Vision ZP3102 EU PIR Motion Sensor Topic is solved
Ralph
Domoticz version: 2.2563
Re: Vision ZP3102 EU PIR Motion Sensor
Post by Ralph »
I have a Vision ZP3102 EU PIR Motion Sensor, it shows up fine in Domoticz, however I seem to be unable to persist the settings for the device. (I want to change the sensitivity and duration of the alarm.) Any thoughts?
bernard
Post by bernard »
Still no working Vision ZP3102 EU PIR
inclussion works (with latest Domoticz beta a lot faster) however , the PIR and domoticz does not register any motion.
takel
Post by takel »
My 3102 PIRs also suffer from battery drain occasionally.
The problem occurs after a restart of domoticz: after a restart, it seems they sometimes no longer enter low-power mode, and the battery goes empty within a month.
thorbj
Post by thorbj »
Hi, I recently bought a ZP3102 EU PIR, and I seemingly have included it successfully in my network. I get 6 different sensors form it:
- Sensor (Lighting 2)
- Alarm Type (Lighting 2)
- Alarm Level (Lighting 2)
- Burglar (Lighting 2)
- Temperature (TFA 30.3133)
- Alert 0x07 (AC)
Which one are the motion detector, and what does all the others do? Temperature I obviousely know what does. And Alert I guess is the tamper switch.
The Sensor, Alarm Type and Burglar is on at all times. The Alarm Level is Off and the temperature seems to show the right temperature.
2xRaspberry Pi Model 2 w/RaZberry z-wave chip (master/slave)|Fibaro Wall Plug|Fibaro Universal Dimmer 500W|Aeon Labs Multisensor|RFXtrx433E|Nexa WMR-1000|Nexa Pe-3|Nexa Remote|Nexa LGDR3500|Lightify Gateway|Lightify RGBW bulb
Yihaaa
Post by Yihaaa »
I have the same issues/questions like thorbj. Any updates someone?
ErFr
Post by ErFr »
Have apparently stumbled over the same questions but in another way: viewtopic.php?f=24&t=8752
Paspberry PI with RFXtrx433, Razberry using only zwave plus devices, onewire (DS9490R) and some LUA-scripts
revenger
Domoticz version: 2.3771
Post by revenger »
I'm having troubles with the sensor as well. See attached image where all sensor of one motion sensor are listed. Why am i not getting any further info per sensor...I really can't distinguish the sensors?
Kind regards,
Remko
Devices
Devices
Vision ZP3102 EU PIR Motion Sensor.PNG (51.51 KiB) Viewed 4810 times
Domotizc v2.3771 on Windows
Aeotec Z-Stick Gen5
GreenWave PowerNode x3
BeNext Door Sensor
Popp Smoke Detector
Raspberry Pi with Domoticz
P1 Energy Cable
Evelen
Domoticz version: 2.4538
Post by Evelen »
Got My sensor yesterday, same problem...
Also: viewtopic.php?f=24&t=9317
gerco
Domoticz version: 2022.1
Post by gerco »
I came across this topic after I recently upgraded my Domoticz with ZWave, and got a few POPP switches and a Vision ZP3102 motion sensor.
I had to include the device a couple of times to get at least a device that represents motion. In the last inclusion I did, I got 7 devices, but though the device is said to have temp + humidity sensors as well, I never got any device that would resemble this in Domoticz.
The current list I have:
I altered the initially called 'Burglar' to ZWMotion1 and changed the type to a motion sensor. However, all the other devices are reported as Lighting2 devices, from which I don't know how to get a temperature value.
Any ideas on this? And what all other devices actually do or how to use these?
Gerco
Eternity
Post by Eternity »
I have silimar problems, and solved it.... a little.
My Vision ZP3102 EU PIR Motion Sensor did show up in my Synology run Domoticz v2.3815, but was "asleep" and did not detect motion.
I installed it under a Windows 10 Domoticz, and it worked!!! Motion was detected.
So, my z-wave stick works, the inclusion was suiccesful, the motion sensor works... but it does not work on my Synology (yet).
Synology DS218+
Homey controller
Z-Wave stuff (Fibaro / Aeotec / NEO Coolcam)
Zigbee stuff (Aqara)
HUE lights
Logitech Harmony Ultimate + Hub
IP camera's
Evelen
Post by Evelen »
worked yesterday, even after reboot, not today.
j0ystick
Post by j0ystick »
I have a couple of those here.
Is there a jumper inside the chassis?
If it is there try to put it on one of the contacts, and repeat the association that way with the chassis left open, after the association is completed put the cover back on... Or something.
Or remove it, or put it on a different couple of contacts. At some point they begin to work, or not.
Basically fiddle with the tamper switch and the jumper and it should accept the inclusion and the group association at some point.
Also it is very likely that they will decide one day not to sleep, thus draining the battery overnight.
I never fully understood those sensors and what the heck is wrong with them and their troubled relationship with openzwave, but they pretty much s**k donkey b**ls.
(They are slightly better with zway software, they don't drain the battery out of the blue, but they are still erratic and temperamental).
Evelen
Post by Evelen »
A have a new problem with this sensor, it start to detect motion that don't exist, more and more often.
Logg (from 18:50 today):
2016-02-01 22:06:07 Off
2016-02-01 22:03:18 Off
2016-02-01 22:03:09 On
2016-02-01 21:53:46 Off
2016-02-01 21:51:01 Off
2016-02-01 21:50:51 On
2016-02-01 21:32:02 Off
2016-02-01 21:29:17 Off
2016-02-01 21:29:08 On
2016-02-01 21:19:37 Off
2016-02-01 21:16:52 Off
2016-02-01 21:16:43 On
2016-02-01 21:10:18 Off
2016-02-01 21:07:33 Off
2016-02-01 21:07:24 On
2016-02-01 20:23:44 Off
2016-02-01 20:20:59 Off
2016-02-01 20:20:49 On
2016-02-01 19:49:33 Off
2016-02-01 19:46:47 Off
2016-02-01 19:46:38 On
2016-02-01 19:21:37 Off
2016-02-01 19:18:51 Off
2016-02-01 19:18:42 On
2016-02-01 18:50:33 Off
Any ide?
FionnanBurke
Domoticz version: 2.4547
Post by FionnanBurke »
I have the same problem here (but had it on Vera also, so I don't think its a Domoticz problem).
My sensor included with no issues at all, I have my motion sensor and Temp sensor. It worked well for 2 days so I mounted it in the corner of my hallway.
It worked for about 2 days and yesterday morning it registered motion at 8.45am, which would be correct but hasn't registered anything since.
I'd love to get this working because I've spent the money on it, but I will not buy another one.
thorbj
Post by thorbj »
Thanks @Lisa, that's what I have figured out also :)
