LastBeta
Post by guantolento »
good evening,
just a question. i can take the 8 ch reley board and install at about 20 mt to rpi2? i connect with an alarm cable 10x0.22+2x0.50.
what do you think about ?
Master (pi3) - MB sensors + Dummy + Sysfs gpio + 1 NodOn MSP-3 + 1 Aeotec DSB28 Energy Meter + 3 Danfoss RS Room + 7 Danfoss Z Thermostat + 1 Swiid Inter + 9 FGS222
Slave01 (pi2) - MB sensors + Dummy + Weather Underground + 2 FGS223 + 1 FGWPE/F
guantolento
sallytech0103 wrote:I had a same problem in my project. I resolved it from this discussion thanks.
how you resolve the problem ? with hardware or software ????
hill2button
Domoticz version: 3.5877
Post by hill2button »
I'm a bit lost. I have a similar relay to the one described above. I have read all posts but still I can't figure it out.
My domoticz setup file (the end) looks like this:
esac
#Run export GPIO Raspberry
/usr/bin/gpio export 17 out
sudo sh -c 'echo 17 > /sys/class/gpio/export'
sudo sh -c 'echo high > /sys/class/gpio/gpio17/direction'
sudo sh -c 'echo 1 > /sys/class/gpio/gpio17/active_low'
I am trying to get gpio 17 to work. Now, doing this works, the direction is correct in Domoticz. However, it clicks the relay on-off at bootup, which is not what I want... I have the feeling it has something to do with the boot sequence. Or, may it first provides 5V to the relay, with a dead gpio pin, and moments later puts the gpio pin in the high state?
Also, I wonder, is
the same command? Is this double?
Thanks for the help!
hill2button
I needed to return one item of my last order, so I decided to include this relay in the return.
If anyone has a suggestion on a active-high relay: shoot! Now that I know what to look for it seems I can only find active-low relays...
RayAmsterdam
Post by RayAmsterdam »
I posted the solution earlier in this topic: viewtopic.php?f=32&t=6050&p=39401#p39401
hill2button
RayAmsterdam wrote:I posted the solution earlier in this topic: viewtopic.php?f=32&t=6050&p=39401#p39401
I appreciate that, but I cannot solder. I'm looking for an out-of-the-box solution. But it seems active-high 5V relays are hard to find...
Lebo2d9
Domoticz version: L stab
Post by Lebo2d9 »
Did someone ever tested the relay interfacing with a 74HC240 in between? 8 port invering buffer.
Kind regards
Domoicz on RPI3 (wifi) directly connected 3x ds18b20 for CV temp, Evohome (9 zone), 1 remote 220V switch based on ESP-12. RFXtrx433E, 16x AMST-606, 5 Somfy RTS motors
Domoticz on RPI3(wifi) as slave for terraruim control
More to come
gohan
Post by gohan »
How did you guys made the active_low to work? I can't find a way as setting it either way makes no changes. I gave the GPIO esported correctly and they don't turn on at boot, so that part is fine.
trackerj
Post by trackerj »
hill2button wrote:
RayAmsterdam wrote:I posted the solution earlier in this topic: http://www.domoticz.com/forum/viewtopic ... 401#p39401
For a simple out-of-the-box solution, you have also this board, 8xRelays, proper driver, can be drive by RaspberryPi without problems directly (version without ESP8266 module installed using the nEXT bus connector) or thru network using the onboard ESP8266 module:
https://www.tindie.com/products/nEXT_EV ... utomation/
You have also plenty of videos, tutorials and related docs.
mjdb
Domoticz version: all beta
Post by mjdb »
For what it is worth...
To use Domoticz with relays you could also use an Arduino with a relay-card.
It can work stand-alone and independent of Domoticz, but you can send On/Off commands and monitor the status from Domoticz.
I made a 4 relay switch viewtopic.php?f=56&t=17656
When you leave out the "hardware" part, you can use the electronics and the program for your relay-project.
You can change the program very easy from 4 to 8 relays.
2 x Domoticz on Raspberry Pi; 2 x RFXtrx433; Aeotec Z-Stick
KlikAanKlikUit ICS-2000 as Relay
Aeotec MultiSensors 6; Danfoss Z Thermostats 014G0013; Kaku Switches, Z-wave Switches
toni1234567
Post by toni1234567 »
RayAmsterdam wrote:This board isn't designed to be used with the pi. It needs ground to switch the relay on. The pi is grounded when off and 3,3v when on. That is why it acts reversed.
Here is what I did:
I removed the led and the lower resistor. I soldered in a bridge and a 100 Ohm resistor as in the first picture. You have to do this for all 8 relays! I put the jumper between ground and vcc (second picture). 5v from the pi is connected to jd-vcc. The vcc pin on the left pinrow is unused (I cut it away).
Thanks for your information it works....!!!
The resistor is not 100 ohms is 1k.
I rescued de original led solderind led+original resistor(1k) like you.
Regards.
BarryT
Domoticz version: 2024.3
Post by BarryT »
macieiks wrote: Friday 10 July 2015 11:35 BarryT, Any update with that? I run these relays too and I would like to invert values. Could you give us an example how to manage to do that?
Sorry for the late reply... Didnt see the replies at all :(
I'm using gpio (sysfs) on all my raspberrys, and using the rc.local file to import the values >
sudo sh -c 'echo 16 > /sys/class/gpio/export'
sudo sh -c 'echo high > /sys/class/gpio/gpio16/direction'
sudo sh -c 'echo 1 > /sys/class/gpio/gpio16/active_low'
sudo sh -c 'echo 20 > /sys/class/gpio/export'
sudo sh -c 'echo high > /sys/class/gpio/gpio20/direction'
sudo sh -c 'echo 1 > /sys/class/gpio/gpio20/active_low'
sudo sh -c 'echo 21 > /sys/class/gpio/export'
sudo sh -c 'echo high > /sys/class/gpio/gpio21/direction'
sudo sh -c 'echo 1 > /sys/class/gpio/gpio21/active_low'
sudo sh -c 'echo 12 > /sys/class/gpio/export'
sudo sh -c 'echo high > /sys/class/gpio/gpio12/direction'
sudo sh -c 'echo 1 > /sys/class/gpio/gpio12/active_low'
sudo sh -c 'echo 26 > /sys/class/gpio/export'
sudo sh -c 'echo high > /sys/class/gpio/gpio26/direction'
sudo sh -c 'echo 1 > /sys/class/gpio/gpio26/active_low'
hope this will helped you out!
